Home » Modeling » GMF (Graphical Modeling Framework) » How to create an EReference programmatically?
icon5.gif  How to create an EReference programmatically? [message #1220042] Mon, 09 December 2013 05:07 Go to next message
Hi all,
I am trying to programmatically create a connection(an EReference) between two EClass on a GMF-based Editor. (cf. picture - an ERefference bewteen the Student and the Lecture)
I tried using CreateConnectionRequest, codes are as followed:
CreateConnectionRequest createConnectionReques = new CreateConnectionRequest();
createConnectionReques.setSourceEditPart(sourceEditPart);
createConnectionReques.setTargetEditPart(targetEditPart);
Command commandConnection = sourceEditPart.getCommand(createConnectionReques);
if(commandConnection.canExecute()){
    commandConnection.execute();
but a NullPointerException for the command is thrown, that means the command is not initiated correctly. I really don't know why Sad .
Could anyone help, how to build the command correctly?
Thanks in advance.
  • Attachment: Student.png
    (Size: 15.04KB, Downloaded 330 times)
Re: How to create an EReference programmatically? [message #1220070 is a reply to message #1220042] Mon, 09 December 2013 08:13 Go to previous messageGo to next message
Le 09/12/2013 13:58, Xiaoying Hu a écrit :
> Hi all,
You don't execute the commands yourself, but must pass through the
command stack (which is responsible for undo/redo behavior):
TransactionalEditingDomain ted = sourceEditPart.getEditingDomain();
ted.getCommandStack().execute(commandConnection);
Re: How to create an EReference programmatically? [message #1220093 is a reply to message #1220070] Mon, 09 December 2013 11:04 Go to previous messageGo to next message
Hi Pierre-Charles,
thanks for your quick reply.
There is a problem here, the execute method is not applicable for a GEF command (org.eclipse.gef.commands.Command), it works only for EMF command(org.eclipse.emf.common.command.Command).
To run the GEF command is the second step, the first step is to get the GEF command, in my case using the code:
This doesn't work. So the question is, how can I get the correct command to run the request?
Any idea will be appreciated. Smile
Re: How to create an EReference programmatically? [message #1692795 is a reply to message #1220093] Sat, 18 April 2015 17:00 Go to previous message
Hello there,
I encountered the same issue.
I came up with the following method which seems to solve the problem.
public void createAndExecuteConnectionRequestCommand(IElementType type, DiagramEditPart editPart, EditPart source, EditPart target) {
		CreateConnectionViewAndElementRequest request = new CreateConnectionViewAndElementRequest(type, ((IHintedType) type).getSemanticHint(), editPart.getDiagramPreferencesHint());
		Command cmd = CreateConnectionViewAndElementRequest.getCreateCommand(request,
						source, target);
		System.out.println(cmd.getLabel());
		diagramEditPart.getDiagramEditDomain().getDiagramCommandStack().execute(cmd);
		//hack to refresh visuals and show the connection!
		diagramEditPart.addNotify();
Best, Nikos.
Previous Topic:GMF multidiagram editor - avoid data lost
Next Topic:org.eclipse.core.runtime.AssertionFailedException:
Current Time: Fri Jul 25 08:42:06 EDT 2025
Powered by FUDForum. Page generated in 0.25731 seconds
