Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Teneo Persists and Retrieves superclass not subclass.(Teneo Persists and Retrieves superclass not subclass.)
Teneo Persists and Retrieves superclass not subclass. [message #1219041] Fri, 29 November 2013 22:38 Go to next message
I have class A which has reference to another class B which has inheritance hierarchy i..e class B has sub class C. when I try to persist class A using TENEO framework which contains subclass C, the table stores class B name and not sub class C. when I load class A from database,which references to class B and not class C. Do I need to set any options to persist and load subclass.
Chandru
Re: Teneo Persists and Retrieves superclass not subclass. [message #1219051 is a reply to message #1219041] Sat, 30 November 2013 06:56 Go to previous messageGo to next message
Hi Chandre,
This should work fine, it is one of the basefeatures of an ORM/teneo. Is there a table for C, is C also being mapped?
Can you check the generated hbm?
Or it could be some multi-inheritance thing, so C inherits from B but C also inherits from something else which is
listed first in the esupertypes. or B has been set as a mappedsuperclass.
gr. Martin
> Thanks
> Chandru
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: Teneo Persists and Retrieves superclass not subclass. [message #1219064 is a reply to message #1219051] Sat, 30 November 2013 12:32 Go to previous messageGo to next message
Thanks Martin for the reply.
There is no table for C. But we have table for D which is a superclass of B. B is stored in D's table but C is not stored in any of the table including table for D. C inherits only from B. In addition to this C has its own interface. Similarly B has its own interface. So C extends BImpl implements CInterface. Iam not sure this could be an issue.
Re: Teneo Persists and Retrieves superclass not subclass. [message #1219069 is a reply to message #1219064] Sat, 30 November 2013 17:44 Go to previous messageGo to next message
Hi Chandre,
The only thing I can think of is that C is not mapped somehow, maybe it is abstract? Can you send me
(mtaal_at_elver.org) or post the corresponding generated hbm?
gr. Martin
The Netherlands
Re: Teneo Persists and Retrieves superclass not subclass. [message #1219275 is a reply to message #1219069] Tue, 03 December 2013 00:48 Go to previous messageGo to next message
Sorry, There was a cyclic dependency in bundle which contains c, because of which it wasn't built. So the C's package wasn't initialized.
But iam getting different problem now.
We have separate ecore bundles for A, B, C, D. C model is referring to model B(Super class) and D. B is referring to D.
When i pass the B,C,D's packages to Datastore and when it executes datastore.initialze,
iam getting following error.
java.lang.IllegalArgumentException: EClass org.eclipse.emf.ecore.impl.EClassImpl@bd98b2 (name: null) (instanceClassName: null) (abstract: false, interface: false) has a null name.This can occur if epackages which refer to eachother are placed in different ecore/xsd files and they are not read using one resource set. The reference from one epackage to another must be resolvable by EMF.
at org.eclipse.emf.teneo.mapping.strategy.impl.ClassicEntityNameStrategy.toEntityName(ClassicEntityNameStrategy.java:71)
But only C is referring to B and not vice versa. Please let me know what else could be the issue.
Chandru
Re: Teneo Persists and Retrieves superclass not subclass. [message #1219302 is a reply to message #1219275] Tue, 03 December 2013 03:53 Go to previous messageGo to next message
Hi Chandre,
It seems that some reference of some eclass is not resolvable by EMF. The best thing is to check the epackages you pass
on to the datastore, so check if are indeed all the ereferences of all the eclasses are resolved correctly when you
access/traverse them.
Something like this:
for (EPackage ePackage: ePackages) {
for (EClassifier eClassifier: ePackage.getEClassifiers()) {
if (!(eClassifier instanceof EClass) {
continue;
EClass eClass = (EClass)eClassifier;
for (EReference eReference : eClass.getEAllReferences()) {
System.err.println(eReference.getEReferenceType().getName()); <--- this should not give null
gr. Martin
> wasn't initialized.
> java.lang.IllegalArgumentException: EClass mailto:org.eclipse.emf.ecore.impl.EClassImpl@bd98b2 (name: null)
> Thanks
> Chandru
The Netherlands
Re: Teneo Persists and Retrieves superclass not subclass. [message #1219477 is a reply to message #1219302] Wed, 04 December 2013 00:52 Go to previous message
Thanks Martin. There was property in class C which we had deleted from other places but not from factory. I have regenerated the classes from ecore now and its working Smile
Cahndru
Previous Topic:Compile errors with EEF code from XSD generated EMF model
Next Topic:Annotate Ecore Model with Hibernate-Validator
Current Time: Mon Jul 21 07:38:19 EDT 2025
Powered by FUDForum. Page generated in 0.04134 seconds
