Home » Language IDEs » Java Development Tools (JDT) » parseCompilationUnit problem with passing in true
parseCompilationUnit problem with passing in true [message #121875] Tue, 25 November 2003 15:19 Go to next message
When I call AST.parseCompilationUnit( cu, true ), I get back AST that does
not have anyting inside of the method bodies.
When I call AST.parseCompilationUnit( cu, false ), I get back full AST,
but, obviously, can't resolve any bindings.
I get the same behaivior in 3.0 M4 and M5.
Am I missing something here or is this a bug?
Thank you,
Alex
Re: parseCompilationUnit problem with passing in true [message #122040 is a reply to message #121875] Tue, 25 November 2003 21:59 Go to previous messageGo to next message
Originally posted by: akiezun.cuthis.mit.edu.andthis
i think you're missing something because otherwise none of the refactorings
would work
they all do AST.parseCompilationUnit(cu, true)
a.
Re: parseCompilationUnit problem with passing in true [message #122079 is a reply to message #122040] Tue, 25 November 2003 22:45 Go to previous messageGo to next message
> would work
> a.
Thanks for the reply, Adam, could you point me to an example of this?
Alex
Re: parseCompilationUnit problem with passing in true [message #122090 is a reply to message #122079] Tue, 25 November 2003 23:05 Go to previous messageGo to next message
well, simply search for references to AST.parseCompilationUnit
in the org.eclipse.jdt.ui plugin
a.
Re: parseCompilationUnit problem with passing in true [message #122128 is a reply to message #122090] Wed, 26 November 2003 01:24 Go to previous messageGo to next message
> a.
Right, I did that. Here is one random example:
IPackageFragmentRoot fragmentRoot =
getDefaultProject().getPackageFragmentRoot(
getDefaultProject().getProject() );
IPackageFragment pkg = fragmentRoot.getPackageFragment( DEFAULT );
StringBuffer buf = new StringBuffer();
buf.append("public class E {\n");
buf.append(" public String foo( int x ) {\n");
buf.append(" return String.valueOf( x );\n");
buf.append(" }\n");
buf.append("}\n");
ICompilationUnit cu= pkg.createCompilationUnit("E.java",
buf.toString(), false, null);
CompilationUnit astRoot= AST.parseCompilationUnit(cu, true);
astRoot.accept( new ASTVisitor() {
public void preVisit( ASTNode node ) {
System.out.println( node.toString() );
Re: parseCompilationUnit problem with passing in true [message #122142 is a reply to message #122090] Wed, 26 November 2003 01:26 Go to previous messageGo to next message
> a.
IPackageFragment pkg = fragmentRoot.getPackageFragment( "default");
buf.append(" }\n");
buf.append("}\n");
ICompilationUnit cu= pkg.createCompilationUnit("E.java", buf.toString(),
false, null);
public void preVisit( ASTNode node ) System.out.println(
node.toString() );
Here is the output:
CompilationUnit[E]
TypeDeclaration[class E MethodDeclaration[method foo(int) returns String]]
E
String
String
foo
int x
int
x
As you can see no method body...
Re: parseCompilationUnit problem with passing in true [message #122178 is a reply to message #122142] Wed, 26 November 2003 04:03 Go to previous messageGo to next message
Originally posted by: markus_keller.ch.ibm.spam.protect.com
> false, null);
> public void preVisit( ASTNode node ){System.out.println(
> node.toString() );
The AST is there. ASTNode#toString() just doesn't flatten the whole AST.
Use e.g. ASTFlattener to flatten the AST.
Markus
Re: parseCompilationUnit problem with passing in true [message #122345 is a reply to message #122178] Wed, 26 November 2003 08:59 Go to previous messageGo to next message
Markus,
Where can I find ASTFlattener?
I am not sure if it will help, because this code:
if ( node instanceof MethodDeclaration ) {
MethodDeclaration md = (MethodDeclaration)node;
Block b = md.getBody();
List l = b.statements();
System.out.println( l.size() );
public boolean visit( Block b ) {
System.out.println( b.statements().size() );
return true;
Prints:
0
0
Alex
Markus Keller wrote:
> > false, null);
> > node.toString() );
> Markus
Re: parseCompilationUnit problem with passing in true [message #122367 is a reply to message #122345] Wed, 26 November 2003 09:21 Go to previous message
I think that I found the problem.
I get error message java.lang.Object can not be resolved,
this is happening because RT.jar is not added to the Classpath by
default.
Alex
Alex Iskold wrote:
> Markus,
> return true;
> Prints:
> 0
> 0
> Alex
> > > false, null);
> > > node.toString() );
> > Markus
Previous Topic:relative paths in classpath
Next Topic:Running Ant and Can't find JDTCompilerAdapter
Current Time: Fri Nov 07 21:28:36 EST 2025
Powered by FUDForum. Page generated in 0.03979 seconds
