2.5.0: Problems using Standalone Xtend with Xpand code [message #1219554] |
Wed, 04 December 2013 10:43  |
Hi all,
I am having problems with the standalone xtend compiler, using Release 2.5.0 Milestone 3. (2.5.0.v201311121244)
Using the simple MyDsl example project, I extended the file MyDslGenerator.xtend to look like this:
package org.xtext.example.mydsl.generator
import org.eclipse.emf.ecore.resource.Resource
import org.eclipse.xtext.generator.IFileSystemAccess
import org.eclipse.xtext.generator.IGenerator
import org.xtext.example.mydsl.myDsl.Greeting
class MyDslGenerator implements IGenerator {
override void doGenerate(Resource resource, IFileSystemAccess fsa) {
fsa.generateFile('greetings.txt', 'People to greet: ' +
resource.allContents
.filter(typeof(Greeting))
.map[name]
.join(', '))
for(g: resource.allContents.toIterable.filter(typeof(Greeting))) {
fsa.generateFile('org/xtext/example/mydsl/' + g.name.toFirstUpper + '.java', g.generateFile)
def String generateFile(Greeting g) '''
package org.xtext.example.mydsl;
public class «g.name.toFirstUpper» {
«g.name.toFirstUpper» «g.name.toFirstLower» = new «g.name.toFirstUpper»();
«g.name.toFirstLower».greet();
public void greet() {
System.out.println("Hello «g.name»!");
That all works fine as an eclipse plugin; it generates the desired code as expected.
My ant script is based on Boris Brodski's example on xtextcasts.org, and looks like this:
NB: This ant script is designed to be run in an eclipse environment, where the required JAR files are
available in the plugins directory. Before running, make sure the ant script runs in the same JRE as
eclipse by selecting the following setting:
- External Tool Configurations....
- JRE tab
- Run in the same JRE as the workspace
This will ensure that the system property "eclipse.home" is set.
<project name="MyDSL" default="all">
<property name="workflow" value="src/org/xtext/example/mydsl/GenerateMyDsl.mwe2"/>
<path id="classpath">
<fileset dir="${eclipse.home}/plugins">
<include name="org.eclipse.xtext_2.5.0.v201311121244.jar"/>
<include name="org.eclipse.emf.ecore.xmi_2.9.1.v20130827-0309.jar"/>
<include name="org.eclipse.emf.ecore_2.9.1.v20130827-0309.jar"/>
<include name="org.eclipse.emf.common_2.9.1.v20130827-0309.jar"/>
<include name="org.antlr.runtime_3.2.0.v201101311130.jar"/>
<include name="com.google.inject_3.0.0.v201203062045.jar"/>
<include name="com.google.inject.assistedinject_3.0.0.201207101151.jar"/>
<include name="com.google.inject.multibindings_3.0.0.201207101151.jar"/>
<include name="org.eclipse.emf.mwe.core_1.2.1.v201311120431.jar"/>
<include name="org.apache.commons.cli_1.2.0.v201105210650.jar"/>
<include name="org.eclipse.emf.mwe2.runtime_2.5.0.v201311120431.jar"/>
<include name="org.eclipse.emf.mwe.utils_1.3.1.v201311120431.jar"/>
<include name="org.eclipse.xtext.util_2.5.0.v201311121244.jar"/>
<include name="com.google.guava_10.0.1.v201203051515.jar"/>
<include name="javax.inject_1.0.0.v20091030.jar"/>
<include name="org.eclipse.xtext.xbase_2.5.0.v201311121244.jar"/>
<include name="org.eclipse.xtext.common.types_2.5.0.v201311121244.jar"/>
<include name="org.eclipse.jdt.annotation_1.0.1.v20130111-135246.jar"/>
<include name="org.eclipse.xtend.lib_2.5.0.v201311121244.jar"/>
<include name="org.eclipse.xtext.xbase.lib_2.5.0.v201311121244.jar"/>
<include name="org.eclipse.xtext.generator_2.5.0.v201311121244.jar"/>
<include name="org.eclipse.xtend_2.0.0.v201311120517.jar"/>
<include name="com.ibm.icu_4.4.2.v20110823.jar"/>
<include name="org.eclipse.xpand_2.0.0.v201311120517.jar"/>
<include name="org.eclipse.xtend.typesystem.emf_2.0.0.v201311120517.jar"/>
<include name="org.eclipse.emf.codegen.ecore_2.9.1.v20130902-0605.jar"/>
<include name="org.eclipse.emf.codegen_2.9.0.v20130902-0605.jar"/>
<include name="de.itemis.xtext.antlr_2.1.0.v201308291703.jar"/>
<include name="org.antlr.generator_3.2.0.v201308291703.jar"/>
<include name="org.eclipse.emf.mwe2.lib_2.5.0.v201311120431.jar"/>
<include name="org.apache.commons.logging_1.0.4.v201101211617.jar"/>
<include name="org.eclipse.emf.mwe2.launch_2.5.0.v201311120717.jar"/>
<include name="org.eclipse.emf.mwe2.language_2.5.0.v201311120717.jar"/>
<include name="org.slf4j.api_1.6.4.v20120130-2120.jar"/>
<include name="ch.qos.logback.classic_1.0.0.v20111214-2030.jar"/>
<include name="ch.qos.logback.core_1.0.0.v20111214-2030.jar"/>
<include name="org.eclipse.m2e.logback.configuration_1.3.0.20130129-0926.jar"/>
<include name="org.eclipse.core.resources_3.8.1.v20121114-124432.jar"/>
<include name="org.apache.log4j_1.2.15.v201012070815.jar"/>
<!-- The following jars are not in the Referenced Libraries, but are required by the compile process -->
<include name="org.eclipse.xtend.core_2.5.0.v201311121244.jar" />
<include name="org.eclipse.jdt.core_3.8.3.v20130121-145325.jar" />
<include name="org.eclipse.equinox.common_3.6.100.v20120522-1841.jar" />
</fileset>
<fileset dir="." includes=".antlr-generator-3.2.0.jar"/>
<pathelement location="src"/>
</path>
<target name="clean">
<delete dir="ant/src" quiet="true"/>
<delete dir="ant/src-gen" quiet="true"/>
<delete dir="ant/bin" quiet="true"/>
<delete dir="ant/xtend-gen" quiet="true"/>
<delete dir="ant/dist" quiet="true"/>
</target>
<target name="generate-xtext-artifacts">
<java classpathref="classpath"
classname="org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher"
fork="true">
<arg value="${workflow}"/>
</java>
</target>
<target name="convert-crlf-to-unix">
<mkdir dir="ant/src"/>
<mkdir dir="ant/src-gen"/>
<fixcrlf srcdir="src"
destdir="ant/src"
eol="lf"
eof="remove"
<fixcrlf srcdir="src-gen"
destdir="ant/src-gen"
eol="lf"
eof="remove"
</target>
<target name="compile-xtend">
<pathconvert pathsep="${path.separator}"
property="classpath-string"
refid="classpath">
</pathconvert>
<echo>Classpath: ${classpath-string}</echo>
<echo>Basedir: ${basedir}</echo>
<echo>Workflow: ${workflow}</echo>
<mkdir dir="ant/xtend-gen"/>
classname="org.eclipse.xtend.core.compiler.batch.Main"
fork="true"
failonerror="yes">
<arg value="-cp" />
<arg value="${classpath-string}" />
<arg value="-d" />
<arg value="ant/xtend-gen" />
<arg value="ant/src${path.separator}ant/src-gen" />
</java>
</target>
<target name="compile-java">
<mkdir dir="ant/bin"/>
<javac classpathref="classpath"
destdir="ant/bin"
source="1.6"
target="1.6"
includeantruntime="true">
<src path="src" />
<src path="src-gen" />
<src path="ant/xtend-gen" />
</javac>
<copy todir="ant/bin">
<fileset dir="ant/src" excludes="**/*.java,**/*.xtend" />
<fileset dir="ant/src-gen" excludes="**/*.java,**/*.xtend" />
<fileset dir="ant/xtend-gen" excludes="**/*.java,**/*.xtend" />
</copy>
</target>
<target name="package">
<mkdir dir="ant/dist"/>
<manifestclasspath property="jar.classpath" jarfile="ant/dist/ulvtdsl_bo_generator.jar">
<classpath refid="classpath"/>
</manifestclasspath>
<jar destfile="ant/dist/ulvtdsl_bo_generator.jar">
<fileset dir="ant/bin"/>
<manifest>
<attribute name="Main-Class" value="com.vxxxxxxl.ullink.xtext.dsl.Main"/>
<attribute name="Class-Path" value="${jar.classpath}"/>
</manifest>
</jar>
</target>
<target name="all" depends="clean,generate-xtext-artifacts,convert-crlf-to-unix,compile-xtend,compile-java,package"
description="build all">
</target>
</project>
The task "compile-xtend" (org.eclipse.xtend.core.compiler.batch.Main) fails with the following error messages:
compile-xtend:
[echo] Classpath: C:\Program Files\Eclipse\plugins\ch.qos.logback.classic_1.0.0.v20111214-2030.jar;C:\Program Files\Eclipse\plugins\ch.qos.logback.core_1.0.0.v20111214-2030.jar;C:\Program Files\Eclipse\plugins\com.google.guava_10.0.1.v201203051515.jar;C:\Program Files\Eclipse\plugins\com.google.inject.assistedinject_3.0.0.201207101151.jar;C:\Program Files\Eclipse\plugins\com.google.inject.multibindings_3.0.0.201207101151.jar;C:\Program Files\Eclipse\plugins\com.google.inject_3.0.0.v201203062045.jar;C:\Program Files\Eclipse\plugins\com.ibm.icu_4.4.2.v20110823.jar;C:\Program Files\Eclipse\plugins\de.itemis.xtext.antlr_2.1.0.v201308291703.jar;C:\Program Files\Eclipse\plugins\javax.inject_1.0.0.v20091030.jar;C:\Program Files\Eclipse\plugins\org.antlr.generator_3.2.0.v201308291703.jar;C:\Program Files\Eclipse\plugins\org.antlr.runtime_3.2.0.v201101311130.jar;C:\Program Files\Eclipse\plugins\org.apache.commons.cli_1.2.0.v201105210650.jar;C:\Program Files\Eclipse\plugins\org.apache.commons.logging_1.0.4.v201101211617.jar;C:\Program Files\Eclipse\plugins\org.apache.log4j_1.2.15.v201012070815.jar;C:\Program Files\Eclipse\plugins\org.eclipse.core.resources_3.8.1.v20121114-124432.jar;C:\Program Files\Eclipse\plugins\org.eclipse.emf.codegen.ecore_2.9.1.v20130902-0605.jar;C:\Program Files\Eclipse\plugins\org.eclipse.emf.codegen_2.9.0.v20130902-0605.jar;C:\Program Files\Eclipse\plugins\org.eclipse.emf.common_2.9.1.v20130827-0309.jar;C:\Program Files\Eclipse\plugins\org.eclipse.emf.ecore.xmi_2.9.1.v20130827-0309.jar;C:\Program Files\Eclipse\plugins\org.eclipse.emf.ecore_2.9.1.v20130827-0309.jar;C:\Program Files\Eclipse\plugins\org.eclipse.emf.mwe.core_1.2.1.v201311120431.jar;C:\Program Files\Eclipse\plugins\org.eclipse.emf.mwe.utils_1.3.1.v201311120431.jar;C:\Program Files\Eclipse\plugins\org.eclipse.emf.mwe2.language_2.5.0.v201311120717.jar;C:\Program Files\Eclipse\plugins\org.eclipse.emf.mwe2.launch_2.5.0.v201311120717.jar;C:\Program Files\Eclipse\plugins\org.eclipse.emf.mwe2.lib_2.5.0.v201311120431.jar;C:\Program Files\Eclipse\plugins\org.eclipse.emf.mwe2.runtime_2.5.0.v201311120431.jar;C:\Program Files\Eclipse\plugins\org.eclipse.equinox.common_3.6.100.v20120522-1841.jar;C:\Program Files\Eclipse\plugins\org.eclipse.jdt.annotation_1.0.1.v20130111-135246.jar;C:\Program Files\Eclipse\plugins\org.eclipse.jdt.core_3.8.3.v20130121-145325.jar;C:\Program Files\Eclipse\plugins\org.eclipse.m2e.logback.configuration_1.3.0.20130129-0926.jar;C:\Program Files\Eclipse\plugins\org.eclipse.xpand_2.0.0.v201311120517.jar;C:\Program Files\Eclipse\plugins\org.eclipse.xtend.core_2.5.0.v201311121244.jar;C:\Program Files\Eclipse\plugins\org.eclipse.xtend.lib_2.5.0.v201311121244.jar;C:\Program Files\Eclipse\plugins\org.eclipse.xtend.typesystem.emf_2.0.0.v201311120517.jar;C:\Program Files\Eclipse\plugins\org.eclipse.xtend_2.0.0.v201311120517.jar;C:\Program Files\Eclipse\plugins\org.eclipse.xtext.common.types_2.5.0.v201311121244.jar;C:\Program Files\Eclipse\plugins\org.eclipse.xtext.generator_2.5.0.v201311121244.jar;C:\Program Files\Eclipse\plugins\org.eclipse.xtext.util_2.5.0.v201311121244.jar;C:\Program Files\Eclipse\plugins\org.eclipse.xtext.xbase.lib_2.5.0.v201311121244.jar;C:\Program Files\Eclipse\plugins\org.eclipse.xtext.xbase_2.5.0.v201311121244.jar;C:\Program Files\Eclipse\plugins\org.eclipse.xtext_2.5.0.v201311121244.jar;C:\Program Files\Eclipse\plugins\org.slf4j.api_1.6.4.v20120130-2120.jar;C:\Users\vb4sd\workspace\branch_Monitoring\org.xtext.example.mydsl\src
[echo] Basedir: C:\Users\vb4sd\workspace\branch_Monitoring\org.xtext.example.mydsl
[echo] Workflow: src/org/xtext/example/mydsl/GenerateMyDsl.mwe2
[mkdir] Created dir: C:\Users\vb4sd\workspace\branch_Monitoring\org.xtext.example.mydsl\ant\xtend-gen
[java] 0 ERROR XtendBatchCompiler -
[java] ERROR: MyDslGenerator.xtend - C:\Users\vb4sd\workspace\branch_Monitoring\org.xtext.example.mydsl\ant\src\org\xtext\example\mydsl\generator\MyDslGenerator.xtend
[java] 31: The method toFirstUpper is undefined for the type MyDslGenerator
[java] 0 [main] ERROR org.eclipse.xtend.core.compiler.batch.XtendBatchCompiler -
[java] 13 ERROR XtendBatchCompiler -
[java] 34: The method toFirstUpper is undefined for the type MyDslGenerator
[java] 13 [main] ERROR org.eclipse.xtend.core.compiler.batch.XtendBatchCompiler -
[java] 34: The method toFirstLower is undefined for the type MyDslGenerator
[java] 36: The method toFirstLower is undefined for the type MyDslGenerator
[java] 14 ERROR XtendBatchCompiler -
[java] 40: The method name is undefined for the type MyDslGenerator
[java] 14 [main] ERROR org.eclipse.xtend.core.compiler.batch.XtendBatchCompiler -
If I comment the xpand code out of the file MyDslGenerator.xtend it seems to work fine.
I didn't see this problem with 2.4.x - am I doing something wrong or is this a bug?
Thanks for any help or hints.
Yours,
Adam Crowther
FUDForum. Page generated in 0.06972 seconds
