Home » Eclipse Projects » Eclipse 4 » Exporting Feature-based Product
Exporting Feature-based Product [message #1219912] Fri, 06 December 2013 11:52 Go to next message
Hello to all
I'm trying to figure out how to create an eclipse based rcp application for the management of the project of my society.
Right now i'm trying to create the base feature-based application in order to add and update functionality through p2 framework.
Actually, i stopped in the exporting process. The application runs correctly in the eclipse environment, but fail to start once deployed in the os.
Java states "error 13" and the log states:
SESSION Fri Dec 06 17:51:04 CET 2013 ------------------------------------------
!ENTRY org.eclipse.equinox.launcher 4 0 2013-12-06 17:51:04.711
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.RuntimeException: Could not find framework
at org.eclipse.equinox.launcher.Main.getBootPath(Main.java:992)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:571)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
Another, more complex project, plugin based, run flawlessly.
Any idea about?
Re: Exporting Feature-based Product [message #1220068 is a reply to message #1219912] Mon, 09 December 2013 08:06 Go to previous messageGo to next message
Probably jvm related. Make sure it can find the jvm or supply it via the -vm arg. Also make sure it's the right 32-64 bit arch.
Re: Exporting Feature-based Product [message #1220087 is a reply to message #1220068] Mon, 09 December 2013 10:40 Go to previous message
The Virtual machine is correct. I tried to export a blank project, one configured as feature-based, one configurd as plugin based. No problem with the plugin based, not working the feature based.
Previous Topic:Can't find contributed HandledToolItem in MApplication
Next Topic:Creating a command line/no GUI application
Current Time: Sun Jul 27 08:57:42 EDT 2025
Powered by FUDForum. Page generated in 0.02995 seconds
