Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Juno crashes on Ubuntu 13.10
Juno crashes on Ubuntu 13.10 [message #1192909] Sun, 17 November 2013 15:51 Go to next message
since upgrading to Ubuntu 13.10, I can't start a Juno IDE anymore. The
4.2 SDK crashes immediately on startup with a libwebgtk error (see
below). Eclipse 4.3 starts normally, it only crashes when an internal
browser is opened, but that's nothing new :(
I've heard that libwebgtk issues might be related to google-talkplugin.
So I tried to remove this package, but the crash on 4.2 startup remains.
Does anybody else has the same problem? Any hints how older Eclipse
version can be run on Ubuntu 13.10?
Thanks, Ralf
# A fatal error has been detected by the Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x00007f3470df75b0, pid=26177, tid=139865627285248
# JRE version: Java(TM) SE Runtime Environment (7.0_45-b18) (build
1.7.0_45-b18)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (24.45-b08 mixed mode
linux-amd64 compressed oops)
# Problematic frame:
# C [libwebkitgtk-1.0.so.0+0x112b5b0] void
WTF::freeOwnedGPtr<_GdkEvent>(_GdkEvent*)+0x16b00
Ralf Sternberg
Twitter: @EclipseRAP
Re: Juno crashes on Ubuntu 13.10 [message #1219253 is a reply to message #1192909] Mon, 02 December 2013 16:59 Go to previous messageGo to next message
> 1.7.0_45-b18)
This error looks like
https://bugs.eclipse.org/bugs/show_bug.cgi?id=392967, which was fixed in
the 4.3 release. I don't think you'll be able to get Eclipse/SWT 4.2 to
work in your environment, as the root cause of this crash was in
WebKitGTK and the Browser's fix in 4.3 was to trigger extraneous native
events to work around it.
When 4.3 crashes for you I suspect you're seeing a different problem.
My guess would be https://bugs.eclipse.org/bugs/show_bug.cgi?id=400626
since many others are seeing it as well. If you look to the bottom of
this report you'll see that it appears to be fixed in more recent
WebKitGTK releases, though I have not personally confirmed this.
Grant
Re: Juno crashes on Ubuntu 13.10 [message #1220043 is a reply to message #1219253] Mon, 09 December 2013 05:17 Go to previous message
Thanks for these pointers, Grant! I've managed to work around the
problem by adding this property to my eclipse.ini:
-Dorg.eclipse.swt.browser.DefaultType=mozilla
There are some issues with the internal browser such as missing icons
but at least no crashes.
Ralf
Ralf Sternberg
Previous Topic:TableViewer refresh does not work in a ViewPart
Next Topic:assertion error while setting focus on text field
Current Time: Sat Jul 26 23:43:06 EDT 2025
Powered by FUDForum. Page generated in 0.03426 seconds
