Enabling DEBUG logging in spring security classes [message #1219763] |
Thu, 05 December 2013 12:05  |
I have added the following to serviceability.xml to enable logging in spring security code.
<logger level="DEBUG" additivity="false" name="org.springframework.security">
<appender-ref ref="SIFTED_LOG_FILE" />
<appender-ref ref="LOG_FILE" />
</logger>
Unfortunately, this doesn't seem to do the trick. I don't see any DEBUG messages from spring security classes. Is there any other configuration I need to modify? Any help is greatly appreciated.
I am using Virgo 3.5.0 and spring-security 3.1.4.
Raghu
Re: Enabling DEBUG logging in spring security classes [message #1219838 is a reply to message #1219763] |
Fri, 06 December 2013 03:50   |
Hi Raghu,
with your snippet I do get DEBUG and INFO messages:
[2013-12-06 09:30:26.471] DEBUG start-signalling-1 .s.s.w.a.e.ExpressionBasedFilterInvocationSecurityMetadataSource Adding web access control expression 'hasRole('ROLE_USER')', for Ant [pattern='/forms/**']
[2013-12-06 09:30:26.472] DEBUG start-signalling-1 .s.s.w.a.e.ExpressionBasedFilterInvocationSecurityMetadataSource Adding web access control expression 'permitAll', for Ant [pattern='/']
[2013-12-06 09:30:26.472] DEBUG start-signalling-1 o.s.security.web.access.intercept.FilterSecurityInterceptor Validated configuration attributes
[2013-12-06 09:30:26.474] INFO start-signalling-1 org.springframework.security.web.DefaultSecurityFilterChain Creating filter chain: org.springframework.security.web.util.AnyRequestMatcher@1, [org.springframework.security.web.context.SecurityContextPersistenceFilter@144edb15, org.springframework.security.web.authentication.logout.LogoutFilter@45114a1d, org.springframework.security.web.authentication.UsernamePasswordAuthenticationFilter@7218d957, org.springframework.security.web.authentication.ui.DefaultLoginPageGeneratingFilter@3d651946, org.springframework.security.web.authentication.www.BasicAuthenticationFilter@385e6227, org.springframework.security.web.savedrequest.RequestCacheAwareFilter@3c7e0b5a, org.springframework.security.web.servletapi.SecurityContextHolderAwareRequestFilter@771b60bc, org.springframework.security.web.authentication.AnonymousAuthenticationFilter@266c13bb, org.springframework.security.web.session.SessionManagementFilter@1836db2, org.springframework.security.web.access.ExceptionTranslationFilter@5b96c1e4, org.springframework.security.web.access.intercept.FilterSecurityInterceptor@6938eb6]
[2013-12-06 09:30:26.480] INFO start-signalling-1 o.s.security.config.http.DefaultFilterChainValidator Checking whether login URL '/spring_security_login' is accessible with your configuration
[2013-12-06 09:30:26.482] DEBUG start-signalling-1 o.s.security.config.http.DefaultFilterChainValidator Default generated login page is in use
Please note the various types of abbreviations for types with long names and lots of packages:
- org.springframework.security.web.DefaultSecurityFilterChain
- o.s.security.web.access.intercept.FilterSecurityInterceptor
- .s.s.w.a.e.ExpressionBasedFilterInvocationSecurityMetadataSource
florian
FUDForum. Page generated in 0.08902 seconds
