Spinner default [message #121273] |
Sat, 01 April 2006 11:23  |
Originally posted by: milnfalcon4163.yahoo.com
I using Eclipse 3.2M5a with VE 1.2M2. I want to set the swing number
spinner default to 300 when it displays initially. I know how to hardcode
it. However, I want to set the default in the number spinner's VE
properties. How do I do it in VE?
Re: Spinner default [message #612528 is a reply to message #121273] |
Fri, 07 April 2006 10:45  |
How do you do it through code?
> hardcode it. However, I want to set the default in the number spinner's
> VE properties. How do I do it in VE?
Rich Kulp
Re: Spinner default [message #612529 is a reply to message #121649] |
Fri, 07 April 2006 11:11  |
private JSpinner getJSpinner() {
if (jSpinner == null) {
jSpinner = new JSpinner();
jSpinner.setBounds(new Rectangle(40, 17, 54, 20));
jSpinner.setValue(300); <--- My code
return jSpinner;
Re: Spinner default [message #612531 is a reply to message #121660] |
Fri, 07 April 2006 12:23  |
The problem is that setValue takes a java.lang.Object and so it can take
anything. This is because JSpinner uses a model, and a model takes
java.lang.Objects. The problem is that the default model for a JSpinner
takes Integers (not int's, so you must be using 1.5 code with AutoBoxing
if setValue(300) works. We don't support 1.5 new syntax features like
autoboxing). But since it takes an Object we don't know what is valid so
we can't put up a property editor to handle this.
> return jSpinner;
Rich Kulp
Re: Spinner default [message #612535 is a reply to message #121684] |
Fri, 07 April 2006 12:37  |
sorry, Rich. i guess we were responding at the same time. Why can't you
let the programmer set property values in the bean properties and let
eclipse assemble or compile a constructor for that property?
Re: Spinner default [message #612538 is a reply to message #121697] |
Fri, 07 April 2006 13:45  |
Because we don't have a code editor there. The property editors are for
it where it knows the type. If it needs to be some piece of code then
the java editor pane should be used instead.
Rich Kulp
Re: Spinner default [message #612545 is a reply to message #121749] |
Fri, 07 April 2006 14:28  |
And even if the VE supported autoboxing syntax, there's still no way to
divine that it's looking for an int value to be passed into the Object
parameter to the setValue() method.
- Keff
Re: Spinner default [message #612569 is a reply to message #121273] |
Mon, 10 April 2006 02:34  |
Originally posted by: johannes.testori.shark-soft.com
hi,
i had the same problem. so i subclassed SpinnerNumberModel to create my
own model and added getters and setters with type "int" that delegate to
the original getters/setters (min, max, value).
kind regards,
hannes
Re: Spinner default [message #612574 is a reply to message #121922] |
Mon, 10 April 2006 08:28  |
Thanks. In this case, some kind of code editor and/or something automatic
that compiles java code like the constructors or the getters/setters would
nice to have. I hate to say this but it is the truth. I have seen
something in another open source IDE. However, since this is not a show
stopper, just a SMALL inconvenience SO FAR and the eclipse
support/maintenance is light years better than the other open source java
IDE SO FAR, I will wait for eclipse to catch up with their competitors.
FUDForum. Page generated in 0.07798 seconds
