Home » Archived » Eclipse Process Manager (Stardust) » Unable to deploy stardust in Jboss 5.1(Unable to deploy stardust in Jboss)
Unable to deploy stardust in Jboss 5.1 [message #1216376] Thu, 28 November 2013 07:54 Go to next message
Environment
1.JDK 1.6
2.jboss-5.1.0.GA
I have try to deploy stardust support case management example application in jboss
step 1: I have exported as Demo.war file from kepler eclipse
step 2: Placesed in deploy (jboss-5.1.0.GA\server\default\deploy) folder in jboss
step 3: start the server from bin\run.bat
I got first error.
2013-11-20 12:10:31,733 ERROR [org.jboss.web.tomcat.service.deployers.JBossContextConfig] (main) XML error parsing: WEB-INF/context.xml
org.jboss.xb.binding.JBossXBRuntimeException: Failed to create a new SAX parser
at org.jboss.xb.binding.UnmarshallerFactory$UnmarshallerFactoryImpl.newUnmarshaller(UnmarshallerFactory.java:100)
at org.jboss.web.tomcat.service.deployers.JBossContextConfig.processContextConfig(JBossContextConfig.java:549)
at org.jboss.web.tomcat.service.deployers.JBossContextConfig.init(JBossContextConfig.java:540)
at org.apache.catalina.startup.ContextConfig.lifecycleEvent(ContextConfig.java:279)
at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:117)
at org.apache.catalina.core.StandardContext.init(StandardContext.java:5436)
at org.apache.catalina.core.StandardContext.start(StandardContext.java:4148)
at org.jboss.web.tomcat.service.deployers.TomcatDeployment.performDeployInternal(TomcatDeployment.java:310)
at org.jboss.web.tomcat.service.deployers.TomcatDeployment.performDeploy(TomcatDeployment.java:142)
at org.jboss.web.deployers.AbstractWarDeployment.start(AbstractWarDeployment.java:461)
at org.jboss.web.deployers.WebModule.startModule(WebModule.java:118)
at org.jboss.web.deployers.WebModule.start(WebModule.java:97)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.jboss.mx.interceptor.ReflectedDispatcher.invoke(ReflectedDispatcher.java:157)
at org.jboss.mx.server.Invocation.dispatch(Invocation.java:96)
at org.jboss.mx.server.Invocation.invoke(Invocation.java:88)
at org.jboss.mx.server.AbstractMBeanInvoker.invoke(AbstractMBeanInvoker.java:264)
at org.jboss.mx.server.MBeanServerImpl.invoke(MBeanServerImpl.java:668)
at org.jboss.system.microcontainer.ServiceProxy.invoke(ServiceProxy.java:206)
at com.sun.proxy.$Proxy38.start(Unknown Source)
at org.jboss.system.microcontainer.StartStopLifecycleAction.installAction(StartStopLifecycleAction.java:42)
at org.jboss.system.microcontainer.StartStopLifecycleAction.installAction(StartStopLifecycleAction.java:37)
at org.jboss.dependency.plugins.action.SimpleControllerContextAction.simpleInstallAction(SimpleControllerContextAction.java:62)
at org.jboss.dependency.plugins.action.AccessControllerContextAction.install(AccessControllerContextAction.java:71)
at org.jboss.dependency.plugins.AbstractControllerContextActions.install(AbstractControllerContextActions.java:51)
at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348)
at org.jboss.system.microcontainer.ServiceControllerContext.install(ServiceControllerContext.java:286)
at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631)
at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934)
at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082)
at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984)
at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822)
at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553)
at org.jboss.system.ServiceController.doChange(ServiceController.java:688)
at org.jboss.system.ServiceController.start(ServiceController.java:460)
at org.jboss.system.deployers.ServiceDeployer.start(ServiceDeployer.java:163)
at org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:99)
at org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:46)
at org.jboss.deployers.spi.deployer.helpers.AbstractSimpleRealDeployer.internalDeploy(AbstractSimpleRealDeployer.java:62)
at org.jboss.deployers.spi.deployer.helpers.AbstractRealDeployer.deploy(AbstractRealDeployer.java:50)
at org.jboss.deployers.plugins.deployers.DeployerWrapper.deploy(DeployerWrapper.java:171)
at org.jboss.deployers.plugins.deployers.DeployersImpl.doDeploy(DeployersImpl.java:1439)
at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1157)
at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1178)
at org.jboss.deployers.plugins.deployers.DeployersImpl.install(DeployersImpl.java:1098)
at org.jboss.deployers.plugins.deployers.DeployersImpl.process(DeployersImpl.java:781)
at org.jboss.deployers.plugins.main.MainDeployerImpl.process(MainDeployerImpl.java:702)
at org.jboss.system.server.profileservice.repository.MainDeployerAdapter.process(MainDeployerAdapter.java:117)
at org.jboss.system.server.profileservice.repository.ProfileDeployAction.install(ProfileDeployAction.java:70)
at org.jboss.system.server.profileservice.repository.AbstractProfileAction.install(AbstractProfileAction.java:53)
at org.jboss.system.server.profileservice.repository.AbstractProfileService.install(AbstractProfileService.java:361)
at org.jboss.system.server.profileservice.repository.AbstractProfileService.activateProfile(AbstractProfileService.java:306)
at org.jboss.system.server.profileservice.ProfileServiceBootstrap.start(ProfileServiceBootstrap.java:271)
at org.jboss.bootstrap.AbstractServerImpl.start(AbstractServerImpl.java:461)
at org.jboss.Main.boot(Main.java:221)
at org.jboss.Main$1.run(Main.java:556)
at java.lang.Thread.run(Thread.java:662)
Caused by: org.jboss.xb.binding.JBossXBException: Failed to create a new SAX parser
at org.jboss.xb.binding.parser.sax.SaxJBossXBParser.<init>(SaxJBossXBParser.java:97)
at org.jboss.xb.binding.UnmarshallerImpl.<init>(UnmarshallerImpl.java:56)
at org.jboss.xb.binding.UnmarshallerFactory$UnmarshallerFactoryImpl.newUnmarshaller(UnmarshallerFactory.java:96)
... 73 more
Caused by: java.lang.ClassCastException: org.apache.xerces.parsers.XIncludeAwareParserConfiguration cannot be cast to org.apache.xerces.xni.parser.XMLParserConfiguration
at org.apache.xerces.parsers.SAXParser.<init>(Unknown Source)
at org.apache.xerces.jaxp.SAXParserImpl$JAXPSAXParser.<init>(Unknown Source)
at org.apache.xerces.jaxp.SAXParserImpl.<init>(Unknown Source)
at org.apache.xerces.jaxp.SAXParserFactoryImpl.newSAXParser(Unknown Source)
at org.jboss.xb.binding.parser.sax.SaxJBossXBParser.<init>(SaxJBossXBParser.java:92)
... 75 more
step 3: I have fixed above error by removing "org.apache.xerces_2.9.0.v201101211617.jar" (Since both jboss and stardust xerces jar is conflict )
step 4: Then i got next error (this is seems to annotation related jar issue)
java.lang.RuntimeException: mapped-name is required for org.apache.cxf.service.factory.FactoryBeanListenerManager/bus of deployment Demo.war
at org.jboss.web.tomcat.service.injection.WebResourceHandler.loadXmlResourceEnvRefs(WebResourceHandler.java:287)
at org.jboss.web.tomcat.service.injection.WebResourceHandler.loadXml(WebResourceHandler.java:325)
at org.jboss.web.tomcat.service.TomcatInjectionContainer.processMetadata(TomcatInjectionContainer.java:550)
at org.jboss.web.tomcat.service.WebCtxLoader.start(WebCtxLoader.java:158)
at org.apache.catalina.core.StandardContext.start(StandardContext.java:4272)
2013-11-20 12:27:39,829 ERROR [org.apache.catalina.core.StandardContext] (main) Context [/Demo] startup failed due to previous errors
Please provide proper step to deploy the stardust application in jboss.
Re: Unable to deploy stardust in Jboss 5.1 [message #1219137 is a reply to message #1216376] Mon, 02 December 2013 05:38 Go to previous message
Please set the geronimo annotation specification jar in the classpath,
https://community.jboss.org/thread/155075
Below is the Stardust setup help doc,
https://infinity.sungard.com/documentation/stardust/1.0/topic/org.eclipse.stardust.docs.deployment/html/applicationserversetup/jboss.html?resultof=%22%6a%62%6f%73%73%22%20
Tanmoy
Previous Topic:findUsers - Webservice API
Next Topic:How can I suspend or abort process using "Spring Bean Applicationa"
Current Time: Fri Jul 25 02:45:45 EDT 2025
Powered by FUDForum. Page generated in 0.04587 seconds
