[Solved:] How to "Generate Java Code"? [message #1219800] |
Thu, 05 December 2013 15:15  |
I just discovered the menu option (right click on Class in Class Diagram)
=>Java=>"Generate Java Code"
It gives me following error message:
"Problem Occured"
'Generate java classes' has encountered a problem.
No classes or packages produced from the
transformation. Nothing is generated.
How do I correctly use this feature to generate java code from an Papyrus UML class diagram? Are there some Tutorials on java code generation with Papyrus?
I only know about some old topics on java code generation:
http://stackoverflow.com/questions/7130937/how-to-generate-code-by-papyrus-on-eclipse
http://www.eclipse.org/forums/index.php/mv/msg/466701/1067046/#msg_1067046
The impression that I get from those old topics is that Papyrus is not able to generate java code on its own and that I would have to use additional plugins. Did this change? If Papyrus is not yet able to generate java code: what is the meaning of that context menu?
[Updated on: Sat, 14 December 2013 14:45] by Moderator
FUDForum. Page generated in 0.07650 seconds
