Home » Eclipse Projects » EclipseLink » MOXy, XmlAdapter, and @Inject(Possible to @Inject or provide instance of XmlAdapter to MOXy?)
icon5.gif  MOXy, XmlAdapter, and @Inject [message #1214064] Wed, 27 November 2013 09:22 Go to next message
I'm doing a short spike to determine if we can move our JAX-RS 2.0 application from using Jackson to MOXy. We use some Spring managed beans for customer serializers/deserializers for Jackson and naturally, would like to turn these into XmlAdapters. However, we have a need to @Inject some things into these adapters (which we are doing via some extension points in Jackson). I'm assuming this isn't supported by JAXB so I was hoping there was a way to do it via MOXy, however I can find nothing on it.
Is this possible? Is there a way to @Inject into an XmlAdapter or is there a way to provide an already instantiated XmlAdapter to MOXy for use rather than it "newing up" an instance upon first use?
Re: MOXy, XmlAdapter, and @Inject [message #1219921 is a reply to message #1214064] Fri, 06 December 2013 13:45 Go to previous message
You can provide a configured instance of an XmlAdapter to MOXy or any JAXB implementation by calling setAdapter(XmlAdapter) on Marshaller/Unmarshaller. Below is a link to an example that should help.
- http://blog.bdoughan.com/2011/09/mixing-nesting-and-references-with.html
To integrate this into JAX-RS you will need to leverage it through a MessageBodyReader/MessageBodyWriter.
-Blaise
Previous Topic:Retrieve joined element using criteria api
Next Topic:MOXy Performance and Caching
Current Time: Sat Nov 01 01:41:04 EDT 2025
Powered by FUDForum. Page generated in 0.03957 seconds
