Home » Archived » Eclipse Process Manager (Stardust) » How to deploy stardust WAR to Tomcat
How to deploy stardust WAR to Tomcat [message #1219230] Mon, 02 December 2013 13:48 Go to next message
How do I generate the stardust war file to be deployed under production tomcat server?
Following command is not fetching the necessary libraries.
mvn archetype:generate -DarchetypeGroupId=org.eclipse.stardust.deploy
.jee.archetypes -DarchetypeArtifactId=tc6-ipp-portal-war -DarchetypeVersion=1.0.
1 -DgroupId=org.eclipse.stardust.test -DartifactId=stardust-portal-war -Dversion
=1.0-SNAPSHOT -Dgoals=dependency:unpack
Rahim
Re: How to deploy stardust WAR to Tomcat [message #1219234 is a reply to message #1219230] Mon, 02 December 2013 15:07 Go to previous messageGo to next message
Never mind. The necessary files were downloaded after executing following command.
mvn clean install
Re: How to deploy stardust WAR to Tomcat [message #1219273 is a reply to message #1219234] Tue, 03 December 2013 00:39 Go to previous message
Hi Rahim,
Yes, mvn archetype:generate will get the project only and 'mvn clean install' will build the project.
You can find the deployable war under target directory.
Tanmoy Roy
Previous Topic:How can I suspend or abort process using "Spring Bean Applicationa"
Next Topic:Mail / SMTP / Authentication
Current Time: Mon Jul 21 10:43:37 EDT 2025
Powered by FUDForum. Page generated in 0.03591 seconds
