Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Xcore] Annotating uniqueness constraints (Newbie)
[Xcore] Annotating uniqueness constraints (Newbie) [message #1219583] |
Wed, 04 December 2013 13:11  |
I have built an Xcore EMF model and use Teneo to persist. However, I
need to have uniqueness constraints - I have looked through the lists
but not found the answer.
For example, I have Person objects that include a last and first name,
and a status (current or past, for example). I want a constraint that
the combination of the first and last name must be unique.
With the default Xcore driven EMF code for my objects, and using MySQL,
if I rerun my test application, records keep getting added to the
database.
I have seen uniqueness attribute and annotations on individual columns,
but mostly in the XML files. I am hoping there is a way to express
these constraints using Xcore since it is much more intelligible.
Thanks.
- Mike
Re: [Xcore] Annotating uniqueness constraints (Newbie) [message #1219722 is a reply to message #1219583] |
Thu, 05 December 2013 09:57   |
Hi Mike,
In Teneo JPA Annotations can be entered/defined as EAnnotations in a model. I don't know xcore really, but maybe you can
define/enter eAnnotations also in xCore and use that to define these JPA annotations?
gr. Martin
On 12/04/2013 07:11 PM, J. Michael Dean wrote:
> I have built an Xcore EMF model and use Teneo to persist. However, I need to have uniqueness constraints - I have
> looked through the lists but not found the answer.
> For example, I have Person objects that include a last and first name, and a status (current or past, for example). I
> want a constraint that the combination of the first and last name must be unique.
> With the default Xcore driven EMF code for my objects, and using MySQL, if I rerun my test application, records keep
> getting added to the database.
> I have seen uniqueness attribute and annotations on individual columns, but mostly in the XML files. I am hoping there
> is a way to express these constraints using Xcore since it is much more intelligible.
> Thanks.
> - Mike
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Xcore] Annotating uniqueness constraints (Newbie) [message #1219816 is a reply to message #1219722] |
Thu, 05 December 2013 17:57   |
Martin - I had tried to insert the following as an annotation (I
preceded this with annotation "teneo.jpa" as TeneoJpa):
@TeneoJpa(appinfo="@Table(uniqueConstraints
{@UniqueConstraint(columnNames={"LASTNAME" "FIRSTNAME" "STATUS"})})")
However, this results in massive error statements. Clearly not the
right syntax. The statements below are fine and function correctly. so
myh error is in the appinfo portion of the annotation.
@TeneoJpa(appinfo="@Basic(optional=false) @Column(name=LASTNAME)")
String lastName = ""
My main problem is knowing if an object already exists (I can guard the
database with code). If someone tries to enter a duplicate person, my
check for existence works fine with objects if I write my own hash and
equals contracts, but since EMF depends on not messing with the hash and
equals definitions, this is problematic.
Thanks for your help.
- Mike
On 12/5/13, 7:57 AM, Martin Taal wrote:
> Hi Mike,
> model. I don't know xcore really, but maybe you can define/enter
> gr. Martin
>> be unique.
>> more intelligible.
>> Thanks.
>> - Mike
Re: [Xcore] Annotating uniqueness constraints (Newbie) [message #1219984 is a reply to message #1219816] |
Sun, 08 December 2013 05:31  |
Hi Mike,
Took some more time as I thought the error was related to the xcore notation.
But taking a look at your example afaics the JPA annotation does not have the correct format. It should be something like:
@Table(uniqueConstraints=@UniqueConstraint(columnNames={"LASTNAME", "FIRSTNAME","STATUS"}))
I think there is much documentation on the net on JPA, so it should be easy to find more specific information.
gr. Martin
On 12/05/2013 11:57 PM, J. Michael Dean wrote:
> Martin - I had tried to insert the following as an annotation (I preceded this with annotation "teneo.jpa" as TeneoJpa):
> @TeneoJpa(appinfo="@Table(uniqueConstraints {@UniqueConstraint(columnNames={"LASTNAME" "FIRSTNAME" "STATUS"})})")
> However, this results in massive error statements. Clearly not the right syntax. The statements below are fine and
> function correctly. so myh error is in the appinfo portion of the annotation.
> My main problem is knowing if an object already exists (I can guard the database with code). If someone tries to enter
> a duplicate person, my check for existence works fine with objects if I write my own hash and equals contracts, but
> since EMF depends on not messing with the hash and equals definitions, this is problematic.
> - Mike
>> Hi Mike,
>> gr. Martin
>>> be unique.
>>> more intelligible.
>>> Thanks.
>>> - Mike
The Netherlands
Current Time: Sun Jul 27 10:02:46 EDT 2025
Powered by FUDForum. Page generated in 0.07865 seconds
