Home » Archived » BIRT » BIRT Engine Version(BIRT Engine Version)
BIRT Engine Version [message #1219221] Mon, 02 December 2013 11:55 Go to next message
We have a scenario in which bits are mislabeled (i.e. a newer BIRT engine is labeled as an older version within the file name); is there a simple way to verify the version of the BIRT engine?
Paul
Re: BIRT Engine Version [message #1219450 is a reply to message #1219221] Tue, 03 December 2013 17:16 Go to previous message
So, the BIRT runtime folder has just been named improperly? If so, if you go into the BIRTEngine/lib folder, you can find the runtime jar and it's labeled with the version. If you're using an OSGi version, you'll have a plugins folder inside the BIRTEngine folder. There, you'll see org.eclipse.birt... jars that have the version info in them. Hope this helps. Let me know if I'm misunderstanding.
Previous Topic:Adhoc reporting using BIRT
Next Topic:Dashboard Application in Web
Current Time: Mon Jul 21 05:25:11 EDT 2025
Powered by FUDForum. Page generated in 0.05421 seconds
