Home » Modeling » ATL » [ATL] Library in EMFTVM launch config?(How to load a library required by a module in an EMFTVM launch configuration?)
[ATL] Library in EMFTVM launch config? [message #1219782] Thu, 05 December 2013 13:47 Go to next message
Hi guys,
who knows how to add a library to an EMFTVM launch config?
I have an ATL module which requires an ATL library (presenterLib.atl); they work together no problem with @atlcompiler atl2006 and a matching launch config, but I have not found a way to load the library in an EMFTVM specific launch config.
Error message:
org.eclipse.m2m.atl.emftvm.util.VMException: Error during module loading: Error during module loading: Module presenterLib not found
Thank you for suggestions.
Re: [ATL] Library in EMFTVM launch config? [message #1219831 is a reply to message #1219782] Fri, 06 December 2013 03:05 Go to previous messageGo to next message
Your libraries have to be on the "module path": http://wiki.eclipse.org/ATL/EMFTVM#Module_import
Note that the library/module name must also be a qualified name w.r.t. the module path: if the module path is "/home/someone", and your module sits in "/home/someone/package/Module.atl", then your module name should be "package::Module". See for example http://git.eclipse.org/c/mmt/org.eclipse.atl.git/tree/tests/org.eclipse.m2m.atl.emftvm.tests/test-data/Regression/Bug419433.atl
Re: [ATL] Library in EMFTVM launch config? [message #1219860 is a reply to message #1219782] Fri, 06 December 2013 05:20 Go to previous messageGo to next message
Dennis, thanks for the hint. I'm not yet sure how to transfer that exactly to my problem.
The importing module is in
/com.customer.dat.modeltransformation.startek/src/com/customer/dat/modeltransformation/startek/atl/files/transformate2startek.atl
and the library to be loaded is in
/com.customer.dat.modeltransformation.startek.atl.lib/src/com/customer/dat/modeltransformation/atl/lib/presenterLib.atl
I'm using
/com.customer.dat.modeltransformation.startek.atl.lib/src/com/customer/dat/modeltransformation/atl/lib/,/com.customer.dat.modeltransformation.startek/src/com/customer/dat/modeltransformation/startek/atl/files/
as module path in the launch config, and I'm not sure how to modify the library's name and the import in the using module. Can you specify your suggestion further?
[Updated on: Fri, 06 December 2013 05:20] by Moderator
Re: [ATL] Library in EMFTVM launch config? [message #1219877 is a reply to message #1219860] Fri, 06 December 2013 08:25 Go to previous messageGo to next message
Your module path looks fine to me. Can you show me the first few lines of presenterLib.atl?
Re: [ATL] Library in EMFTVM launch config? [message #1219878 is a reply to message #1219782] Fri, 06 December 2013 08:43 Go to previous messageGo to next message
Sure thing:
-- @atlcompiler emftvm
library presenterLib;
--- This is an apparently very general helper which is intended
--- to be used for OclUndefined only.
helper context OclAny def: getSpecification(): String = '';
helper context transformate!MessageModelTransformer def: getSpecification(): String =
	self.message;
--- Many more of those helpers...
I had a partial success by moving that file to the same directory as the ATL module that uses it: There is no more error message in that case. Instead, just plain nothing happens.
Re: [ATL] Library in EMFTVM launch config? [message #1220014 is a reply to message #1219878] Mon, 09 December 2013 02:43 Go to previous messageGo to next message
Hi Gunnar, I'm not entirely sure but I think you would need to change the name of your transformations to include the path (at least that's how I made it work for myself), this is what I use:
- Main module:
module "Transformations::RCP2GWTPSM2PIM";
create OUT: UML2 from IN: UML2, Plugin: XML, Profile: profile;
uses "Transformations::Libraries::UMLLibrary";
- Library:
library "Transformations::Libraries::UMLLibrary";
That's the header on each of the ATL files and it works fine for me, hopefully for you too!
Re: [ATL] Library in EMFTVM launch config? [message #1853952 is a reply to message #1219782] Mon, 25 July 2022 09:30 Go to previous message
I'm currently giving EMFTVM another try (after 9 years!).
The solution was to rename the importing project from
to
com.customer.dat.modeltransformation.startek.atl.files
so its name is no longer a prefix of the library project name
And of course add both comma-separated to the module path.
[Updated on: Mon, 25 July 2022 09:31] by Moderator
Previous Topic:Collecting all instances and calculating the values
Next Topic:How can I tranform a feature of the Parent class accessing from the chield class?
Current Time: Fri Jul 25 22:14:52 EDT 2025
Powered by FUDForum. Page generated in 0.06404 seconds
