Home » Modeling » TMF (Xtext) » Is it possible to start a parse from a sub-rule?
Is it possible to start a parse from a sub-rule? [message #778190] Wed, 11 January 2012 10:14 Go to next message
Hello Xtexters,
I come from an antlr background where it was possible to start a parse from a sub-rule when under certain circumstances we just needed to parse a fragment from a much larger language, e.g. validating a single expression that the user has entered via a dialog before inserting it into a larger (language described) mathematical model.
Is this possible with Xtext? It seems that the parse always needs to start from the first rule?
I suppose it would be possible to augment the first rule to accept the language fragments we needed to be able to parse separately and then as a post-processing step analyse the semantic model to check that what has been parsed was appropriate to the context (i.e. whether we thought we were parsing a fragment or parsing a complete language text) ?
Tom
[Updated on: Wed, 11 January 2012 10:15] by Moderator
Re: Is it possible to start a parse from a sub-rule? [message #778212 is a reply to message #778190] Wed, 11 January 2012 12:46 Go to previous messageGo to next message
Maybe you can divide your grammar into 2, the second one starting with the fragment you want so that when you want to parse juste a piece you'll use the second one only.
Re: Is it possible to start a parse from a sub-rule? [message #778419 is a reply to message #778190] Wed, 11 January 2012 11:27 Go to previous messageGo to next message
Hi Tom,
Xtext uses a partial parsing strategy transparently.
Please have a look at the IParser interface for more information (but
note it's actually not meant to be used directly by clients).
Sebastian
Am 11.01.12 16:15, schrieb Thomas Williams:
> Hello Xtexters,
> fragment
> the user
> described)
> mathematical model.
> Regards,
> Tom
Re: Is it possible to start a parse from a sub-rule? [message #1220122 is a reply to message #778212] Mon, 09 December 2013 15:54 Go to previous message
Hi everyone,
Is there a way to choose different start parsing rules for the EmbeddedEditor ?
In that use case it makes even more sense, as it might be that different EmbeddedEditors on the same form parse different parts of the language.
Vlad
Previous Topic:xtext rename participant
Next Topic:DSL debugger
Current Time: Sun Jul 27 16:19:20 EDT 2025
Powered by FUDForum. Page generated in 0.04188 seconds
