Home » Modeling » TMF (Xtext) » Customization of NamesAreUniqueValidator
Customization of NamesAreUniqueValidator [message #1219389] Tue, 03 December 2013 10:59 Go to next message
Hello everyone,
I would like to know if it possible to customize the "org.eclipse.xtext.validation.NamesAreUniqueValidator"?
I would like to keep this standard validator which I enabled in my workflow. But in some special cases, I need non unique names in my dsl-model. (example: several constructors of a class with different parameters).
Is this maybe possible?
Alex
Re: Customization of NamesAreUniqueValidator [message #1219595 is a reply to message #1219389] Wed, 04 December 2013 14:51 Go to previous messageGo to next message
HI,
you could try todo something like
package org.xtext.example.mydsl.validation;
import org.eclipse.emf.ecore.EClass;
import org.eclipse.xtext.validation.NamesAreUniqueValidationHelper;
import org.xtext.example.mydsl.myDsl.MyDslPackage;
public class MyDslNamesAreUniqueValidationHelper extends
		NamesAreUniqueValidationHelper {
	protected EClass getAssociatedClusterType(EClass eClass) {
		if (MyDslPackage.Literals.GREETING == eClass) return null;
		return super.getAssociatedClusterType(eClass);
or change the nameprovider
Re: Customization of NamesAreUniqueValidator [message #1219670 is a reply to message #1219595] Thu, 05 December 2013 05:45 Go to previous messageGo to next message
Hi Christian ,
By overriding NamesAreUniqueValidationHelper's getAssociatedClusterType will not solve probelm...
Also should make this helper to be injected to the validator.
Girish
Re: Customization of NamesAreUniqueValidator [message #1219675 is a reply to message #1219670] Thu, 05 December 2013 06:02 Go to previous messageGo to next message
Of course you have to add a binding
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: Customization of NamesAreUniqueValidator [message #1219685 is a reply to message #1219675] Thu, 05 December 2013 07:18 Go to previous messageGo to next message
Hello Christian,
it works perfectly for me. I can now delimit the subset of elements, which I dont want to get checked.
Binding should be done in the runtimeModule like:
public class MyDslRuntimeModule extends  AbstractMyDslRuntimeModule {
	public Class<? extends INamesAreUniqueValidationHelper> bindNamesAreUniqueValidationHelper() {
		return MyDslNamesAreUniqueValidationHelper.class;
Thx,
Alex
Re: Customization of NamesAreUniqueValidator [message #1383948 is a reply to message #1219685] Tue, 27 May 2014 07:02 Go to previous messageGo to next message
after rechecking my models and my validators I recognized, that this is not working! I also tried to manipulate my if-clause so it may really catch only special instances of my model.
public class CdalfNamesAreUniqueValidationHelper extends NamesAreUniqueValidationHelper {
		if (eClass.getInstanceClass() == de.mydsl.Operation.class || eClass.getInstanceTypeName().equals("de.mydsl.Operation") )
			return null;
When I debug my code, all operation-instances are found, but the NavesAreUniqueValidation is disabled for EVERY ELEMENT!
Does anyone have a clue?
~Alex
Re: Customization of NamesAreUniqueValidator [message #1383996 is a reply to message #1383948] Tue, 27 May 2014 14:18 Go to previous messageGo to next message
make sure that u you the validator at all
your impl looks very strange for me the following works fine for me
Model:
	elements+=Element*;
Element:
	AElement | BElement;
AElement:
	"a" name=ID
BElement:
	"b" name=ID
		if (MyDslPackage.Literals.AELEMENT == eClass) {
			return null;
public class MyDslRuntimeModule extends org.xtext.example.mydsl1.AbstractMyDslRuntimeModule {
	public Class<? extends NamesAreUniqueValidationHelper> bindNamesAreUniqueValidationHelper() {
 @ComposedChecks(validators=NamesAreUniqueValidator)
class MyDslValidator extends AbstractMyDslValidator {
Re: Customization of NamesAreUniqueValidator [message #1384130 is a reply to message #1383996] Wed, 28 May 2014 03:53 Go to previous message
I had enabled the composedCheck = "org.eclipse.xtext.validation.NamesAreUniqueValidator" in the workflow-file! After disabling it, your example works fine.
But what about nested elements?
Example: I disable the checking for operations ---> is the namechecking for nested elements of an operatin (parameters, local variables etc..) also disabled?
[Updated on: Wed, 28 May 2014 04:10] by Moderator
Previous Topic:XText cross-reference to rule containing a cross-reference
Next Topic:Getting root project absolute path
Current Time: Mon Jul 21 02:41:30 EDT 2025
Powered by FUDForum. Page generated in 0.10342 seconds
