Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [CDO]When CDO can support GMF Editor?
[CDO]When CDO can support GMF Editor? [message #105183] Mon, 24 December 2007 02:51 Go to next message
No Message Body
Re: [CDO]When CDO can support GMF Editor? [message #105290 is a reply to message #105183] Thu, 27 December 2007 06:24 Go to previous messageGo to next message
Originally posted by: stepper.sympedia.de
I can't see the content of this message but the title is quite straight ;-)
This question has been asked before in
http://dev.eclipse.org/newslists/news.eclipse.technology.emf t/msg00815.html
and although some technical details of CDO have changed since the main
problem seems still to be that GMF non-optionally uses EMFT Transaction
which seems to be incompatible with CDO's own transactions. I'm still
unfamiliar with GMF and with the details about EMFT Transaction as well,
hence I'm reliant on contributions from users like you to make GMF work
with CDO. May be there's even action to be taken on GMF's side, for
example decouple the GMF editor from EMF Transaction. I may be wrong but
since GMF would work on top of CDO and since a transaction model is IMHO
not the core business of a graphical editor I have the feeling that the
question should be "When can GMF support CDO?" Of course I offer my help
when it is of value. It would really be nice to see GMF editors working
on CDO models.
Eike Stepper
http://wiki.eclipse.org/CDO
http://wiki.eclipse.org/Net4j
Re: [CDO]When CDO can support GMF Editor? [message #105365 is a reply to message #105290] Thu, 27 December 2007 08:17 Go to previous messageGo to next message
Eike,
I suspect that the transaction API approach could be made to work as a
redundant layer on top of CDO resources, but I'm not an expert on how
that would be done. Perhaps it's as simple as using a CDO enabled
resource set within the GMF editor...
> straight ;-)
> Transaction which seems to be incompatible with CDO's own
> transactions. I'm still unfamiliar with GMF and with the details about
> EMFT Transaction as well, hence I'm reliant on contributions from
> users like you to make GMF work with CDO. May be there's even action
> to be taken on GMF's side, for example decouple the GMF editor from
> EMF Transaction. I may be wrong but since GMF would work on top of CDO
> and since a transaction model is IMHO not the core business of a
> graphical editor I have the feeling that the question should be "When
> can GMF support CDO?" Of course I offer my help when it is of value.
> It would really be nice to see GMF editors working on CDO models.
> Regards,
> Eike Stepper
Re: [CDO]When CDO can support GMF Editor? [message #105380 is a reply to message #105365] Thu, 27 December 2007 08:47 Go to previous messageGo to next message
Ed Merks schrieb:
> Eike,
I'd really like to work on such a prototype but I must admit that in the
past I never managed to properly install a working GMF and develop a
working GMF editor ;-( There have been so much version incompatibilities
that I simply didn't get it to work. May be it's time to give it another
try...
Eike Stepper
>> straight ;-)
>> main problem seems still to be that GMF non-optionally uses EMFT
>> about EMFT Transaction as well, hence I'm reliant on contributions
>> from users like you to make GMF work with CDO. May be there's even
>> action to be taken on GMF's side, for example decouple the GMF editor
>> from EMF Transaction. I may be wrong but since GMF would work on top
>> of CDO and since a transaction model is IMHO not the core business of
>> a graphical editor I have the feeling that the question should be
>> "When can GMF support CDO?" Of course I offer my help when it is of
>> value. It would really be nice to see GMF editors working on CDO models.
>> Regards,
>> Eike Stepper
Re: [CDO]When CDO can support GMF Editor? [message #105411 is a reply to message #105380] Thu, 27 December 2007 09:19 Go to previous messageGo to next message
--------------000308010808030705030100
Content-Type: multipart/alternative;
boundary="------------080002070101000005080905"
--------------080002070101000005080905
Eike,
I'm playing with the Ecore graphical editor from the Ecore Tools
component and it's really very cool! I typically install all of EMF and
anything else I need other than the platform from CVS:
http://wiki.eclipse.org/EMF/Setting_up_a_development_environ ment
I've attached the *.psf that has all of GMF as well. Eventually I'd
like it if every project had such psf files so that any developer could
easily set of a development image to create high quality patches. I
hear there's working going on in the platform to solve the "JDT can't
compile against an external folder" problem; this will really help with
the bootstrapping problem...
Eike Stepper wrote:
> Ed Merks schrieb:
>> Eike,
>> a redundant layer on top of CDO resources, but I'm not an expert on
>> how that would be done. Perhaps it's as simple as using a CDO
>> enabled resource set within the GMF editor...
> the past I never managed to properly install a working GMF and develop
> a working GMF editor ;-( There have been so much version
> incompatibilities that I simply didn't get it to work. May be it's
> time to give it another try...
> Regards,
> Eike Stepper
>>> straight ;-)
>>> editor from EMF Transaction. I may be wrong but since GMF would work
>>> on top of CDO and since a transaction model is IMHO not the core
>>> business of a graphical editor I have the feeling that the question
>>> should be "When can GMF support CDO?" Of course I offer my help when
>>> on CDO models.
>>> Regards,
>>> Eike Stepper
<html>
<head>
http-equiv="Content-Type">
</head>
Eike,<br>
<br>
anything else I need other than the platform from CVS:<br>
<blockquote><a
href=" http://wiki.eclipse.org/EMF/Setting_up_a_development_environ ment"> http://wiki.eclipse.org/EMF/Setting_up_a_development_environ ment</a><br>
</blockquote>
Re: [CDO]When CDO can support GMF Editor? [message #105453 is a reply to message #105411] Thu, 27 December 2007 10:15 Go to previous messageGo to next message
--------------030104060002030505020504
Ed,
I just tried it with newest versions of GMF and all the dependencies
(although they're broken on the GMF download page). I can't get the
examples running properly. Geoshape always positions small figures in
the upper left corner and the Logic example can't start the wizard at
all. May be I'm mad but I've never seen a project that is so difficult
to use. I'm so jealous of everybody getting it to work.
More comments inline...
Eike Stepper
Ed Merks schrieb:
> Eike,
> and anything else I need other than the platform from CVS:
> could easily set of a development image to create high quality patches.
I have one ;-)
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.emf/org .eclipse.emf.cdo/develop/psf/pserver/All.psf?root=Modeling_P roject&content-type=text%2Fplain&view=co
> I hear there's working going on in the platform to solve the "JDT
> can't compile against an external folder" problem; this will really
> help with the bootstrapping problem...
After 2 years and 29 votes - huuh!
> Eike Stepper wrote:
>> Ed Merks schrieb:
>>> Eike,
>> develop a working GMF editor ;-( There have been so much version
>> Regards,
>> Eike Stepper
>>>> straight ;-)
>>>> work on top of CDO and since a transaction model is IMHO not the
>>>> help when it is of value. It would really be nice to see GMF
>>>> Regards,
>>>> Eike Stepper
<html>
<head>
</head>
Ed,<br>
<br>
to use. I'm so jealous of everybody getting it to work.<br>
<br>
More comments inline...<br>
<br>
Regards,<br>
Eike Stepper<br>
----<br>
<a class="moz-txt-link-freetext" href="http://wiki.eclipse.org/CDO">http://wiki.eclipse.org/CDO</a><br>
<a class="moz-txt-link-freetext" href="http://wiki.eclipse.org/Net4j">http://wiki.eclipse.org/Net4j</a><br>
<br>
<br>
Ed Merks schrieb:
<blockquote cite="mid:fl0c9n$v80$1@build.eclipse.org" type="cite">
Eike,<br>
<br>
<blockquote><a moz-do-not-send="true"
</blockquote>
Re: [CDO]When CDO can support GMF Editor? [message #105468 is a reply to message #105453] Thu, 27 December 2007 11:21 Go to previous messageGo to next message
--------------030605030208000208060200
Eike Stepper schrieb:
> Ed,
Even the Ecore diagrams that you mention don't work properly: All
diagram elements stick in the upper left corner and are very small. I
can't move or resize them. I'm giving up again ;-)
Eike Stepper
<html>
<head>
</head>
<blockquote cite="mid:fl0fj0$t74$2@build.eclipse.org" type="cite">
Ed,<br>
<br>
the upper left corner </blockquote>
can't move or resize them. I'm giving up again ;-)<br>
<br>
Regards,<br>
Eike Stepper<br>
----<br>
<br>
<br>
</body>
</html>
--------------030605030208000208060200--
Re: [CDO]When CDO can support GMF Editor? [message #105479 is a reply to message #105468] Thu, 27 December 2007 11:33 Go to previous messageGo to next message
--------------090005030604020904000005
Eike,
Hmmm. It worked for me, other than that I can't figure out how to make
lines show up...
>> Ed,
> Regards,
> Eike Stepper
<html>
<head>
</head>
Eike,<br>
<br>
Hmmm.
Re: [CDO]When CDO can support GMF Editor? [message #121908 is a reply to message #105479] Tue, 06 May 2008 06:42 Go to previous messageGo to next message
Originally posted by: jan.herriger.gmx.de
may be a little late, but I just felt over this topic ;-)
Sounds like, you're using Eclipse 3.4Mx. It seems, that there are/where
issues with grid size settings. Maybe this problem is related to german
clients (I think '.' and ',' is messed up a little, so grid size results
in a thousand inches or stl...)? Turning off snap to grid should should
enable you to position shapes correctly.
Jan
Ed Merks schrieb:
> Eike,
> lines show up...
>>> Ed,
>> Regards,
>> Eike Stepper
Re: [CDO]When CDO can support GMF Editor? [message #121921 is a reply to message #121908] Tue, 06 May 2008 06:45 Go to previous messageGo to next message
Jan,
It's working really well these days!
Jan Herriger wrote:
> are/where issues with grid size settings. Maybe this problem is
> related to german clients (I think '.' and ',' is messed up a little,
> so grid size results in a thousand inches or stl...)? Turning off snap
> to grid should should enable you to position shapes correctly.
> Regards,
> Jan
> Ed Merks schrieb:
>> Eike,
>> make lines show up...
>>>> Ed,
>>>> dependencies (although they're broken on the GMF download page). I
>>>> can't get the examples running properly. Geoshape always positions
>>>> small figures in the upper left corner
>>> I can't move or resize them. I'm giving up again ;-)
>>> Regards,
>>> Eike Stepper
Re: [CDO]When CDO can support GMF Editor? [message #121934 is a reply to message #121921] Tue, 06 May 2008 07:30 Go to previous messageGo to next message
Hi Guys,
I'm a bit confused. Is this an old post or a new one? Is there a question
that I can answer?
Cheers
/Eike
Ed Merks wrote:
> Jan,
> Jan Herriger wrote:
>> Hi,
>> Regards,
>> Jan
>> Ed Merks schrieb:
>>> Eike,
>>>>> Ed,
>>>> Regards,
>>>> Eike Stepper
Re: [CDO]When CDO can support GMF Editor? [message #121961 is a reply to message #121934] Tue, 06 May 2008 07:49 Go to previous messageGo to next message
Hi Eike,
I'm sorry about the confusion. I just wanted to mention, that your
problem with setting up a GMF environment, wasn't really GMF related. I
shouldn't have posted in such an old thread...
You can safely ignore my comment and concentrate on your great work ;-)
> Hi Guys,
> question that I can answer?
> Cheers
> /Eike
> Ed Merks wrote:
>> Jan,
>> Jan Herriger wrote:
>>> Hi,
>>> snap to grid should should enable you to position shapes correctly.
>>> Regards,
>>> Jan
>>> Ed Merks schrieb:
>>>> Eike,
>>>>>> Ed,
>>>>> Regards,
>>>>> Eike Stepper
Re: [CDO]When CDO can support GMF Editor? [message #121998 is a reply to message #121961] Tue, 06 May 2008 12:36 Go to previous message
Jan Herriger wrote:
> Hi Eike,
Ok, no problem!
And thank you ;-)
Cheers
/Eike
>> Hi Guys,
>> Cheers
>> /Eike
>> Ed Merks wrote:
>>> Jan,
>>> Jan Herriger wrote:
>>>> Hi,
>>>> Regards,
>>>> Jan
>>>> Ed Merks schrieb:
>>>>> Eike,
>>>>>>> Ed,
>>>>>> Regards,
>>>>>> Eike Stepper
Re: [CDO]When CDO can support GMF Editor? [message #613015 is a reply to message #105183] Thu, 27 December 2007 06:24 Go to previous message
on CDO models.
Eike Stepper
Re: [CDO]When CDO can support GMF Editor? [message #613029 is a reply to message #105290] Thu, 27 December 2007 08:17 Go to previous message
Eike,
> straight ;-)
> Regards,
> Eike Stepper
Re: [CDO]When CDO can support GMF Editor? [message #613031 is a reply to message #105365] Thu, 27 December 2007 08:47 Go to previous message
Ed Merks schrieb:
> Eike,
try...
Eike Stepper
>> straight ;-)
>> Regards,
>> Eike Stepper
Re: [CDO]When CDO can support GMF Editor? [message #613034 is a reply to message #105380] Thu, 27 December 2007 09:19 Go to previous message
Eike,
Eike Stepper wrote:
> Ed Merks schrieb:
>> Eike,
> Regards,
> Eike Stepper
>>> straight ;-)
>>> on CDO models.
>>> Regards,
>>> Eike Stepper
<html>
<head>
</head>
Eike,<br>
<br>
<blockquote><a
</blockquote>
Re: [CDO]When CDO can support GMF Editor? [message #613038 is a reply to message #105411] Thu, 27 December 2007 10:15 Go to previous message
Ed,
Eike Stepper
Ed Merks schrieb:
> Eike,
I have one ;-)
> Eike Stepper wrote:
>> Ed Merks schrieb:
>>> Eike,
>> Regards,
>> Eike Stepper
>>>> straight ;-)
>>>> Regards,
>>>> Eike Stepper
<html>
<head>
</head>
Ed,<br>
<br>
<br>
<br>
Regards,<br>
Eike Stepper<br>
----<br>
<br>
<br>
Eike,<br>
<br>
</blockquote>
Re: [CDO]When CDO can support GMF Editor? [message #613041 is a reply to message #105453] Thu, 27 December 2007 11:21 Go to previous message
> Ed,
Eike Stepper
<html>
<head>
</head>
Ed,<br>
<br>
<br>
Regards,<br>
Eike Stepper<br>
----<br>
<br>
<br>
</body>
</html>
Re: [CDO]When CDO can support GMF Editor? [message #613042 is a reply to message #105468] Thu, 27 December 2007 11:33 Go to previous message
Eike,
lines show up...
>> Ed,
> Regards,
> Eike Stepper
<html>
<head>
</head>
Eike,<br>
<br>
Hmmm.
Re: [CDO]When CDO can support GMF Editor? [message #617996 is a reply to message #105479] Tue, 06 May 2008 06:42 Go to previous message
Jan
Ed Merks schrieb:
> Eike,
> lines show up...
>>> Ed,
>> Regards,
>> Eike Stepper
Re: [CDO]When CDO can support GMF Editor? [message #617997 is a reply to message #121908] Tue, 06 May 2008 06:45 Go to previous message
Jan,
Jan Herriger wrote:
> Regards,
> Jan
> Ed Merks schrieb:
>> Eike,
>>>> Ed,
>>> Regards,
>>> Eike Stepper
Re: [CDO]When CDO can support GMF Editor? [message #617998 is a reply to message #121921] Tue, 06 May 2008 07:30 Go to previous message
Hi Guys,
that I can answer?
Cheers
/Eike
Ed Merks wrote:
> Jan,
> Jan Herriger wrote:
>> Hi,
>> Regards,
>> Jan
>> Ed Merks schrieb:
>>> Eike,
>>>>> Ed,
>>>> Regards,
>>>> Eike Stepper
Re: [CDO]When CDO can support GMF Editor? [message #618000 is a reply to message #121934] Tue, 06 May 2008 07:49 Go to previous message
Hi Eike,
> Hi Guys,
> Cheers
> /Eike
> Ed Merks wrote:
>> Jan,
>> Jan Herriger wrote:
>>> Hi,
>>> Regards,
>>> Jan
>>> Ed Merks schrieb:
>>>> Eike,
>>>>>> Ed,
>>>>> Regards,
>>>>> Eike Stepper
Re: [CDO]When CDO can support GMF Editor? [message #618003 is a reply to message #121961] Tue, 06 May 2008 12:36 Go to previous message
Jan Herriger wrote:
> Hi Eike,
Ok, no problem!
And thank you ;-)
Cheers
/Eike
>> Hi Guys,
>> Cheers
>> /Eike
>> Ed Merks wrote:
>>> Jan,
>>> Jan Herriger wrote:
>>>> Hi,
>>>> Regards,
>>>> Jan
>>>> Ed Merks schrieb:
>>>>> Eike,
>>>>>>> Ed,
>>>>>> Regards,
>>>>>> Eike Stepper
Previous Topic:[CDO] Problem with single Ecore, multiple packages
Next Topic:[Teneo] hibernate3.jar dependencies
Current Time: Sun Jul 20 20:23:14 EDT 2025
Powered by FUDForum. Page generated in 0.10594 seconds
