Home » Eclipse Projects » NatTable » Collapse All Rows in TreeLayer(help)
Collapse All Rows in TreeLayer [message #1133107] Fri, 11 October 2013 12:08 Go to next message
I need to add Expand All and Collapse All functionality to the TreeLayer.
I have tried the following code to Collapse All rows in the TreeLayer. It only works when all nodes are expanded, otherwise it throws a NullPointerException.
int parentIndex = 0;
ITreeRowModel treeModel = treeLayer.getModel();
List<Integer> childIndexes = treeModel.getChildIndexes(parentIndex);
Collections.reverse(childIndexes);
childIndexes.add(parentIndex);
System.out.println(childIndexes);
for (Integer index : childIndexes) {
	if (treeModel.isCollapsed(index) == false) {
		treeLayer.collapseTreeRow(index);
If I have the following tree structure:
-[-] A
  +--[-] B
  |   +-- z
  +--[-] C
  |   +-- y
Running my collapse all code will successfully collapse A,B,C. But if I were to expand all of them and manually collapse C, then running the code will throw a NullPointerException on the following method:
ie:
-[-] A
  +--[-] B
  |   +-- z
  +--[+] C
Stack Trace:
	at ca.odell.glazedlists.impl.adt.barcode2.FourColorTree.get(FourColorTree.java:169)
	at ca.odell.glazedlists.TreeList.getTreeNode(TreeList.java:302)
	at org.eclipse.nebula.widgets.nattable.extension.glazedlists.tree.GlazedListTreeData.getChildren(GlazedListTreeData.java:76)
	at org.eclipse.nebula.widgets.nattable.extension.glazedlists.tree.GlazedListTreeRowModel.getChildIndexes(GlazedListTreeRowModel.java:89)
	at org.eclipse.nebula.widgets.nattable.extension.glazedlists.tree.GlazedListTreeRowModel.getChildIndexes(GlazedListTreeRowModel.java:93)
Any ideas?
[Updated on: Mon, 14 October 2013 07:32] by Moderator
Re: Collapse All Rows in TreeLayer [message #1133302 is a reply to message #1133107] Fri, 11 October 2013 15:27 Go to previous messageGo to next message
I'm not really sure, but maybe it is a race condition. Maybe it is necessary to lock the list prior collapsing.
At least in GlazedListTreeData there needs to be a null check.
Could you please file a ticket in bugzilla? This needs to be investigated in more detail. It would be great if you could provide a small running example with the ticket so it is easier for us to start the investigation.
Re: Collapse All Rows in TreeLayer [message #1137450 is a reply to message #1133302] Mon, 14 October 2013 09:59 Go to previous messageGo to next message
Done. Bug 419366
Re: Collapse All Rows in TreeLayer [message #1220150 is a reply to message #1133302] Tue, 10 December 2013 01:45 Go to previous messageGo to next message
Hi Dirk,
I checked on the Bug 419366 in Bugzilla and that it is fixed. I wanted to check when this would be available i.e. the next targeted release for NatTable?
Prerna
Re: Collapse All Rows in TreeLayer [message #1220165 is a reply to message #1220150] Tue, 10 December 2013 02:30 Go to previous messageGo to next message
We haven't scheduled a time for releasing 1.1. But we are on our way.
Re: Collapse All Rows in TreeLayer [message #1220171 is a reply to message #1220165] Tue, 10 December 2013 03:17 Go to previous message
Thanks for the quick update Smile
Previous Topic:Avoid flickering when resize a table
Next Topic:Row numbers are also changed , when rows are reordered using row reorder layer
Current Time: Thu Jul 24 22:48:13 EDT 2025
Powered by FUDForum. Page generated in 0.07427 seconds
