Home » Newcomers » Newcomers » Failed to load JNI(Tech/install help)
Failed to load JNI [message #996409] Tue, 01 January 2013 21:02 Go to next message
I have looked around and tried various things including reinstalling java and messing with the config to change the java use. I am using a 64 bit windows 7 PC and I downloaded the 64 bit adt bundle. I also have both 32 and 64 bit java.
Any suggestions? More info below!
The location my java jvm.dll file (for 64 bit) is in:
C:\Program Files (x86)\Java\jre7\bin\client
My current eclipse.ini file is as follows:
-startup
plugins/org.eclipse.equinox.launcher_1.3.0.v20120522-1813.jar
--launcher.library
plugins/org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.200.v20120522-1813
-product
com.android.ide.eclipse.adt.package.product
--launcher.XXMaxPermSize
256M
-showsplash
256m
--launcher.defaultAction
openFile
-vm
C:\Program Files (x86)\Java\jre7\bin\client\jvm.dll
-vmargs
-Dosgi.requiredJavaVersion=1.6
-Xms40m
-Xmx768m
-Declipse.buildId=v21.0.1-543035
Re: Failed to load JNI [message #996426 is a reply to message #996409] Tue, 01 January 2013 22:23 Go to previous messageGo to next message
Note. I tried changing the eclipse.ini to:
-vm
C:\Program Files\Java\jre7\bin\client\jvm.dll
and now I get the error "Failed to load the JNI shared library "C:\Program Files\Java\jre7\bin\client\jvm.dll"."
Re: Failed to load JNI [message #996597 is a reply to message #996409] Wed, 02 January 2013 08:41 Go to previous messageGo to next message
> both 32 and 64 bit java. Any suggestions? More info below!
> -startup
> --launcher.library
> -product
> 256M
> -showsplash
> 256m
> openFile
> -vm
> -vmargs
> -Xms40m
> -Xmx768m
Of course, this eclipse.ini is clearly saying to use a 32-bit Java, no?
Re: Failed to load JNI [message #996600 is a reply to message #996597] Wed, 02 January 2013 08:45 Go to previous messageGo to next message
>> -startup
>> --launcher.library
>> -product
>> 256M
>> -showsplash
>> 256m
>> openFile
>> -vm
>> -vmargs
>> -Xms40m
>> -Xmx768m
(Oops, didn't read all messages before asking this; disregard please.)
icon14.gif  Re: Failed to load JNI [message #998853 is a reply to message #996597] Thu, 10 January 2013 15:38 Go to previous messageGo to next message
hey thanks man...this worked for me..all others please try this
Re: Failed to load JNI [message #1219472 is a reply to message #998853] Tue, 03 December 2013 23:39 Go to previous message
Yes, I had the same problem, though of course should have twigged when I found javaw.exe in Program Files (86) and not just Program Files. I had previously assumed that given I'm running a 64 bit version of Win 7 the Java being downloaded and updated was automatically the 64 bit version given there doesn't seem to be any way to specify it unless you choose Offline download.
In the end I had to do that to ensure I got the 64 bit version, uninstall the 32 bit version and then install the 64 bit version.
PS FWIW I then noticed that in Control Panel/Programs and Features that for Java it now says (64 bit) whereas with the 32 bit version it has no indicator.
Previous Topic:eclipse jcde java card project problem!
Next Topic:JAXB project wizard is not appearing in Eclipse J2ee
Current Time: Thu Jul 24 23:31:32 EDT 2025
Powered by FUDForum. Page generated in 0.33291 seconds
