Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [TEXO][Xcore] Generating JPA Entities from Xcore
[TEXO][Xcore] Generating JPA Entities from Xcore [message #1220353] Wed, 11 December 2013 04:21 Go to next message
Hi All,
I'm trying to use Xcore together with Texo. After creating Xcore file I've created accompanying ecore file (using EMF Generator Model) as described on Xcore page. From such generated ecore file I try to invoke Texo (i.e. Texo / Generate Model + DAO Code) but then I got error:
Diagnosis of platform:/resource/org.ngo.help.sample.model/model/model.ecore#/
The feature 'eType' of 'platform:/resource/org.ngo.help.sample.model/model/model.ecore#//Library/name' contains an unresolved proxy 'platform:/resource/org.eclipse.emf.ecore/model/Ecore.ecore#//EString'
The feature 'eAttributeType' of 'platform:/resource/org.ngo.help.sample.model/model/model.ecore#//Library/name' contains an unresolved proxy 'platform:/resource/org.eclipse.emf.ecore/model/Ecore.ecore#//EString'
After looking into generated ecore file I see that there are local references to the file system:
<eStructuralFeatures xsi:type="ecore:EAttribute" name="name" unique="false" eType="ecore:EDataType ../../org.eclipse.emf.ecore/model/Ecore.ecore#//EString"/>
And when looking into examples of ecore files provided with Texo, it looks quite different, e.g.:
<eStructuralFeatures xsi:type="ecore:EAttribute" name="name" unique="false" lowerBound="1"
    eType="ecore:EDataType http://www.eclipse.org/emf/2003/XMLType#//String">
I manualy edited ecore file to use these global addresses instead of the local ones and now generation with Texo works. How to force generation of ecore from Xcore file so that it references Ecore model from the global address?
Dominik
Re: [TEXO][Xcore] Generating JPA Entities from Xcore [message #1220434 is a reply to message #1220353] Wed, 11 December 2013 12:35 Go to previous messageGo to next message
Dominik,
I chatted with Martin and I suspect he just needs to use:
resourceSet.getURIConverter().getURIMap().putAll(EcorePlugin.computePlatformURIMap(true));
These models load fine in the Ecore editor and that's what it does...
On 11/12/2013 2:12 PM, Dominik Leszyk wrote:
> Hi All,
> Diagnosis of
> Cheers,
> Dominik
Re: [TEXO][Xcore] Generating JPA Entities from Xcore [message #1220516 is a reply to message #1220434] Thu, 12 December 2013 05:07 Go to previous messageGo to next message
Ed, Thanks for the reply.
Martin, should I report this to bugzilla? Maybe I can offer a patch then (if I find place(-s) in the code... could take me a while:)).
BTW. seems that there is a similar problem in CDO (see my post from today).
Re: [TEXO][Xcore] Generating JPA Entities from Xcore [message #1220548 is a reply to message #1220516] Thu, 12 December 2013 09:01 Go to previous messageGo to next message
Hi Dominik,
I published a new build with this addition. Can you try it?
I have entered a bugzilla myself for it:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=423904
I have put the XCore/Texo integration on my thought list, it was there already but moved up. It would be really nice to
make that more direct/fluent (directly generate code from xcore for example instead of going through a genmodel).
gr. Martin
> me a while:)).
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [TEXO][Xcore] Generating JPA Entities from Xcore [message #1220610 is a reply to message #1220548] Thu, 12 December 2013 12:04 Go to previous messageGo to next message
Hi Martin,
Yes, sure. Please find my comment in the bugzilla that you've created.
> I have put the XCore/Texo integration on my thought list, it was there already but > moved up. It would be really nice to
> make that more direct/fluent (directly generate code from xcore for example instead > of going through a genmodel).
This would be great!
Dominik
Re: [TEXO][Xcore] Generating JPA Entities from Xcore [message #1289762 is a reply to message #1220353] Wed, 09 April 2014 12:16 Go to previous messageGo to next message
Hi Martin,
I ran into the same issue and tried the newest stable and nightly version, but without luck.
Could you have a second look, please?
Also, I read somewhere in the Texo wiki pages that generating code from an Xcore file already works for you. Do you have any plans to release a version with this change? That would really come in handy. Thank you.
Re: [TEXO][Xcore] Generating JPA Entities from Xcore [message #1290510 is a reply to message #1289762] Thu, 10 April 2014 03:17 Go to previous messageGo to next message
Hi Moritz,
The past days I have picked up the xcore integration, trying to get a working build with improved xcore handling. Xcore
works locally for me, but just not on the build server. I will update the issue when it runs through, am on it.
gr. Martin
On 04/09/2014 06:37 PM, Moritz Höser wrote:
> Hi Martin,
The Netherlands
Re: [TEXO][Xcore] Generating JPA Entities from Xcore [message #1386237 is a reply to message #1290510] Sun, 15 June 2014 13:39 Go to previous messageGo to next message
Hello, I am also experiencing the same issue as described above by Dominik Leszyk.
Is there a work around for this, so that I am able to go from xcore to ecore, to texo?
Thanks and regards
Re: [TEXO][Xcore] Generating JPA Entities from Xcore [message #1386383 is a reply to message #1386237] Tue, 17 June 2014 05:05 Go to previous messageGo to next message
Hi Anton,
Give me a few days to pick this up again. Feel free to ask for an update on the newsgroup.
gr. Martin
> Thanks and regards
The Netherlands
Re: [TEXO][Xcore] Generating JPA Entities from Xcore [message #1386496 is a reply to message #1386383] Tue, 17 June 2014 16:49 Go to previous messageGo to next message
Thanks Martin, greatly appreciated.
Where do I find the newsgroup?
Re: [TEXO][Xcore] Generating JPA Entities from Xcore [message #1386534 is a reply to message #1386496] Wed, 18 June 2014 03:32 Go to previous message
The posts on the forum are automatically synced with the newsgroup, so works fine :-).
gr. Martin
The Netherlands
Previous Topic:[EmfStore] Commit observe on server
Next Topic:Target platform for ECP and RAP
Current Time: Mon Jul 28 10:59:54 EDT 2025
Powered by FUDForum. Page generated in 0.05436 seconds
