Home » Modeling » QVT-OML » goal for new objects in a transformation
icon5.gif  goal for new objects in a transformation [message #1214821] Wed, 27 November 2013 16:41 Go to next message
I want to create Objects in the modelpackage itself.
The Objects are created directly in the xmi-Model at first level, and not as childs in a package.
The following QVTo transforms a Component Diagramm in a special Class Diagramm, with an Administration class and a Monitoring-Class for each component and each port
and shows the Problem:
modeltype UML uses "http://www.eclipse.org/uml2/4.0.0/UML";
transformation kompo2administration(in Compo: UML, out decomp: UML);
property curadminclass : UML::Class = null;
property curmonitorclass : UML::Class = null;
property model : UML::Model = null;
main()
    model = object Model { name='model' };
    Compo.objectsOfType(Component) -> map toAdminDecomp();
mapping Component::toAdminDecomp() : a: Class, m:Class
   object a: Class
	  name := "Administation_"+self.name;
   object m: Class
   	   name := "Monitoring_"+self.name;
   curadminclass := a;
   curmonitorclass := m;
   model.ownedType += a; // Try: add to the model, but in the result,
                         // the model remain empty
   model.ownedType += m; // this too
   self.ownedPort-> map toAdmin();
mapping Port::toAdmin() : a: Class, m:Class
   object a: Class
	  name := "Administation_".concat(self.name);
   object m: Class
   var pa = object Property
      name := self.name;
      aggregation := uml::AggregationKind::composite;
      type := a;
      lower := 1;
      upper := 1;
   curadminclass.ownedAttribute += pa;
   var pm = object Property
      name := self.name;
      type := a;
      lower := 1;
      upper := 1;
   curmonitorclass.ownedAttribute += pm;
The result is:
<xmi:XMI xmi:version="20110701" xmlns:xmi="http://www.omg.org/spec/XMI/20110701" xmlns:uml="http://www.eclipse.org/uml2/4.0.0/UML">
  <uml:Model xmi:id="_4LFAoFelEeOXFqUo7lQK7Q"/>
  <uml:Class xmi:id="_4LFAoVelEeOXFqUo7lQK7Q" name="Administation_ISP">
    <ownedAttribute xmi:id="_4LFAolelEeOXFqUo7lQK7Q" name="Gateway" type="_4LFAr1elEeOXFqUo7lQK7Q" aggregation="composite">
      <lowerValue xmi:type="uml:LiteralInteger" xmi:id="_4LFAo1elEeOXFqUo7lQK7Q" value="1"/>
      <upperValue xmi:type="uml:LiteralUnlimitedNatural" xmi:id="_4LFApFelEeOXFqUo7lQK7Q" value="1"/>
    </ownedAttribute>
    <ownedAttribute xmi:id="_4LFApVelEeOXFqUo7lQK7Q" name="AccessRouter" type="_4LFAsVelEeOXFqUo7lQK7Q" aggregation="composite">
      <lowerValue xmi:type="uml:LiteralInteger" xmi:id="_4LFAplelEeOXFqUo7lQK7Q" value="1"/>
      <upperValue xmi:type="uml:LiteralUnlimitedNatural" xmi:id="_4LFAp1elEeOXFqUo7lQK7Q" value="1"/>
    </ownedAttribute>
  </uml:Class>
you see, the generated Objekts are in the first level.
and not as I expect, the Objekts should be ownedTypes in the Model:
  <uml:Model xmi:id="_4LFAoFelEeOXFqUo7lQK7Q">
  <uml:packagedElement xmi:type="uml:Class" xmi:id="_4LFAoVelEeOXFqUo7lQK7Q" name="Administation_ISP">
    </ownedAttribute>
    </ownedAttribute>
  </uml:PackagedElement>
  <uml:Packagedlement xmi:typ="uml:Class" xmi:id="_4LFAqFelEeOXFqUo7lQK7Q" name="Monitoring_ISP">
    <ownedAttribute xmi:id="_4LFAqVelEeOXFqUo7lQK7Q" name="Gateway" type="_4LFAr1elEeOXFqUo7lQK7Q" aggregation="composite">
   </uml:Model>
Thank you very much
Rudolf Weber, Germany
Re: goal for new objects in a transformation [message #1215935 is a reply to message #1214821] Thu, 28 November 2013 03:52 Go to previous messageGo to next message
try this:
model.packagedElement += a;
icon5.gif  Re: goal for new objects in a transformation [message #1219434 is a reply to message #1215935] Tue, 03 December 2013 15:36 Go to previous messageGo to next message
I changed it, but the effect is the same.
I added simple objects
main()
    model.packagedElement += object Class { name :='Packman'; };
    model.ownedType += object Class { name :='Type'; };
This has nothing to do with my mapping - but the effect is the same:
'model', 'Packman',and 'Type' are in the same level, and not packaged in model.
What is the problem ?
Thank you very much
Rudolf
Re: goal for new objects in a transformation [message #1220027 is a reply to message #1219434] Mon, 09 December 2013 03:56 Go to previous messageGo to next message
Your problem is that "=" is not an assignment operator. That's why in your code, the model variable remains unassigned. Consequently, it is not possible to populate your model. Instead, all created objects will be top-level.
Just try
model := object Model { name='model' };
i.e. replace '=' by ':='.
As of QVTo 3.4.0, there will be a warning message printed in this situation.
Re: goal for new objects in a transformation [message #1222215 is a reply to message #1220027] Thu, 19 December 2013 17:59 Go to previous messageGo to next message
Thank you for the answers, the answer of Christopher Gerking helped:
main()
    // excercise polulating the model
    // The transformation
   object a: Class
   object m: Class
   curadminclass := a;
   object a: Class
   object m: Class
      name := self.name;
      type := a;
      lower := 1;
      upper := 1;
      name := self.name;
      type := a;
      lower := 1;
      upper := 1;
The solution was
* using := as assignment populates the model
* The created objects are added explicitly to the model.
But I still don't understand:
* is the model the output-Model which is referred in the output parameter decomp ?
* why I need the allocaton of a model ? (first line in main() in the above code)
* (Ok, I have a manual model, and I have to explicitly add the objects)
Greetings
Rudolf
Re: goal for new objects in a transformation [message #1223208 is a reply to message #1222215] Sun, 22 December 2013 14:32 Go to previous messageGo to next message
Rudolf Weber wrote on Thu, 19 December 2013 17:59
No. I'm not familiar with the UML meta model, but it seems as if every model requires an explicit instance of class Model, maybe as a root container.
Because Model is just a class in your meta model, and you need an instance of this class to accommodate other model objects. As stated above, this seems to be a particularity with the UML meta model.
Re: goal for new objects in a transformation [message #1226613 is a reply to message #1223208] Thu, 02 January 2014 02:44 Go to previous message
Model is a derivation of Package and it is conventional for the root of
UML models to be a Model rather than a Package. This provides a single
root for potentially diverse contents.
However you could have a "http://www.eclipse.org/uml2/4.0.0/UML" model
whoose root was a Comment.
As you discovered from the accidental comparison rather than assignment,
everything that lacks a parent is placed at the root.
Beware that QVTo provides a built-in Model class too. This doesn't seem
to have caused you a problem; yet.
Ed Willink
>> parameter decomp ?
> container.
>> above code)
Previous Topic:Execute native OCL query in qvt-o code
Next Topic:Plz help me [ QVT Relational]
Current Time: Wed Jul 23 06:45:36 EDT 2025
Powered by FUDForum. Page generated in 0.04944 seconds
