Home » Modeling » EMF » EObjectValidator not being regenerated after chnage to xsd
EObjectValidator not being regenerated after chnage to xsd [message #1220456] Wed, 11 December 2013 15:53 Go to next message
Here is the recipe:
- Open my.genmodel
- Reload (from xml schema)
- save genmodel
- generate model
- generate edit
The EObjectValidator in the util dir does not get regenerated with the new
elements from the xsd. Is there something else that needs to be done to
force regeneration of the validator?
Re: EObjectValidator not being regenerated after chnage to xsd [message #1220477 is a reply to message #1220456] Wed, 11 December 2013 23:27 Go to previous messageGo to next message
Drew,
Unless you add named constraints to you model, I don't expect any
validator to be generated. All the standard constraints supported for
XSD are supported direct by EObjectValidator itself, without a generated
subclass.
On 11/12/2013 9:53 PM, Drew wrote:
> Here is the recipe:
> - Open my.genmodel
> - save genmodel
> - generate model
> - generate edit
> new elements from the xsd. Is there something else that needs to be
> done to force regeneration of the validator?
Re: EObjectValidator not being regenerated after chnage to xsd [message #1220549 is a reply to message #1220477] Thu, 12 December 2013 09:13 Go to previous message
Ok. So by adding a dummy named constraint the new validator methods get
generated. Now I get it.
thanks
"Ed Merks" <ed.merks@xxxxxxxx> wrote in message
news:l8bdvi$ss6$2@xxxxxxxxe.org...
> Drew,
> validator to be generated. All the standard constraints supported for XSD
> subclass.
>> Here is the recipe:
>> - Open my.genmodel
>> - save genmodel
>> - generate model
>> - generate edit
>> new elements from the xsd. Is there something else that needs to be done
Previous Topic:[EMF] Is there a standard model modelling only data types (without operations)
Next Topic:Linking of EObjects from different resources, detect saves
Current Time: Sun Jul 20 21:05:08 EDT 2025
Powered by FUDForum. Page generated in 0.06854 seconds
