Parameter with % value - showing and records with null values [message #1219585] |
Wed, 04 December 2013 13:38  |
I suppose this is simple question for many.
Lets say I have this table:
SERVICE:
A
B
C
null
null
I made a SQL data set (not by scripting) query:
SELECT SERVICE FROM TABLE WHERE SERVICE LIKE ?
I created and parameter service which is not required (to be able to select null value)
So If I enter A it shows A which is ok.
If I enter % it will show A,B,C which is not ok, it should show and two others.
I can not put in where clause "service like % or service is null" because if I enter A it will show 3 records in that case which is not good.
I want when "%" is entered to show all records but if specific value is entered to show only that value.
Please can someone give me instructions how to solve this in BIRT?
Thank you
[Updated on: Thu, 05 December 2013 07:37] by Moderator
Re: Null Parameter - showing and records with null values [message #1219837 is a reply to message #1219770] |
Fri, 06 December 2013 03:47   |
thank you very much for information but it seems that this does not work completely.
If I enter as parameter value % it works OK.
But if enter some specific value, for example "Internet" I am getting error.
If I do the regular expression with only one "?" and enter "Internet" I do not have those errors.
Below are errors which I am getting when using your query.
The following items have errors:
Data (id = 367):
- Cannot execute the statement.
SQL statement does not return a ResultSet object.
SQL error #1: DB2 SQL Error: SQLCODE=-302, SQLSTATE=22001, SQLERRMC=null, DRIVER=3.53.70
Cannot execute the statement.SQL statement does not return a ResultSet object.SQL error #1: DB2 SQL Error: SQLCODE=-302, SQLSTATE=22001, SQLERRMC=null, DRIVER=3.53.70 ( 1 time(s) )
detail : org.eclipse.birt.report.engine.api.EngineException: Cannot execute the statement.SQL statement does not return a ResultSet object.SQL error #1: DB2 SQL Error: SQLCODE=-302, SQLSTATE=22001, SQLERRMC=null, DRIVER=3.53.70 at org.eclipse.birt.report.engine.executor.ExecutionContext.addException(ExecutionContext.java:1121) at org.eclipse.birt.report.engine.executor.ExecutionContext.addException(ExecutionContext.java:1085) at org.eclipse.birt.report.engine.executor.QueryItemExecutor.executeQuery(QueryItemExecutor.java:88) at org.eclipse.birt.report.engine.executor.DataItemExecutor.execute(DataItemExecutor.java:75) at
[Updated on: Fri, 06 December 2013 03:47] by Moderator
Re: Null Parameter - showing and records with null values [message #1219987 is a reply to message #1219978] |
Sun, 08 December 2013 07:24  |
Hi Dejan,
It seems your setup is fine, at first sight i can't find out why it does not work. Though you should set a default value in the 'service' report parameter: it would allow to preview data within the dataset definition, and therefore might help to solve the problem.
A key point would be to know if this very query runs correctly when we hard-code parameter values: for example duplicate the dataset and replace all '?' with possible values, in particular replace the two last '?' with 'Internet', can we preview some data like this?
If so, the problem might be a birt bug. It seems the report is designed with birt 2.3.2, i never used this version may be it was not possible to use twice a same report parameter in a query?
In this case, i don't see any other easy way to apply that filter. A possible workaround would be to use a DB2 stored procedure instead of a regular SQL query.
You could also apply this 'service' filter in a BIRT expression, but this would change significantly the report design and might be less efficient.
[Updated on: Sun, 08 December 2013 07:32] by Moderator
FUDForum. Page generated in 0.04174 seconds
