Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » EcoreUtil.getURI(feature)(EcoreUtil.getURI(feature) returns an unusable uri)
EcoreUtil.getURI(feature) [message #1219575] Wed, 04 December 2013 12:28 Go to next message
All,
I have an EMF document that I'm trying to persist. At one point in the persistence process, a FeatureMap is encountered where we loop through the contained entries to get a uri for each entry:
EStructuralFeature feature = entry.getEStructuralFeature();
EcoreUtil.getURI(feature);
The call to EcoreUtil.getURI(feature) returns a usable uri until a feature that contains embedded XML is encountered. At this point, a uri is returned that starts with "#///DocumentRoot/"<name of embedded xml node>.
Why does this happen?
What I would really like is to get this embedded xml returned as a string. Is there a way of getting this result?
Re: EcoreUtil.getURI(feature) [message #1219580 is a reply to message #1219575] Wed, 04 December 2013 13:04 Go to previous messageGo to next message
Geoffry,
Comments below.
On 04/12/2013 6:28 PM, Geoffry Roberts wrote:
> All,
Usable for what?
> embedded xml node>.
There is demand created metadata for processing things like wildcards
and such things aren't contained by a resource.
You can try org.eclipse.emf.ecore.xmi.XMLResource.OPTION_ROOT_OBJECTS
specifying the EObject you want to write out. You can use
org.eclipse.emf.ecore.xmi.XMLResource.save(Writer, Map<?, ?>) to write
directly to a StringWriter...
Re: EcoreUtil.getURI(feature) [message #1219599 is a reply to message #1219580] Wed, 04 December 2013 15:36 Go to previous messageGo to next message
"Unusable" is what I am calling anything that starts with #///DocumentRoot/. The reason it is unusable is because when converted to a ExtensibleURIConverterImpl.normalize(URI uri) it returns as "file:///"<the directory from which the program was launched>--not good.
In the xml below, everything within the <text> node is generated as a FeatureMap. When looping throughout the contained entries the continued features return from EcoreUtil.getURI(feature); as #///DocumentRoot/.
<text>
<content styleCode="Bold">Henry Levin, the 7<sup>th</sup></content>
is a 67 year old male referred for further asthma management. Onset of asthma in his
<content revised="delete">twenties</content>
<content revised="insert">teens</content>.
He was hospitalized twice last year, and already twice this year. He has not been able to be
weaned off steroids for the past several months.
</text>
I hope this helps.
Re: EcoreUtil.getURI(feature) [message #1219609 is a reply to message #1219599] Wed, 04 December 2013 17:08 Go to previous messageGo to next message
Geoffry,
Comments below.
> #///DocumentRoot/.
Unusable for what purpose?
What are you doing with the URI?
> #///DocumentRoot/.
> <text>
> of asthma in his
> <content revised="insert">teens</content>. He was hospitalized
> weaned off steroids for the past several months. </text>
> I hope this helps.
It doesn't help me understand what you're hoping to do with the URI.
Nor does it respond in any way to what I suggested about getting an XML
snippet. Nor does any of this explain how the two issues are related.
Re: EcoreUtil.getURI(feature) [message #1219620 is a reply to message #1219609] Wed, 04 December 2013 19:26 Go to previous messageGo to next message
Ed,
Thanks for being so patient. I appreciate it.
The application stores and EMF document into a document oriented database. When it stores data it also stores a uri(s) so the data can be retrieved into the proper EMF class(es). When I wrote that EcoreUtil.getURI(feature) was returning #///DocumentRoot I called it unusable because #///DocumentRoot normalizes into file:///<whatever>, which is not a uri for an EMF class. At store time all appears to be working, but at retrieval time #///DocumentRoot cannot be interpreted successfully and errors ensue. A FileNotFoundException is thrown with the message that file:///<whatever> is a directory. I have included two examples of usable uris so you see what they look like.
http://www.eclipse.org/emf/2003/XMLType#//XMLTypeDocumentRoot/text
http://www.openhealthtools.org/mdht/uml/hl7/datatypes#//EN/given
Perhaps my question should be why, when processing this embedded xml, am I not getting a usable uri?
Thanks again
Re: EcoreUtil.getURI(feature) [message #1219633 is a reply to message #1219620] Thu, 05 December 2013 01:04 Go to previous messageGo to next message
Geoffry,
When processing wildcards, the deserializer is using things like
org.eclipse.emf.ecore.util.ExtendedMetaData.demandFeature(String,
String, boolean) to create a feature and such demand created metadata
has no enclosing resource. You might consider using
org.eclipse.emf.ecore.util.ExtendedMetaData.getNamespace(EStructuralFeature)
in the case that the URI you get from EcoreUtil.getURI returns the empty
URI, but keep in mind that you "find" that feature again, you have to
demand create it again, and for that you need to know if it's an element
or an attribute to call demandFeature with the right arguments.
On 05/12/2013 1:26 AM, Geoffry Roberts wrote:
> Ed,
> Thanks again
Re: EcoreUtil.getURI(feature) [message #1220078 is a reply to message #1219575] Mon, 09 December 2013 09:40 Go to previous messageGo to next message
Ed,
Your suggestion to use org.eclipse.emf.ecore.util.ExtendedMetaData.getNamespace(EStructuralFeature) when EcoreUtil.getURI(feature) returns an unusable, error producing URI works. In cases where EcoreUtil.getURI(feature) returns "#///DocumentRoot", ExtendedMetaData.getNamespace(EStructuralFeature) returns "hl7-org:v3"; which I can live with for now. Whether it will continue to serve in the unforeseen situations of the future, who knows?
Thanks for the help.
Re: EcoreUtil.getURI(feature) [message #1220086 is a reply to message #1219575] Mon, 09 December 2013 10:35 Go to previous messageGo to next message
Hi Ed,
Geoffry is attempting to use MongoEMF to serialize / deserialize his model. The code in question from MongoEMF is:
protected void buildFeatureMap(DBObject dbObject, EAttribute attribute, Object value)
  FeatureMap.Internal featureMap = (FeatureMap.Internal) value;
  Iterator<FeatureMap.Entry> iterator = featureMap.basicIterator();
  ArrayList<DBObject> dbFeatureMap = new ArrayList<DBObject>();
  while (iterator.hasNext())
    DBObject dbEntry = new BasicDBObject();
    FeatureMap.Entry entry = iterator.next();
    dbEntry.put("key", EcoreUtil.getURI(feature).toString());           <<<-------------------- Get the URI here
    if (feature instanceof EAttribute)
      EDataType eDataType = ((EAttribute) feature).getEAttributeType();
      if (!MongoUtils.isNativeType(eDataType))
        dbEntry.put("value", convertEMFValueToMongoDBValue(eDataType, entry.getValue()));
      else
         dbEntry.put("value", entry.getValue());
    else
       dbEntry.put("value", buildReferencedObject((EReference) feature, (EObject) entry.getValue()));
    dbFeatureMap.add(dbEntry);
  dbObject.put(attribute.getName(), dbFeatureMap);
Can we improve upon this solution to handle his case generically, or is this something that is model specific?
Bryan
Re: EcoreUtil.getURI(feature) [message #1220139 is a reply to message #1220086] Tue, 10 December 2013 00:14 Go to previous messageGo to next message
Bryan,
I assume you're using this URI so that later you can use
ResourceSet.getEObject to load the feature again, but this only works if
the feature isn't a demand created one. If it's demand created, you'll
really need to remember the namespace, the name, and whether it's an
element or an attribute, so you can call
org.eclipse.emf.ecore.util.BasicExtendedMetaData.demandFeature(String,
String, boolean) with the appropriate arguments. Note there are even
cases (an xsi:type within a wildcard's feature map's contents) where you
could end up with an EObject whose eClass() is created using
org.eclipse.emf.ecore.util.BasicExtendedMetaData.demandType(String, String).
On 09/12/2013 4:35 PM, Bryan Hunt wrote:
> Hi Ed,
> entry.getValue()));
> else
> else
> Bryan
Re: EcoreUtil.getURI(feature) [message #1220237 is a reply to message #1220139] Tue, 10 December 2013 09:32 Go to previous messageGo to next message
Ed,
By "demand created" do you mean created at runtime? If so, this is not the case in my situation. What I have are XML tags that are embedded within an element but are supposed to be treated as a String. This is what the designers (not me) envisioned. As a result, when EMF is used to process these documents (a very attractive thing to do from a technical standpoint), EMF creates a feature map treating them as elements. In the corresponding ecore, these embedded elements are not given a datatype. <thinking out loud>I wonder if this problem would go a way if they were given a type. We have ST, which, in Java, is implemented as String.</thinking out loud>
Re: EcoreUtil.getURI(feature) [message #1220256 is a reply to message #1220237] Tue, 10 December 2013 11:50 Go to previous messageGo to next message
Geoffry,
Comments below.
On 10/12/2013 3:32 PM, Geoffry Roberts wrote:
> Ed,
Yes it is.
Treated by what?
> as elements.
Because they are.
> datatype.
They're instances of AnyType.
> were given a type.
No.
If you saved such a thing as XML, the things like < would be encoded as
&lt; so they would not be embedded elements, they'd just be a value that
happens to look like XML when it's decoded.
> Thanks
Re: EcoreUtil.getURI(feature) [message #1220264 is a reply to message #1220256] Tue, 10 December 2013 12:56 Go to previous message
Hi Ed,
Here's the other half of the MongoEMF code ...
protected void buildFeatureMap(DBCollection collection, Resource resource, EObject eObject, EAttribute attribute, List<DBObject> values)
  FeatureMap.Internal featureMap = (FeatureMap.Internal) eObject.eGet(attribute);
  for (DBObject entry : values)
    EStructuralFeature feature = (EStructuralFeature) resource.getResourceSet().getEObject(URI.createURI((String) entry.get("key")), true);
      featureMap.add(feature, convertMongoDBValueToEMFValue(eDataType, entry.get("value")));
    else
      EReference reference = (EReference) feature;
      DBObject dbReference = (DBObject) entry.get("value");
      EObject target = buildReferencedObject(collection, dbReference, resource, reference.isResolveProxies());
      featureMap.add(feature, target);
Previous Topic:[Eclipse Client Platform] EReference of Type "EObject" throws null pointer exception
Next Topic:[EMFStore] handling dangling references
Current Time: Thu Nov 06 15:16:30 EST 2025
Powered by FUDForum. Page generated in 0.05333 seconds
