Home » Archived » Test and Performance Tools Platform (TPTP) » TPTP newbie gets NoClassDefFoundError -- huh?
TPTP newbie gets NoClassDefFoundError -- huh? [message #121488] |
Mon, 28 January 2008 15:34  |
Eclipse 3.3.0 (Build id: I20070621-1340)
Just installed TPTP using the update manager; the "code analysis" ran
correctly (cool)
Then I tried to profile our RCP -- which launched but TPTP threw the
exception (Error!) below; setting a breakpoint of course doesn't help,
since the profiler ignores breakpoints, whereas the debugger knows
nothing about TPTP and doesn't throw.
Any ideas?
thanks,
Paul
java.lang.NoClassDefFoundError: org.eclipse.tptp.martini.CGProxy
at antlr.BaseAST.<clinit>(BaseAST.java)
at java.lang.J9VMInternals.initializeImpl(Native Method)
at java.lang.J9VMInternals.initialize(J9VMInternals.java:192)
at java.lang.J9VMInternals.initialize(J9VMInternals.java:157)
at com.ibm.talent.fsCompiler.CfgCompiler.<init>(CfgCompiler.java:233)
at
com.ibm.udat.cats.jfstcascade.FstCascadeModel.compileGrammar (FstCascadeModel.java:178)
at
com.ibm.udat.cats.jfstcascade.FstCascadeModel.loadCfgFile(Fs tCascadeModel.java:136)
... 43 more
Re: TPTP newbie gets NoClassDefFoundError -- huh? [message #121536 is a reply to message #121503] |
Tue, 29 January 2008 14:42   |
Alexander N. Alexeev wrote:
> Hi Paul,
> org.eclipse.tptp.martini.CGProxy is special class which is used via
> instrumentation.
> Do you run profiling of your application via "Open Profile Dialog... "
yes.
> Could you send your OS vendor and version, environment variables and
> classpath used for RCP execution.
> You can use this snippet of code or by other ways.
> Map<String,String> env = System.getenv();
> Iterator it = env.entrySet().iterator();
> while (it.hasNext()) {
> Map.Entry pairs = (Map.Entry)it.next();
> System.out.println(pairs.getKey() + " = " + pairs.getValue());
> System.out.println("java.class.path = " +
> System.getProperty("java.class.path"));
OK, when I run 'normally' (the 'Run' dialog) I get these:
APPDATA = C:\Documents and Settings\Administrator\Application Data
ComSpec = C:\WINDOWS\system32\cmd.exe
PCOMM_Root = C:\Program Files\IBM\Personal Communications\
USERNAME = Keyser
NUMBER_OF_PROCESSORS = 2
windir = C:\WINDOWS
SystemRoot = C:\WINDOWS
COMPUTERNAME = AGATHODAIMWN
PROCESSOR_LEVEL = 6
HOMEPATH = \Documents and Settings\Administrator
tvdebugflags = 0x260
OS = Windows_NT
FP_NO_HOST_CHECK = NO
LOGONSERVER = \\AGATHODAIMWN
CommonProgramFiles = C:\Program Files\Common Files
PROCESSOR_ARCHITECTURE = x86
TMP = C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp
SESSIONNAME = Console
PROCESSOR_IDENTIFIER = x86 Family 6 Model 14 Stepping 8, GenuineIntel
IBM_JAVA_COMMAND_LINE = C:\0-UIMA\BlueJay\eclipse\jre\bin\javaw.exe
-Dosgi.compatibility.bootdelegation=false -DIBM_JAVA_HEAPDUMP_TEXT=true
-Xms256M -Xmx1024M -classpath
C:\0-UIMA\BlueJay\eclipse\plugins\org.eclipse.equinox.launch er_1.0.0.v20070606.jar
-agentlib:jdwp=transport=dt_socket,suspend=y,address=localho st:2497
org.eclipse.equinox.launcher.Main -launcher
C:\0-UIMA\BlueJay\eclipse\eclipse -name Eclipse -showsplash 600 -product
com.ibm.udat.core.workbench.udat_workbench_product -data
C:\0-UIMA\BlueJay\eclipse\workspace/../runtime-udat.product
-configuration
file:C:/0-UIMA/BlueJay/eclipse/workspace/.metadata/.plugins/ org.eclipse.pde.core/udat.product/
-dev
file:C:/0-UIMA/BlueJay/eclipse/workspace/.metadata/.plugins/ org.eclipse.pde.core/udat.product/dev.properties
-os win32 -ws win32 -arch x86 -nl en_US
ALLUSERSPROFILE = C:\Documents and Settings\All Users
PD_SOCKET = 6874
USERDOMAIN = AGATHODAIMWN
PROCESSOR_REVISION = 0e08
HOMEDRIVE = C:
tvlogsessioncount = 5000
Path =
C:\0-UIMA\BlueJay\eclipse\jre\bin\j9vm;C:\0-UIMA\BlueJay\ecl ipse\jre\bin;C:\Program
Files\ThinkPad\Utilities;C:\WINDOWS\system32;C:\WINDOWS;C:\W INDOWS\System32\Wbem;C:\Program
Files\IBM\Infoprint Select;C:\Notes;C:\Program
Files\XLView;C:\lotus\compnent;C:\Utilities;C:\Program
Files\IBM\Personal Communications\;C:\Program Files\IBM\Trace
Facility\;C:\Utilities\WinSCP3\;C:\Utilities\PuTTY;C:\Progra m
Files\ThinkPad\ConnectUtilities;C:\WINDOWS\Downloaded Program
Files;C:\Program Files\ATI Technologies\ATI.ACE\
PDBASE = C:\Program Files\IBM\Infoprint Select
TEMP = C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp
SystemDrive = C:
PATHEXT = .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH
USERPROFILE = C:\Documents and Settings\Administrator
java.class.path =
When I attempt to run the profiler, after the exception I reported, I
get these:
windir = C:\WINDOWS
CLASSPATH_ORG_OPENGROUP_ARM =
C:\0-UIMA\BlueJay\eclipse\plugins\org.opengroup.arm_4.0.1.v2 00709261752\arm40_java_interfaces.jar
JBOSS_HOME = null
OS = Windows_NT
CLASSPATH =
C:\0-UIMA\BlueJay\eclipse\plugins\org.eclipse.equinox.launch er_1.0.0.v20070606.jar;C:\0-UIMA\BlueJay\eclipse\plugins\org .eclipse.tptp.platform.jvmti.runtime_4.4.1.v200709261752\age nt_files\win_ia32;C:\0-UIMA\BlueJay\eclipse\plugins\org.ecli pse.tptp.platform.collection.framework_4.2.101.v200709261752 \hcframe.jar;C:\0-UIMA\BlueJay\eclipse\plugins\org.eclipse.h yades.execution_4.4.1.v200709261752\hexr.jar;C:\0-UIMA\BlueJ ay\eclipse\plugins\org.eclipse.hyades.execution_4.4.1.v20070 9261752\hexl.jar;C:\0-UIMA\BlueJay\eclipse\plugins\org.eclip se.hyades.execution_4.4.1.v200709261752\hexcore.jar;;C:\0-UI MA\BlueJay\eclipse\plugins\org.eclipse.core.runtime_3.3.100. v20070530.jar;C:\0-UIMA\BlueJay\eclipse\plugins\org.eclipse. equinox.common_3.3.0.v20070426.jar;C:\0-UIMA\BlueJay\eclipse \plugins\org.eclipse.osgi_3.3.0.v20070530.jar;C:\0-UIMA\Blue Jay\eclipse\plugins\org.eclipse.core.runtime_3.3.100.v200705 30.jar;C:\0-UIMA\BlueJay\eclipse\plugins\org.eclipse.equinox .common_3.3.0.v20070426.jar;C
:\0-UIMA\BlueJay\eclipse\plugins\org.eclipse.osgi_3.3.0.v200 70530.jar;C:\0-UIMA\BlueJay\eclipse\plugins\com.ibm.icu_3.6. 1.v20070417.jar;;C:\0-UIMA\BlueJay\eclipse\plugins\org.eclip se.equinox.common_3.3.0.v20070426.jar;C:\0-UIMA\BlueJay\ecli pse\plugins\org.eclipse.equinox.common_3.3.0.v20070426.jar;C :\0-UIMA\BlueJay\eclipse\plugins\org.eclipse.tptp.trace.arm_ 4.3.1.v200709261752\cbeLogging.jar;C:\0-UIMA\BlueJay\eclipse \plugins\org.eclipse.tptp.trace.arm_4.3.1.v200709261752\armL ibrary.jar;C:\0-UIMA\BlueJay\eclipse\plugins\org.eclipse.tpt p.trace.arm_4.3.1.v200709261752\armModel.jar;C:\0-UIMA\BlueJ ay\eclipse\plugins\org.opengroup.arm_4.0.1.v200709261752\arm 40_java_interfaces.jar;C:\0-UIMA\BlueJay\eclipse\plugins\org .eclipse.hyades.logging.core_4.3.101.v200709261752\hl14.jar; C:\0-UIMA\BlueJay\eclipse\plugins\org.eclipse.hyades.logging .core_4.3.101.v200709261752\hlcommons.jar;C:\0-UIMA\BlueJay\ eclipse\plugins\org.eclipse.hyades.logging.core_4.3.101.v200 709261752\hlcore.jar;C:\0-UIMA
\BlueJay\eclipse\plugins\org.eclipse.hyades.logging.core_4.3 .101.v200709261752\hllog4j.jar;C:\0-UIMA\BlueJay\eclipse\plu gins\org.eclipse.hyades.logging.core_4.3.101.v200709261752\c onfig.jar;C:\0-UIMA\BlueJay\eclipse\plugins\org.eclipse.hyad es.logging.core_4.3.101.v200709261752\hl14.jar;C:\0-UIMA\Blu eJay\eclipse\plugins\org.eclipse.hyades.logging.core_4.3.101 .v200709261752\hlcommons.jar;C:\0-UIMA\BlueJay\eclipse\plugi ns\org.eclipse.hyades.logging.core_4.3.101.v200709261752\hlc ore.jar;C:\0-UIMA\BlueJay\eclipse\plugins\org.eclipse.hyades .logging.core_4.3.101.v200709261752\hllog4j.jar;;C:\0-UIMA\B lueJay\eclipse\plugins\org.eclipse.emf.ecore_2.3.0.v20070626 2000.jar;C:\0-UIMA\BlueJay\eclipse\plugins\org.eclipse.emf.e core_2.3.0.v200706262000.jar;;C:\0-UIMA\BlueJay\eclipse\plug ins\org.eclipse.emf.common_2.3.0.v200706262000.jar;C:\0-UIMA \BlueJay\eclipse\plugins\org.eclipse.emf.common_2.3.0.v20070 6262000.jar;C:\0-UIMA\BlueJay\eclipse\plugins\org.eclipse.tp tp.platform.logging.events_4.3
101.v200709261752\tlcore.jar;C:\0-UIMA\BlueJay\eclipse\plugi ns\org.eclipse.tptp.platform.logging.events_4.3.101.v2007092 61752\hlcbe101.jar;C:\0-UIMA\BlueJay\eclipse\plugins\org.ecl ipse.tptp.platform.logging.events_4.3.101.v200709261752\tlcb e101.jar;C:\0-UIMA\BlueJay\eclipse\plugins\org.eclipse.tptp. platform.logging.events_4.3.101.v200709261752\config.jar;C:\ 0-UIMA\BlueJay\eclipse\plugins\org.eclipse.tptp.platform.log ging.events_4.3.101.v200709261752\hlcbe101.jar;C:\0-UIMA\Blu eJay\eclipse\plugins\org.eclipse.tptp.platform.logging.event s_4.3.101.v200709261752\tlcbe101.jar;C:\0-UIMA\BlueJay\eclip se\plugins\org.eclipse.tptp.platform.logging.events_4.3.101. v200709261752\tlcore.jar
CLASSPATH_COM_IBM_ICU =
;C:\0-UIMA\BlueJay\eclipse\plugins\com.ibm.icu_3.6.1.v200704 17.jar;C:\0-UIMA\BlueJay\eclipse\plugins\com.ibm.icu_3.6.1.v 20070417.jar
CLASSPATH_ORG_ECLIPSE_CORE_RUNTIME =
;C:\0-UIMA\BlueJay\eclipse\plugins\org.eclipse.core.runtime_ 3.3.100.v20070530.jar;C:\0-UIMA\BlueJay\eclipse\plugins\org. eclipse.core.runtime_3.3.100.v20070530.jar
CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION =
C:\0-UIMA\BlueJay\eclipse\plugins\org.eclipse.hyades.executi on_4.4.1.v200709261752\hexcore.jar;C:\0-UIMA\BlueJay\eclipse \plugins\org.eclipse.hyades.execution_4.4.1.v200709261752\he xl.jar;C:\0-UIMA\BlueJay\eclipse\plugins\org.eclipse.hyades. execution_4.4.1.v200709261752\hexr.jar
RASERVER_HOME =
C:\0-UIMA\BlueJay\eclipse\plugins\org.eclipse.tptp.platform. ac.win_ia32_4.4.1.v200709261752\agent_controller
CLASSPATH_ORG_ECLIPSE_EQUINOX_COMMON =
;C:\0-UIMA\BlueJay\eclipse\plugins\org.eclipse.equinox.commo n_3.3.0.v20070426.jar;C:\0-UIMA\BlueJay\eclipse\plugins\org. eclipse.equinox.common_3.3.0.v20070426.jar
PD_SOCKET = 6874
CLASSPATH_ORG_ECLIPSE_EMF_COMMON =
;C:\0-UIMA\BlueJay\eclipse\plugins\org.eclipse.emf.common_2. 3.0.v200706262000.jar;C:\0-UIMA\BlueJay\eclipse\plugins\org. eclipse.emf.common_2.3.0.v200706262000.jar
HOMEDRIVE = C:
CLASSPATH_ORG_ECLIPSE_CORE_COMMANDS =
;C:\0-UIMA\BlueJay\eclipse\plugins\org.eclipse.core.commands _3.3.0.I20070605-0010.jar;C:\0-UIMA\BlueJay\eclipse\plugins\ org.eclipse.core.commands_3.3.0.I20070605-0010.jar
TPTP_AC_HOME =
CLASSPATH_ORG_ECLIPSE_EMF_ECORE_XMI =
;C:\0-UIMA\BlueJay\eclipse\plugins\org.eclipse.emf.ecore.xmi _2.3.0.v200706262000.jar;C:\0-UIMA\BlueJay\eclipse\plugins\o rg.eclipse.emf.ecore.xmi_2.3.0.v200706262000.jar
LOCAL_AGENT_TEMP_DIR = C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp
ARM_LOG_PROPERTIES_FILE =
C:\0-UIMA\BlueJay\eclipse\plugins\org.eclipse.tptp.trace.arm _4.3.1.v200709261752\config\ARMLogger.properties
SYS_TEMP_DIR = C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp
USERNAME = Keyser
JAVA_PROFILER_HOME =
C:\0-UIMA\BlueJay\eclipse\plugins\org.eclipse.tptp.platform. jvmti.runtime_4.4.1.v200709261752\agent_files\win_ia32
CLASSPATH_ORG_ECLIPSE_TPTP_PLATFORM_MODELS =
;C:\0-UIMA\BlueJay\eclipse\plugins\org.eclipse.tptp.platform .models_4.3.1.v200709191245\fastxpath.jar;C:\0-UIMA\BlueJay\ eclipse\plugins\org.eclipse.tptp.platform.models_4.3.1.v2007 09191245\tptp-models.jar;C:\0-UIMA\BlueJay\eclipse\plugins\o rg.eclipse.tptp.platform.models_4.3.1.v200709191245\fastxpat h.jar;C:\0-UIMA\BlueJay\eclipse\plugins\org.eclipse.tptp.pla tform.models_4.3.1.v200709191245\tptp-models.jar
CLASSPATH_ORG_JUNIT =
;C:\0-UIMA\BlueJay\eclipse\plugins\org.junit_3.8.2.v20070611 1738\junit.jar;C:\0-UIMA\BlueJay\eclipse\plugins\org.junit_3 .8.2.v200706111738\junit.jar
CLASSPATH_ORG_APACHE_JAKARTA_COMMONS_LOGGING =
;C:\0-UIMA\BlueJay\eclipse\plugins\org.apache.commons.loggin g_1.0.4.v200706111724.jar;C:\0-UIMA\BlueJay\eclipse\plugins\ org.apache.commons.logging_1.0.4.v200706111724.jar
CLASSPATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK =
C:\0-UIMA\BlueJay\eclipse\plugins\org.eclipse.tptp.platform. collection.framework_4.2.101.v200709261752\hcframe.jar;C:\0- UIMA\BlueJay\eclipse\plugins\org.eclipse.tptp.platform.colle ction.framework_4.2.101.v200709261752\config.jar;C:\0-UIMA\B lueJay\eclipse\plugins\org.eclipse.tptp.platform.collection. framework_4.2.101.v200709261752\hcframe.jar
PROCESSOR_LEVEL = 6
CLASSPATH_ORG_ECLIPSE_EMF_ECORE =
;C:\0-UIMA\BlueJay\eclipse\plugins\org.eclipse.emf.ecore_2.3 .0.v200706262000.jar;C:\0-UIMA\BlueJay\eclipse\plugins\org.e clipse.emf.ecore_2.3.0.v200706262000.jar
AGENT_TIMEOUT = 5000
CLASSPATH_ORG_ECLIPSE_SWT =
;C:\0-UIMA\BlueJay\eclipse\plugins\org.eclipse.swt.win32.win 32.x86_3.3.0.v3346.jar;C:\0-UIMA\BlueJay\eclipse\plugins\org .eclipse.swt_3.3.0.v3346.jar;C:\0-UIMA\BlueJay\eclipse\plugi ns\org.eclipse.swt.win32.win32.x86_3.3.0.v3346.jar;C:\0-UIMA \BlueJay\eclipse\plugins\org.eclipse.swt_3.3.0.v3346.jar
PLUGINS_HOME = C:\0-UIMA\BlueJay\eclipse\plugins
JAVA_PATH = C:\0-UIMA\BlueJay\eclipse\jre\bin\java.exe
IBM_JAVA_COMMAND_LINE = C:\0-UIMA\BlueJay\eclipse\jre\bin\java.exe
-Xms256M -Xmx1024M
-agentlib:JPIBootLoader=JPIAgent:server=controlled;CGProf:ex ecdetails=true
org.eclipse.core.launcher.Main -launcher
-configuration
-dev
CLASSPATH_ORG_ECLIPSE_HYADES_LOGGING_CORE =
C:\0-UIMA\BlueJay\eclipse\plugins\org.eclipse.hyades.logging .core_4.3.101.v200709261752\hl14.jar;C:\0-UIMA\BlueJay\eclip se\plugins\org.eclipse.hyades.logging.core_4.3.101.v20070926 1752\hlcommons.jar;C:\0-UIMA\BlueJay\eclipse\plugins\org.ecl ipse.hyades.logging.core_4.3.101.v200709261752\hlcore.jar;C: \0-UIMA\BlueJay\eclipse\plugins\org.eclipse.hyades.logging.c ore_4.3.101.v200709261752\hllog4j.jar;C:\0-UIMA\BlueJay\ecli pse\plugins\org.eclipse.hyades.logging.core_4.3.101.v2007092 61752\config.jar;C:\0-UIMA\BlueJay\eclipse\plugins\org.eclip se.hyades.logging.core_4.3.101.v200709261752\hl14.jar;C:\0-U IMA\BlueJay\eclipse\plugins\org.eclipse.hyades.logging.core_ 4.3.101.v200709261752\hlcommons.jar;C:\0-UIMA\BlueJay\eclips e\plugins\org.eclipse.hyades.logging.core_4.3.101.v200709261 752\hlcore.jar;C:\0-UIMA\BlueJay\eclipse\plugins\org.eclipse .hyades.logging.core_4.3.101.v200709261752\hllog4j.jar
CLASSPATH_ORG_ECLIPSE_TPTP_PLATFORM_LOGGING_EVENTS =
C:\0-UIMA\BlueJay\eclipse\plugins\org.eclipse.tptp.platform. logging.events_4.3.101.v200709261752\tlcore.jar;C:\0-UIMA\Bl ueJay\eclipse\plugins\org.eclipse.tptp.platform.logging.even ts_4.3.101.v200709261752\hlcbe101.jar;C:\0-UIMA\BlueJay\ecli pse\plugins\org.eclipse.tptp.platform.logging.events_4.3.101 .v200709261752\tlcbe101.jar;C:\0-UIMA\BlueJay\eclipse\plugin s\org.eclipse.tptp.platform.logging.events_4.3.101.v20070926 1752\config.jar;C:\0-UIMA\BlueJay\eclipse\plugins\org.eclips e.tptp.platform.logging.events_4.3.101.v200709261752\hlcbe10 1.jar;C:\0-UIMA\BlueJay\eclipse\plugins\org.eclipse.tptp.pla tform.logging.events_4.3.101.v200709261752\tlcbe101.jar;C:\0 -UIMA\BlueJay\eclipse\plugins\org.eclipse.tptp.platform.logg ing.events_4.3.101.v200709261752\tlcore.jar
CLASSPATH_ORG_ECLIPSE_JFACE =
;C:\0-UIMA\BlueJay\eclipse\plugins\org.eclipse.jface_3.3.0.I 20070606-0010.jar;C:\0-UIMA\BlueJay\eclipse\plugins\org.ecli pse.jface_3.3.0.I20070606-0010.jar
Path =
C:\0-UIMA\BlueJay\eclipse\plugins\org.eclipse.tptp.platform. ac.win_ia32_4.4.1.v200709261752\agent_controller\bin;C:\0-UI MA\BlueJay\eclipse\jre\bin\java.exe;C:\0-UIMA\BlueJay\eclips e\plugins\org.eclipse.tptp.platform.jvmti.runtime_4.4.1.v200 709261752\agent_files\win_ia32;C:\0-UIMA\BlueJay\eclipse\plu gins\org.eclipse.tptp.platform.ac.win_ia32_4.4.1.v2007092617 52\agent_controller\bin;C:\0-UIMA\BlueJay\eclipse\plugins\or g.eclipse.hyades.probekit_4.2.201.v200709261752\os\win32\x86 ;C:\0-UIMA\BlueJay\eclipse\plugins\org.eclipse.tptp.platform .ac.win_ia32_4.4.1.v200709261752\agent_controller\bin;C:\0-U IMA\BlueJay\eclipse\plugins\org.eclipse.tptp.platform.ac.win _ia32_4.4.1.v200709261752\agent_controller\bin;C:\0-UIMA\Blu eJay\eclipse\jre\bin\j9vm;C:\0-UIMA\BlueJay\eclipse\jre\bin; C:\Program
SystemDrive = C:
CLASSPATH_ORG_APACHE_COMMONS_LOGGING =
JONAS_HOME = null
CLASSPATH_ORG_ECLIPSE_OSGI =
;C:\0-UIMA\BlueJay\eclipse\plugins\org.eclipse.osgi_3.3.0.v2 0070530.jar;C:\0-UIMA\BlueJay\eclipse\plugins\org.eclipse.os gi_3.3.0.v20070530.jar
java.class.path =
..101.v200709261752\tlcore.jar;C:\0-UIMA\BlueJay\eclipse\plu gins\org.eclipse.tptp.platform.logging.events_4.3.101.v20070 9261752\hlcbe101.jar;C:\0-UIMA\BlueJay\eclipse\plugins\org.e clipse.tptp.platform.logging.events_4.3.101.v200709261752\tl cbe101.jar;C:\0-UIMA\BlueJay\eclipse\plugins\org.eclipse.tpt p.platform.logging.events_4.3.101.v200709261752\config.jar;C :\0-UIMA\BlueJay\eclipse\plugins\org.eclipse.tptp.platform.l ogging.events_4.3.101.v200709261752\hlcbe101.jar;C:\0-UIMA\B lueJay\eclipse\plugins\org.eclipse.tptp.platform.logging.eve nts_4.3.101.v200709261752\tlcbe101.jar;C:\0-UIMA\BlueJay\ecl ipse\plugins\org.eclipse.tptp.platform.logging.events_4.3.10 1.v200709261752\tlcore.jar
> Also you can enable the Profiling Agent Logging set the following
> environment variables for your RCP:
> MARTINI_LOGGER_DIRECTORY=<an existing directory for log>
> MARTINI_LOGGER_LOG_LEVEL=5
> and post log here.
Apparently not -- when I try to set those as VM args, the launch aborts
claiming the directory is not a file (true, but ...)
> Also I can suggest to try allinone bundle from TPTP download page.
Well, setting up our RCP is somewhat painful, but if the update-site
install crashes and burns, I guess I'll try that. If that works, I'll
ask that you adjust your website to recommend the all-in-one, rather
than recommending (as now) the update site.
thanks,
Paul
Re: TPTP newbie gets NoClassDefFoundError -- huh? [message #121550 is a reply to message #121536] |
Wed, 30 January 2008 01:43   |
Originally posted by: alexander.n.alexeev.intel.com
Paul,
Seems everything what required for profiling is on the class path.
Please check what path
available for your application and under "org" directory contains class
files loadable by your JVM.
I wasn't able to reproduce your problem.
So could your provide more details about your configuration
(OS and its version, JVM vendor and version, version of other eclipse
plugins which may be important)
If you have some specific properties of your RCP deployment it is also
worth to mention.
Currently build Eclipse 3.3.0 (Build id: I20070621-1340) isn't accessible
so it is difficult to reconstruct your configuration completely.
Could you provide exact message?
In most cases update site works well but if problem looks like
misconfiguration all-in-one sometimes can help.
I will continue investigate it and hope problem will be resolved on your
current configuration.
Alex.
Re: TPTP newbie gets NoClassDefFoundError -- huh? [message #121773 is a reply to message #121550] |
Fri, 01 February 2008 10:57   |
--------------050701030501080304030507
> Paul,
Sorry - I don't understand the request here. That directory exists, and
contains a dozen or so DLL's; the subdirectory is
C:\0-UIMA\BlueJay\eclipse\plugins\org.eclipse.tptp.platform. jvmti.runtime_4.4.1.v200709261752\agent_files\win_ia32\org\e clipse\tptp\martini
and it contains two .class files (sorry -- I am ignorant -- how would I
tell if a class-loader could load them? My guess is it cannot, since
that is the exception, eh?)
OS:
Microsoft Windows XP [Version 5.1.2600]
JVM:
IBM 32-bit SDK for Windows, Java 2 Technology Edition, Version 5.0
java version "1.5.0"
Java(TM) 2 Runtime Environment, Standard Edition (build
pwi32dev-20070511 (SR5))
IBM J9 VM (build 2.3, J2RE 1.5.0 IBM J9 2.3 Windows XP x86-32
j9vmwi3223-20070426 (JIT enabled)
J9VM - 20070420_12448_lHdSMR
JIT - 20070419_1806_r8
GC - 200704_19)
JCL - 20070511
uh -- give me a hint -- for which eclipse plug-ins do you need the
version? there are really quite a large number ... I attach a screen
shot of just those conveniently listed by the Eclipse Help -> About
dialog (other than the TPTP stuff, of course); but there are several
hundred found in the "plugins" directory, so I attach a text-file
created from a DOS window listing them all.
> worth to mention.
Probably there are many (the lead developer is prone to hasty hacks
which he refuses to document); the only ones I can think of that sound
relevant are that:
a) we install the jre in the "jre" directory under the "eclipse"
directory (and since I now see that TPTP requires Sun, that is probably
the problem, eh?)
b) we use an "Eclipse Extension Location" for some of the dependent
plug-ins (i.e., things outside Eclipse that we need for our development
code)
Next I'll try to run some of the function in an Eclipse-launch that
includes all our plug-ins (not sure how well that will work, but ...)
> accessible so it is difficult to reconstruct your configuration completely.
Since the current build is 3.3.1 (i.e., a maintainence release
difference), I would be surprised if the Eclipse-build were the cause.
Or are you saying the TPTP is in fact that sensitive? The web-page for
the all-in-one download
http://www.eclipse.org/tptp/home/downloads/?ver=4.4.0.3 does say
"3.3.1.1" (even!), but the web-page that encourages us to use the update
manager
( http://www.eclipse.org/tptp/home/downloads/installguide/Inst allGuide44.html)
says nothing about the precise Eclipse-version that I can see.
>> aborts claiming the directory is not a file (true, but ...)
My recollection of the earlier message differs from what I get now,
which is:
org.eclipse.core.runtime.CoreException
Agent Controller is unavailable under port 10002. Make sure that the
service is started and the port number is correct under preferences.
org.eclipse.tptp.platform.execution.exceptions.AgentControll erUnavailableException
at
org.eclipse.tptp.platform.execution.util.internal.AgentContr ollerPool.getConnection(AgentControllerPool.java:227)
at
org.eclipse.tptp.platform.execution.util.internal.AgentContr ollerPool.getConnection(AgentControllerPool.java:78)
at
org.eclipse.tptp.platform.jvmti.client.internal.launcher.uti l.AgentControllerDelegate.getConnection(AgentControllerDeleg ate.java:47)
at
org.eclipse.tptp.platform.jvmti.client.internal.launcher.uti l.AgentControllerDelegate.getConnection(AgentControllerDeleg ate.java:52)
at
org.eclipse.tptp.platform.jvmti.client.internal.launcher.TID elegateHelper.connectToAgentController(TIDelegateHelper.java :394)
at
org.eclipse.tptp.platform.jvmti.client.internal.launcher.TID elegateHelper.launch(TIDelegateHelper.java:309)
at
org.eclipse.tptp.platform.jvmti.client.internal.launcher.TIR untimeWorkbenchDelegate.launch(TIRuntimeWorkbenchDelegate.ja va:32)
at
org.eclipse.tptp.trace.ui.internal.launcher.core.LauncherUti lity.delegateInit(LauncherUtility.java:1153)
at
org.eclipse.tptp.trace.ui.provisional.launcher.PrimaryLaunch Delegate.run(PrimaryLaunchDelegate.java:196)
at java.lang.Thread.run(Thread.java:801)
Yeah, that's what I'll try if all these config data don't answer the
question, and if the "launch inside Eclipse" attempt also fails.
Thanks ...
> Thanks, Alex.
Content-Type: image/png;
name="PluginVersions.PNG"
Content-Disposition: inline;
filename="PluginVersions.PNG"
iVBORw0KGgoAAAANSUhEUgAAA6UAAACqCAIAAADa/X5ZAAAAAXNSR0IArs4c 6QAAAARnQU1B
AACxjwv8YQUAAAAgY0hSTQAAeiYAAICEAAD6AAAAgOgAAHUwAADqYAAAOpgA ABdwnLpRPAAA
YwVJREFUeF7tfcmR5bqS5WuRSoUwSwV6X0KEXVVilcvetwgRIpQImbXvRYnw mph8BggO4HQ9
7Nm3/Jcg4PDxwAnA/9e///7797///uN/zgHngHPAOeAccA44B5wDzoFHcmDC u/53dw78z//7
n7tPwel3Drw5B9yK31wBfPrncsAN8Fz+HzD6PweM4UOM5oAb6mgOe//OgdEc cCsezWHv3znQ
4IAb4OPVYxXe/fv18evrz+N5c58JLjbUi0vw4uTdRzGc0htxYLEV32huTqpz 4PIcONQAPcad
oQ8W3p0kwbZufHz95aQlUbnAzhCYOaY01IMl+PNCffn8/pcpxp+vX1F/CEkf v9VayexhkYIt
anwZwTkhzgHgQD3cfr/s/MJ3MbzXt8HH9lP1gmGhugf5y5/fPFZM5v+vNW4x 8GL7PW2QQmuU
f/8VTuPff3uJ4VOff0u70x8IkYnz84ya1/NpOiDlMGIKuwuFOD+Mt6hy4AS8 62HrWH2s4N12
+taFdKyQZkcz8O5REozRAsPt9+f074JxJ7qzqkxeG1ZN368QFEUw4z2sULAV r8yy1Rs4Bw7k
gBluMxqzzPn785/XT6AvtOE2FYBS86kxrZ9X6i1irGCtuofZESc4a7QJwJQh 8p42NcZP706j
WG6HvRGbfX/9yiwK4Ljjm6T9lulb8MfJ3YlR9C9dagRsSXOcBLuU/q5hvFGF AyfgXZfFsRzo
x7uw0Pzn9Zvkd4PZv16/coIP/W/6IbkYXB+rVDF7Gn1i9CNfn9PL5f9C8rDD YR3LvauM1od3
R0iQQFsOYXMi5+cV/zENbaagQrDOCWDKS/EBQegPakjQjKhyITCkPyN5fBUp OR3OgRYHquHW
XssRmzIaNJ8GgwJ71LaZTFL30NOn0eb7U7j9njYVRmXKbbeD7+RmdGoNF1Te q701g3f1KNa4
NElcC2Tg97J02v1YwdQtbAMHDANEqS0HJwbsGRGCYY1aMNgEz5R140eM9wZR HfsZAoPIQrNA
0ryfAb+8pA9Mr2/iTGO2b9Yv8yxF1BKSaSj/9gRe3ZJn9jOMkyALnIS+SRNi wolmLII5qixU
XAspKMzwrtIfqiGQtnH12ODo/dUrcGA93jXWkzNQDwwzOG1hlfhNRmDiVp8l JWmCP9zuFB17
TxtbIHmUmtspLxFiABTOQeTorMrinL+Fuxd4EidDB/rxCpYKYtwAdHJQa3qq QMOvD5Foj9Oq
LUKuoLkPoUEZIEotf0JZAE407BkHonjPJOxm65aQ7CHyWjGNvvyuMFEKR9ij ZPlpEVN8JV3X
0t8TsfT1JBXxC93S9N5Lk4Z05/O7gyRY9d3J2ic75Fg2bbmj8bWRO8FsB91O XtEQx7srrN9f
uRIHjsS7AHOt5CvsHO3GuxhQm8nO3KynDW7GxS82MErb2CkaZtGn9ompRCI7 ZnGHAwojIxf4
KPVZshHUtPppR00WCzGXxJ3hlRT47rS0wuhScKIlNSgECxCVZID5JroLvKn/ dxdeH/0j8G4a
uaDeWd/ENulz5yK28DverQh1b7zbL0Ga22DEhTg65UV0Qlfmoqweqgsqa40E e2ZcPfps3ltd
kwPr8a7hY9tf1SYGpLWoOAlHjXHBfoaSGU1un2Q6gklSdNuxU8Lc4JQiSs6/ plGqX/NJMyLn
ufVw663Gmlxokm6ZfukPZDU6qUu8pvren6pleLct05omiPWSIVZhgzF12A+i cv816yaJyPvL
a8UM+vBuez8D4IykAX+/XvkAPng32J9QKGT5ALWfAYELkf2cw1ox+ce8Mo93 d5dg4V314EhM
5eInPAC+So5GD8wLkE+BaVCRWcE94r5+fYxGv+NEuvAuSV4ap766nwbA+/vj 9Zm21xez4iCy
97wazada5+QQSpaWZs+ZEt4b6gH/vep27NfDB9/Wzv72W714V48Cv3QHMjvM 0X5UMH1HWxky
5679DG1wYgEbCJV4+hCimMa7a0CU3M8grVtCsiHcu0WnHft3kxMk+Xl5Xo1+ cAmTxk3ZxIWV
RhqdYM+4JRwvrKKXzngCr6JTXfeR7StBQgm70AcTuiKvA1piJGZkD8ILEMrT ggqvfyb/noKo
n1e7hdNxIk0OtO5niNYTVo8MmYGnpZvH6CaEZHTmU9GVvMyr7GTlPRjXY2mQ p6jC46TkkpZy
uqbc1QJHTs3ErQFYLbejmsl70EzGz71F/U/0MeHLFaVfj1L/JbzXCGQC7+p+ hDN0W9qPA53n
1VrghJqnltS+IbgyFuaY2Km1rK9vfp57Vb0JqmGHpV31uYr9FP3uPW26SOUw Cd6dy06/c2Ak
BzZZ8UjCvO89OeCBbE9u7tnXegPcKFMPwXuKsdXX1fFuStqxLMVRrLnROOsN FT6s3Gi2Tqpz
4Ikc2GTFT2TIgDnht8cSVg661UsFstMoGcDVh3S51AB3AyeOd4/SoIB3JzH7 f84B54BzwDng
HHAOOAecA86BR3Jgc373KGDu4zQ4sHRh6sx0DjgHrsYBt+KrScTpeSsOuAE+ XtyOd58gYjfU
J0jR5/DeHHArfm/5++xP5oAb4MkCGD/8Krzr203GC2bRCIsN9eISvDh5i2Tj jZ0DfRxYbMV9
3Xor54BzoIcDhxqgx7gekezdpvs+MjqwvjRub7K8v0Uc6LqPbJwE6Z1x031k zJJLGU9yFYtx
JYrZwyKPULsjE46lTPeM8nuFjPKe9M7gRQLwxs6BzRyoh1tRFQJG0jd/USLa TxW5hoXqHuQv
7FKwydbCdYTWuPJerZ42SKE1SipfX/7iNYi9xPCpz781ex+ZMeWFzJ9IEvUL 8l3Iy/vZrIdv
28EJeHdRjHtbwew38c56E3xAF9J+AtilJwPvtu8q3k+C1sXvpFR9HojXjOFF 16r1JhaxxpiR
GlRc3AsXmuKd0Acd1l40M2/8Jhwww21GY5Y5G/UmCKfaTw2W/rzyCrBUL+ut N1H6SnUljHED
MGW1YHra1ISeRqnWm2DEfOMN/xRN1vUpdq7eqq2ls1DIbf95FP1LlwoDW0qF jpX9dA3mjRQH
TsC7LoVjOdCPd/H+FFlv4tfr9avcGTbdiE7X2YgkUgMLT+DqGetNfIVryFQh cq83UVGOPrw7
QoIE2hLapmiUk7g/qYATrT0h5mD1ID4goIaU0ie/vqKGxMv0g8rBZfW0ipIa VMQtOkoYwsHu
sb7HR+McqIZbe3XarhjcfEpvqjdss6PqryYp92mMG0qL/6VT7WlTUY48iu12 8B1NTMsFlfdq
b83gXepn0r/1L6xgU7XeBHikvDxo9+P+amcPYhjgFnAiwlYgdkQITkzgPbNK EwFH4UcMBaLk
I2vKucQGiZiI0OjQuSBOHeztLLHF3XXsZwgM4gXrakAhreOJM/3+5MZvJ+FU PWGoQxtZaXx3
XjzNh78ws59hnARZ4CRMLvdv04xFMAKe2Q0vmD0wvKuiYzTIrBWQtrFiUr4f sVrKOPYcXvxw
sPtwC7nD9NbjXQPMWVCJMAEMM3xGF1aJ32RoqbYKjCt9lpSkCf5w30E02542 tsDyKDW3YxAD
oHAOIsdKyGVxzt/CampxIpDEydCBfkeCpYIYtzeQBRp+fYhEe5xWbRFyB82+ CY3KAFFqARSm
rXq94EQv6saBKFlPWFq3hGREHgZaU3gMIDKux6CotRi6vQg/Xw/68rvtxJis KJ2WGrSIJfo7
8WGL7fVMrKdj1f59Pt+uRcF8fneQBM3MR15uTgowGQP7jpm33NH42sidEOsi ClTRkColZZ+f
3Fhc4m7Quo+v369Wkc9rSdupeSYHjsS7AHOt5GvCan1pyyQKjJrNt3KznjaY kcLt/jBKw9jF
EhqTVSQkmepDMbR4q+GjcPrgotRnyUZQ05RoR00WCzGXVA+mzzSL42bVCqNL wYmW1KAQnBRe
ZG0x3wS2XNN/hdYoujVVt4HKLq+fI/BuUtDCx1nf1OCv2MLv+xkqtr833u2X IM1tMOJCHJ3y
IjqhK3NRVg+AdCeJa/0x7a2tZmnQhsdJX3wMao/ztj7Sm3NgPd41lH820ZLW ouIkHDVG3UO1
z5IZ5Sg5U0XRbcdOiZzINHSBj1L9mk+akU5m/AMkd/m41BEJimZBMEDhyYn1 B7IanQ1K3txs
9pv+Mrzblmk7bAFINcQqbDDi1H4QlblRs+451Cti6wq8e22Q1od32/sZYIZJ A/5+vcKWzekP
vBtkv4tu4mLa+mQgE8bxrTmHtZ/a36+neby7uwQLk6oHR+hdB5PsqpsKUiIH 08BhDwzzAuRT
IA0h4t80PQOPxKBMhUq3+GP4NGPcHXE/dXCKb8mBLrxL9Nw49dX9NHjn3x+v z7S9vjhYvoW9
97waNz3zrTxKadnTRoqQj1J1O9oP5EjUNO32W53QNvpY7kDgFwJiFmOXFElh r4UKprdU9isS
3bWfoQ1OLGADoRJPTzbw7hoQJfczSOuWkIx8kKmjNbKFI0fn8IvMQOn9DJfW z479u8kJBkGW
E0K/Y/4cQAn94BJki1uniZsrjfAEm97wgOfVig/ml85ce+lwogV33Ue2rwTJ bNmFPpgiFXkd
0BIjMSN7EKteQrm0NxI80m5dEm/wEFs+KEn7gdCuQLBD3hM1+Z2Hbt3PAEcz GTIDT0t9Kd10
m490hsu6Uoil9yQYCBJdednJynswLt7SIE9RhcdJwfZ72lBdMNailttRzeQ9 aKZ+zb3F/Ebw
MeHLVQmGgbd6lPovuAPYpEWgYd2PcIbvbDB7z73zvFoLnFCb0pLaNwRXxsLz TuzUWtZXsfJs
ojUCc+PbH9PyWH9xpZNi59XKTve9xbSlv1X1JuiA7dXqFtLEu/pcxY6d37yr TRepHCbBmzPZ
yXcODOXAJiseSpl3viMHPJDtyMxdu1pvgBtl6iF4Vzk2Ors63s1H7OkBuKNY c6Nx1htqyvp4
4vxGwnZSH8qBTVb8UJ7sPS389lhS2Qfd6qUC2WmU7M3S5/S31AB3Aycego9S ooB3JzH7f84B
54BzwDngHHAOOAecA86BR3Jgc373KGDu4zQ4sHRh6sx0DjgHrsYBt+KrScTp eSsOuAE+XtyO
d58gYjfUJ0jR5/DeHHArfm/5++xP5oAb4MkCGD/8Krzr203GC2bRCIsN9fES vN0Eb0fwIgX1
xh0cWGzFHX16E+eAc6CTA4ca4GiHP7r/Tp5erFn3fWSUbnFd1MWm9IbkdN1H NkqC5dqv7Yfe
+L0/pajmKnkeZu1yIHoJGr8Cpj2PwwhexU5/6QAOWOGWnGqyS7eUY1etp7zG YW0mxPrKlXz6
1jD5C7sUbKIlkKHf0jd29bShhM5TUlrTChrWKKWdRblkjdGG2mm5LCzIQJdv hCjJKqLRu8zE
XW9kdOYJ+8RnzSvLUVRG4LcsVxU7zE4UlO4zgporY5M66JhgH8W51Ql4dy+3 r/uBX/YaYhEr
r9q4s94EJ985eDFxGni3jT53l+AuHdJOonNcD3l3oadHyg3nvmgBcBjBPZPy NmdwwAi3P69i
Aql2Dyer+dSoRtGeFPaWiyP01psApPkZbr82xmXIKbTuacPQ7md2BVAE0Zxd hqfF7vo5YJdk
4+wSbapVcuCtWlaox9IFqu72JLkiQKYhwP0EeYEVPTOFGUDjUJpkulp14590 78tw/MbBe14/
Ae/2kLWujeNdi2/9eBczDS9Rb+LX6/Wr3L4drQKXxVhdIjWwVnW47MN6E1+h doAqRN5t9us0
5L5v9eHdYRKcGFesi2REoEyJTBLINiJC6P+LGlLtk9RDKW2k7oF2cXUNlOdf Xj85O0uu7CZ6
G+cYNTNejxdUHbO5skqFiGpCyRPH6JX1moGu7fc1yFWUN8Mtrd6ie9dPm/WE g+41UncdVX/N
fFLo0xg3lBZnSL2nDYO7oRh4+iGPW58dEtbkAO0euKGNlPqiiYaU0A2GaS0/ tMnPlkPHSWmn
NI2S/spEDPJI+j9QRUvRUnYVvrGZcgUwnFsaOiakWVGxkq82gzuyiLo47pPp pFZZyqCXDAPc
Ak5E2MqzLk5/RxBl8xwUdclnxkGcvUy3HfsZsnmTZBtduQahFneW1vHEmYba sJYHJNPHarGk
fh2MhU/9mtiGzszsZxgrQe5YgcpyBTekFkIVIvHVVfwig2hy9GZ0LBqSe1Bt MC7yzJCtrlGB
g/aWf+TgwaNs9F8ZCsMnwlq2hv2ulDx+801dodqn6FhCe7Qd/3sjDlTwblpT 1ZSh9pQiYAMr
t6xSY8psg60+Sy5QtyGYLOt8T5sK3p2lxMS71IcohSKUyywytMW0KMQ+LRHE NwQRih+zjdMt
DiliqhhaIGZJ2WofQkq50ojMJoisDlP4hWlaqQCmc8upK1iuqBHN4F5bk1CX SLdYXMbElQFu
ASc6bPHSu3uCKLoOLBEKuF2LUJdh+5GE9OV3GytXGdcn20gOTpcLtrYr0ddT sBe/wMrSxVbX
i/n87jgJYooiJiSof0+yQ+Bb/KZuIzrJM40uQ0aRqFeiT91GBwCtXSJ7IRxE rU89XzMR21Bj
reT4C7edIz2Bj3U2B+byu40tjyqxxxCelRvWVolGlwYyUWklK4zrtOZbuVlP G/xI+PH7C/O7
2/AufFnCrzFAuY5EoA84O5Io1Vbf8LFUtXQg0zEU6xWXoqwGebVFfmWpIMbV LtQMtZAFCL1a
I7LdyfiFNi7dNaznueGzLU6M3wqjS8FJO3ykQAnp/40gSvTWGaEuxvxjyBmB dxPlJXK3cWob
74qN9v6Ft6IUe+PdJRKk1hWMnIDaLK9pXRvTtPj9S7eJvXQGjNBU9Sl0Yxe8 a/bZ6U1W4l3O
+WN8gI9yDQ60tw9iQs6iVj01vorw97gF5WcUN+seqn2SXaHNt/I2gJ42bdBW nx3a3SwHYpSK
e46l86EAl7ZBH6UXGN3uqxPvtp2P/eFLUVXzQm0XKniIUbgHYdeXBDShUP1e caYpLsO7bXAy
I+VZvLswBJvxDgKuA6eiVn14N+5TxB3rtaVJ0oC/X6/kQdC7qYNHLB9gfdjV /reNm880k/PH
nse7u0tQTLqIHnZ60ZMT4bjD50vHFX66QgQM+JaEH5XomKxPsj0gt8naYn2Q AuMXNFN3nPcz
cL01gwcPjUihXLKLT6UVwqTtnK9aTsFhHNB498/vV9n5WqAM0bf2U+O0FtdV bkHpywxLIfee
V1PokG3UEZgyAh2zZ/QPCgz1UoJ4NGNZQYkUJaNcbxiIzYWBF7ve87wa9RXK kRaaO/YzpO0H
fK+tjNqEBTW3TA9jwCkF/g/rAzr0rHwv98nx/6kjjIdZWWOgrv0MjL0qcWMB mzLiOBBFxZFJ
Qk2oRagrcPxwGjr27yYnGLhW2WqNXy3S166U2Y3H02DpDG0wyac3PJCvIcAI eueLL1Mq+tF1
H9m+EsyUgKyzmUFJ8Y8J4NIPZCSG2W1yaAFFIaGXUI7eXMchqmMsl0A20tCu 4ECkWAcb78av
ipVkSZrOTufVlO0c7hF8wLM4YN7PAEpNzlAWz0l8o/FU3wtmmAxuCxZ3b0V9 Bm2k2xjEtrQQ
xbny67fgWCcYdU8bKoceSsg5adwobG2iyx0rytE5wHytNnRnLYhn0X1kOncr YqiZ3NHkWY6R
ypFdqqD7pPqgnZu8xaxyfFzT0OM/5c7gs2yOjdt5Xq2cI8Rb9oL0WsCGPh0G omD3YIJeJP7a
EeoSLD+aiFX1JiiRpmWOmIU+7TRilHv2uekilcMkeAXevtVkr8Bwp6GbA5us uHsUb7iJAyMO
Wm13SiaWHZoeatA8gkWbZNb78noD3AhOtivAbXneK5ud2l0d70IusH5CeSdO 3Lmb9YaasqpD
PeOlGPtWk70U552YOQ5ssuK5zv35Zg6kHPOAQgnbnZLVQwmdAwiuRo1hLNos vJ4OlhrgbuBk
kwLcm+c9ctmxTcC7k5j9P+eAc8A54BxwDjgHnAPOAefAIzmwOb+7I/b2rtZy YOnCdO04/p5z
wDkwigNuxaM46/06Bzo44AbYwaR7N3G8e2/5JerdUJ8gRZ/De3PArfi95e+z P5kDboAnC2D8
8Kvw7qbtJuPn9H4jLDbUx0vwdhO8HcHvZ2WjZ7zYikcT5P07B96JA4ca4GiH P7r/eypG931k
dHqJlc7Qy4i86z6yURIslw1tP/RGr7aByr3rmHyYcsqB4OolvGFIXlVmzmiW YMKc0KHJK9pJ
vKyKXUi0jpP+1lEcsMIt3k8na3EHqjqf9hWmFgrG+q/eRyZuMYtE6rvD8Oam Ygs9bSjfu+4j
iy+UujY2/dinRbmUtNFGmVi280X3kaFvCDZqlA1n1t0nvkI7pTlzW94s1neC jV2RSypNzJpD
zZWxSfXRMDvWrg1OwLuzbr9zgo0LOvYaopOSazfrrDfBJ+EcvJhQDbzbRp+7 S3CXDmkn0Tmu
h2u70NMj5YZzX7QAmCGYVk76fongCryCTsIvV4woPRx92zZGuP15FROY1lFK oM2nRr2JNmex
t6xsC6o8JKQZa5UZ46riAj1tGNr9FOVajIoVU/sM9Yrd9XOA1Ier8ki02bPe hB5ToOpuT6Lr
TSTIC6zomSmQA41DZYqfzXYp3fsyHL95+PkOTsC780StbUFjQbf+rB3sNu/1 413MJbx+i9LP
r9evcotytApcYuIlzLkARSkXRBiEyz6sN/EV7vCvXHB9G94eR2gf3h0mwWmi xbpIdgHKlNDk
UPi3bAN8EpiPoTeiP0FhZJ8k31nGlboH2sXVNYySf3n95Owsub2fj/vrK2pm +IOCQ7lFrilY
JqPnUt7L6RxL7afQJG0n96fyKyav0o8Odo+zvD1HaobbdoJNP1WlXymlpgVh g4StdQ89fRpt
vj8FUu9pw+DuC+w9q32dErSLJrUmN4RJ6japwEdwLNbyo2GSoiujVrB2StMo 6a9MxCCPJPhz
SUjOagF6QO5aAWJL7tzS0B9fP/TCSjEiLUQVh0YWqUeMP0sSxnsaWasvwwC3 gBN8V5dZ+WdP
EGXzHBQ1Bx7xmbEO0lTZLwgrWUNkWbEQCo3JHiW2JeN07GfI5l2vJwyZpLSO J7b0/Tmxpu13
gv2wqo+RcWU1iU/f65rYJSKc2s7sZxgrwUir8PXTL+UKbkgtwC84OXFNt+wk aY4ZHYuG5B5U
G4yLWruK90F1BU9d/pGDBykBmHEkGVdUZRMik869t54wQPloO/iX73oM34tN hkcOhEE/PLO7
0Hqu0ryCd9MarJYMqz2leMLAFi2r1Jgy22Crz5IL1G0IQsKyZ2K9qttU8O4s JSbepT5ESZtQ
LrPI0BbTorikVBLBkF/2KxSngfsX9C85YiqnRKu4ZXckyCP1aQkiwepfFCun 7PsvTNNKBaBh
l+x/iKgI4Joa0QzutTUJdYmXrI+gDHALONFhq1lPeBOIsso7i6WODk/FpRSQ pgIlLY8qwl9Y
79Gvr91ry7N9bV9+t7FylXE9JQaIg5ZegLsJ+noCyuIXwfSz+XXN8efzu+Mk KOAXFTdUOIwo
DdM8uk0bw+ntbgimZbHrlHvNWtTWLpG9EA5C662pmRro67nMKjmqPbcdrW1p Ka83C6bAE2j+
+Pr9wqrL19RXp8riwFx+t7FBJebh/rYxIh9SWBBZWJWuTOSqvquAtufw2Xwr p0J62uCHjo/f
X5jf3YZ3IaeFua5MEl+xw49ydqWZafUNH0t5r9/VMXRKqYLT0+tqzcYOvCtT EtqFmqE2OBya
njRSAMQ9k9Sg6T/FpC7mB1phdCk4aYePaeJUZBtBlOhNR2RjP4MCaVT6Jgyr AbM0+uyW9GvI
egTeTTMrDK0BAhMWCEaLjfa+DaWiNHvj3SUSpHJMeCvFXZT7tBaMaVrcYKDb iFfI/7X1R/Vp
fCLkRyq1w5rFu2afXd5Ehc+2NxFqD7ZjixtSufDFU4bhENchE3wNR+NUzHKg vX0QE3JWR+rp
bMaFW1Duk+Jm3UO1T7IrtPlW3gbQ04ZOcgElxO3MciBGqbjnmPurFL8xL8P2 vGZ3pBcY6htX
DYN24t2287E/fCmqGhglyIK7ZQPvRh5iFK59RuMaOTtxsZyYNYyjGizDu21w MiPlWby7MARr
ngMBLQBmgbQasm/j3Ztgsz68K9LXtaVJ0oC/X6+8lxH2gamDR6jx1icD5B0x 4DZuPsokrjnO
PN7dXYKCEUX0UJqYnpwIxx0+Xzqu8NMVImCAYqCG0DFZnxEgshMVGJbqn2kE zdJB1Prk0Lzm
u+WSvXc/A7edMuOpN7GTweyfrTFKIL+myjpVigMa7/75/SpZ2+IJib61nxqn tbiucgtKII8l
iXvPqyl0yPanCUwZcaTZM/oHtXmjlxK2zLbPtDGuM8pVJIKVLaWnmNie59Wo LStHWgjW5Ond
BTEpzqKn2oVI5l9zy/QwBpxS4P+wPqBDz8r35idimtUtOqe5hq79DG1wYgGb Mp/mfgbodg2I
ouLIJoyaQJUc/l0HaTlXwvxMVCoWcfR+hg2Hyw8UeMf+3eQEw/zLiRtxXg1T 2XIjM3FhZEtT
8kr0CAI9yiNwbfqAm/5usoY4UHx5qK77yPaVICaEkmyymUFJ8Y8J4IqkJnju cuSLtclaAcIm
oZdQjjoggKZoQ8Gr0C6hrhLmEthd61OF1TD/fc6rpQV3ZCjrkF5zprdwmPny 0FXXVWjH66uP
aHHAvJ8BtJWcoSypR+Ibjaf6XjDDZDCLKe7eipoD2li9j2w6YDnt5ONqpt8C 7dUHd6Bn3Yby
qIcSehA2RV/9FlsyS8rR3hlVbHYkPDGOLbqPTOdua06J0qvJsxwjpcpKAZAe RRQW+V15i1nl
+LimwfC9MXbzyM53Bl/CI3SeV8Md0hqc2MCmQJd9Q7ApvkISja0pKJdbLGdB WlZ+3PyTQrkA
ZnQu7LzapXHaqnoTwgiPgaHibNMlDOQqRGy6SEXo8VXmNIaOt5rsGBZ6r4M4 sMmKB9Hk3QoO
jDhotd0p6R6299kWfaP/ESw6RA/XG+BGcLJdWLfl+SGCxUGujnchX1g/oXww x6443HpD5anK
K85tX5q2e5Z96fHenAOFA5us2Nk4nAMpWzzgWuvtTsnqoYTOAQRXo8YwFg0X bhhgqQHuBk42
KcC9eX6IYDnencTs/zkHnAPOAeeAc8A54BxwDjgHHsmBzfndg/G5D2dxYOnC 1LnoHHAOXI0D
bsVXk4jT81YccAN8vLgd7z5BxG6oT5Ciz+G9OeBW/N7y99mfzAE3wJMFMH74 VXh303aT8XN6
vxEWG+o4Cfb3XE6S7lCZ/f0k7jN+HgcWW/HzWHD8jPr91V60HT/iXpQ/vZ9D DXCoGvR3/mZR
uPs+MqrriZv9PH26nZw+v677yEZIkF5Gky6Ya2gFe2Rd2H46H50A58B5HLDC Ld5PZxUQ6Xxa
q0XMp0psudzANX8LmLjFLBJp3QIG1ySxW/ZKDZrkN+yb+NryID2IcfX1SaUm Kt79NR0+myqZ
0fuF6pcu0VsXN+kIRE9CRzmNrVgH9PTxh4qjdhdhT5tNE7ztyyfg3UEgyqNw RQk7600oz3jM
HWS3tZyDCTfwbltAe5kZ7ad6U3phBm0c3HdfGD6YlT6cc+AkDhjh9udVvn6k 2j2csuZTo95E
e17YW16LLqjyEHtOdciMcQPYlcaeURe5Zr/MtHclzHsgF+CbjqiWozFhMTBq Lz/ZlWtQU8C3
KE++X5XSibrYhIa8vM2fr09So/Ektb/OsCfg3UGT78S77xeF+/Eu5hJeot7E r9frV7nTP9zy
Te79xhKyrCoBkzKuXDFB+BVuSK5ccD1IRe7cbR/eHSBBmbJ9fZdfSBYhxWms mPDx+wuLiLCk
i1KA0FvWrtdP7sH3P9xZVZ32Kgea4ZaUcjU60E/JLzr4sTin34W6mAWk5h56 +jTafH9WrsSy
o7KF7Gs8wx7oLOK/a/ndWp3eAMrn0r0xuE1VKrAISAqF08/I0lSntxEEjeIL ab0QyM4zjf9O
SfHQvyl9kt3PbTifDfb2riXe00oNA9wCTvBdXWblnz1BFImSATal6g9RLT0K C03u2M8QGNcs
hQdXEqZ1PHGm35+xQjctpSbzjsFoWf3JqCVkrV/+PWKp/RSzntnPME6CRCg5 c6DFBHdxi/xu
1oSmAgRliM4iRaP0D/+28BS99XlQDlTwbgJYtY8htacKPHFeQxY2GJTIF2p0 m314q8+U3DVA
G24zCOBtpuJXAo79Bs7wLqCKiJjNjQoIQSJkhV15ELM0Sqa7Dihh2RFlnqTa vLmoW17DZ5GV
IMgDmaAkyJeC0QL6Cz35qleUlCombKNbrjaLePt+xqkMcAs40bBnGIiCKDmJ DDCYMCKPwlGf
+/K7jbUye5QsNq07SW7A2KhUjElgILEutxHS+xni3Izn87uDJEi9NuQ5ZFKf VFMUJStFeEtR
xxQ6/Ogue04Z/PlNOTCX320UDtB5uxm8CzBXJV+hK91DvU/McTTfIqmQICMb ouVpYjlTUamb
SleGD0y8LsjvimjV2M4LQxOEkRgYQO30Y6oqjJuYRYI8vp9oNv0YA8HWcYiU 8c39887reFcW
hg1ElCx1/9Lipka1hOxWGG3EJlOT9XpmUAiWo0f7hcVeI0DTFzth2P2j8Ai8 m1SsoN42QGkz
WpTwduOsWO/eeLdbglq44M0h628aSe1Hx7tLHLS3fRIH2tsHMSNrzVk9bX9V S4gn5hSZU6W4
WfdQ7bMkd5Pbr++CCIMS1C69x/Kv7TXUqAFlDWXG379/f+QktwlKJMNZoi5k dn8SGyNLcRt0
JQg28C7F0yJ9gDQkDpt8XrifwXMHXLLL8G4bnNQioxCxoQzCBmPqsB9Epa8E Ce+SVRmuLQXi
0mrWQPbvgnfb+xnImYP0heiVV+SwD4x/xkoLi+wWrU8G6IKJ7N0467F9Hu/u LsFETAPvFiHi
CQkUOn2xqQDawFwNngTxfC6EAxrv/vn9KmfUiickRtR+apwbowYY9/ZNn+Dx SBONjilj8cl3
mlm/ZCdAtluYb+VROAHMe6jRu1TD8AYBjJadFYj/ghdKydfK/t0M2Tvwbu6K AJfXr480wUki
E0uDyIwgSPLWtfxu7hOmQJLBsJMhU6j2M6TNmix0qrAr2rgvbePdmLOTmy3b 4MQCNmWQ5n6G
LSCKypEe1iS/exROUujYv5sSdUGQ5VCaOK9Gtu/H7fYpsxv+iJsrP+HHbr3h of4FJ73t+d1K
EOi6j2xfCbbxbgyNWQemmFoEl34MWiFWmUWz5I1mjne7wr43egIHzPsZ8At9 PApMMgVpr16x
HP1U3wum4SbBqeJmsQIZU//0HJX4hYCzLATw//AWnPHiAJQQb40+I1P6SgAl +soz4vFy7KC/
RFdEtvkGsj8mZ0XDmW6fd+tRJpCkDOb8VBAE8pI/NLGmOYWcOQayCg/17Nj5 JAPsJob6fWQ1
xeo8rxZWNumPGCBRMGsnp9rjJ8+rbQFRTEsZiPIoLGS9qt4E7eOwNaI+V/GE GLfPHDZdpHKY
BPeZq/fiHHgmBzZZ8TNZ8vaz6jmeW09avz37ljFgvQFuBCcbQ/DG15cx6d6t r453YYFSP6F8
bwHsQv16Q00ZI0+c7yIG78Q5sIEDm6x4w7iXfxVzpfDhUF5FfPk5LCcwzbpx SLF0aTnwEjc7
Xl9O2VPfWGqAu4GTjSF44+tPFac1r4B3JzH7f84B54BzwDngHHAOOAecA86B R3Jgc373nRYH
l53r0oXpZSfihDkH3pYDbsVvK3qf+BU44AZ4BSkMpcHx7lD2HtS5G+pBjPZh nAPDOOBWPIy1
3rFzYJ4DboDzPLp5i1V41/eLXEzqiw11nAT7ey6HW3euD9xPwFlCvD6FZ3Hm vcddbMXvza59
Zn+8MR4/4j6cen4vhxrgUDXo73xQFL6qsnTfR0YnkLjZz9OrTv4xdHXdRzZC gvWbUAzeMoVZ
fre8Ka1FBDTkPavM/GaiTRh9dqyleslo8xMqS9l3lfZWuCVHtUTV30B159Na LWI+caJF5VJe
fbOY/EXcI1ZKf4k7y6zLwhL9tOAiHEZrFFSTsqL1MjhtwsogZuHFT+I+sti1 fku0/7tZW2xK
kowUw4EeQzoGJT13jfW02TzJW3ZwAt7dPRYkxje6HRGF7yPtvvpqYj6DhHQf rl2NUgPvtq9c
2EuCtB9603UNm7Lw1heG27xeRMAWsdGBYuxZD3n3Yj5MR9K2B2O38MrfXcUB I9xisS5emSz1
33xq1JtoU4W95bVob72J0m0q2WCMG3JIUicz6iLX7BeD6l0J8x7IZf6mI6rl aExYbFrWKpka
L1WzRWoK+DKvuWWsfEJTXW8Ci4mUrnibP1+fU1k4/8scOAHvDuJ9J94Ngey9 gkU/3sVcgrwq
+dfr9Ytde44rSHnNspV8wpUrXpX8FQoTlP8LK2y/NqtiHn14d4AE5WIRKx+S LEISOtw5PwXF
L7woP5c9JAmh2GdWgPDvrF2vn9wDA5o1AgQEVNd9y9olJAjFoeMl++kO//RX i4uovVCWhV7O
L3S4tJH0gOZLUyJ1XvBdtA6DNl5oNE+F1HZKv1QJKPFPMkTknyJzxNzpVfZu qssjWTPcErEa
Peunut4sV2ZWQkLEPKiLWa8MrANqjp3GuN+flW8OdlS2kH2NmdgD5UD8t2mw JtlJVwMop+Un
LKuPqHKq3wZ/ORQm/5BZmgo1k7IOpvMx5q6mkL41h9dN6ZPsfm6zsJ7wchV9 9huGAW4BJ8o9
0g8ye4IoEiVz2CradVAUjmpRR32qjtiq4LKL7nXsZyj1XTD80xVqEGoxs7SO J4uG70+z0jel
3CrZh1ADn/o1sQ15z+xnGCdB4rVz5kD7cbiL28SgZs1GUADQrhSNJtwsLmCv EWCM1dQlUGkY
uj5QFESKQGZ0L0A5T1y1ybSZms9NSfcffahMLdPJsgpPHK8YhlmvlqkZIkpS 27TlEaPh+98y
DlTwbgJYNX7WnirwxGmBLGwwKJEvRP0UK7dWn7keL0NmYCMEIDbWkObCss1C hncB7UXE/MOv
FSf6jNTArjwwDY2S6X4GuorLhpZ5koozR8OMWyzqtpYDGYIhWOrTJG4B/YWe fNUrSkrVE54B
0DX4vkxFn91aGeAWcKJDQ7Oe8BYQZWIwkXEYGoXZem8qrZoi467BZSfN68vv ai9APYWsKJ3W
nVZVPfq79m7JR9ioyMsitAQ+n98dJEHqtSGNUUummpIVP9YUAJo1AhIlQI9l jQ5L0lBHVGxJ
NzmGQig5JLa9L+p88Sw5raUDG4ResbuDjRiD3xSzRf9GVGO1vjFvbQdUbpgN AkwiqQ+d7X8n
D/U+3czldxs7s/UegBm8K7WUKXYaSPdQ7xPhXfMtggLDgDZEk98i9Ed5JFZ6 D0y8Lsjvimgl
lNz8UkEQRjLzEOOnHyc8mv4378QVCXICOmcNGT5vCpA9UZv7V6tZSSpi8cSX 7OUCFSVL7d9h
iH9phdGl4KTm9mE46mC1589lq5eDqKB4ZLHXCNDUADdG4ZwAGhpc9okDI/Bu oqygXtOwhdQB
+wq4Q3Ns7X724cZde9kb73ZLUAsFzBgWrCZUrf24Au8Kl10Dam1d6oF3OhDa Opk+aJaTNA0W
9eBdc3ZCTykz6TrTDmaWYda8ufCDPVBARPq7mtQJdLe3D2JG1iJNPTW+PPD3 uJbmZxQ36x6q
fZbkLkfJWXkoAuZ7FaRpaNQ+J4UaahRrVwjtFWP8/v2Rk9yiQdXA8RtLyOz+ JGOPLMVt0JUg
qF2NnqXpHlFG5pclxT2DeN7GQyrn/DK82xNQaP+mahnKIGwwgsh+EEXxbvDq ZZE8NArjNEcH
lzmHMPe8D++KT5m1pUk5KPDKB2xhH5j1BTYH5mbeOwnvb5yEG2ddlvN4d3cJ whJlDm7iCYkE
quSLHR8+qPRnAxIC7jxWIaCpS8vwLtCMxFPhpI+b9JC7tRW4OXH8WtrcRqyl gGeDFG1/v2qG
GViUUlNFQNbuFP49jnyxynOX/c/5Hn/eDrdhS9yrFM4t2stk1HpqnBujBhj3 2xEtTV8JWAq5
97wa79Z8K9sCb8lcuhq9SzuMoBC0NA7HsB1qeGUBmSH7rHtJ+xTpDpBJ7X99 pAlO8ppYGkRm
2BrJW2s4zmYLUyhRb6IKRswUqv0M1nk1faaWnVfzkDpjgMvBCWq4Dg3N/Qyg litAFJUjPaxJ
fh8VhWG+o4NLlzuYb9Sxfzc5wTCx/Ce3WpPdWfxSleR3rO+tAvqUjsPrwgjL /XB4yGZ+Um/X
ous+sn0l2Ma7U7Qpp77IR7T8Y9AKKmUkrLKxfQXeJdvnkYCGLvXgXdRzAgsI V/leArLhUrSh
S22h+dKUlO2YIYr/GDdpSJstp17yAMowydqAfvrU4R+cADuvBqdqeP9vZ4ib Jmzez4Bf6NPO
V+o5iT5nZMMAZcq1iK1lQi3x/4qbxQpk5D3oC7PiQppvOVDj4hkvNBw63ES8 NfoMM0UP8cBZ
/GoP15lp26S/xLZkm28gO/gKaoO6ff7QTNlCgDXbPc9tAcjTW6dgouYUyumL QhdJAAGpBS1J
nlgs9PvIaorVeV4Nb7TQAcUGNvp88D97giimpSyGDo/CHN8zAxRhXUfkZcFl k2uFl1fVm6BD
H7ZG1Ocq9uHAE3rZdJHKYRK8DqevqUtvKIjrqMQFKNlkxReg30nYnwPi1Kw5 gPYb7klWSWK9
AW4MKBvltfH1Vby66UtXx7uwQKmfUL4p5/cke72h6oT6nnRdq6+r65K7rWvp y9HUbLLio4k9
cjxIGEM+8x2KqqRZd8zU8hvF13W8fqQkrz3WUgPcLaBs9PwbX7+2UPalLuDd Scz+n3PAOeAc
cA44B5wDzgHngHPgkRzYnN/dF357b6s4sHRhumoQf8k54BwYyAG34oHM9a6d A3MccAOc49Dt
nzvevb0IU4b+CdPwOTgH3pgDbsVvLHyf+vkccAM8XwaDKViFd32/yGCpLO1+ saGOk+C4npcy
pdb++hTuNVPv51YcWGzFt5qdE+scuDgHDjXAw8LQYQNdXLqRvO77yOhkEged j5cRcNd9ZCMk
WL8JZRlvZnWJXwyk75VcMNzsWAv6ajY1z03jbUd9h1GmEQ4jWGvIXqzwfjo4 YIVbclRLVP0N
HXY+7avtTEyMXh3NbjRT95GJe8RK6S9xi1ksOsguC5N3lln9IMvk0+m+W3Hv WLyQy2xG78oN
B4z0/bvEJPFat9niMhAEhUXrmohpHpQD3JtVDqVxFunLm/hE2NTssSpqQC/V Ah0zf+zQ4Vs3
OQHvHuDbDxjiPlLvrDfBJ+QcvJiADbzbLhS5lwRpP/Sm6935QweK0WI95N1r 7rNzNPHuXQp4
HsalWTa+TQMj3GKxLl6ZrECoYgXGU6PeRJuTOFa+ULa33kTpNpVsMMbFGii5 aZs2Uq3NoDg8
DVfYvqYqD41SRJVmHyFTU1vXgWMxwWXPj7XVqeBAh3FJFjXxbplsnJridmPB HFcIiINDVeS8
bJA/voMVnoB3D2Brh7IdQMVFhujHu5hLkFclB9dTbjaPl6LjOjs5F1zOWtej 4FO8KvkrVCso
/1fdqn0R3l2HjD68O0CCzJZi4VCd+4c2NKtRr8oWRR9vyU8X7Ke/mrsXqhX+ L3jqUshUt5Fq
CYrHNTkMmn95/eSK8+Ri/5yxytVYfn1xykuFeisRJebFXtRTICy17EJYTWHd 7sRfR90fSkkz
3BZltueun5JfzHWXNhPsGepiimqIPX0abb4/hdvv6aci42QdaUZw6WltgvH3 qVZwSlcHBPk7
vljDu+BneqCtdnSmp4o/Sg4YEATdRXR9ikV1vDtFW1rBR3FbOE8SBYJP0xHZ /PGhJsenZRjg
FnBiwJ4BITgrrcRgtEBY/qbRhmFvIeGe/QylvgviD2rqgYnFZtLKkgTsuF5s ejdSlZQUNQWs
Q4ry+TKlrpEz+xnGSZAIhVWgpcLK/26KEjQKYK64aF1KPymVGVyL8uRwWIsc Vq1IQ5OjbgfF
Lv8IzLT61JTbYZh8/kybgtSLkNoJ46Yyv6Jl22og0Q4070L8ezjEE2dZwbsJ CdX2JNSeUgRs
YGWpYwYE1D20+ixJWfMtUrIsLGJ7+qng+phChtVvnoUyNF4cuLIOt+EpaSwW 2zUQTPczFDul
WySim+IcQOQRf6cQHAuJ83W7eKW8lcEuZgTUWCxZoEraar1i6+0TreGEoZUB mjGiE5zo2NSs
J7wFRGkMRou9Y/wVy9cTOHz6kH353cZ6lz2aZDzBgmRyhLlshxN33AIYwdpd OyPHu4vwbn8a
Y4sEqReGpKnY260TIWVE+A6QS/4aKLnM2cS7MgZE1SpZn5zn0G1MeoTiBX9B ao3C6AR6spBm
Um7i3fbn1PRUT8FkKdiIaTWCZpq7EvbYSfzpvurpBMzldxu1A5LjpQyawbtS x/BV6GoJ3kWQ
1HwrN6vTRsAWOgdWH5iXHNe2nPQcvg1Gg0p1AUK+puZ52PRL/rgT77Y9beiE Qx/paojUELgo
FpkhGAs1F5MOO5tp5LXYJeYlzOqN42zrM2lSqlqEMl19w81SbyyPQm0DUSJy Ndz+092pOb8R
eDcNVFBv237aeJcm+d7YDmc1c34/g+kujWhBA2eHBGuQTvuFtijrmDjPvUG/ 5M60jI6pX4q/
aZtd8G4PbF2Nd0MYU1NouNqleHcd8bNa6A22caC9fRAzstYo6qnx6YO/x3Us PxPm37ufgey4
1eNS6FbbKVGGT+nbyh+OQmxhgsVil4LRTCFgHKHHsdRQtXlo24hTigPTmTZj Hz/N/yk22niX
Y2Xx6Sm4kbgK0ktfQ9zQlV47bVPr+7y9DO/2RDQdd8RiY3sIBkRLZUoVzNTe +whlX0r78G5c
R1b3M4Dplg+pr+yzwLup00W4jrc+GaAvILbneLcu+Xm8u7sEEzENvFvSDHmf Q1p3Ts63/RaI
vuXfQWdQeShvQgicTrRkJVRtcs9NxRNn72TAqPXJZ4dKXqhrI2ARxWEKtk/M NoW7gATrdJBT
E89kmUhaE7+v4/HeFAc03v3z+1WytsV8iFzaT40zYVym3ExSWpQliXvPq/Fu zbeyMZaW9nm1
tsrRp8yO4rKcKj9NcM4mX1VXMcwxzJdNzPyxbdFFxAyCV/K7ZZQCW6bdxnAY BjY1CbRkwSk5
FvO3PI5XjqaZh9jewV679jO0wYkFbArrhoEoqoS4HybbMom/Gw55P0X83feR BUGWg0Rp1z+E
YbI3KXxQJtuViJuDDy5wgk1veOAfXxKL6cUoxpr4KXLYNo+u+8j2lWAb75Iz i3mvQluUGtJp
vItqRqIymZQd85K7h3dpSgZ/Vycj+fdQI0FS65Oj+fQhFVNW9K345EsvxIGx ImxXGaKsRjDT
BL4mQ9rEb1NRf3uWA+b9DCAoclCyeE7iG42n6u4w/NCvdUxd5hWVNn3hIZvT jF9CFOdJWf0W
HMYCy7Xb1JO7fBRhC5hpazbj6o2LvWWORQcy+t2aWzSKnHNA+4G8CZBym7NI m38VytfGkl4O
8TTMoNxHxm52My7Cm9XlWzboPK+GHyA0OBGrMupmeSSSh/63gCimTtI5YPw1 Y+UtBbWe6FX1
Jqxl5XoSOt+E07id7d+p2aaLVHSKYjTrrinK4/kwms/e/604sMmKbzVTJ9Y5 cEEOrDfAjRFt
Y+jZ+PoFJTGMpKvj3ZQh4zmGYcy4bcfrDdXMeYzhw9VF6V5jjNy9104ObLLi zjG8mXPAOVDh
wFID3C2ibQw9G19/J30IeHcSs//nHHAOOAecA84B54BzwDngHHgkBzbnd99p cXDZuS5dmF52
Ik6Yc+BtOeBW/Lai94lfgQNugFeQwlAaHO8OZe9BnbuhHsRoH8Y5MIwDbsXD WOsdOwfmOeAG
OM+jm7dYhXd9v8jFpL7YUMdJcFzPe/H8+hTuNdPL9uMisESz2IovK18nzDlw Qw4caoCH+cDD
BrqDxLvvI6OT0bdH3WGqD6ax6z6yERLUN6Gss67Zt/gNPngV9Aqhzo61ok/z FT2QcQ9Rx2CH
Eaw1RPxCbl66lggYYxt1yDq4fV4TK9zCpVT/hMrS8q/zaa0WMe+O8JDeXd2+ j4xdXDU1DUTq
u8bwWslaz1Y/SJ58GqqI8Wv+4uVcZjPKt3DASF/jpbXavPyr9iO9jizdMMh+ UfdDpXrI4q2/
Wu2W3UfGplbuycq1l9sHvumlWqBj5o/nmcYxI5+Adw/w7QcMcYx49hils96E 8ox+Fe4e3N+r
DwPvtgW0lw3QfkSNhr3mlvqhA8VosR5v7TX32QmaePcuhtMm/moikOrRh/Bm JXhsAyPc/ryK
npdaWZSk5lO7pkNjRthbrrbQW2+i9JkqHRjjBvDEJNKmjVRrM8gNT6dSLL9e r1Q8TDgHSozR
7EMWNjMdyyK8O1vSYiJJcKDDBUkWmSTJyZZq5JzbRlWg8qJZWsLrTRxh9x06 sA8Zhw20D7lj
e+nHu5hLkFclB9dTlpBQEib9ADVd83Mr9YKLXbw5/ytcQ6aqANwFK4wVmdF7 H94dIEFmS7EG
ZvpFRBGpBlaWpbwVRR/vuI+6lP9q7h6Vp1TORF9fanLqNpIeUDyuyWHQ/Mvr J9/iTi72T2Ri
xU5OOdz6biSixLzYi4FaAAeSpZZdCKsprBtNPEhkqAgSmqHeI46LfNDLoZBf 1LVsSLUh2zW1
ynaQ4YgRTfopaKMpxuXOqpleojVptQfQT1VBWvqS1jHWZa3qb0+fRpvvT+H2 e/qp+NBEedI9
uPTUXJuVZt+/P1JSOSDIVClJsIL+ot0X4OkeEFwF35wDBgRBdxFdn2JRHe9O 8DTnceNEFLdF
FUyqwNYiCqoQHx7FTh/QMMAt4EQ5B1qKa08QRVw9xk0cvQuG4beRanAshkNs pN8xni7cREDH
foYw/2YpPKhCmVaxxJl+f05RpOnd4scvWTgRsQ4p3OrLlLrKzOxnGCdBIpRc t7CKd5uihLdA
9LQ6uRFFklKZwbUA5RwOa5HDVLwSllCT4y/h/5Z/iCL1DcrtMEw+ZCaIr6YM qZ0wLpQSpS3b
VgOJdqB5L+IZVjhEBFrEjA/Wcgg1xxJ9gcLFNXWUZUZ3JMqxzva/zMlX8G5C QrWMde0pRcAG
VpY6ZkBA3UOrz5KUNd9CnS/VevmKjow+n9xN+wEytoviU4aWO8m/V9bhxkop oGJctIvFdg3v
0p0JxaLpFonopjgHKBaBrFAaDuvBqkUv2wKRQUwGu+gh1VjMeao4rvWKrYWW KfDdWysD3AJO
dGwaBqKCyHjkIgGiWEfvInOIY7yMZvTldxtLW/Zo4unE92RyOsWS03ZsGxp9 na7dtTNyvLsI
7/anMbZI0FxEmvldIWi+3y7XPLTa5ElL6ZewxGJAVLmS9cl5DhFaahloWdQ+ ajIU+4XRCbpl
Ic2k3MS7DblAez2FWso8BTNBvFhyjCL+KBEIEZt+QOth5gx9OS2QuGsCccyy US+6tGqJ/hd6
+bn8bmNfcnK8dLwZvCvNBF+FrpbgXQRJzbdyszptBGxBwomX4+ZpeKHqEDV4 PfBUF4AiY+w8
7HmgGd/leHd+PwOHGtLVEKkhcFEsMkNwzEOxv7CzmUZei10CxwstfeM42/pM uhSc1OKOuYja
EoKlX+KRC54azkq4i6GOcaErHNZ8BN5NxJbQ0rYfARSEL6BJvje2w1npz+9n MN2lES1o4OyQ
YA3SafzXFqWmxPbvhRNmnMsPpxgQkQ18lzEDUlvxgvY28W4PbF2Nd0MYU1PQ LKXRXT8VMJc6
vl2IP1gEnUGaAKb6tkVLsdfhXXvTAkfVs9ZbGrSPy2BG1upQPW2mc0IPXMdy n8L8CXIyP2sU
SkhSVo9LoVttp0QZPu4ArjEMRyHaPiFXsUvBaAZaMWuSNQAtFpyd1oRchWRt 5AAspNlUaf5P
sbHtDxH0aG6T/Lecvl4mpcB91xOf3aZmN1yGd3siGh1nUAjux7vzO6xGO8aN 8tnh9T68297P
AHwsH1Jf2WeBd1OnizAsBRbL/QwoGGJ7jnfr4p7Hu7tLEMBWDU2WNEPe50Dd aD9KtlEO6Awq
D+VNCIFT2iYroWqTR28qnjh7J7Fjrc9IBW08e3CkgmLZFOxlSceHeIH41cQz 00waKHA0ZH2U
COiHuZrKCY+PZ4MMMdVcU9DStHVE6C3TVb2fQe4y5/0vc9Aa7/75/SpZ2+IJ GYWtp8aZMC5T
bibpQwEDOr3n1Xi35lvZGEtL+7yaVjkBF2jmksUIch6gveCZwbtUq5EVWTc4 EESFmc/vhq3D
jANWLCujIPSvh0VjCwfd4yG4TRZ+QoHTjRa4VSZ+y7Z/XKbK92zdtZ+hDU4s YFOY0dzPsAVE
UXXC/TDkxEJerNZh2N+vsY7xMvrQsX8XTuSUDydyqzXZmxT3KqRVQvgjhld+ ghhsbHhQR0am
zujFKPMLlMvw9VhCuu4jC6aY/3aQYBvvkoM7ea9CW5Qa0unVMKoZicpkUnjT kAicog3Do2SP
DW3Gv4cyCIsKTFS6AlvTh1T+QZZ+fuSZHtGJiO5VhrQOWoVcmQTr9JRVBApr iD9KBIl+4JlO
s1l6GKM4nF+knqfhmnLUl1+663qYv49T2rTrW+IHzPsZoHtyUFJecZU/1mde 0X2fRL3l07IT
BqJxYBqxsbBcBHbV+4wLaZ6U1W/BZ3dQG7tNPbnLRxFCwUxbs5lYF4HmLHMs OpDVLRqlzznA
XE3wEGUTIJUXZ5HWwyrOro0lz38jnoYZlPvI2M1uxkV4S9T6Pm07z6vhBwgN TsRyizkH5sp2
CMEwlo5cJNpi/NWxkqPzCmbbxTFeRQlW1ZsQy+5jYCicxr0K6y5Ex6aLA61k w9i5XVOUx/Nh
LJdv2Pt7i2CTFd9Q2k6yc+BSHFhvgBsj2ka/t/H1S8lgMDFXx7spQxb/aieU B3PoDt2vN1Qz
5zFmylcXpXuNMXJf0Ot7i2CTFS/gsjd1DjgHDA4sNcDdItpGv7fx9XfShYB3 JzH7f84B54Bz
wDngHHAOOAecA86BR3Jgc373nRYHl53r0oXpZSfihDkH3pYDbsVvK3qf+BU4 4AZ4BSkMpcHx
7lD2HtS5G+pBjPZhnAPDOOBWPIy13rFzYJ4DboDzPLp5i1V41/eLXEzqiw3V JXgxCTo5zoHF
VuwsO5IDb+szyy0ErMD7kZw/aqxDDfAYdUqjHDPWUWLaMk73fWR0EGfiFpYP eLfrPrIREjRv
QmlPsN/2zJZkxFw1nlwHhHc20esMsR7sANZ7l86BnThghVu8QC1cDyz/Op/2 nfQVlhXGmr+P
jF1cNVliIFK/hddK0lux6Slkqx+crXwaqoilsfJfODnESzZmrxDalPu59AVe wnUgByyO9Tku
SmqjdgaTJO050EBvbeuWHasUaPYQ+cCaqbPgtg6Uq/0oA1d4/rqZrGHaTkZH uzkB7/Yp1fq5
OlTjvOusN8FfGi2k9eJ90zcNvNu+JG4vCdJ+aL2ZXeRgEMnrP6UCAdyD06qh +gr9XejyTpwD
IzhghNufV0mqpdo9fNjmU7umQ4Nu7C1bWW+9CQI6J4RnjIsVQBCesmIKnCpS rc0gNzwNRYBf
L2BIcAIfvCxwROu0Wpt2JsJ1iOIseuQOn1lq66SXA+7vg7xYFG3qYZqLsW6f UbiOHgL9gmml
kLIqUhCIT8uJgGute/H38/xrmba/CZ6Ad/efhAXVOlR3NCEX6b8f72IuQV6V HKyo3Bn2E+aF
yzV5Ob9VqFCsqqNsvsI1ZPJ+bFybXoR5lyGjD+8OkCAzpOhzq+KL0kyfxqpa QSj8wdLwJGag
W8+8F5ZMl7MsU3IZUTkhzoEKB5rhVmk+60Q/Jb+YUA+vd9Tv1qr+9vRptPn+ FG6/p58KjxL8
ijP6nqBhrKEYEPZvsu5NrwJQg//bKIQG96eq9TMmofMj9EtY5iMTS1fjhYY8 KPVsBAcXHwUs
ChXOfkptyPwP1X4qR6zE1+whB+W0GsEiUKxUWCxgLi/9JB8QwG8b/IQXSXvT yTOhpLcaTDva
UxgGuAWc4Lu6zErRWAxYm0BUHXHxikIh/r5pseikTB37GYLiNkvhAQfTOp7o dKxP2PRupF4o
KekJhe+C/Sxf7B5tJ6ePN7OfYZwESXjIy/Ro5CUpheLDapn5Fa0VstYly90W FucrD+FTpozl
gLmnL55vbdin66QTsJQDFbybAFbtu3btKcUuBlaGLGxYgoqdEtpCsw9v9VmA lG7DMFP0DD39
2MzLo1AK6RKXvCSTxDbohw/6xVdgM+W7RA/6c5aRRUsztTxb/h2LvkYY+ufr c4q2368IFlFG
OaRijl+LLySGGz0EGuJYQLZ23XHE8Ef1AZqZmYXI8JKgJdOsOnkyqaR4VaYt tZ4d2isDtHTA
im4zsyArJdwDXUvNrABRBuLiqAnGevsiBn35XVPXDUeT1mrJwRUHjascq2yE XE/ntXsu2See
HlPIbQfDObqL+fzuIAlS4eoPglq4Ke+SdtCTzXN5mdRIwAiOpjyx4S4L3p30 8PfLPwgcrYg+
3gYOzOV3G+s3lSRrYspAY4G5VvI1DWQiV1pYmEBwjLjNt3KzOt4lkRsLO8ck bviDp8WxJHzG
tjCJliCO8oqsFw3thfuaDUxlOW13mMeF5XfZOVDoSW+xSuPJm+UNxwklI4dl ey2+9G6tB5xO
URXtuoFX4F3BXdN/IIeLB8ccNgn6ppPXindlvDurA3QrXXN3uBHgBN5lufaF ICrvmOfMp4qd
Zd23F3yDB7v+qyPwbpp1Qb2GQhO2tFWKrqHb/Vyf0yMp3BvvdktQC6W2RBGx qv2iCEI266xY
wtdgmFQeyXzv2zmwCwfa2wcxpWcNpp62v6pNXSQ4lVOJpUuKm3UP1T5JMrX5 Vs4y9vRjTNL4
Fq8QcPZcdOduzZkwF1RIgh9bgUnlaxHd8jUJd0dsShFTyp1aZQv1n9+vkDai EEq21+KLU6j0
IA785ZO+rfxRkyEa/uaIr/CuMYSgXC3Vzgv0rTCaNI3S1gYnswFuBu92h2DU KgtxkVGm/T/W
mdddXNdtOunDu+39DPQsfFzVvfKKHPaBwQfuwhfwU+Z+BrnWiW+dZwbXF+Y8 3t1dgr1RJIve
2s8gtKL21Y+vjsROBhm0RLIn9Nl3ZOT6QnYKH84BjXcj7oHIV47Jl09n7afG uTH0uqHPySRf
08Evlj1lcK33vBrv1nwL94xG4u2zdLwfKWz6dHaZrb/btrcfGF/5q/sZGqvo ytErjY8TmmRQ
b0q0TyfVsrinnbvTCTwQDe4nQQFJ8QWu1nrgBKTJmjzU+8TMBYAdjs39DCr0 K8W78Hm19p4W
Ij7Kpax7+G7R5Oam0C0gykBcuE+Gyrp9EvTh7jVOr2P/bvpwk1Pi8ftROhwA Swf8MJ2Wd2md
Ef6Im+PfPoTzyg+tc6Dl8j885/QOYlk4x677yPaVYBfepWqjvrYQetQJtuwl 0/dK4vfpYRGp
lrgTX4Fgh7wLFcqbn8AB834GcK54jAHAHPGNxlN9L5gAlAr+0h1G0WTAk9Nt DGJbml5S6rfA
bPXBHei5vTTlT1t4V/QDxKjdINT/yLPR4qg0DUwY3cxN1TSTyjZrFua+fggS IjdXMNgXadOn
IOJ5X7pRkH2hrvYg2RWB2nToTSZflXeluFawy0w/NV06vwpNUY78OcH00pCd 59XK9hq8ZQ/B
iQ1s9BHtfUGUQlzFM8SbTOjaJrR852i4qt4EVcjD0q76XMVpdnG5gTddpHKY BBPbdr+27HLS
cIKcA2s4sMmK1wzo7zgHxnDg4Jiy0yTWG+BGcHJPdu3E9UO7uTrezSdG6QG4 Q/lzj8HWGypd
wQ+fa1qG+rUJwxntA9yRA5us+I4TdpqfyoF7ArilBrgbOLknu+6ovAHvTmL2 /5wDzgHngHPA
OeAccA44B5wDj+TA5vzuHUH+42heujB9HAN8Qs6B23PArfj2IvQJ3JkDboB3 ll4X7Y53u9h0
8UZuqBcXkJPnHJjlgFvxLIu8gXNgHAfcAMfx9iI9r8K7vt3kItIrZCw2VJfg xSTo5DgHFlux
s+wsDhzvP8uJe7zz4ay5P3fcQw3weBV6ruD6Z9Z9HxntEm4i84Jn/Zwe2bLr PrIREmSX1PCD
aPQiuVT4R95bN5Ij3rdz4G4csMItuf1KVP0Ns+t82ldXiVhoubFo/j4yUcgg Xmiv38Kbm2o9
W/0Q+SFt9dOus22YCyoHZ8Vb8f+yO4mNOmHmZV5c28x+tMjo/WKsoJ3QXXXV K0VLYSx60Zu4
TE3fClpucqThG2K68NLVicQywuLi0btZnKD3BLzrqPdYnemsN6GM2ZHusXJq j2bg3baA9jIz
6XZzZI2uEKPs92e9Ms2V2Oi0OAdO5IARbku5rFgOTUG95lO7pkNjethbRle9 9SZKn+k2e2Nc
huoi6PtUZWgIYepWfDL36m2GHW0Mp6feCm1eL2B1LbMz6z/NfqY5KpHBZEP9 iJ+KeALoFIsW
rFE3vTgVp8ALmIPnp5Usvl+5RjEWszDqTeiZYlkKxZBYM4JUa//z9SkLJp9o R6uHPgHvrqbV
X1zFgX68i7kEWW8iOIhSMSJaLK78oCh5KUBRygWZa3e81vsrFBqQ61RiYKvm +tyX+vDuAAky
vw8u2IrNdsvnisRn5hxYyIFmuEV8Y/Wqn5JfNDhj+Em/C3UxRY2Ynj6NNlPd L+72e/qhsyT+
JM+FlqpK2E63ocVurIxmjFS4iqCAD65TbeFdiHqkllUKc3DDv+iHSQ6YUKv+ AK1phYvSf6ym
lrgasglTPbZUjC3/oybT2Kc5KePH2En6XU6E4umFWn7h5oYBYvp/OTgxPjgM CMFFoAiZyGef
CNUkPLuwBIaT1rGfIWDWZik8+JiS1vHEmQZTpJ9pjGUxFpvJdRqjlhilZWaX 1MN5dd0BZvYz
jJMgFQqtyanreZKWPDdwXa46Zc6BIzlQwbup6lVtT0LtKUU8BlaGDGuo/yJ2 SmRT1T20+ix5
SvMt8o08JER6+hGMB6BAkpSJbKRftFGoGvEHokay+4Jh4swf4yt/gbMl6mVv JqJecXesnzwn
KbKYHmreSi4+o8UsUkjrBoybcqvfr/gjiDVfDcsky/kjuEFheqQT50V7ri0A jrSTYWMpA9wC
TvSibhiIYpBJjSLg2TDu3aLjvvyuwJpU6WXebrLbZFe07CEtVMkdt7BkWFAm 5ll2fgu2Hkzk
fH53kASp04QdFObKxGx5MJt8OOfAhTkwl99tQCKdb5vBuwATreRrGmgJ3kW0 13wrN6vTRlAj
fCQkeyQiUswYLndCEV7MkpQ2Es/xLVVFDcrr5C34JglpWu3QdNjKSTWrajor 6Ar6R0QW8kSL
8W4IjulcRN6uMA09zYKH13SIInKsOlMaarWXhpnaQb+UIH7E/sZWGE2aWQMk poZQ1CPeBWxj
rB+SYmwAUXpbdla6Z2blF3n0EXg3EVAEZqIfoLGNd+lurXY/iyb9uMZ7491u CVJviCkoy65c
fI/TOp/Qvhxobx/EjKw1qnqq00vitYSNcl4Q4F+MtWD+vfsZyI5bPS5Ft7Wd EiUgxx3Acn7M
deAOhDjl0rlu8xM/xNO+2rA17W0gb4UNteFz8NefLrxb9ZnYD59YEVmcQrvK ug2z8ovpW+if
368AkgzcGZvN8scAXpFc8iKZCPfwT/Hty/BuG5zMKBvfVcIaU96uAlGOd+t+ uQ/vtvczAH/L
DvdX9lng3WB/QiGE5QP42YWa7J9iVPvGyNTbPN7dXYJpYCoUcipl5rzaCBZ4 n86Bm3NA490I
YgBIlQ/uZWHZfmqcCUOvmxDSx+uz7PtMtsyzjL3n1Xi35lsZxZaW9nk13g8R Jn5WjkSyL4f0
wgc8sxXakLe0syoAO+zAS6fEdAIvpWzm8C5sw2NRj6Ht0k9GpUyg5Zga/wwt NLmSVpxy89NJ
tawh087dX2mHQ5wL7GTI7yoeinjagXdzDqvspsDjNE8JzV37GRBNEmBq5H2U +u0egsEW5GKG
wC0RoB+Rht/i5jv27yYnGJhbDqXRVS/5vexhSIuS8EfcXPkJT7DpDQ+4JRzX 5fRaq7eXVk3S
XfeR7StBK4TQjWjsgqH03c3Ft8VS/d2nc8C8nwE+inIwF3lBfKPxVN8LJgCl gr/0A2x03eDJ
4Su5/iUANZ6UtdukgEDgexoNetb9EHmj76Lf/fm5WN2GxibzWjEW16wzbXBH Afs2HdPA8Et2
azzqCXcHuUAhMpEjrO3SruBddhAiTraceynbDCjPBX/W4N2ocsWNv8V9ZMi0 PnCi1mNZTeTB
/X/koX+yxT1uS18CorQoKVSTPT/djTbnt6reBO3xMByjz1W8teDY5DddpHKY BF1ezgHnQJ0D
m6z4DRnb3gPwVIa856wPkeZ6A9wITsaF4HE9HyKR3Qe5Ot7N50xZJmB3Jty+ w/WGmj5+eeb1
9irgE7g9BzZZ8e1nv3gC7Q3Ni7u7yguY2IOvpDwp3jzZdpVZ3JKOpQa4GzgZ F4LH9XxLCf8b
8O4kZv/POeAccA44B5wDzgHngHPAOfBIDmzO794T5j+M6qUL04dN36fjHHgA B9yKHyBEn8J9
OeAGeF/ZdVLueLeTUZdu5oZ6afE4cc6BDg64FXcwyZs4B0ZxwA1wFGcv0+8q vOubQi4jv0TI
YkO9uAQvTt7E8etTeDEVdXJmObDYimd79AaDOHC8+ZeLHcoNDIMm9tbdHmqA x6vQW8s2T777
PjLKrCQqF9hlFKjrPrIREmS30fGDFPQiuXQfWe1iFP1onWrNvsUGUndCL5Lm 7FiLeksAGvnj
R1KWsu8J7a1wS04viaq/YcadT2u1iDnTiAbSS235rWHyrjF27eDUNBCp7yPD q9NqPVv9EPLE
XVqmtGfbcPPPl6PpW7rgGk1Y1uoXdTELQVJ8Ba9pQ3fBRUbuLOcF7UR36qpX 6n/CWKpKiJam
nqkuTGC6YnsiseCwuHj05lZ4At7dPY7cXASjye+sN6E8o5/oHy2ZJf0beLct oL3MTLrdHFln
6k2IK3VoJ3Dh5QgFk9RugLx7MRCkXOHkEi3wtvfmgHn/LrlRVa2Cfl6Np3ZN hwaHsLeMrnrr
TZQ+U5U1Y1yG6iJOD6XRwj9ysQZOFanWlh6Qe3art3F1tDFsVr0V2rxeUMSh ltmZNX+zn2kq
SmQw2VJ4wpJQgKFi0YJV66YXp0oTeAFz8Jy8RlcuOIyVKYwiGnqm6IoVQ5Lg 0EX/+frkpezu
aYgn4N17Muq+VPfjXVyYyquSg4MopSjAi6Uf5DXLVuIK15R4pfPXZ7mKnK44 R2Cg+4qOUN6H
dwdIkPl9cMH8HvhEp92y8kg7X3i9oQ/krag/8RK7VDzJoIGQZOR46AX7RS1z l/xeekN7pTmQ
3C2+ixre5o+gLUUa27jUjeiSIWlSRA0m5sz2/wgDucUkmuEW8Y01F/2U/KLB GcNP+t1a1d+e
Po02UxmwcqNWor2nHzpL4k/yXGg1soTtdBul2228S30OXKfawrtg5nl2zDDT i6IfJjlgQqS/
lTBWN5TFOAhc/f4M5YhzLjn/oyZT4m8FN4yZxk7siVA8fQvb6iLSMMAt4ES5 VuZ7RdGuLSAq
yogEFBHoVTwizBgdTbr4fmCjjv0Mwbp4tUNqG0GoZOGYLKQsRoMptr0bqfoI hRlJnZggOb5y
PZA39xlqZj/DOAlSpwmpFyMbIeuwk9yA9aiKd5v6AG+BzjQSyRh3zQhdtC5H LNUmTxzpIdrL
zUHrf/SDch+eyUn73YzFi3HVy3FrhghDnu//PjZwf0oreDfVyqrtSag9pYjH wMp4ea2+Kh91
W6z6Wn2WPKVuw+BaVPuefoQ4oRNiXGmDB9Iv2lg2S8ukybpobB2b+UMsCF/N pdoIzM2/EMMs
5sz6yXOSIqNlKW0tps6h/DukdUMNvJRb/X5lEJy9Qb4alu2B4fxBNFZmxvco 5gyuORFj5XB/
8zOOwZjuHVx3G5zosDIMRLGAokYR8IwKyoBqu0aT6ylFX363sRZkj9KyL9mV LhecM27RS5U/
YcmwoEzPLTu/Hg/Pp2g+vztIgtRpQvbd9IZmS5AyBBP4ICA2iFcRMOY7Pz6n CvJ8W7k5axRX
SWDQKJj0tgTRnESRsaGkPdram74q0tKjyS76+aPHzdlZYlyU7ab5NIxotv/z VfuNKJjL7zZ2
det82wzelRrOjCINZCJX9d0DTRi+HtRRco6vddpIAIbME9kjEZFixnC5EwDu 5R+lTc1muUIZ
b2kXpA1WG37NMLXjygQQkYX9Hs0t+6YJTz+mcxF5u8LE9mnufF2UDlFEjlVn SkOt9tIwNJ0I
0lMKFz/i02srjCbNrPlSU0NEWBkUgtswyYBn1AAUVNs5mlzOe4/Au2mShZVm dO/Eu6K8+COM
aoQK7I13uyVIvSGmoKyvXQ01qIUT7Vza+lDHxJnnDY8jpZIiR86aGLcxmGNJ LFvwrtDbGt7F
zT8WnGUUWsZV88htvGvbFPeDI1TW+1QcaG8fbJcTU0+NrxZ8QK7hGoQZ3+Wq fZIdt7oNRbe1
nRJl+LgDWDKG2QvuW4hTLp3rNnqHQBu2pl3C5K2woZZ+dKZkGXi36jOxHxtq xym0qwTbJpxf
LDuhXyHTZJhzWdXT7bZ8poGuGi4nQ5OJcA/fDvH3sfRleLcnGNV0RjC8ikpX gSh9DNGwbgv1
aq3WircmmlxIA/rwbns/A/C37HB/ZZ8F3s36epvhkfXJAAVG7OopRjVC+PN4 d3cJpmlQoZBT
KTPn1QQLGni3YOhyPKKpD8vwLige+SxFCAvOfUoYZ01WbTLNTe3NDrH2LueC zUnj3ZpxkQ0V
5NSgSHgb+xnkFmfe/wht9T5tDmi8++f3BGIASJUP7mgUrafGmbC0IiqDcw1P u11ZlrH3vBrv
1nwr21FpaZ9X4/0QHhEroG3CvwEf6zY9dqfeksgjHkFpAmWwO2Y4DG1H1BKD mhZoOabGP0M3
PCQhZvr6NJ1Uyxoy7dz9lXY4RFHCTgblqaKg1VemDrybc1h5IuS82lNCszLA 5eAE9VOHleZ+
hi0givHfGiWpk95w+PdrbDS5nqfv2L+bnGB0LnlHgthqjXl7eSCGuDmySSgZ pLHhQR24SUIS
H7uvx8TTKeq6j2xfCWq8m49SqdMb6YNawyfWwwl+00x7Fdr60IN3UZlIaCec wY3FIvqKNkAz
/i6OtVW29JjhU6wcKCclbWnFH/6UcdHLMWIDvcEjm14xZHZeLYVk1f/pyv02 BJj3M4DC4jEG
8JzENxpP9b1ghkoz+Es/wEbtAmWgWxTEtrQQX3lSVr9Vvnqza7Nm+yGCRyug iJyfi9VttM2y
T8wirvFzqBQi0H6iYbFNSnIfcOSG8GkANYTIRI6wtkub9kb+zS5JiESS+zpg qoVjgj+Cwi68
SzATPThLLyy7s7V2nlfDDxAanNjARh/c/0ce+t8CorQoKVSTPVP0NTqaXE4b VtWboLM4bG2n
z1VcjpmnEbTpIpXDJLgve66pDzdl5r6i8d5WcWCTFa8a8d4vtfcA3Htuderf c9aHSHO9AW4M
RuOixrieD5HI7oNcHe/mc6ZhjdJ3a/ruHLpDh+sNVWUWLz7dq+uD+5eLK9CF ydtkxRee1yDS
2huaBw06vltMucGHHLKnJWaX/46n4i1HWGqAuwWjcVFjXM/31JCAdycx+3/O AeeAc8A54Bxw
DjgHnAPOgUdyYHN+954w/2FUL12YPmz6Ph3nwAM44Fb8ACH6FO7LATfA+8qu k3LHu52MunQz
N9RLi8eJcw50cMCtuINJ3sQ5MIoDboCjOHuZflfhXd8Uchn5JUKGGOpqKS96 cVHji7F9hpwH
T+1egrgJtUOs+CZzdzKdA6dz4FADPCU6lAslZHXP01l/FAHd95FRgmp3lxxF tI8jOGAaKpbG
XndfjDbIThOtX4+S7tFi5y2ELsG7nWMJtWT3DZ19wHHFFFyz35gDlhWT00us NmxiU+fTPkMg
t27Ra6ejSVXvI6NOJjQMROr7yPBaSX1DZX2sN1YFn/oZHDgB7x4aI3iVkDM4 fPqYnfUmOJ2H
Cul0Ft2AAG2o7GrGXGN94URWS9m82bE2+KLG7RmsJnghY3qbX42eXrq93Tkc MMLtz4vcqKoO
5jef2jUdGjPD3nJc7K03UfpMVdaMcUklmty2Y6xzZOCjvjEHTsC7R3Kb3g18 5LhXGqsf72Iu
QV6V/Ov1msqapzzAdIM9vYkaS6Sm59ZdKphXwHoTX58lqUCyDlgL4EocvAIt ylCtlVyEX8BY
kpiBi9a5HLF9kSwCOKIMP1PRIChFYt3ZbsI+IdbcBu6lZ7USIs2oXbT0CVOJ SkK6Z8qvnzw0
ubefaCzNOudcVylV39BeeCvEe79F6AqGcmkamuF2srhGmlY/Jb+YdsFStqLn WtXfnj6NNlMZ
sPoVWjMVhi8tMCfuWRwwDHALOMF3Qf8PAFG6tkUanXwLsmvIP0uWldl07GcI 3GmWwoNYntbx
ZBnx/Tl50qaXjGJAlJwKcWGdGF7v8Y3l1FZGaah1iGls3El3ZQe2Y2nKIsdS sKdUio5Fzuql
L6ErUcKbbjMoRbwQWdKSY2I/A1UGXZ5X54bFfgamS4SFYsqAR3GIggDyEFmH UwnWSHkqVd/U
3vSur6rfwpHuMMkK3k0rsRrYrT2lCNjAynh5rb4qn+t8nFjqodVnSu6Wlokb 8BaapfQ/1bF2
4Kd34RxYxAErbbQanGjYcwSIKoX9LNDl3xv//bcvv6uBBWAU9iilFdNKgiCG xq5K+npCBuIX
QE4urbrt1vFuyZjqMrZ2hhUCVayZKZgPAE4sPFpdxeqFur3Z8zS4xru1lrRx oro9UGoAqjgH
sonOBk1OOaqwfps6ScsDUSTZ1F6293GR7/XGb8eBufxuI0uqv+fM4N1Qpz1u CFbJV+hK91Dv
Exd1zbfk2q8x1ttJ3yd8OgdaaaOl4ITGmhQFDgNROclCURd+OcdiyKez+wwC RuBdwEyWmMUk
23hXlBf3/G5FRWb2M2icGqyR1FWXaDjGoU68O9PVHAwVtM3i3YZKzALr2pQb gxaGh8zuT8rp
xp0MaQNix2rte9rsYZw0OsPWfcxrc6C9fbBdTkw9bX9VmxiRNuQklYY/ipt1 D9U+S3I34Gfc
d2HkbtPuBbKoxn+LLyrXFpVT90QOLMO7bXDSk3xpJQ2XgChNiZkc9Ixhb363 vZ8BPGb56v0K
H7aSS83pXuMzVk4AW1+E0QUT/+vSqruYmfNqJt4tTM4n2yh72e6FOCrrwfou k+Q9YTszkSwX
KihW+QpkgKo011ViFu/WpizwLtmlgCz/+/X69ZHOkv/5/Zp2NcCmKLkbR32R IGjgiVHC57QT
BywrTmqWcGTZHF8+nU162HhqnBvj6dW0Oadcj5C+frAUcu95Nd6t+Ra5lqGk mubG2omp3o1z
oJcDXfsZ2uCEfegouwHz+M39DFtBFM9eVUKY/NDay5jntOvYv4t+thwb+l02 JsrMeVqjp/0M
8XhaAr40t5/kSl0kPrWy7uXGuNCd53critd1HxmHg1D7+2OKeaYcRfJSbAAo Ip7QntEVlZT8
shMts4gVRy+vpN7075hMranE3JK6SqfEu5bGAuCYRCDW08UsgvJrphWLQGDx HO/hM9mTA+b9
DPBVkpykLKlQYgjGU30vGAemzAnTQ8bousGTV+8ji0mN4uczM/RbcA41R2Vx i1nZ+Jvm2nd7
2p6M976cA4EDnefV8HuIjkQ2sNFnyP6Rh/7JFvc1IMqmpHQKoOvtEdSqehPU Og5Lu+pzFW6k
hQM7XKRymBx3lJqrxI7M9K7O5sAOVnz2FHx858B9ObDeADdGoh2D70ZK7iu8 PsqvjnchJ+fr
/oZA1xsqdLqjyfVp3upWrhKrWecvXpkDO1jxlafntDkHrs2BpQa4WyTaHHx3 o+TaAtpOXcC7
k5j9P+eAc8A54BxwDjgHnAPOAefAIzkg87v/8Z//97/+z//2/70XBybVdKk5 B5wDt+aAW/G9
vK5T+zAOTAb4sBkN9YfQ+fQP/d81Ofn/AWabpzrpgeZKAAAAAElFTkSuQmCC
name="plugins.txt"
filename="plugins.txt"
08/23/2007 03:23 PM <DIR> com.ibm.icu.source_3.6.1.v20070417
06/28/2007 07:33 PM 4,071,685 com.ibm.icu_3.6.1.v20070417.jar
06/28/2007 07:33 PM 180,376 com.jcraft.jsch_0.1.31.jar
08/23/2007 03:23 PM <DIR> javax.servlet.jsp.source_2.0.0.v200706191603
06/28/2007 07:33 PM 62,681 javax.servlet.jsp_2.0.0.v200706191603.jar
08/23/2007 03:23 PM <DIR> javax.servlet.source_2.4.0.v200706111738
06/28/2007 07:33 PM 107,606 javax.servlet_2.4.0.v200706111738.jar
08/23/2007 03:23 PM <DIR> org.apache.ant.source_1.7.0.v200706080842
08/23/2007 03:23 PM <DIR> org.apache.ant_1.7.0.v200706080842
01/28/2008 02:02 PM 483,619 org.apache.batik.bridge_1.6.0.v200706111724.jar
01/28/2008 02:02 PM 242,180 org.apache.batik.css_1.6.0.v200706111724.jar
01/28/2008 02:02 PM 430,788 org.apache.batik.dom.svg_1.6.0.v200706111724.jar
01/28/2008 02:02 PM 93,278 org.apache.batik.dom_1.6.0.v200706111724.jar
01/28/2008 02:02 PM 370,574 org.apache.batik.ext.awt_1.6.0.v200706111724.jar
01/28/2008 02:02 PM 53,124 org.apache.batik.extension_1.6.0.v200706111724.jar
01/28/2008 02:02 PM 44,430 org.apache.batik.parser_1.6.0.v200706111724.jar
01/28/2008 02:02 PM 488,209 org.apache.batik.pdf_1.6.0.v200706111329.jar
01/28/2008 02:02 PM 169,596 org.apache.batik.svggen_1.6.0.v200706111724.jar
01/28/2008 02:02 PM 144,562 org.apache.batik.swing_1.6.0.v200706111724.jar
01/28/2008 02:02 PM 68,766 org.apache.batik.transcoder_1.6.0.v200706111724.jar
01/28/2008 02:02 PM 144,096 org.apache.batik.util.gui_1.6.0.v200706111724.jar
01/28/2008 02:02 PM 88,032 org.apache.batik.util_1.6.0.v200706111724.jar
01/28/2008 02:02 PM 27,106 org.apache.batik.xml_1.6.0.v200706111724.jar
08/23/2007 03:23 PM <DIR> org.apache.commons.el.source_1.0.0.v200706111724
06/28/2007 07:33 PM 127,489 org.apache.commons.el_1.0.0.v200706111724.jar
08/23/2007 03:23 PM <DIR> org.apache.commons.logging.source_1.0.4.v200706111724
06/28/2007 07:33 PM 43,545 org.apache.commons.logging_1.0.4.v200706111724.jar
08/23/2007 03:23 PM <DIR> org.apache.jasper.source_5.5.17.v200706111724
06/28/2007 07:33 PM 1,721,077 org.apache.jasper_5.5.17.v200706111724.jar
01/28/2008 02:02 PM 387,876 org.apache.log4j_1.2.13.v200706111418.jar
08/23/2007 03:23 PM <DIR> org.apache.lucene.analysis.source_1.9.1.v200706181610
06/28/2007 07:33 PM 70,351 org.apache.lucene.analysis_1.9.1.v200706181610.jar
08/23/2007 03:23 PM <DIR> org.apache.lucene.source_1.9.1.v200706111724
06/28/2007 07:33 PM 444,151 org.apache.lucene_1.9.1.v200706111724.jar
06/28/2007 07:33 PM 1,488,708 org.apache.xerces_2.8.0.v200705301630.jar
06/28/2007 07:33 PM 78,348 org.apache.xml.resolver_1.1.0.v200705310020.jar
06/28/2007 07:33 PM 95,081 org.eclipse.ant.core_3.1.200.v20070522.jar
06/28/2007 07:33 PM 1,086,221 org.eclipse.ant.ui_3.2.100.v20070511.jar
06/28/2007 07:33 PM 670,079 org.eclipse.compare_3.3.0.I20070606.jar
06/28/2007 07:33 PM 5,057 org.eclipse.core.boot_3.1.100.v20060603.jar
06/28/2007 07:33 PM 103,384 org.eclipse.core.commands_3.3.0.I20070605-0010.jar
06/28/2007 07:33 PM 82,727 org.eclipse.core.contenttype_3.2.100.v20070319.jar
06/28/2007 07:33 PM 38,146 org.eclipse.core.databinding.beans_1.0.0.I20070606-0010.jar
06/28/2007 07:33 PM 249,670 org.eclipse.core.databinding_1.0.0.I20070606-0010.jar
06/28/2007 07:33 PM 81,798 org.eclipse.core.expressions_3.3.0.v20070606-0010.jar
06/28/2007 07:33 PM 110,081 org.eclipse.core.filebuffers_3.3.0.v20070606-0010.jar
06/28/2007 07:33 PM 17,003 org.eclipse.core.filesystem.win32.x86_1.1.0.v20070510.jar
06/28/2007 07:33 PM 43,130 org.eclipse.core.filesystem_1.1.0.v20070606.jar
06/28/2007 07:33 PM 81,726 org.eclipse.core.jobs_3.3.0.v20070423.jar
06/28/2007 07:33 PM 31,097 org.eclipse.core.net_1.0.0.I20070531.jar
06/28/2007 07:33 PM 120,994 org.eclipse.core.resources.compatibility_3.2.100.v20070502.j ar
06/28/2007 07:33 PM 32,197 org.eclipse.core.resources.win32_3.3.0.v20070226.jar
06/28/2007 07:33 PM 678,655 org.eclipse.core.resources_3.3.0.v20070604.jar
06/28/2007 07:33 PM 21,261 org.eclipse.core.runtime.compatibility.auth_3.2.100.v2007050 2.jar
08/23/2007 03:23 PM <DIR> org.eclipse.core.runtime.compatibility.registry_3.2.100.v200 70316
06/28/2007 07:33 PM 91,248 org.eclipse.core.runtime.compatibility_3.1.200.v20070502.jar
06/28/2007 07:33 PM 73,300 org.eclipse.core.runtime_3.3.100.v20070530.jar
06/28/2007 07:33 PM 30,803 org.eclipse.core.variables_3.2.0.v20070426.jar
08/23/2007 03:23 PM <DIR> org.eclipse.cvs.source_1.0.0.v20070606-7C79_79EI99g_Y9e
06/28/2007 07:33 PM 12,929 org.eclipse.cvs_1.0.0.v20070606.jar
06/28/2007 07:33 PM 298,297 org.eclipse.debug.core_3.3.0.v20070607-1800.jar
06/28/2007 07:33 PM 2,144,097 org.eclipse.debug.ui_3.3.0.v20070607-1800.jar
06/28/2007 07:33 PM 515,486 org.eclipse.draw2d_3.2.100.v20070529.jar
06/28/2007 07:33 PM 106,420 org.eclipse.emf.common.ui_2.3.0.v200706262000.jar
06/28/2007 07:33 PM 175,511 org.eclipse.emf.common_2.3.0.v200706262000.jar
06/28/2007 07:33 PM 22,858 org.eclipse.emf.ecore.change.edit_2.3.0.v200706262000.jar
06/28/2007 07:33 PM 75,797 org.eclipse.emf.ecore.change_2.3.0.v200706262000.jar
06/28/2007 07:33 PM 104,843 org.eclipse.emf.ecore.edit_2.3.0.v200706262000.jar
06/28/2007 07:33 PM 188,933 org.eclipse.emf.ecore.xmi_2.3.0.v200706262000.jar
06/28/2007 07:33 PM 900,353 org.eclipse.emf.ecore_2.3.0.v200706262000.jar
06/28/2007 07:33 PM 131,695 org.eclipse.emf.edit.ui_2.3.0.v200706262000.jar
06/28/2007 07:33 PM 229,756 org.eclipse.emf.edit_2.3.0.v200706262000.jar
06/28/2007 07:33 PM 73,522 org.eclipse.equinox.app_1.0.0.v20070606.jar
06/28/2007 07:33 PM 92,736 org.eclipse.equinox.common_3.3.0.v20070426.jar
06/28/2007 07:33 PM 17,760 org.eclipse.equinox.http.jetty_1.0.0.v20070607.jar
06/28/2007 07:33 PM 35,606 org.eclipse.equinox.http.registry_1.0.0.v20070608.jar
06/28/2007 07:33 PM 34,270 org.eclipse.equinox.http.servlet_1.0.0.v20070606.jar
06/28/2007 07:33 PM 9,445 org.eclipse.equinox.jsp.jasper.registry_1.0.0.v20070607.jar
06/28/2007 07:33 PM 21,742 org.eclipse.equinox.jsp.jasper_1.0.0.v20070607.jar
08/23/2007 03:23 PM <DIR> org.eclipse.equinox.launcher.win32.win32.x86_1.0.0.v20070523
06/28/2007 07:33 PM 42,719 org.eclipse.equinox.launcher_1.0.0.v20070606.jar
06/28/2007 07:33 PM 103,444 org.eclipse.equinox.preferences_3.2.100.v20070522.jar
06/28/2007 07:33 PM 160,885 org.eclipse.equinox.registry_3.3.0.v20070522.jar
06/28/2007 07:33 PM 788,743 org.eclipse.gef_3.2.100.v20070620.jar
06/28/2007 07:33 PM 16,772 org.eclipse.help.appserver_3.1.200.v20070510.jar
06/28/2007 07:33 PM 319,558 org.eclipse.help.base_3.3.0.v20070606.jar
06/28/2007 07:33 PM 429,029 org.eclipse.help.ui_3.3.0.v20070530.jar
06/28/2007 07:33 PM 457,952 org.eclipse.help.webapp_3.3.0.v20070607.jar
06/28/2007 07:33 PM 140,769 org.eclipse.help_3.3.0.v20070524.jar
01/28/2008 02:03 PM <DIR> org.eclipse.hyades.analysis.engine_4.3.201.v200709261752
01/28/2008 02:02 PM 35,889 org.eclipse.hyades.execution.correlation_4.1.301.v2007092617 52.jar
01/28/2008 02:02 PM 39,446 org.eclipse.hyades.execution.trace_4.1.201.v200709261752.jar
01/28/2008 02:03 PM <DIR> org.eclipse.hyades.execution_4.4.1.v200709261752
01/28/2008 02:03 PM <DIR> org.eclipse.hyades.logging.core.sample_4.1.201.v200709261752
01/28/2008 02:03 PM <DIR> org.eclipse.hyades.logging.core_4.3.101.v200709261752
01/28/2008 02:03 PM 194,791 org.eclipse.hyades.probekit.doc.user_4.2.101.v200709261752.j ar
01/28/2008 02:03 PM 371,964 org.eclipse.hyades.probekit.ui_4.1.301.v200709261752.jar
01/28/2008 02:03 PM <DIR> org.eclipse.hyades.probekit_4.2.201.v200709261752
01/28/2008 02:03 PM <DIR> org.eclipse.hyades.resources.database_4.2.101.v200709191245
01/28/2008 02:03 PM <DIR> org.eclipse.hyades.statistical.ui_4.2.201.v200709261752
01/28/2008 02:03 PM 963,601 org.eclipse.hyades.trace.ui_4.4.1.v200709261752.jar
01/28/2008 02:03 PM 900,055 org.eclipse.hyades.trace.views_4.1.401.v200709261752.jar
01/28/2008 02:02 PM 347,812 org.eclipse.hyades.ui_4.2.101.v200709261752.jar
06/28/2007 07:33 PM 357,242 org.eclipse.jdt.apt.core_3.3.0.v20070607-1200.jar
06/28/2007 07:33 PM 21,605 org.eclipse.jdt.apt.pluggable.core_1.0.0.v20070529-2100.jar
06/28/2007 07:33 PM 65,907 org.eclipse.jdt.apt.ui_3.3.0.v20070430-1135.jar
06/28/2007 07:33 PM 142,695 org.eclipse.jdt.compiler.apt_1.0.0.v20070510-2000.jar
06/28/2007 07:33 PM 48,375 org.eclipse.jdt.compiler.tool_1.0.0.v_771.jar
06/28/2007 07:33 PM 49,762 org.eclipse.jdt.core.manipulation_1.1.0.v20070606-0010.jar
06/28/2007 07:33 PM 4,124,603 org.eclipse.jdt.core_3.3.0.v_771.jar
06/28/2007 07:33 PM 1,274,947 org.eclipse.jdt.debug.ui_3.2.100.v20070531-1800.jar
08/23/2007 03:23 PM <DIR> org.eclipse.jdt.debug_3.3.0.v20070530a
06/28/2007 07:33 PM 6,058,153 org.eclipse.jdt.doc.isv_3.3.0.v20070613.jar
06/28/2007 07:33 PM 6,989,987 org.eclipse.jdt.doc.user_3.3.0.v20070608-1300.jar
06/28/2007 07:33 PM 51,035 org.eclipse.jdt.junit.runtime_3.3.0.v20070606-0010.jar
06/28/2007 07:33 PM 14,683 org.eclipse.jdt.junit4.runtime_1.0.100.v20070606-0010.jar
06/28/2007 07:33 PM 493,898 org.eclipse.jdt.junit_3.3.0.v20070606-0010.jar
06/28/2007 07:33 PM 264,644 org.eclipse.jdt.launching_3.3.0.v20070510.jar
08/23/2007 03:23 PM <DIR> org.eclipse.jdt.source_3.3.0.v20070606-0010-7o7jCHEFpPoqQYvn XqejeR
06/28/2007 07:33 PM 9,176,040 org.eclipse.jdt.ui_3.3.0.v20070607-0010.jar
06/28/2007 07:33 PM 42,386 org.eclipse.jdt_3.3.0.v20070607-1300.jar
06/28/2007 07:33 PM 91,827 org.eclipse.jem.util_2.0.0.v200705302225.jar
06/28/2007 07:33 PM 121,478 org.eclipse.jface.databinding_1.1.0.I20070606-0010.jar
06/28/2007 07:33 PM 844,786 org.eclipse.jface.text_3.3.0.v20070606-0010.jar
06/28/2007 07:33 PM 973,717 org.eclipse.jface_3.3.0.I20070606-0010.jar
06/28/2007 07:33 PM 24,661 org.eclipse.jsch.core_1.0.0.I20070426.jar
06/28/2007 07:33 PM 66,409 org.eclipse.jsch.ui_1.0.0.I20070525.jar
06/28/2007 07:33 PM 259,832 org.eclipse.ltk.core.refactoring_3.3.0.v20070606-0010.jar
06/28/2007 07:33 PM 442,821 org.eclipse.ltk.ui.refactoring_3.3.0.v20070606-0010.jar
06/28/2007 07:33 PM 1,299 org.eclipse.mylar.bugzilla.core_2.0.0.v20070615-compatibilit y.jar
06/28/2007 07:33 PM 1,296 org.eclipse.mylar.bugzilla.ui_2.0.0.v20070615-compatibility. jar
06/28/2007 07:33 PM 1,289 org.eclipse.mylar.context.core_2.0.0.v20070615-compatibility .jar
06/28/2007 07:33 PM 1,287 org.eclipse.mylar.context.ui_2.0.0.v20070615-compatibility.j ar
06/28/2007 07:33 PM 1,286 org.eclipse.mylar.doc_2.0.0.v20070615-compatibility.jar
06/28/2007 07:33 PM 1,280 org.eclipse.mylar.ide_2.0.0.v20070615-compatibility.jar
06/28/2007 07:33 PM 1,280 org.eclipse.mylar.java_2.0.0.v20070615-compatibility.jar
06/28/2007 07:33 PM 1,286 org.eclipse.mylar.jira.core_2.0.0.v20070615-compatibility.ja r
06/28/2007 07:33 PM 1,288 org.eclipse.mylar.jira.ui_2.0.0.v20070615-compatibility.jar
06/28/2007 07:33 PM 1,274 org.eclipse.mylar.monitor.core_2.0.0.v20070615-compatibility .jar
06/28/2007 07:33 PM 1,286 org.eclipse.mylar.monitor.ui_2.0.0.v20070615-compatibility.j ar
06/28/2007 07:33 PM 1,292 org.eclipse.mylar.monitor.usage_2.0.0.v20070615-compatibilit y.jar
06/28/2007 07:33 PM 1,282 org.eclipse.mylar.resources_2.0.0.v20070615-compatibility.ja r
06/28/2007 07:33 PM 1,292 org.eclipse.mylar.tasks.core_2.0.0.v20070615-compatibility.j ar
06/28/2007 07:33 PM 1,285 org.eclipse.mylar.tasks.ui_2.0.0.v20070615-compatibility.jar
06/28/2007 07:33 PM 1,288 org.eclipse.mylar.tasks.web_2.0.0.v20070615-compatibility.ja r
06/28/2007 07:33 PM 1,282 org.eclipse.mylar.team_2.0.0.v20070615-compatibility.jar
06/28/2007 07:33 PM 1,285 org.eclipse.mylar.trac.core_2.0.0.v20070615-compatibility.ja r
06/28/2007 07:33 PM 1,287 org.eclipse.mylar.trac.ui_2.0.0.v20070615-compatibility.jar
06/28/2007 07:33 PM 1,279 org.eclipse.mylar.web_2.0.0.v20070615-compatibility.jar
06/28/2007 07:33 PM 1,230 org.eclipse.mylar_2.0.0.v20070615-compatibility.jar
06/28/2007 07:33 PM 114,084 org.eclipse.mylyn.bugzilla.core_2.0.0.v20070627-1400.jar
06/28/2007 07:33 PM 7,969 org.eclipse.mylyn.bugzilla.ide_2.0.0.v20070627-1400.jar
06/28/2007 07:33 PM 121,327 org.eclipse.mylyn.bugzilla.ui_2.0.0.v20070627-1400.jar
06/28/2007 07:33 PM 4,741 org.eclipse.mylyn.compatibility_2.0.0.v20070627-1400.jar
06/28/2007 07:33 PM 66,981 org.eclipse.mylyn.context.core_2.0.0.v20070627-1400.jar
06/28/2007 07:33 PM 228,464 org.eclipse.mylyn.context.ui_2.0.0.v20070627-1400.jar
06/28/2007 07:33 PM 757,351 org.eclipse.mylyn.help.ui_2.0.0.v20070627-1400.jar
06/28/2007 07:33 PM 15,509 org.eclipse.mylyn.ide.ant_2.0.0.v20070627-1400.jar
06/28/2007 07:33 PM 23,356 org.eclipse.mylyn.ide.ui_2.0.0.v20070627-1400.jar
06/28/2007 07:33 PM 153,274 org.eclipse.mylyn.java.ui_2.0.0.v20070628-1000.jar
06/28/2007 07:33 PM 38,339 org.eclipse.mylyn.monitor.core_2.0.0.v20070627-1400.jar
06/28/2007 07:33 PM 33,763 org.eclipse.mylyn.monitor.ui_2.0.0.v20070627-1400.jar
06/28/2007 07:33 PM 48,293 org.eclipse.mylyn.pde.ui_2.0.0.v20070627-1400.jar
06/28/2007 07:33 PM 43,961 org.eclipse.mylyn.resources.ui_2.0.0.v20070627-1400.jar
06/28/2007 07:33 PM 95,936 org.eclipse.mylyn.tasks.core_2.0.0.v20070627-1400.jar
06/28/2007 07:33 PM 1,168,070 org.eclipse.mylyn.tasks.ui_2.0.0.v20070627-1400.jar
06/28/2007 07:33 PM 6,837 org.eclipse.mylyn.team.cvs_2.0.0.v20070627-1400.jar
06/28/2007 07:33 PM 91,680 org.eclipse.mylyn.team.ui_2.0.0.v20070627-1400.jar
06/28/2007 07:33 PM 991,229 org.eclipse.mylyn.web.core_2.0.0.v20070627-1400.jar
06/28/2007 07:33 PM 57,299 org.eclipse.mylyn.web.ui_2.0.0.v20070627-1400.jar
06/28/2007 07:33 PM 3,495 org.eclipse.mylyn_2.0.0.v20070627-1400.jar
06/28/2007 07:33 PM 63,704 org.eclipse.osgi.services_3.1.200.v20070605.jar
06/28/2007 07:33 PM 22,773 org.eclipse.osgi.util_3.1.200.v20070605.jar
06/28/2007 07:33 PM 927,485 org.eclipse.osgi_3.3.0.v20070530.jar
08/23/2007 03:23 PM <DIR> org.eclipse.pde.build_3.3.0.v20070612
06/28/2007 07:33 PM 996,049 org.eclipse.pde.core_3.3.0.v20070608-1300.jar
06/28/2007 07:33 PM 3,420,727 org.eclipse.pde.doc.user_3.3.0.v20070614-0800.jar
06/28/2007 07:33 PM 14,717 org.eclipse.pde.junit.runtime_3.3.0.v20070608-1300.jar
06/28/2007 07:33 PM 150,490 org.eclipse.pde.runtime_3.3.0.v20070608-1300.jar
08/23/2007 03:23 PM <DIR> org.eclipse.pde.source_3.3.0.v20070607-7N7M-DUUEF6Ez0H46IcCC
06/28/2007 07:33 PM 570,955 org.eclipse.pde.ui.templates_3.3.0.v20070608-1300.jar
06/28/2007 07:33 PM 3,809,143 org.eclipse.pde.ui_3.3.0.v20070608-1300.jar
06/28/2007 07:33 PM 68,417 org.eclipse.pde_3.3.0.v20070608-1300.jar
06/28/2007 07:33 PM 28,623,875 org.eclipse.platform.doc.isv_3.3.0.v20070621.jar
06/28/2007 07:33 PM 6,238,155 org.eclipse.platform.doc.user_3.3.0.I20070615-1300.jar
08/23/2007 03:23 PM <DIR> org.eclipse.platform.source.win32.win32.x86_3.3.0.v20070612- _19UEkLEzwsdF9jSqQ-G
08/23/2007 03:23 PM <DIR> org.eclipse.platform.source_3.3.0.v20070612-_19UEkLEzwsdF9jS qQ-G
08/23/2007 03:23 PM <DIR> org.eclipse.platform_3.3.0.v20070613
08/23/2007 03:23 PM <DIR> org.eclipse.rcp.source.win32.win32.x86_3.3.0.v20070607-8y8eE 8NEbsN3X_fjWS8HPNG
08/23/2007 03:23 PM <DIR> org.eclipse.rcp.source_3.3.0.v20070607-8y8eE8NEbsN3X_fjWS8HP NG
06/28/2007 07:33 PM 12,907 org.eclipse.rcp_3.2.0.v20070612.jar
08/23/2007 03:23 PM <DIR> org.eclipse.sdk_3.3.0.v20070613
06/28/2007 07:33 PM 471,437 org.eclipse.search_3.3.0.v20070606-0010.jar
06/28/2007 07:33 PM 1,997,851 org.eclipse.swt.win32.win32.x86_3.3.0.v3346.jar
06/28/2007 07:33 PM 14,592 org.eclipse.swt_3.3.0.v3346.jar
06/28/2007 07:33 PM 383,939 org.eclipse.team.core_3.3.0.I20070607.jar
06/28/2007 07:33 PM 568
Re: TPTP newbie gets NoClassDefFoundError -- huh? [message #122195 is a reply to message #122119] |
Tue, 05 February 2008 11:33   |
--------------060806060306000406010704
Alexander N. Alexeev wrote:
>> how would I tell if a class-loader could load them?
> Just try %JVM% org.eclipse.tptp.martini.CGProxy
> and see message like "There is no main method in class:
> org.eclipse.tptp.martini.CGProxy"
I'm sorry, I don't understand what %JVM% means? I tried this: open a DOS
window, cd to the directory
and then tried java <that class-name>:
C:\0-UIMA\BlueJay\eclipse\plugins\org.eclipse.tptp.platform. jvmti.runtime_4.4.1.v200709261752\agent_files\win_ia32 >java
Exception in thread "main" java.lang.NoSuchMethodError: main
So I guess (?) that class is bad. Why would it be bad?
>> probably the problem, eh?)
> No TPTP doesn't stick to Sun JRE and IBM's VM should be a problem.
I'm sorry -- I don't understand your answer -- Can TPTP run with IBM JRE
or not?
>> which is:
> This message is quite different from previous. And such problem
> sometimes happens. Seems what Integrated Agent Controller can't be
> executed automatically.
> Info about AC: http://help.eclipse.org/help33/nav/28_0
> You can try to run IAC manually by pressing button "Test availability"
> on "Monitor" tab of profiling dialog.
> Also worth to look in log, it can contain cause of problem
> C:\0-UIMA\BlueJay\eclipse\plugins\org.eclipse.tptp.platform. ac.win_ia32_4.4.1.v200709261752\agent_controller\config\serv icelog.log
That log is attached.
Paul
> Alex
name="servicelog.log"
filename="servicelog.log"
<CommonBaseEvent creationTime="2008-02-01T15:49:24.015000Z" globalInstanceId="A1016B716238489EA6A6932C2C0B2684" msg="Received command for unrecognized interface: iid=org.eclipse.tptp.eventProvider, cmd=listenerAccepted" severity="50" version="1.0.1">
<sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.0.3\TPTP-4.4.0.3-200709261752\ agntctrl\src\transport\TPTPClientCompTL\Connect2AC.c, line 2238" instanceId="1004" location="agathodaimwn" locationType="IPV4" processId="4668" subComponent="Client Compatibility TL" threadId="7532" componentType="Eclipse_TPTP"/>
<situation categoryName="ReportSituation">
<situationType xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:type="ReportSituation" reasoningScope="INTERNAL" reportCategory="LOG"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-02-01T15:49:25.140000Z" globalInstanceId="A2EAD8A58A0641EB82B8BCA9B025F513" msg="File server started listening on port 10005" severity="10" version="1.0.1">
<sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.0.3\TPTP-4.4.0.3-200709261752\ agntctrl\src\transport\TPTPClientCompTL\fileServer.c, line 177" instanceId="1004" location="agathodaimwn" locationType="IPV4" processId="4668" subComponent="Client Compatibility TL" threadId="6536" componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-02-01T15:49:45.171000Z" globalInstanceId="A78C84C50E8C48F58FE3E95392A378BB" msg="Received PUT_FILE command from client" severity="10" version="1.0.1">
<sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.0.3\TPTP-4.4.0.3-200709261752\ agntctrl\src\transport\TPTPClientCompTL\RACmdHandlers.c, line 877" instanceId="1004" location="agathodaimwn" locationType="IPV4" processId="4668" subComponent="Client Compatibility TL" threadId="4520" componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-02-01T15:49:45.375000Z" globalInstanceId="A18F9DBA938E4F819DF14E6A4F803F40" msg="Received PUT_FILE command from client" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-02-01T15:50:54.984000Z" globalInstanceId="AFB6B7776F76478EB5BDDDDFB2534A06" msg="Data connection not found" severity="50" version="1.0.1">
<sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.0.3\TPTP-4.4.0.3-200709261752\ agntctrl\src\agentController\ConnectionManager.c, line 728" instanceId="2" location="agathodaimwn" locationType="IPV4" processId="4668" subComponent="Connection Manager" threadId="7940" componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-02-01T15:50:55.015000Z" globalInstanceId="A842561892BF4B30ADF046EC237775DB" msg="CONSOLE LAUNCHED COMMAND for connection(5000). " severity="50" version="1.0.1">
<sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.0.3\TPTP-4.4.0.3-200709261752\ agntctrl\src\transport\namedPipeTL\namedPipeListener.c, line 564" instanceId="1002" location="agathodaimwn" locationType="IPV4" processId="4668" subComponent="Named Pipe TL" threadId="7940" componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-02-01T15:50:55.343000Z" globalInstanceId="AD536A2DD42642DBA62C21F1F3DB2D6C" msg="Data path is NOT established yet." severity="50" version="1.0.1">
<sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.0.3\TPTP-4.4.0.3-200709261752\ agntctrl\src\transport\namedPipeTL\namedPipeListener.c, line 1306" instanceId="1002" location="agathodaimwn" locationType="IPV4" processId="4668" subComponent="Named Pipe TL" threadId="4872" componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-02-01T15:50:55.343000Z" globalInstanceId="A6F03D1D7C8B4019B3B97CD0DB54A873" msg="Data path is NOT established yet." severity="50" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-02-01T15:50:55.343000Z" globalInstanceId="ABCE06D660DD4E40894EB9DEF0C2E1EA" msg="PC handleProcessEvents: Process has exited with status 0." severity="50" version="1.0.1">
<sourceComponentId component="ProcessController" componentIdType="TPTPComponent" componentType="Eclipse_TPTP" executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.0.3\TPTP-4.4.0.3-200709261752\ agntctrl\src\agents\tptpProcessController\ProcessController_ md.cpp, line 284" instanceId="102" location="agathodaimwn" locationType="IPV4" processId="4408" subComponent="ProcessController" threadId="3888"/>
<situationType reasoningScope="INTERNAL" reportCategory="LOG" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:type="ReportSituation"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-02-01T15:50:55.359000Z" globalInstanceId="AAF99F5F968D472585D9EC06FB367B0D" msg="CCTL Scrubbing process 1556" severity="10" version="1.0.1">
<sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.0.3\TPTP-4.4.0.3-200709261752\ agntctrl\src\transport\TPTPClientCompTL\RACClientSupport.c, line 488" instanceId="1004" location="agathodaimwn" locationType="IPV4" processId="4668" subComponent="Client Compatibility TL" threadId="7940" componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2008-02-01T16:02:54.000000Z" globalInstanceId="A7C2B8C057774D079EF7DC414B0D9407" msg="Agent Controller shutdown requested through ACTL" severity="30" version="1.0.1">
<sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.0.3\TPTP-4.4.0.3-200709261752\ agntctrl\src\transport\TPTPAgentCompTL\ACTLServer.c, line 376" instanceId="1005" location="agathodaimwn" locationType="IPV4" processId="4668" subComponent="Agent Compatibility TL" threadId="4708" componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
--------------060806060306000406010704--
Re: TPTP newbie gets NoClassDefFoundError -- huh? [message #122316 is a reply to message #122267] |
Wed, 06 February 2008 10:41   |
--------------030602000500010102090107
> To try it you should select "Java profiling - JRE 1.5 or newer", after
> what button should be enabled.
> Please try it, but probably it will be successful.
Yes, that reliably gives an info dialog "The connection was successful!"
(Fairly non-obvious that one can only select the root of the tree to try
that ...)
> Could you also configure DEBUG mode of agent controller logging?
> To do this you should in file
> C:\0-UIMA\BlueJay\eclipse\plugins\org.eclipse.tptp.platform. ac.win_ia32_4.4.1.v200709261752\agent_controller\config\serv iceconfig.xml
> replace line <Logging directory="%TPTP_AC_HOME%\config" format="CBE"
> level="INFORMATION"/>
> to
> <Logging directory="%TPTP_AC_HOME%\config" format="CBE" level="DEBUG"/>
> delete
OK did all that.
> Exit from Eclipse and rerun AC
Eh? how do I "run AC"?
> After this try to run profiling.
> I hope debug log would help to understand problem.
Anyway, when I restarted Eclipse, and tried to launch the RCP-profiler,
I am back to getting this error (in the console):
The java class is not found: MARTINI_LOGGER_DIRECTORY=C:\0-Temp
after which the profiler quits. Evidently, however I am supposed to
specify that "martini logger", I am doing it incorrectly. How do I
actually specify it?
Attached is the servicelog.log (zipped, b/c it's huge).
Paul
Content-Type: application/x-zip-compressed;
name="servicelog_20080206_001.zip"
filename="servicelog_20080206_001.zip"
UEsDBBQAAAAIANxURjg4QUy2F6EAAMJODAAOAAAAc2VydmljZWxvZy5sb2fs nXtvG8d6h/9u
gX6HhQqc2EBEz/2ixAVmZmdaBbKPYSlBWxAIKHItMaFIHl5sq5++v+XVtiwl 1CU6Xg1gS7zu
7M7Oo/f+zo9hdHExGvrOtIrvq+Gs6E6qzqw/Gp70L6qXe4wQs0/YPlEnVB5w dUBFS3BNCPnf
veJsMDrtDA6H01ln2K0Oey/3HGM0cWpEKaUoNTOlCYR7F1Qqg+Nir7iYnr3c W4xRnUw6w+l4
NJkd9aezalhNimfTUff3avZ8r5hW76tJf3b5ck/uFXg4xRm93KMt0qJ7//Fv //ovP05H80m3
wsmPR0Oc9mGv6K4f4zTO8CuMhrPJaDCoJnt4b/O5k8sxruvkzcmbzZf3iupj 1Z3XVx2H7/uT
0fBicZjyoN29PPvQH7bPRxdV+3TeH/Ta9TfbmAScCl882V892cdcaWKZolqy dudsOOvOJoP2
dNJtz9ZX2l5e4MnR8sHmylvd74tBf1gVWrC9ov/JjFJM9V4xGHU7s8UUdM46 s/NRr9O/+DDc
vr68qMM3v2CGx5NRt5pO6y9rpQzmcn4atnNzvBi4ODnaK2bnuA+9+oMMn9tO 0vJosTvoj6fV
r/U17r1YTnp/Nl+MV2DY6mw0uXzdqVfJ26q+uOP1u4s7tPz05uyKjxeD4fTg 47T/cu98Nhsf
vHjx4cOH1gfeGk3OXmDq6Iv/fnV03D2vLjr76wnYK/D5gxm+fnWMAuc+HQ37 w7Pj7mhx9a9P
4tvX7gjvLD4aVqf4cu/o7/+5uoAXm3PC0x9ffLH28dptcFDmWhwkM1RTzr02 witumCY0KMOC
DVEpu8LheN6t79i7+WBwiVva6VW9YrNkikHnspocFOuV87d//+h+aBognc/P p42Hw6pbj/eq
M8SbW0Dwt+VzQNi90rEduFiNnDF5eEyIIUIyxnjphfTEl0aVsZRcYL1Exm/A pIvz6Ax7WJ8A
pjsbAZTZeDYOF72IV54uJozLjEnTMClJGYjVIkglbGlsIk5IawBMVDrKP1Ku hpjdXjHuj6vn
raaRsdWwFlf5Bhd5crR9fEXPsvyqnkXvFZHXi9muB8+61l9Ch/NOsyCNKaOg gVkOERJkSWTJ
DCc76VqbdZPVraxuNY8UZi0VVtpkuHBBmBi00obLUtlSOpfVrZ0xyepWAzHR NEkiPASLFM5a
z3kgKhEqPQ3B66xu3U3dul9Esrr1F9PBnBVKe+VKJpgLJgnFlSbM0cRYlFnd uo0cyepWA0lR
XHDOnKDOCZG8McRwb6zRZUmol1nd2hmTrG41EBOddFTGW+EhUIxwwpMY4Apm pZWlU3+kbk3P
OxMgc1Fd4DqapXEdvw3tk7fu9fGbv789aS8v9FV1cXK0fXxF46L0qsbF75WS 4+WEv1pMeFa6
/hJGWMmJVkTTEIWGrwshdq9Fkj7C36XCLkrXZulkpSsrXc0jxccUgoZLmDv4 uIhnpXBOGcG0
ZYSnrHTtjElWuhqICYMoUUpb5YwQXnppKbQtkiyM+bgJmrxZ3rpijDWC61nd l+XQVe/7Ytbv
FS8LfKVpdGz9XItxB30cvh4dqtfqycnRVo4Qaq/oXOJ+IVkMWtSv4Kun/UF/ llWvv4YUS0ni
teFOkohEOxE4KVlinCjLNgIlHLnj4zfu5L+K+RSy5N1oUuAYkxqad/1BBTwm gAKwhIM22f/5
8JVr+8G8+qlz2a6WN6k9HszPMGttTGZr9VqrFkCt8aAzwwEvWr+9v5j1W5P5 cIYr+bVexbT1
/otFjAv+tR5x2gYGv/Y7nP1wlyG74HH517n1boKF8mE0+R0jsxYlX4593l18 ovVbZ7LjkOeX
EMDT1obpr17aefVx8oDHHjzgsbujyXJadjx+/b3N7eYtjkknq6NLTm5xwtU/ 5v3h6CMOXBOy
OOT6gIKpWxxwND3rLw6z+3nhHFr9U/zvznEEtZk3QTWO0Dh9ayeJwjjNAuWb FihGXO8WDqVI
PJXSe3wM4RRkBEcpjK51sHIdXjxaGiU//fIKS+J00plc3iA6fptgaWKNdged 6bTfbUNQtHqD
wRNi6LfO+84GH5PpaSw9AbF5R6lWUQslotWlLBNB7NE4BumzoKe+tOlo8B78 YMDJ5XjUx7i1
TvbT68Nfw8J6+QkL5pdXT5UQSzIh3y4hskWEup4QQ310uCc+CcHwM6oUkfuF OD3g2SkfcuH/
CtlRnB3FzcPEUwQbjaNWMyF4cCEokaJxLmllLcuO4p0xyY7iBmISJEjRAeET ImwIpqTSEieV
dcqXaY2Jg5BY379iPJ+cVdf4ihkRommEfK50ubONzrVmBWlyW1nClbyie8l7 BcWdZdXrcWAx
PHIY9VQZLYQlJmkrlSlLZaIPeqfcyFqiuKx6ZdWrgZiUjhsks3jGYaHQEmXx pTPKQKQwD3M+
q147Y5JVrwZiIhii89C1jKLCW+JT4Mwg+ujRUYWWa0P+Le7CZTEbLeKNs1Wg cdp0FD47v8/k
hf4chPttohIQkctL/+GXvtQlYcRzR2Ccq2gkp5F4lZgXHJ2FVkt/seJzN6Gr 3YQMU7mbUHNo
KCVJSfNgaus5BquNS0ZrjYKSaINf0fB6XXe4yTbpTwtkD9QXV9RK06BeJstn s+Jv/5iPZj+0
2612/Y32oX/lQrvTvejgM5Plm4tjNSqh/lYljEQ9Vgkjun2oDNQDAGWoM94H ZpITlsFsR9GJ
NsixR/86FdyXmlUHhsh4Vgyrj/ixpWyCdJpqOnvyhFBiSUbkW0REsetlDvek NB7hEBgfxHkm
CergPfWBxGjI/cucwegsi53PxM5jNSpSnLLM1AMwxQmCJorU9SkiITRvfMlL U8qkYLZyncXO
ToTUYicj0jBEjGQccEgmgkApF9xdNjCOnkUOrmK/FjufOULPIHX2i+mn3uJO b+Es3nzqsCyw
NhYZYJtVtnxNPPH4CjyK2XHcNIio9Ykjj97EElKmtBHw4CUUDqPjV9yaN92q /34bVFngMR9O
qu7obNj/P7zRH0Ive9fpVgdFv997eaVKpKrPFTVi7/u9avJ90b3ovRys/kq7 heyqep+RRRqA
1pUMyxuj/Whta3KmZVM5Q3MXlhTyxxgTHv+AHHqHoZgsyWTJJoXs0wYVf95M 6nRP5+/erX1x
tQLYLKPoNs0tOJOP2dxCGJI5uiVHlMnr24DbEvllwZCSCxTCGDS5QG2MUoLH YOyyu8U65PA1
gGbFInNmOL84xTujd7ViR1SjaNkt/qMseZT4D1EiA3JbQAS5vmQsSUNY9DoI gc7flgSKthbo
wRejLqleA1KHQ2sg1mX727V78Mf1mNfXAHe6rXUt8Q1Fx93NYItStPoQq/PY nkZdKts0Kr+a
mXDFzCL2C8l1v46KxaDZxLpnIjW9XmQFQVUpGVUBppVGCMlr0OlQVMA0S9mV d01GdJ3SelxL
8C0byJR99IRoKXX2592WE/RVur45P0qbbYScsiiyQYqnJ0bIECDFuONxo9r9 HEI8Pk4/Hx39
zzKPrep9RYoVz8ZwQyhKRONye/6cFKGMZCnyrdFBzfUOhHq/o1jC2c0F9Dsb tTEO7WFRpqm4
XHu7MdLkcnaOS/nE6nkSAHwlwZMRmhM8v42VL8n1Fk3kZYIRE0WwyLlBSrMs 0fsCDZZg0Qh2
pzgPzXGef7I4DxphZ7/AQ1AEiEjUMcVIhXbRaeJRgSZ8EJKmreOsHkiQ4vRy Vk1ra6S7CBk0
DYYbIjNvXVg+P56P609ssZD/BJ37Mh53wEPd4FfGrsSeRWxLLBH/RPJaouij DGuEaG2tsF/E
QZ8Ju0SkWU3Eb5NaY0RO6GwaDNxb6ZJCYCSJQJFPIyExqBXYRpIau/ZY/dIZ 9Hud2vy+wN2D
IK/DKSswGldUtisWWuZSgKZh4Ui0HPEyB0cuQ9jecZ2kiBLdkb3m4i6GCPua IcKyIfKIhkim
6GEoitCyvHfYK08K5bRHjRoeMexXrJKR+tNqgcUft7Nqdjjsz94u4x9lZ9bx uNm/H+CSZvPJ
Iqr/yZ08LA9qnJ68WkYVz/KnYeQkqRTn6DkWIHWYRB8MjV59TitHvI7rfpY/ /1wzYDoCHmPb
3e9Up2Rf9Ozp/inrkv13/LQuB8WruvfkIcFOHxmShkEiSmFhu6MQuhTeJO8V LT11sq4QIEp9
KV4OioXLi6qVy6ue6K00WepmTx0Txh5tZ9aMyUNhQpV0DJu5cPi7LKx6baCJ 1fnIzCC7Miel
7ERILmv+VhG5IZNSK0ORd4LqMoNWGgIReI4Efmk9WpBJF790CVvBsk947RPO 1ZZNo4EiE4sj
iOiJFahJtgl7FEeGOjGCgJm0N/mEQUZ2Ci+dwrlQv2lcKKs8qn0QU0dP8OSg SkkZKTZfVZLK
VeBwtXK/mxbPruS5P//U3uj36rSt/fswOlYD7ULLDavjwVFaeIWny1/1rWnX PxazdngxHrS6
4/G62QX7Mgx/B0Wrzg9dInTjxG0x4ig5ugdSdlvY9w7W45DiEhqCw/frsDEe uinBBcwo86lE
w2NPee6ktJssyS0tdlvzOzL3OIjo4NGxNUqGDSa0RCJ8oqjKR3TRIzlF62xy ZJOjaTRIdf12
qipwHVG9SFLt07VcC04Vw3wTbxTPJsef4CKbHN8oFzdJCU4SnFDYY0UL64wp g+bYkohHhDmo
p5+aHM+gHT8/KHyNApZB/U4xqN7NagXrtFrf2qp3UKxyfu8sSJpqdxgqst1x R7oeEJcbxEjd
Dzk55hDrEBQRDoF0E89FCjphYy+R7Y6dBEq2O3Zb8zsy9ziICE3QOx8mhuVC J41dJALFXvYa
zSSisfaK3SFFtjuy3dFUGgj8t4mVpKRcRC4djUIQJb3x8F1RcaPdIUW2O7Ld 8Q1zcYPdEVFq
XqLklsEmV3DdMkiI0qVQGl6WcR0Q3yjQOPOzellMFs8OisWvmyIgVa/Wv1wo 7gpPU20Qrtkj
2iCaW3YP6Oy20u+dtAdE5waR4gLSERO26NJJ0OixAT0kjPBlcLVlErMNspNw yTbIbmt+R+Ye
B5FY9yKmEfFzJ2TitdOXGR2RqKgC9eSKDcKyDZJtkMbSoAhUrFKHVFvkiiDp UGLneSo1woCB
0xttEJZtkGyDNJQL7O+IHBIq6n1RDCqfYlLG15XqngdERb6UEpTrLCVyo4am 0oC2o8bQiK0d
S4EfaIuF2KB2qH/yPrEbGzWAjCwlcqeGZnJhJIr98H4MMCIC6jisNC4KK1Fs HtW62RUqy914
POgvb6gb9DH6FFOMZdxrGhV/qmkoNZw+StPQDMIDgUBtYtxhg2xWb+sTsQcJ kdxQ6iwHH/5G
EKbVsIerw9VMcVumT7MbOzXCZiSahAQxNClf5xBSdD+kjriIrUoVdixF9YZe p6HXi//VSlt6
tnXBPq+9s+ivO/28aqNOs8oWBqXWZlWqYbhAaxI0CEQwkIrulS9Nwg4VyerS M+3SNf0UGPwf
uaNC7qjwhEBJTGpLBSwNA8+URnkspSqVUpaI+LncUWE3QnJHhQYigu1bjBVo rotgBiIZHrta
MyqxSzw2QrSb1m8nk0tM/rzuylNveLiWHrUdMh/M6upYI+8sQZqaIiINzSki d2TpceAovcLu
Hwj5eSEcdrbmRECISJEir8MbWX7cXX7cr+meg39/NSI2CRLqBqJKikCw/U2C nuWxHSiydZOV
V1JEaA7+5RSRxtJQ732HDjyLjjwo/DMBkQ1pgrVKltSoG1NEaA7+5RSRhnJh GbioFwfVgpjo
bLCKumRq28MmebU8dn0LITh6r6Zn02d3lxdNNS+0IY9oXuQq2NtTgRaGCZEO XYqIaj/kh4iE
glhuSVl6m82LHeVGNi92W/M7Mvc4iKAanKsSRDAmGDYajFRGTSW2hWLaW3PF vOB5E6hsXjSW
Bs685xobPqEHVSqVgXERmIBvHHE/EHKjecHzLlDZvGgoF5oxSAUufd0TWifj JMDwWpT4JVZt
DNd5Pd9dUWe/K84R0xjgEuvZK7oXd840bKqpYXRuuHNXoB6HEFPGlDg2SPMG DXfQKr1E42gF
91Si6I2bG+7sJkOyqfH/7J19bxy3EYf/7rc4oEiQAq3LIYfkjIMG4JDDxK1t uZKatkAAQYnl
RK1iu4rcpN++vDe9nXX26qxetab8cne8vSN3yUfDH2c5M2zMD2RuO4hw8CiC kC2j8Umc9aKW
HQRgNem61LBoe6TPrjVGi4MzNbhkyWaHsVi2JTgnAhAzA67VGg2NHuqzi42R gmGtsGpV1owB
MjEIeCaX6iwz+TvFxuvD0xbdcyk1Jp+enH2e22MbXn/49F9vXp19DvOHyfM2 1VoWGbso/O7s
l2Whmz98Mf2Gw9W9IsfHzxcHtt54cDTv+Qdnr89ePzi8tK3i8pfMPzl7vrr5 5ItZ6ttf/era
u9N7wV4cf//mdPZqUePzoxeH7caw+YsFlIffnhwt3v7H4b8PH7TS+asLHOav P9n7+97Bvj55
dlAe7X6yOOZ142T5/h/T1+ngWdr/avHmomXzpn19eHo8rWrSqFzWlx+nvb3p B5Zf9qqNmYsK
28VrWwsW7/378OTN0bKm8w8e7Ox+eaD58aNne3qgf/7Lo6c7fzvIO0+e7Dxd NOL372zFzQ14
fXp0Uwt2057ufq27B1/tPNFPvvn2+OXV6lpt7cWl/piXf4heenZ0+qJxMxvJ Kz11Y+suuuvm
g765/NUXA2He9P9ZN37191R076D9Jvny0dMvW2/u6rIv/8ctmf46Pnj2OO3X nd0n5w3Sr/Xp
/t6WmrS4OPo3zX/Zf7TzdEvNuHJlWhc9fqx52pyDupue6F93dv90tWELHDad d4x2Aaf7ijee
pGxn1lEycKVsKWcsRKLeIgYWspqio76AM2he3hdwho35gczdISIRbkQkJa/R YDYoWMWRDVA5
IipPP5NXfMXB9PWbvn4zVhpirWQrBC4FMwcqDoLkCsJFRfJaX3EwffmmL9/c Yy7WbZ5mTqip
RFtQGwoAgQwYTSg+h+W65rO87Llp7c09fH5Haju76brNw+srLpvTcj9Fx3RB aaXlby+9JESA
YuxKZEPe7hCgNYYFohi0WVIu6B1QNFGY2JKKRw9diQwyMV2JDBvzA5nbDiIU iWdTL83oVNl6
BDbRYzVcCFdzRrquRLoSGSsNmki8qTYTIxfLDji6rNU7a7mY9TkjXVciXYmM kwvUCuJ98ZDR
R0tC6EipikIRNT1n5ACe3t8D0nNGbkzXdnCxygRiKVVBUpHABkLJGmvSlGzX HYMMStcdw8b8
QOa2g0iKARTZ5FhRIqUGSCziY8RmUDCu5mvxXXd03TFWGtBWMoVSyhZzriSx Vq1TE1JYM63P
1+K77ui6Y5xcuJSIPNkEHj1HKZ4FcsiSvRWRHvJvc5XRQ/5tztJ24IBoazaM 0x9ygR06F0L0
KuhS6CFjh5mPrjKGjfmBzG0HkayZaq3AxaHxNWngdqaGrQowuJWNcqbH5Oj5 vkZLQzROxXA0
mjDYmgAjKXjnxZJHWbtPzvSYHD3f10i5oFilhsTIDhG4cRHIQqgUrRhdqu8r +eg/m6xMa387
AWMnv/moM4BZjj3d0ZjQKJSMQSKuGdkIcSgAmWpOVEP2Pd3RrQ1JT3c0QlzU YHKiKtZjlijV
xSJOMXEFdqv7OoC63uhejbHSYFMksS6xUSSRZI2HHAUlea5c1ocYp643uldj nFxUqzmWSqEa
9CIcU2aq3leTKaTaQ4xv4M7oIcY3h2g7VGA1MbJl46dSw3LgoprABEoZrd6Q KhJszxTZM0V+
oIE/ELwtcUKuZJ+pQkBDWWxgDRqRIBfD2t1+gwjpmSJHiAhhjaaKwZow+SA5 pWoQraTqE8SO
yOaIdA1yvxERVxCUwOeI6ojRcPBcDStT+29131+PQNJXqkZLQ1GDDi0Ei1hR U6gJUkJF54IN
sn7fX49A0leqRsoFSiEKMVkwCJklIKiJhAZVIME7A8j2bBXvt2rVs1VsDtR2 CAlV2QJb4yuK
r8mpA/ZGSmikuK7Gh9mQLjWGjfmBzG0HEZezRy81scEaMpkEHkr752LWaq9L DQDoMUa61hgt
DtnnZG0pahO6VJipVmXfyJBcclqnNRoaPchIFxsjBYMTBTLIGCpWMbONf4o1 gLMZs3+n2Phg
2Sr4cqKJaXW7i1t/j57fIlXF7699xbywteyLTSEerRrqPvyNid8OwgWME+ts 8IzAgZOtNRAG
Uz0l9l0NDTJyXQ0NG/MDmdsOIioiRGiCrUjVJ5exFnSx2AThLbcIhx74pIuh 0dLgK6VSMEg2
qJQlgXrHjYWKahTXh37vgU+6FhopF8nWQsrCltCZkpDIZeZqFCgmd3Po9/M5 9dz3cvR8FgH+
igTZfHPi/RQetw3/Hnr4902Z2w5EYgWjiC+Q0VVDlo1hk6bmxUiWrkYGmZmu RoaN+YHM3SEi
FG9ExJBxXlSCJAQ1lIpU145XT7mm1NVIVyMfEQ3ZRdf+oosVY7YUONgMECkH SMJdjbwHF12N
3FMu1q1ZZeuJndVokNEksDljquolm1KXauRCelwJlfJwcrVw8vPx2Q+TlGcd dXI05eizlSnw
bzbF6H5KlHf7RhyHLaqRHq7x9sZFCgl7rClk5BCSq8Vi+2NsVO9rVyODzExX I8PG/EDmtoOI
OgkGCaEikiVJQib4aGIsEng1KHyErka6GhkrDSWgI4tZQ0STIpuSQE0pWFyR vN43EqGrka5G
7jEX68KnmBp8IjGomIIlGxScU6BmJEKlORer89gWMOLs8PSsnVvrpKNJa9Dx 2avTxWGzdv20
6L0HDza2J/dTftzOQ2J97JpkU/LuEKV1Ey6UUlSyQMCU2oNxiW00VCwRdw/J MGPTNcmwMT+Q
ue0gYnL7ESfeMAZXGakQa8wBkdWZniC3a5KPiIbiMxVWwyWhFSUJHsmIWs2W kXuC3PfgomuS
e8rF2lCnPmefvRKiA2UjxrtIodqSbK49Qe4Ant7bF9IT5G5O1x3issaMeOt8 TRRddGi0MmMu
EAqhcbkwdN0xyKB03TFszA9kbkuIoDMMlKtmjFU4MLicsDAmJF7VHb7rjq47 RkuDU1WwUshX
LAbEReREziGYTODW6g7fdUfXHSPlQiNnCbmCItYCjEGCYFJbotQcz/eJLHaD XPF2PJz8esrH
6ZuX05Oc9e1Pkz9MzKac3E+58Xbfx0rJwY/Pr2wOcVtUIAGN+QDgDBvnH5yz 7YDjoHLGxk/2
yFUYTFGAEiFkTyl3BTLItHQFMmzMD2RuO4igAymuJvAZgYVdsArJGkBvDYVV z0ffG9IVyGhp
UBPYBLLVG2RKUlPgDKnG9qSWst7z0feGdAVyn7lAcyMXmYOwVtBIaIohCTY7 Z3Mw3tP53pD2
gdOzxWS2uT32Z/3ysPk7vm8ekJ8Pj8/6PVeD7rkCNLxN5QGx33N1S0NCntSx OA6AgFUC+ejF
YszJgoSuPAaZlK48ho35gczdFSLhgTFrbIozWNAhgEVGJM4sPnDJps20YDnX qscnR230n7Yx
P5nZl9ZLJ9PxMVvOald7ejoTaLX4y5SAGRUms3pPjtvXT2tvrLxol2WvXZXL kMS4wgh+UEbm
LZhMS9pHvz0+aZf6Gi0uWOq03IYWSw/AhxtpkRCYcjuiFgSvbIOfOtFr4gBJ ZEFLPs+N2EKU
ft+Q+V3rwu+mffrizcnJfyaHz583fi4yKM4SKLrJi1enk/PBNisz+Omvf0mf j83wHF5tzzdX
rld784ImZ+kqTbefeL0NpYuKJ4uar9ocxE7RHVBUkrUCVKMrmLwQesO2Vsje g7d2QdHetKJl
xp/p9Kxd+VY0NhjWmJfdlOev9968nh5xgYXn7RuZjscmeKwLSOdM5hKqBoug SbIni5htKg7F
+SUer77759HZsh/n/bU7VyoPJ1NJMwH7gW5q/P9F5qfZRWiozJ+sSBaPq6tg 5oOCMu+G62h4
6vOvu0ADCksiFy0RgrOUtErlmpLnAlrfgsZFJveHk8U6y+w24Benr36cLMb0 5Lvmsn95dPIR
g4KOOygjAoWDZVUsLlWknBLnihKCGKemKl0GZWkuDs8mJ+3MziatK84DBi19 K79ddu/keMwL
Ye/ExPuOyYgwQaKoDOCtwwzAaqOxoFVyKIKh25NbgxKhgzIiUEwKVhyDdYxg I1GIAU0tCl4N
8lV7srgDcpJ3nj7VvL90oEw+u8bHmO9eeRcgEG0HZESApKyNiWoQHYqQWElO FNGHaMjwJivD
+LaVYdNXhre4MtwpuhuKNINVVkgaUL1PxUNhpy76lD1elS0LK7MwMg8nb36a +iIvddyj8nBK
z9gYGWBjqKuVMdEhxQJmE7JXzBmTSTWaXCEbAaN4bRI2859YWPhPplf5Mhof NxmMffZ138iw
xt283KXOgxFrq8VaqlBiqq005hCquPd3mQTsPpPuMxkVGylXH8SlyIwFqthk g/PeVBONiO9r
XLcFpftMxgUKAFtllPYECaxUNd5HR8UWX43tPpNbYtJ9JqPChDBTycZlB4g+ Uc6JU05FneWq
sduTW4PSfSajAgU4Bl+r1CDouVCs1ZcEIDGpV30rKPs/HD2ZW4+vWvfMI2mf Hr9+3VaFf5gV
zKF5+erl7/YfLw3NR8yMc6YzMyJm/sve2Ta3cSMJ+K/w025StfF2Aw2g26m4 qrsB3OVqL5VK
9vuVYtGJLrLkk5Xc7r+/ISWuVaJDaUL7GFOwXSUOKHNegIeYZ4BGi5WgsaKp E7GoCbkjd23i
Wjay8uPy+mZ9x8VW6Nzi8+lSn5/vn3j3j8bE/aGR9fHdHxUpck9JPmx41nqf Y0Dk/5GHpomb
KoekVCIqFaqKkjGtpGTjJK/OLk51erL7683anba+qlMFX/48nd1q9HCbkyeJ RwwhDj6OiY+A
Co41NK0UoUvKXIybC6hyzbv4WFfHydU6ScnlgOQOJBEGJMcEiWTh2AqgIZXo LFosQ1BlDAi7
IXl9cv3yp0HGhgwaZBwTGVWFQ0IpIZAEtFi0aPZpM0fHsFlRZXlxemvli8/e LQzx+dRvTJV0
9vbuyPrZ6WrR+WOe2fjIxSJwS0Vgj2VT5i0WMXD5OLhwhSw9WMFEJQcBFokW mzVCr3KLyzeb
RnE7BwVT/u1JKOGpgxJCGJwcGycETZuDmxJLNmukMXdzzwIR3tet3Dzf/O0u hfZO0/7HBeWh
h7zMY2DkmPDwUEVab71Eqp5Uck5oaiEXB+7vm8eIuYyJjGMi49GjUWMGZ+pV jICdMbl1NoNE
3MCHkPzu+6whJEeISzdOjUwzVFIMmnoQdIlsoWveEpLHdCZDSIaQHB0nmCP3 HksPhXoJkokb
EzBmIpW2tb488lhffqwvf6w0JKnFiMDViUMzzdDELRQIOUPaub488lhffqwv f5xckEhAiKkT
kLlwVc8pN9CKnUy2M+ven9772f79xae5svzDCXQLwwEXkR8JdH8/FV17rZyD 9UzuarVnidBS
Ak0GcSwiP6vfGIvIz2vzM5k7FCJl+ttCKkIRipSKWBp5yyVm9u30VTD0YujF sdJg1gG4QiWj
bkXNrTVIjVtMOeHu9FUw9GLoxXFyEbREyKbqQgQmEhsri3VpPdRyVy8Wf966 nf3zzXo/0ymu
rt7i5eu9IzyOVTW40FCNPYE6DCG1COUGpQUkK27asOfCmhlT7zJUY1YfMlRj XpufydxhEKHO
YESlMZMQcfFeRQKrBbW2NZKBWHC4xnCNTxoH5B0LX1ld/QtKlMAF0GtN5qF6 zDXvco0VGkM2
hmx8wmDs6CegBCduLdVE2UkEqVDuqkHdLD8oG1Nk4Nvl6UY1Fn86v/7Sp59T 8/rqT//zy+X1
l3jzY3E63WptiiDcFr68/sem8IvbX3yx+oiLy+uzV//8bvlqebWcjnRxdnZ6 +2tTXTxb3tT7
s1VG2mfrQ7vzX6f3VkDVFwi02v7rpmD97qvzkx/fvoD1Gzev1y/v7e+mcDqP F/sif7TuNIZp
9v5++IjA7+oJu1pxIo5AWZtZahKwZIzUeqnDnWZ1icOd5rX5mcwdBhFkVhIh TIEEQCJWiFiq
xBK009YwTU5DnYY6HSsNTWMpRsIhEwloKqS5GUXqicR2DtPkNMxpmNMnzMWu 2ZFJXTO3yEAi
3cxbC1HJU8zR0y0X3/qm5lZ7n0Zmni8299SbzAynK3N6fk9B9iXm0xSPldFt Hfn7S+/ICHIu
w0b2ZO4jQrSjc2HhoJlyiESsRTF1apVKStyKpmEjs7qZYSPz2vxM5g6DSOMG NRNREGpOmjQF
rJFVS48Ut2yE4rCRYSPHSkOqgilAyE0opWaAXDEy9MoZU99pIxSHjQwbOU4u DGIDjjmgUavZ
AicuFJuzawZ/T0yKrVCYmsHqnSk7w6vr1Q3WD8tN1S4nU4EPlOTn05SRR4yC 4JhBti9dh8El
ITuFCB6RJAUjLcjg1ir2UG14x6wOZXjHvDY/k7nDIFKD5wZAmIBAO4P0XGoL 0koWwxELP7zj
CdHAwYpE7aJCEtCkcYoxgDEHDDxi4R/BxfCOI+RCqVJpGqMTikqsqYAqSim1 mo5Y+D30YsTC
7w/RYaigFhhrN61EjlGksndMxSqIUB56MavfGHoxr83PZO4wiLAwRbMgQYmZ pZsbd2+9FG5R
Riz80IsnRIMjS2xVQnZiJ0khEJihCqP1NGLhH8HF0Ivj44LFOWUMEAKhs0ZL QbjGKGTW9cHw
lBEL/zjVGLHw+wN1GELECrRYq3cngqq5aQBj8yZWnIZqzOpDhmrMa/MzmTsM Ir0wNo3unclb
ExcmBYdeslDA98TCD9cYrnG0OBQDztg1lkalIocWUvTeM1pUkAdi4YdsDNk4 UjByS1DVtBqQ
i5p1jLGVVtkBjB+UjQ8WC4+w+nMnqH06ybPry6vbfX5/fXK9Myb+zf1ju/NR m1ZXX+RNhPy7
ovXm9s5GQPzDAjXGavb+kjgM9Z6qZGFI3AkzSzNG99gcI0kaISjz+sUhUPPa /EzmDoOIRMrM
WaJUMgPxqrFg72DSIdl2QHwY/jT86Vhp6ELQsgMUJA2JxWvqaBUVp2LcHRAf hj4NfTpOLnIk
66lxqUweWTqFWru4tmwY4m8GxG+2p7NbR8Jv+8eIhp8VDV9GNPy+wB2GoIiJ mtauHCjXoHXa
CKEnU2AJI4XKvD5mqMi8Nj+TucMg0gPk7tkBAuVWFT0iY6gs0ZvbiIYfKvKE aFAjF6cmgUha
tRA5xF6xmkQyHNHwj+BiqMjxccE9ucWGHCIV71Y9KdRk3CKA64iGn8HT44dA RjT83nQdBhfq
zgypZGKCTEoMUxlBC5m5tuEdszqU4R3z2vxM5g6DiIfeqYbMMVBrog2CZMda QFEbb3lHoeEd
wzuOlYbSHKgX64jkyGZJAlksuTeKEHd6R6HhHcM7jpOL6AWsibSaqISoMUUi jAEgOoT6ryGQ
25V/b29o13t++3zx4+Xqpup/F+dTU1mhcvXLxep819X89i+Li19ef7t6tfhq gfvC82k6yPsH
RLZK/uv16R0tCZgOqCWZAD4ATfMa/weH70A0EUqrLVHL5BHYHVi1S08xCpah JbP6m6El89r8
TOY+IiKSdyw0oWqxIoARSjPJIYFEN+DcygaR7y9f/ry8/te4+zoh1nc3WDxf rPhZxMIf6OnW
HxeTt+urMDFy82ILkETbN2TwQfm4qYf7bCTmwcZHYKN6jdB7kdgoGTCT1my1 OmMs0bfYuLsq
0fPFba++fh786ury9eK2TS9eTvduF8vzJwwKRRmgHBMoISZNwSUahZpMC9fU p1eslAvfBWXT
X5xcT4MkJ5OmTFWxrpLz5fVyo/l/2VTv4uyYb7sexCSlgckRYaIlFHdtPXTy ntkcBDF5qtG0
0uhPfjcoBQcoRwRKVOzWQnZiKpwYMXErpQlMsER8Lyh//2n5nze9x79P1bO8 er74/vrq7M2b
ySd/WhfcQHNxefHF3/+26WieMDMxwmDmiJipQuScS4JOPRX2qpiALaMIxnDL zNvlxektJovP
3j3j+nx6/DVV0tnbqWamvuTl+sKfTStZQBjjj4iypSt7PAGe99xr4PJxcOmt 5SQGXJxQotYS
vZWuJqRK7RaXbzaNYupNpn2+e8o1actdVL6uC4Tw1EEJIQxOjoyTDDVjC73E RjWKejKqpWjy
RK2XkcRhTFt5QjQIp0LYUgChwJljSdQsapeakvWRxOERXIxpK8fHBVXqkZKU nIgSC2kzJ9EO
OaRWRxKHPWbFjyQO+0N0ICrArGLjWpkoZykawBkLOBvSiMad12+M6Sfz2vxM 5g6DiHOLzal6
CiQ5s0Fu2HNPBlKMRhKHoRdPiAYTzBSxWUQKvQrkztIAAnhK3UYSh0dwMfTi +LjQXKshTRg0
8g7MxAIptW7FG9iD66qOJA6PU42RxGF/oA5DCDXqtalZSpQ4qIgWR0q5as2t D9WY1YcM1ZjX
5mcydxhEUhUi0yKNqBJwBxGvrQKkgsW3kjgQyXCN4RrHioNht4xClokKNO6O yBU6iLa6OwIX
iWTIxpCN4wQDPZeioWeKFElEKkdXLJbAOj6cMe43kji8L2XD3cwOQNtpHOKd tAvTEV5d3+7u
96ZuOD/55eLlT19fvLpcb+qbN+dnNy3yFqyTH86Xtx/83ye/njybSm+23jXp m+1ndz7125Or
qUVdL69eLL5YO8b52Q/P/+Pbr+3y8vpvl6upl19NW+sL9vzt8urXafvl5uhO v/R/m07q1WLr
PF5Pp3t2cfZsms25Ctn9xz/XGSTe7Wu9eecM1gU/L5dvvrsJen4B69+4W7Iq uLj85vL6bLpC
t++/215v3rtCf7171UcOiwf9cQxV7f0d+fG+9CKGHbNHQxUq3UOi0ESytFxL YU1UcqrDH2fd
Fgx/nNfmZzJ3GERKpFoCFpNKKTfGTME0mkSIueWtoaqUhj4OfTxWGiwodHbq uRKkrl4stvWj
FGg9w86hqpSGPQ57/HS52Bm6liixgFYhEkLRagG4TSXEavjoHBZ3xGNvTj5N 3fg/9s62N44j
R8B/ZYAFLjawCqpYJIv04T6Q9YLLYbN3yDrfDBwca5R4V5EXsrS7vl9/PSON rFiO5JblTNyu
D4blgY2e7qrHrKfJKo7mFR860x+ctE+Hzm0hRQCImweQilWrmqYYGgKT9SY2 HGRWcBkOMm/O
z2RuP4jEGrClAGYJc3JrUHs18p6ckesNB8ljN85wkMXSkJKHoIk4dMREQlAp lA4gqFxvd5A8
duMMB1koF0GsY7IsJaN4MLLGoVcpWClmv+TiumFMG5qfbsflyWoXPFYnU17k aJcempCZDpbd
DfVm+XWRKflYfL4oNUHYZ3kdxwwPQNQ8AB4cwP0QRSqSouWWOwoF8apeoWmW WsVHi+95MWeo
ybw5P5O5/SDCoRdA4YAJG4mrNGDoRN051z7UZKjJF0QDGUvWXhAzanMxVYcg FllLiTrU5AO4
GGqyPC7ccsKAPTRFV/PYs0nVwCloy/nX0yN/3trINFrvaMvFmO385OXZ+ufV q5NtA4yPxedL
UhMAiHtUk5E1uT9RPSFF7cKSMTKLhcRda63SulcYajIr5gw1mTfnZzK3H0Q0 RW3ac4yM0UgD
UnNPGsG0SRpqMtTkC6JBIEVF7KVUDLkqSgeJAjFDIhhZkw/hYqjJ8rjwHqVT 8+KO1F2oA7YQ
wVSgo79Vk+sGssmXTMeMr/8x3dtuSC9TI9P8OHp1cej49X/xp6Ems9QkIu21 /d7ImtybKCya
EC0GFOwVDJCTVxCtCr3zUJNZMWeoybw5P5O5/SAC1AtJyFIERaJkT4UVc2UJ YjezJpiGmgw1
WSoNWiNz9K5oaJA9u3dLyQtDb73dqiaYhpoMNVkmF4GpgMbmATAAqtfICSVG SxxSf8/xyr5B
YZoG225hx+ujs80C64f1bmjXU0YlPFC/1s9TRj5gM3vcZ7XWSIncH5cSmTBb AWlYKSuLAyXu
mIHJ4/COWQFleMe8OT+Tuf0gYqqxaOWkBYtViSEwtC4IiB1vpERigDzEY4jH UnEonhIoCBTG
nMEsUy65WQVPpPE28digMcxjmMcywSB1SC7k1TCgORmXXChxU+rKb5Mih6/K 5kLrq7zIX85f
bH44Oj8+fnOZEVkf7gZ4M3VXX5Unz8LB9998a8/8+Hz9X8/fPLs8AezZX0+n iTvN4N0hZF9N
HcFfHq4Sp49usvd56so9cyeg+9wMP3In9wcPvShja9IYxZs2i1IgWAlJoo0D neeFpuEw8+b8
TOb2g4hG05xb765YuJi01HJxj71zK34jdwLjQK6hMIulQaxS9exeHWsoVgWs dMrUYil0q8Io
jAO5hsEslItcQzJO1bBhxGCCnWKoHjIh0S5KPD19Mz388+lqcTXtN9n19p7u 4/X58dnqYBUl
hI/F4/NUj7szJST73DwyLOP+cGDKKplygYQtRY2BmCwjYUnZb/TEkKA81lBX a6i9NbtH5REr
PgEOuVvW3rRTxSDqtYVonFtNECWMhq3zCBnSvUBEQirdPVnbSje5I9fqUSs6 FOq3ZkqYRw/8
K9EYwWNhZEhkouDSqaDFLsl6joF7TiIa2s3z4Ucp73gdtVgaCsdKoVMOgoVR Uy4arHIKWAB3
icP/nub60avjV/9cHRxsbut4O7bTnV3FjR/Oj47Wp6tHkTmOfnxXwOgIHwsD BikFD61JFDQq
bpatouTcXLKW2xsqjNr38f52oVxYTFCBsbBi70WshelXCawkXOKNSkXmOI5v GO+oFstDK+wl
ZKpVsEdScELill1Mc8Ih4B9ExhDw5ZHhKTgUpMIRY1VN5JLEUtLaKV07wOGn KcN3vKtU3F55
qlf8w4aQ04tOoduxfb36j9WoNrxWbXjjk//9+fB6saGkfWYBMYQHAGfePH9w zvYDDnDoTSEw
FYytSbUUuKpD7U1snG49L7SMtMe8OT+Tuf0gQr12KcCxEIIlJa8WDKbPc4tp h8jr9cnht5fr
rUevX7342/rs8UTMNEAvX+9KSjYP/eXkKQEfL5eUi3ufMLn44aaYSLyBSHhQ RP6yvfBYev1G
eGiDDoAIgh2rCbcEoaGk2CLnmycs4lD0kftYKg3YKHqvMREj9eBUDbvmBlRT zXecsIhD0Mer
3GVyYaEiRU5cFLkH6VlqhZpK7UB4l6D/+GrjHP/cnu1+w9X/uDo5//l/hrXP tnaIez1dcVj7
vWkKlpWkFUfACkExgnQCyoUslwsl2a2Dp+24mwtG5nhZwDt1SbhuJN/UVQz4 sdz8foPOXUKi
CENIPmy2z6RtP3BAxlATGiTA4OiZG1V22fZFyKOSd95iLAYdicSlISI9clfn bI7AZk0ZgmlL
PQVvOBD5eESGsHwGiID8KiIxdYNITNWxkxpER8wl1Vaz1/SLJdZu9Mrxy+nC 311g8WS14WcV
QR7osMXfLyZ3rbAIeS8rLBIZbHwKNiBGSBSxKXIV6Q2BvTBayaXSe9mYXgAf fvv6x0nmL61w
85cuWiRczunVi8n9T9bHXzAomHSAsiBQHIyVUo3MWKJJSaEamQaAnnq5Dsou Xjw/Wx1Pd3a2
moZiOyTH67P17jXxH3fDu3q55GXXnZgQDUwWhIlpBA3QQ6uIXrwljhJyDylj 6Triyb1ByfvJ
tQ9QPhEoqUj3Kr0hemZHD1RKzCopSpX3gvL0p/VlXcp/TsOzPp3eB09dq/7+ 98knf9p+cAHN
yauTg6d/2gWaL5iZlMJgZkHMJMwxceeCiEmbS5HKQEGgc/XdrvVJ2U/ffHeR VrRtTm16vtPM
PVwaCM9/+X2ebb/ft89Pps/fMhCZ3wkcD/s6a3vR1eVVBwW/AQXqQtmVLTYs Kpq1RaZYC2KF
6qOIcV6Q2FcR48Dj0+AhGULKUlvtyGhGWBujaw7Zssj7EuoAeaTTf0fp9IHG /dFAiL+KRtcQ
Qs4laUNN0Zt0JKMaM0BL9m59L46TGsYO3MXCAFKJklJOhlBIKorVkGtDCgT1 tvJe1FHdO7bf
LhOLEoJBldxBUCRbruylVahmhXSXLC9Xi6TJ/Cbxm47WfX29U8jzw8P14bWl 1HYlRaujV6er
q0m2/SzAv/3hX/bvSyPpXTV/+7ze9fME8kuGHhagtxfeOfqg6DegKGIDga7e FCmxubfSrGuq
miHugsufd/+zrn5cn31z8nJXb1Kfnz33abD/9mS6pbPz022BfLnuJU82OH3x y7LIacSfhZHD
mLJHUwVA9ezaIrWMCSkrXBWkfP/9hgF8zvjiCF8cvIgKB6h0eCAB0sEPxEdH pCqY8xcPCUIe
kCwMkmScQ2DNnLFx8JSL1SzWhC0kfze87PaN3LJphL50TABgYLIwTJQbBaGW pKJIscjBIGrK
LlhiGbXxswgZ20c+V0RS/lVE2AQ8ZRRkhJiFTXOwEAorRPKbx12PBtLjyIfF 0lAxAkX30h0z
Zc9RQoLiOaB3wttP7x39o8eRD58zF7cspKxllaI1hoaZXakRhYScWlPPbcvF 5cz96vXq0fQo
vr7sAf315jiDr//6j5/PXj7+ZdnJaqpDOXgI83j/1e7m5ndw1sPdTdkU9F2a 6N4wJU5wAdPd
T+8tVTlHfgBw5s3zB+fsE4JzS0ChDqWUAhUiYjdvRIk0WMecyXgYyKzQMnbn zpvzM5nbDyKh
J/CuyVjRgbxr7J2wteji+T0GAsNAhoEslYZM0gShsXXMqbkqobVoKikC2u0G AsNAhoEskwuo
kHMH6oSIKQtDhlxYwQq0jNcN5FEM9PjJyjcoTNNgu5nweH10tllg/bDeDe36 8MkqPNBxDos2
EIk4DOQhONsPOEzYFb3mCsgFLURsKo6eogbUYSCzQsswkHlzfiZz+0HEsdcu gFQIsZK0Xp28
RIpuqPWGgfCoix8GslgaalUVMDVC1JqkBzUhTRZ6SplvNRAehfHDQD5nLm7J gVAgIiy5G6JU
9pacGCgEjpZKueTiahU9ffMfN9PidPunJ6vtb3emRtaHm0WYldXHErRoJUkZ 9q0kMQo+AEnz
Jv6Dg/cJSbolwqizsaWKCbC3YpgkU6ueMDS1OJRkVqwZSjJvzs9kbk+ImAaQ WBwJa8ieSzFr
PWaOAqI3lARHWdZQksXSkDiIhiLFABOy917NuCCaddV8q5LgKMsaSrJQLtQS NdEoGrBxkh5q
6y7ek4QWwk5Jrq+iVwfTMK6/u3STzZ7DlxM2/7f9Eo8eP9BBWYuWD4Y85OMh ENsPM4ilFgEV
EKwortXJk3YVq1X7kI9ZUWXIx7w5P5O5/SCSIGrrGi1GFG5Sm3AOzL1313Az H5JGG9AhH4ul
IYQWYzdprujSHWPx7qSMnZvorfKRRhvQIR8L5YIMg2Mnq4Yg4L3kTNoAGna9 6s329PTN9PDP
p6vF1fOTqyOBpvt4fX58NtlIlPjRjT4X7RskcfjGQ1C1H0wKSCbC7hxRWnBr BVTJSkwYxx70
/2fvbHvbOJIE/Ff4KfGHXWxVdb11gjXQ1S+4BQ6HwyZ/wGfLG2EVy+souM2/ P+qFF0W0GY1e
wHjchgFSTWk4w+mHNc9Ud/XCQDJ9Y1mfX8jccRABYAIq2KCwSHitjmG5cTW1 XO76BuH0jVmX
dLU0YInI6slAWA2KSafWolJETXbQNwinb8zCpCvlwmwAuvXRM7MW51K1WxQn ipzaDRe/GXX1
YvPxa9s/XRUjfapsxx8NlvstC0LZjrMsyOTjefjQkZNCz1QGm7sblTS8SK/q 3uRjy4L8Khif
XhpE5lUWYs4znKwMl2K5NhzO3VlFg7K2XAUExZKkvSQHzRFWM8mxWhpCclJz Dwd2qq6l1Io9
2FACDhe+ojnCaiY5VsoFRRIZGJUH545Zk1cGF2GmUnF/2vndNW1fPD5erDq7 YQ7Hzm7M2eUP
50NBW44hHM6jDBcshcQ9e5diMLMbiyLIzG4s6/MLmTsOIq1D5DpyQOIAKFkR NKIPRsyAe6Ih
M7sxRWO1NBRnqqNJH8LVPCgQTJnDpcKIg6IhM7sxRWOlXDSTNIg19cJFIYcO HTyESVuY3xaN
zdcfv6b9evPDdoTV2fY4Lz/CzesfH53ZWLV5uM26Vk/C13GA0cKpWMpDiKNx 7ibqXIpRpxCf
5rEopEzzWNbnFzL3jIhI+iQiQ4K1NsydOPXIPSmMYTbYOGe/ax6IM8cx1WO9 OHgXTeFgDVi1
Re+JeuqsAFALHlIPxJnkmO7xWYNxaL6fGXij2kYwQs9S0wAc4OVSzuV+7vH+ 1YdtTd2deWy+
Orv4tm4ft33sr1/96+fzi2/x+mHzZnu9tWsCuWl8ffHvXSNfP7y83MLVVfxu svp266enb25+
a283Xt0a5XRrC3+5s4nrxu2evXwsyeuWo5mWeZovgGck+kCoQy6lAQ5kYc0j lLONhFFKi85t
ytGimDflaFmfX8jccRAZJY3gMpSVi5Rckhq1moePkNC57Mh0oy+Ihg7emFQp MRflGDVLDao5
pNWc57Ij9+BiqtEKuSBzC2jNB5uZR9Y+KNWsQ6PjXHZkKVT3N5C57MjTcHYc cEhabQ5orTNz
K3UMSwwQTQfDrPG7LLRMA1nW5xcydxxEuGmRKhQtLp96FQOGiOodCWLPQBym gUwDWSsNZNSj
qyR3tlq8JRUpraB5hqYHDcRhGsg0kHVy0SvW0l0ZGnNtEUCRaiFqzEnpfsuO 7Bo3/3t68cOm
1KsTdXay5eiTK5I8lqVVy0nKemw5mTW5Hs4UejfGUrsmliolj661llY5q9Cs ybUs6kw5Wdbn
FzJ3HETcxVs3yp3ZMLmKW1cwJh0SOzn5r12n+Gbz3eV7It3cC96cv7tdSeJv bYMgXzooRDTL
SKyOE0ttDC+V2IA9YU2k1NGaxJgTIJcRgpBnQbvPEhHnA8u9ZdVWBmRlci4Y FSmjimboKd0g
8t3563+eXOzOXj07vRq2dYXFN5tLfjZI/kSJkz8uJj9dfQpbRq6f7AEivG/4 8KR8XJ+Hu2yI
+2TjGdjoKVh1pBTAISM7c22eK6YcucgeG7dLS3yz+e/rhqtU49sP5z9ubvr0 5vV2Jti7k7Mv
GBROeYKyIlBgBJuwFc7snIOaBvQkKm4cvwkiu3jx6mJztj2yi832VPz/Da/d feM/7U7v5nTN
l12/i4nIxGRFmPSSU9U0omYmTN6HkXSknIqypRlPHgyK4QRlRaAADG3dUjdm InQyTWhDVZlb
iY+C8v0PJzelU/9je3pOPmxvel18OH3/fuuTP1w1XEPz7vzdn7//z12g+YKZ SQkmMytiJqWE
iUELCGOULIVBWb1azTjKDTNbZf/wy99/fnd5MOUqofZF19lWxePU2Z4UPA8F wzQguIU1JivO
lIZ7jaHkavixOtvX34+frrHNj862/9HYuH+QcJ8XVmvCwy1sRDdjY5fkOZnk Hk4MXAfcEfWr
rGFC+HTWkL9cNDLTROMzQ0PMP+0cXCyZVKXEUaEMldzYBCQ1U7x/IkTTTITM RMiq2NDckrgA
DeGBWopUUsecGg+RMm9cPRSUmQhZFygDOhO5Dh+M3cMyVRleWlOhjDMR8kBM ZiJkVZjU2mpv
qffITJjLAGf3IirCHduMJw8GZSZCVgVKp87BaJgHA3GmUsnVgIOGeJmJkCdg ZiZC1sUMBrYG
DWsVNmmOTJe8aBrZU+UbZv5xcnHVZeOX78//efLuxQbBkjFmyl/42qMAR1p7 dALxPEBY4dqR
GbkwR8tWhxVFrD60pbYHxN/ai7kEr2eZFKyJArAiwNIbNOaenIPFBo6COsjK XIH34fNCjrkC
78TleXCpVHNuCCmAoapXxorONoKjm35qiqHonGL4h5xiODl5Jk4qeS+WOgED 1MxSI3l29hGG
aQ44WSbjc8DJuvBAFS1ceuTB0SBMk1ttGATWAz824ATV5oCTOeBk9Wh0SI2h ESXlSjnUW0pS
2dU19wcLCU0hmUKyQlxSBaZGubXBwDl3ccqalGFoJLwrJPcJJvSlgzKFZH2c UOkF2qjWC/sY
zl4HY09kYQnyXuFS8lm4dBYuXSsNFqV3kfAibLkVTlgGDiUxC0wHC5eSz8Kl s3DpOrkgSJis
deDC5lBSbck9tyHJtML+0gl3h2G9eHy8WHURUptrtD0NTsfhwzFAODQNYiot c8cmOXckzwnH
rBy3KILMIqTL+vxC5o6EiOc2EkJLiatIIWpFtRGZNBTeEw2cojFFY700BEvP xVJu3Gt1KcMt
MlCBQmQHRQOnaEzRWCkXrAZSjUMHR2YfkrHXAdK6ltzuiAY9i2jcTBhZQsbn 6hgPv3urCLzD
5cAH9ysyid2fgIplnfjJIXpGKnL6dDKjVClac4zKEhQsRaO3oZJ0+CxMvSxu TL1Y1ucXMncc
RIbm3FKVCpU11L0JRO/oqRu67+kFzwXYpl6slgbMkoglt9KYvHsvpTZp1BSo /c4S0DwXYJt6
8TlzcWhUCEkvUYe5sVUplfMgjwSCrUm9rRebr/cuZ7/ebGeMvznbHuLlp7d5 /eOj5zqtVTXc
eKrGI4F6RkIORA5wSlqbbf9zYCpSIcMYhtkzdJmqsSiGTNVY1ucXMnccRKKW CtAisnETzlKk
gGLmao5tXzVEpmpM1VgrDV6shQzWZKzUg8lSISwhzInqQdUQmaoxVeMz5uKA auRoYiBCI3Gp
FC2jCSWuFC4Qv1WNj4/OeXrfWPUYKjeeY6iegq9nBOZAIKnOvSFRhLNA9Y7W WpRCTtgKTvNY
FFKmeSzr8wuZOw4iliuyMatnTlljoESvmTkxqeFd80B0neox1WOtOHjuzSVV B+A0JHgMkFw1
I/VR4ZB6XKIx3WO6xzrBiCgji1sHZW2RKwFhltoUzILu5x7vX3346eTNzjw2 X51dfFu3j9s+
9tev/vXz+cW3eP2webO93to1gdw0vr74967xzze/+PJyE+/OL07f/vL3k7cn H062u7s5PX1z
82t7+3G1f7f+dPvaJVXtJQJf/vyXXcPVq2/PXv3jp5dw9cL186und97vunF7 HC8fy/26VWpO
R3mar4vj8C/DsBQfNQFLpFCU0krkhEZQ21SpRRFyqtSyPr+QueMgUjE5C7Ib M4woaH0YDOyV
IvpHkjhpmtQ0qbXS0L2gSIgW56GWAwGoWYdI4pEPJ3HSFKkpUuvkogwoXiJj bTxyywhGXpNK
QdPIH5n3HpcobLvB5Subs5O3F5cXWP9zsju1J2++2cATLfi2bgPBmcx5Es6O A07SUQEbFXLu
gzMms16L14DsRaeBLAot00CW9fmFzB0HkYACrREbVQ7spQYriDBq5yqyn8yx OWVlKshqceiU
e3dPqMKII48c2C1yoYhB9XAyx+aclekgawXD3av3mrRyoSiECiDczKRIK787 Z+VheRzaz+Mg
bP/dzuVsD/L04vzDzXt+d/Hq4mA+5/3dfbu1qZvXtrmcpImukjS/Nl39uP9m T5jMWe08nDnl
/9FfEsehPpKkaMI9hEfB0rqHcc82yLnmKVCL4uIUqGV9fiFzx0Hk/9g7ux65 cuOA/pUG8rIL
xEB9kawS4IdisYgYyCaBve9BsJKxgtfSQjOCkX+fntFMJKO1M7pqyW3d4Ysg tR7u3CbPFA+L
rPJpo0cbUIa0Ojt2m4bdKwWa0UkKp9Lyp+VPe6WhuyW32oJZWu1atUSx5ljY XMqDKZxKS5+W
Pu2TCx1YqAr3RBnQOjTrwNDQU3H0Oy7+K+5H7ubpx1s3z+7/fXy7G2969hH/ OBeXb9M6blzu
5Cf/+KcfmAhqa0tFzgTuMgRNCwUhlzlk9NEhYcoEUO7WqC8V2RRjlopsm/Mb mbsMIgRJdXqR
0sVz9uGVptUoY9QJ80RFZJ0mWyqyXxrE3JBz1iK9Du1SZ+mlDgCUeLgkgKzT ZEtFdsqFR4Il
Q1cQLuA4RyZbpHAanBQ3/seeJvs2ZeQTUiC4SpGdS9dlcJkzCiCMBiRFq2Ph 1sNqOIx0X96x
KaAs79g25zcy9/UQaYq/jYjAZIpBLBKRfWobCI2tVUaHv+uXfT96cXtr8o/v sHh2uOHngKJf
KIz882LyWMPsInU1zN4RG9RwMFUufQomGGQxyRAA7z7lhI0Pu0g8O9xF9duF 15/fvP7r4W5O
H3461mR69eKXJwyKsC1QdgRKMbDog/scUkB7k9qkcuteqTN9CMp9vPif68Mv xze7PhyH4nZI
fnlx/eLe4//1fngPL/e87HoUk1IWJjvCBLIOIJ7ZpnhlS2ugwlQ5xJ1XPPls UBouUHYEClMl
gxEhQ4q7VafhVvqEASrlo6D8+POLH95Fj387Ds+LN88Of7p+8/LXX48++fPt B++gefX61e9+
/Pf7QPOEmWGGxcyOmBmAQwDVxhQHcirTaIgVG97Z75i5evHq+R0mh+/e73F9 f7h+fRykl1fH
kTnGkp9uv/iXz79DoJVgRLQTXTljB3jbvtfC5evgMrVNJOkKLCPZm4uGlV5G FOL7EPMf95Pi
GE2Oz3y/y3XUlg9R+cM4INBTB4WIFic74wRmpyqAqiyU2oUagfRoXRhKXU23 17mUJ0QDM6Ji
g6giDqnDDbgr8DQjLavp9idwsc6l7I8L00Eh1K2xzEzrwcc/G7IBtrTVdPuM 4yer6fb5EF2G
CowobZAFTDFl1+aCNGCI9BFtHT/ZFDfW8ZNtc34jc5dBxK1HcyVPkxypIAMl dSohRFtNt5de
PCUaEgm0cKCpeESvo0JKNR7pVmk13f4ELpZe7I8LzUouyj2bhI2uZkW5B6l7 4f5oAaMv3QRv
r6qxmm6fD9RlCJHGXsKLZpPC3MGbz0K9oeDg1a9hWwxZqrFtzm9k7jKIzD66 uRYLll6LYYUu
qW00L9z7abXUgss1lmvsFQcIEY1sA4bMXpxpQEMJL9qYysPVUgsu2ViysU8w HCdH48KVBEvR
jNKkTkWbwTgelY2PV0v9aG3UD0uogpzWS20f1De9un59Xx7n65VI/eAhqzTq o7a0EjNn/0a4
DOJTAhRbK7WJ99ZNZxMhIyROX6VRtwXBZUvb5vxG5i6DSKm1U3HCEDFmUykA YWlUFY1Pu9vJ
kqUlS3uloUdaUGjOEB/cYVbAUoMrMEB/uLudLFdarrRPLiokta4+GQVtKufE SPXulWboJ5dG
fe8dZ2PybdrGKon6qRP9i4P2Fcmx+tsKgmpoVilQ5gwvxVmk5chqJLEUZFNs WQqybc5vZO4y
iMCUEpS9u4jiNC+z9RYZqQ0QVknUpSBPiAZPxchSpYJUqaYjgpRo0IwGY5VE /QQuloJ8o1w8
pCBIw2DMxBCYaoDubmWWjNETV0nUDTx9eupjlUQ9m66viMtD3mGTJ0edU6T3 ojR5UEG3OV1z
3UnZFlCWd2yb8xuZ+3qIqMFvR5RsOmarCCg5rU9IxkHpk5zy1DtqWd6xvGOv NAxrdUQR1CJe
0lXIw4KqNRnsD3pHLcs7lnfskwsIN9VimkOE1BvKlCwSQI6V3qc+bi+fvLhb 0N4++X0xx+N/
Xh0n68sbcP728vrnw/EB12+vDvD3oQQ+g5lvUz0+ngc5+eS///r8AxshvaSN VAH4AhBtm/Nf
nLnLQDQkM+ZUH0N4creYg2E2z2ASXjayKcwsG9k25zcydxlEZskGMbM1ktaq zj5xcIGWs4aO
ExtpKwuybGS3NCDEYJsQUqQbWLYOrnWKWvFRH7SRtrIgy0Z2ykWnUm0UmmFi UXRORuMRniEB
+YiNzNdvXz0/DtOLexe5b7/AlekmU3LE4Th3vsAS6ylZidGykjPZuwxM1nHW bLWBi0jXHL13
DEUmByjLSjaFm2Ul2+b8RuYug0jPHFNKrX1Kp2phtVecQMFm1E+sROqykmUl e6VheM4xBwqk
OHdtBIFMStlAEh+0EqnLSpaV7JMLIpPBBhOrkIzuI3MAouiA6f7/VnLbXeH5 zWWQIwKvbs9j
/effjpPjBpBfXz6/0ZCzmyvsyTweuxfCtS71OBOwyxDj3jARy6guOcJrDilN wg1SRy712BRT
lnpsm/MbmbsMIsMH5ZyMMWRMUTYt0qFFEaxMJ+pB63jWUo/d0iBeOmOQZpNi qo0zgKaU2Rqj
PagetI5nLfXYKRdDp5ADpXZRmB6JUHW0hOJa9I6LH9/87/HLf3t8Gh6OiZH7 lm7H97h6+8v1
4XcHVIBz8fg2zePxSyBFcVnGmSxdBo4+jAoF4ugikdoaCDoilFp6O1lCoa4l 1Psl1MVaHIrV
FSq+Ag3FUwq4MLuUUhXNg0tH8CFg+GAlVF1LqPsl1OLiG+TCoP4mF421jxE1 1WRaM0IysgIj
upivmvLbCFl7UTtEhGsguwwhFcjQxtzJuE4Wd46TvahVUn7tRe2Xhg5Qe0Mx ryLGjiolXGpQ
8hj64F7Uqii/9qK+ZS4e1G3ymjEkNWRqs4hRRhMrkibFHkqD4+GH49tdv35z tXLhn5kL13UM
91zKvh42D4WTMrFwD20qUnvrNqMhCHLHkb3eYXN1ROaHu0Dy3dXrn/7y4vr7 G3Kuf355db+f
e/Olv3z+HYJ8fy46/7zx5d27H4PLu7+crrgUTyILfDYJH4ssf7p98NLzfwwe HYjLYCtZZODQ
WZmrRUrMLPHOPe7H5DayXB9Q72pRH16/+pCNP4wDgjxdNExoobEjNJqzNA+S 0QQZDGhGjqGT
2GqjtXO1SUkQbCU99oZIjlpK6ejahJV9VsBIg2BpZroQOR+Rpe3fNiLBDaXW oT1Epql2NVFx
ou6hcx00XJu7T4gGBawdWLSq1FaspcnMZpMgRdZBw0/hYm3u7o8LUJ91AmMJ Gc2tQtTsU6J2
69LWQUNYBw2f7BbuSLDEQuEiPEwZp9aJrY2q1ufpQUNdS6h10PAzpvdGvC5D AzLAoBIZKpWa
U6kY2jJbqwPWgapthCzn3iEifQKNzkHYxat7K5ht9O42y0h6+CyuLstYZ3H3 yUWm1p5VMEzU
SEdODZsyIZIjVy58W8Jv5cL3hQdmoo8xa6j4aN4n1uzaEjKhw0dz4QVXLnzl wnePxuRZuEsp
TGKj+nRL4p4EVoesXPi2tdXKhe8QEcoiTQcAixCkJY0C1QM9ioGd3uJYJdZX om+3NFTltNCq
tcnEtKlzFuYsVFuv5eFbHKvE+kr07ZSLaKgxoWdW8TArzLVBULNei8yHbnHA 4X6GXB3+/PrN
usfxGfc4BFaTp3M5uww4Gn34AIU2RaF5r306+cCSWTsuA9kUWlbaY9uc38jc ZRCJ0huCmWcK
M7pXmTy4TTJoBstAloE8IRqoFGpEUrQIz2baC3GWQdwm91wG8glcLAPZHxci oK0CA1Tpxfoc
0QsWYAMEs0eaPP3LDR9v3r66ecnbsb06/P6A53KyJwV5pKETKi8DOZOzC4HT yHkKgaLE7Nqq
/h97Z9vbxpEk4L9C4IBsDtj4qqqrqqsSnIF+3Q2Q7AWO78MBBwSKRTvGyS8n M9nk39+QIiNZ
kmXRso/JqP3BEoeUhjPdj2oeVtdUyuaMnZ113FV9v9AyDGS/Ob8nc4dBxJAy OSeSyF3JOWfm
VmOrGhvT1TazPAxkGMhcaSAvpXtEjZVTc6PupaWigrHXZDe3meVhIMNA5skF RsFE1DsnRkoZ
mhrV2BMahxreYyDPXq0vqv656SR7RUb+unj584vvhpbsrSWEMrTkjvAdhqbu GVutwTUyBMtg
2itbMUJJaSzN2i/eDC3Zb87vydwnQiTog8DhnYhklkrRao+JNVjyKin3lNAK NclbRMrvy3e/
PXr5bOob+MU0cE/WI/n055OT3xZHx8fL4wuLfDdrfHWTiv99lm22AX/2L7+m r+aG0ia8XIgo
b52v6clziALZ2wx9eCi5CtDFgVps9/w2RcyDok9AEVSOmEvN0piMLEgGzA1b k2iSthRtlsUz
nNnLOuBMZ37aNDcYzuPKZr+bY1zvfQouj1I5e/z9z6/XrzjHQvxKaOGPS8Zm v4v1lulHf3x+
Mp3vKcgMPD4WHuLvxCOCxM7JCjMHimaZEnRpnTxBiTfZPs9e9q9AUsrjb75f nv5yIWqQy+Hx
YFUYeHwCPHpmroxNa2CHYAEtQ8Vknvm8ldrWEqdDucjHyfLls9VPv2MyY0m5 DScB/gBhZHDy
iTgpWIuDcSTnqGa5WA0UGGqgkvgqJ4/SD9+mf6S/tR/619+0+40G6ggh80VD AyVVQufKGqtr
y0BYPUkFyOlSdnHx3X8+3iCxHooX69tlPT199eIaHUGYNyeTj7w4/vvmo/TT N+cJxxgHKrNF
JTQNtVXs4uwgqbOgiJPF3qrCW65uw9X/oK4+8LgLHjc16+zdokPAUth6y7EF RiWB1mLQMFy9
DFe/x3iwhKQJegPinswCJSwB1QpBIh+ufmtOhqvPmRNNFjp4zC1zT+QcU8Cs EINk9zhcfbj6
fUWjSbKCIGSVqWPOyGoIXEVD4Dpcfbj6QOUMFdJWzclTZ+5RE3NCJYglIqO0 4erD1e8zHlxC
wtZMMLIWz60QlF6Fs6kHu8nVbbj6cPWZ4+GYq1k178yxUA4FnaiEWqRCwNu4 ug1XH64+d06o
15CqFy/CAOSxx14liruXWOhaV/9be/zDd4/+47v26PF//fDN198/vt+AoA5A /tyA8I3tbl1L
QSYjTtmsqZdMPfaurh0vagjC8JDhIXPjg8MDJHknH8VaK700CZUxeOqtSSqt 1BprqG93St+N
49l4PTqrrfpysS7CWmCg2V9uve/28MJ6kNvDi9lg4xOwERAoFOhUGkNBZ+1C qXTCilz5Wjam
z36Pv33zbKro3V50rV909rnvdk4vnkwFwC+XJ/cYFA4+QJkRKD1TLDW59MBS LWFM7NQiGCtA
vQjKLl4crRYn05GtFtNQbIbkZLla7iz+r7vhXTyfc+3uezERGZjMCBPjlKC1 XGrg3CF17hLF
pGZC0BFPPhyUeJiWVQOUTwOKECM6qyEylOjUago9e0gWkOVaUB7/tNy2d/v7 NDzL0+lW86vT
569fT7mTnzYbzqB5+erlF4+/2QWae8xMCDCYmREz7gIUq2CInLW4loyQNdTW qepO5CdlP/0t
/XL0/OTox5OzhuJvpjM8zd3juaFw+cYOm/d3+Z4OKHbJ2T/uXVE2O93dz2Fw 8P/AgaRcQg6O
BuzKmYhVyCk35WA0uoHuFyYO1Q104HEHPBjeiUdSa7m0QNw4FXZpQROEEKFx 7HJdN9AgMrqB
/oG6gQ40PhyNgPTuyME1xF56ToklNBOs1bKYEXdguH0qROe/8uTNSIXcKzYc CoJVQhL2UqwJ
OoZQapAcaxofXX0oKCMVMi9Qcis9t5aiNhaNKWRLTdyxC4D6SIV8ICYjFTIr TIJYDR27KHBL
YIIZI3VCZUAPI558MCgjFTIrUEDIBASLCHMqDuree8+YgDSPVMjHYGakQubF TGOQ2GIUbVzU
cwfPUmMrwC0F3jLzbLnaTNnPF1du4r/41/ucE4nuIyUyKx46JDflxsIYqrlq KB5jVYie8paH
p89fHqfpk91fztKCeXNWpwF+9T/T0a3vB3+Vk3uJRyAKg4858VFdsRWHrMhZ qlmtoB6Ld4TI
ehMfm+E4Ol0Tsno1ILkASYAByZwgUenVo+ViytibNSgNuUAK2UKvN0Ly4mj1 5KdBxo4MHmTM
iQzqyqhZeg8spoksAVKKSEgW03UrTs5bVL171QmN9qGIV1QE7tDAbb+2VQOX T4OLJ04UoYg1
Bqds3msKVaJ5JZQtLv/YTYrtIhQUffciFLrvoBDR4GRmnEQU1ghSemKJahUi BvMC2dgkj4WM
+33IOxYyzguPLh0TKfUQ2SClOP1zlBpzkxjhuoWMqHEsZBwLGWePBpiR1VYB lVHR2aCnXqIJ
QpYwhOSDr7OGkMwQl+iRCzVjzJxN3NQ9oxWEiq34ZSG5TTAZQjKEZHacAGnp VLTGygkxWaMm
iF4iePF26ebXnzvaGSAjbBiP7utzo6FwpUIg3IkpmCOHkno3a8W53Nhsx9Hm fgff23ERRQcX
M+NCJSBLISyZG5l3g2KNE8WivO30uZ25G6f48vLy3s/vHi+2mcZ9yLhhJnxy bDZ5wzdnX9bD
8N/r/zZn6OupGODBk9evd7zY5Thyh4sqReAtLjeduHNkApt9BCr2m8QfHaLD UCEcI5aCLUZG
ocQlAjA37WDn693X5SC/rf376MmT5evV4uXy19XiXM0Xp5s6wznXgdwubiD4 uKDaY87vydxh
EKmgtYt3N2LA6B5bYAGiWs1yuaIXDEMvhl7MlQZjDtIDdCRGjblB7tYiK4pT kBv1gmHoxdCL
eXLBZh1q7jUGphayRgZpqQRM0Llc1IvFX65czv5l8dO6C9l0iOuzt3jy4s4V HnNVDYs8VOOO
QB2GEGERZwqIyoXInByaOFRUYcpDNfaKIUM19pvzezJ3GERi1gSOaE5cajNR rUIaKBeleiWT
gRhxuMZwjbniIEqZc6ICiZnZQysMSlZFW0twk2sgRhyyMWRjnmBYypAq9+jG gXuuuQaOmCFl
zFnfKxtTZeCb5fFONRafnay+KtPXaXr9+2f/+/Or1Vd49mVxPF1q7TYBbTc+ Wf262/jF9oUP
17/i5avV86e/PVo+XZ4up3e6eP78ePuyaSweLM/G/cHq9er1g81bu/Cj03Nr oOpDBF4//rfd
hs2zT0+Onr15CJsnzr7ffHtpf2cbp+N4eFfkZ+tOI01z578PhwG+BGSPzTQD c1evrVnhhtpa
L6UNd9orJA532m/O78ncYRDJPcVG3gIiSwmJPUV1aWhSMfiVNI3KUKehTnOl IRoGkcQhdG7u
2RtGJdKg1kPSG9M0KsOchjnNk4tUHXJtzl45GiT33MgoREghZt71pS67kVvv fcrMfLn4/Zr6
LFOzPF6b05eXFOSuxPw5xWNtdFfe+fVbL8gImsZhI3dk7jAQSRFuASsrsIk7 gDXLpWINEGQs
GtsvzAwb2W/O78ncYRAx9iyYk8XAjGxNpZkkLr3X2OsVG+EwbGTYyFxp6LVz 41qDMIuCEwkF
DZDcEnK60UY4DBsZNjJPLmpKUIo1rIWT9iQtW2RCCZ4Q4jU1KXmNwjQN1s9M 3RmertYXWD8u
d0O7nEwFPlKTnz+njNwiC4JjBdld6fqEuJC9ExczRKRehIy1mjOzdaEOknMq cXjHXgFleMd+
c35P5g6DSFdMrs2JgTFxiqy1FK0teEktjFr44R33iIbSakocgYGYYk3CoViU 2DjFFGnUwt+C
i+EdM+QiqIVUijOyFc4SA/ZUINbMOfuohb+DXoxa+LtDdBgqUJ1BGLxUJhFz BIy5ZKg5edeh
F3vFjaEX+835PZk7DCJQIMeqXbFyAMoO0rhY0MixQRu18EMv7hENMWKk3kxL 49qCQfCSrBkk
yhTLqIW/BRdDL+bHhZVaBTRRMq7ejTEiAEqowgHtveUpoxb+dqoxauHvDtRh CFEvLTYpMRYW
bUlSrKStxNpCwJHJ2C+GDNXYb87vydxhEOnuiXvuORT21BJQVyTLUCphKNfU wg/XGK4xWxw0
FWZSh+Zcs+fQtFFGDC32CvieWvghG0M2ZgpGxIrADtqdMZs1hRhCrRVUjOC9 svHRauERAIAu
FLVPB/l89ep0u8/vV0erG2viX19+bxd+1W7W1Ye6q5A/37R5eHVnoyD+/QI1 cjV3/iNxGOo1
WmwWpKmzg+aqlYzR3NVSGiUo+8XFIVD/x97Z/7ZxM3n8X9kf8wBne4YcDoc+ 9AAOX56myBsS
t3gOKBAotpLoqtiGJbd9/vtbvbVu3DjeOD5dZDoGpJWj5S5nPjv7JTk7w3x+ IHPbQaSAWkyu
RsxUQcVE1uKMC4q+puspKGyafmr6aVdpsEKhuIRUgExAlWQSYvTZpqwWb06I N00+Nfm0m1ww
uGSs9Yky2exFDWlAdsZASBE/mRC/2e7PbpkJf11/tGz4QdnwvmXD3xW4LRFU GGK2UB2QTxi8
DTWRUWcpKKUmRQbFmCZFhvn8QOa2gwhBUeSQvI0UfYhKLGqxGvUGuLRs+CZF HhAN2YdUE4Oz
lmLOoRIkzlFtdi5kaNnwt+CiSZHd46KKAFH2tiCRKwq2QOFUcqqqIbds+AE8 3X4KpGXD35mu
7eACXMkF5eiYyEEksJ6ZXBUMhdsasmEBpemOYT4/kLn7Q4SAP4mI5GRMyELB EySM4qrJyYvz
kYwLa0RenR3/Mp5vrJeWT55/ucLisFvw0yF/pSjy/5eS2bITekRWb67x4Yiv 4QFfFY+1GT5C
gzw3NO4Bjcr9PyWirIQpi3dgU7YE0fiS09+iscn+PezWQX153/X24uxDt/bp 7rhfu386nj5g
UMiGBsoOgRJ9UALrsRoSzEIOUkTh5EPUAldB2YSL0byb9mc273pTLE0yHc/H Gxn/HxvzdpNd
vuv6LCbONUx2CBMMxiCjU8pksgYD4hHRMFpUxBZPvhgUjw2UHQKFo+TMEnwq RMLBQzE+5xqo
Mov9azxZP2y+S8+fPSvp6HWOR/Fgs9G/vnr+pGwkfPcoj+ajDTG7PHXyOWQM NmR2CRkb1Vpn
xaohSiS+/1UMCRI7a/1fkFkTcxWYw+5yuUwlnfVgHC87/nE+7BwAPGBGjDRG dogRR5TVCWQP
5BxrqUyawFbCIlw+CiuvFg2adYXUbtHLV9l44GgEMg2Nbw0Ng59W8BYhxorO V4rRa0qILudU
Uy4J/O1HgY35WrOJ3y4c2xoHdiINjnuAw1vgglxzIgpaBAGtBCOabakpNN3+ paBsaxy4gXI/
oFTLsYIlF4FCgeBBagg+M6nxKm0c+Asx2dI4cMPkfjApidSTF+VAQUFTzVJK zMrOAEuLJ18M
ypbGgRso9wMKBG+splDIEtUSimFKwWBWQkvmb0E5ej9+uooe3/fmGV/0Qn5+ MTk/H59075cf
rKA5PTvdO3qyCTQPmBlroTGzQ8yEiBachtVqx6LOxYLkKqgnrnHNzGx8erLG pHv051LHf/Sr
IHsjTWZXB7smJ48QzC5Pltxy+SOGa3LlDguBhy1/bLjcDy4xJ7UVDMVEpnhB EKGgiDlbLmmN
y7ONU6yHhdEY+NTAMIJ56KQYYxooOwYKZhvBe9GQqVSOLoFUMGprwpRKq5rV 8hMfEA05sAHJ
6HwmE0pA0AzgitSglkqrmnULLlp+4u5xkTJw4IAUE4VMmgVMDEWFk83WtapZ d0hDbFWz7g7R
dqhwWQpJhVAdRS9RvM05RxsTlUqhpSEOihstDXGYzw9kbjuIgHO+1kJciCqF iN66WrIUWyIT
t6pZTV48IBqwIvnkKQWl4CEweWOLeg6BkraqWbfhosmL3ePCKlvLShiFRKqC hGwQqUoQo/Wz
D7JvVbNuJzVa1ay7A7UdQiS7mtFZ4UTZ1JhiToGL4+w5QivQOyyGNKkxzOcH MrcdRBJqUUkx
eyVW1sCQwbrsAkbj6GOpYUC4aY2mNXYVB5eSJlMLIpCPRlK1kDFzLCFAhJu0 hgHhJjaa2NhN
MGKEHKQwG0vR1qheAAsFqa6KT58VG39fNetva2RdLaUF9Dd1s/BKoav+EC/m 6/a+tFjWdHR5
evz+8enbs+VmPD+fTlYuuSZr9GY6Xu/4f0a/jvb7T1dbf/r0ajsd/gx7Pz5+ Gn/W6eX4h9G/
f14fxJXWXowuelebjy/+ay+fzd5N9hfe2u/kzWTaXzH235ydzU/G0/G71X7f jqazcbeXH+vT
1z/En+Lr70t8kX98+uL1UfnX0Xfzi8v+r//6MDOOny7e/I5g6Gn3NL48evzs 8eveYf5ZXr7O
j1+WdPT85X9/tzzCo/GH84//S//y+kn5qTz5znV7S1E0nbw5/OHFY+0P6MnZ YrHod/3W0sKH
s/HFr/328aY3T/4z/bM3wtvDRX+djOejyXS2OrbuiiX6M70Y7696u79cPB31 D+Lc22x2n+nB
v/Zkt7e4/HRrsru92fuz32bn09HsfccA3V5v7pPL4/niSrA/efNh/7K/XK+a /+3s4pc3477J
5Wev/9h8vfnKXv/x6LNHs/je7Hx0PD7Y3z+4uDyd91TtLVtZ72dznH0fvZ28 u7xY+dPq07eT
6fgwHR6s9n2w3vfBet8HV/bdO8pocTwH++fTy3f91eTgan+en6z69OBqwweb lk/Gv/6ftNe3
s3h/Pr6YT8azTetns64PPdZ0e7/98W50cfy++124t960G5++/vHVsuLcn0Qs Nn8aXUwWwC0l
2IarJ/HVqxfx6Pv13s/PZpMr2J3318l+Def6j7+O+vPbfPGusXhnBzXa/Omd A/d2IrFzLnEJ
BWsio6I1GgZiT9HkirkNagy6V22DGsN8fiBz20FEPNqgvmZDZLTGLLGKVSJg iddLgQfn2phG
G9PYWRoYhLOTEiMZEalJasiGVWrwn6lk51wb0mhDGrvJBQOGKtFaZorJSzKW ga1zqUaT7K0r
2V0ZgrgzJ9+m3Ggl7G7r6V+dtO2gE1wyKBlsUSrRR+BoXHQE1lmFpkGGBZem QYb5/EDmtoOI
LznaUolYqWTUGMAWclVRkdlf0yC+pYg1DbKzNIgipYBqECjaqFK8uMRVxICg 3qhBfEsRaxpk
R7lAR4qVTaJK0fpI6AsnKdZVAzV/WoM8O5tP3k56a11VH+PZ2mYLbk7Hv3WT +fjDIil/2vvS
XfF5SNLEGINNmtwRwO0QlYpPzkNKyZEGiRm9sAmEJkeo0KTJoJjTpMkwnx/I 3D0iYv2npUnN
yWMIJTBFH8V7SWwtJ4++turaTZo8KBrQhgyI1htLlXOsmSMzhWylaJFWXfsW XDRp8o1ycVN6
WVBIVMW7SglrqNmIlVCikvFVWnXtATzdfllWq659Z7ruEZcbwojaDBSziEYi Y0Ox1mOAHCSj
Ymy6Y1BAabpjmM8PZG47iFTwVr1JPihBQgUvNaMlEES2qU2JNN3xgGiIzgpZ ShojmZRi8pm8
QgCI6KJpUyK34KLpjm+Ui5umCouxyj5mMWQcqZoshMEUE1ywbs3FR9MeR0u7 HHab4NGdLudH
VuZez4ZsTL24/VplHd0Vn29ThXzZlAiS2aY0YfTmKxA1DICvDuA9EmX9DURB NCwcjRIBaxWG
UnNxDDlJbdJkUMxp0mSYzw9kbjuI5BBz9SwuExUPMQSG6hKGLIpSmzRp0uQh 0WBrsVZc8Ey1
ahSp3kUIlYxzVZo0uQUXTZrsHheGfco1sSuBQmaVWGPRxFiMDUh/rta6qk4W oqQvujX+tT+3
jUnX+qP3j7dnyxJcf/nGk7Zaa6A0ca5JkzsCuB2iHCK4CDb5RKgQqweM1Zha UQpJkyaDYk6T
JsN8fiBz20HEYgRngI1h8mgDGTLReA+SKSpekyamJbM3abKzNETBYitwCkxG QgjBi6/GpYBa
kW6UJqYlszdpsqNc+KjCwcaaPfnAwSvHJJUJ0InfRImji3/3nX/Zt4Zdn0ay KdbYn8fscjrv
9joMlu+Kx7cpPT6/NsvJNnNCmsr4cjjIg4g1ugwaJYpmTi54FLQovjSVMSh8 NJUxzOcHMrcd
REpxWV2pjGl1XwUZBVLOxEHp2tosxiYy/hAZWyvvS4EbDPcAA1ckTayqQKVW RRLfvxhHbDGG
m0QGY9MYa43RsNgxLCxQjpacA0cJavCZ0EIVh0ZRYI1FPDnpT2O54CrHo9id XXTp+bNXz5+U
7vj9qNcb0wcfM9D5BseOwdH/uGwBWYVSsAIZEhivaCqLSUs41nZZmuXdeP74 dDJ/uRIVeTQf
aW/nXw77U5pfXpwuEEpLdb40wuN82DkAbOiwbejsGDomYa5Qc4BEHk2smBMU m0pxxoZNXOmd
dnY2HXc//riAYXzsTo6tjPdOcMR7ND6GvQAS9uiNefPGL37FPnhYSNpN2K7B 4liqEljWRJBY
Q3CqEWuoXLjQGpbNHVf/+qyko8PxbFHEZDJ7Pz5Z3pkd/xFaeo93APjgUQnt lmzXUCkmWxts
zTYTGq9qkjdFTOSK0ZlrM+fYFvW2mfOdpQESB04SPCaqqUYhtRopsitIePNj 4LEt6m0z5zvK
RaEkKNWAT4QUo1L06oMpOceY3PXnnGxM2AeOk6ezd7NHd48Xuzpl7luVqTtD tB0qnIqIGknZ
kckafBTLGlMIBYmoTZkPihttynyYzw9kbjuIoIsOUcGVQJxsSFrQQywuOrbe XZMXzjR50eTF
rtKQJNQCzhgXiU3SXELAFD0HU1O6OWfQmSYvmrzYTS68U8eAXqFQrUmrBPJF QDXFivazhbP7
KfOT6WI28O10tKw31cHvAAYWP3flZVdlhzhpsuOOcG2HFiMSmaGQVEIThazL RZ1FUxJq/HgW
/bB7tWgTeRU/ukVHX5007xDMXSH51oOKMabNbNze7wdytx1MKFIVj1yKIQM1 BEeGaiJMlKGl
zQ4kBCG0Nby7hkjUwuCqSxzJFFEM6AuGpCnFEPnqY+S64/XSknXxnEd/MvKP /f0Hj4e1sjU6
PFCj4x7oUHXiOaDNRE6KeDIgAGKSzeDtX5dcHXa/jSbzpQbpF/P28n20eWbJ ydllCx//y97Z
9sZ1Gwv4r+ynJgVa3xlyyJlx0QKcIQftRZwU1803A4FjKa1b124t6eLm39/V y9pylGx8tHEX
PqYBY7WSsG+Hj4YPh5zJNPlYGx8dR5E+yqiD2HvLmhQaMlbDMcbO2r99dXHV 5ODyetyaWT3Y
/PHS2k8/pwJztTeTTj5WxkdJWFw9hWcqPTfC3HkMU6sleM6uFtBxxNlV5bnm +yHoaEQt4wiV
TjBY25BapDFLSr2XObtawscRZ1eTjw/DRyrWNSXFVCmiGWWTIhZYuOTA955d kczZ1TFnV5OP
D8OHZBhmwFSELKm6F3ekChWTW5/Lu4sImZuvVogIsfTUZXQhKkM0FyvdasuI FP1HeknB3Hw1
N1+tlQYouWcIU1Ci0qS3CANGcwfkvL9gO8zNV3Pz1Tq5yBrY2aNypahNIYaW kpIkGmpxzcVu
N8/m7eC91Ujq9enZ9qqcne6KmHxzc6R2e/voz1+Mv4xDufk4N2Hds1K7zI1Z h4L3AUkq+SdJ
QupapMrgRkIkwSwDvZljcJrnQZbFmqkky8b8QuaOgwgXGM2KtBLUUcUdopeS e+buqd5REqpT
SaaSrJUGYmahZuhO6NQaWXSJpp1KF9+rJFSnkkwl+Yi52Jf7QEtMA1M4ISYr 3qibdaidk9ed
kvjDzU40bsRjN3naPP7afTx+HF9/cSgfn5J6pKOeCZnV2+8fSTQBkpYwC7Ks 5p1REqkLEOFU
j2UxZarHsjG/kLnjIBItSm88FIHcWbVYbxANnILc76pHnuox1WOtNHg1H+HK PZEGiZdGkYtg
r+jB+9UjT/WY6rFOLqx1GwMMhEhdtDpxzmaEKbrZj1S6sksUtsPg8iebF6ff XW3H+vZ0d2lP
Tx5u4JqXgwPJx+ki73EWHemI3jFTHvfHBVoC6NK9EVlC4RahrUGvETnl6R2L Asr0jmVjfiFz
x0Ekt5ygd+Ss5IWbBQ/TrqGpgY+7u7Bmhd3pHauloUZrQ2tzZsoAyj6AS8t9 FGcd+3dhzQq7
0ztWygV4wk6JIymlkSRF9Iy1CXcvYm9SHpuTV375RKc3U9qr6j5XzaS+ff7y 5G03nLPN5evb
ngG5OjHlu+OFrzbND8Xn47SQ+2VEMBU9oprMlMj9idJmkrUXy0RatGkYQjir c1TWqSaLYs5U
k2VjfiFzx0GEEbUSZcJGI4e2XDxFzV3VUr+rJqlMNZlqslYaPJlJvdoNT8nR qvqg6lgagJjs
VZNUpppMNVknF02a5lJGKp2SSSujNa+dc1Aeo91w8ZfX328//Ivts+Fmqx27 GqOXZ0MuXpxv
frtBzfVQPD5O9fj5BEgRnJZxIEvHgaMMCk2tUENSNQPrWLmUniBv//9wCpUQ 5xRqN4WaBUUX
DO+FeB2HBh95OBYeXqkNtBygnA0hkAli3xQqIc4p1PUUajakXRsXhcMBET11 6iwmngC6Q0br
ZPGDKHG1lHvZ7fztcu5uHWptcDx99/U8efuOHz19+fSvt7AonN/F4pdl4tZH ffPME4z/ABiW
UxPVOsqgrEV8uCN3sSFAVG/AODs9/9PL7ae/fS+XWMTFy2e3KyTe7tTcPy8A +OvNv56+Pt/+
Vb2+PwuMbjClMsPKyugBBElKfVSmMVgyuiGZMXpksD30nL169o/T87vkwA/I wV+vF5zrz2BL
zfUXd5FBuosM/KLIPL565onLfwaXqLmNap1bJR1s4Zpr5eSG0Ae9weXlyaMb L3knypy/2l6k
52e3mNk8P/kcIc3ogqjHq7A4cfkwuEh41p5KGBETKvPoJcQGVwvxmUBfhshM oK8PEe/ewFPG
1ok0qQ4umFskyFHhbntbnHt7ZwJ9tTRQqa2TlZKY3MlManPyxpRKyvvLmeDc 2zsT6CvlopZe
lJ2RGtUEbZTcc2dvlFKycfdM4e4SbgPHyaOzv559fni8WGvmnAWOmDmfRwfv T4Vi7d5Tx95J
S5MaIRJNCmBh9Z9qY5vz7GM7+9j+MgN/IXjH4QSzg5WqV/utUAWDvZBjgyIw 5hHbZYRMDV8h
IpxZ2tj+80YJsxTu3TggFHIVuKPhNBsdTA1fLQ1RGIoq0QjK3AVydEiVdJQY yfZqOM1GB1PD
V8oFZsdGYrUBSaoiAblkFmzJBtXbGr757I72fbb522VHte1bvPz0Ns/+eXIo I2tVcuFZzedQ
oI5DSO4FG0FrOmgwmWlYSEkU4p5nFdFlMWSqxrIxv5C54yCCiUurg0t3MmAp 3ZqF51ahpwYT
kcMRuX+wWIbIXLD6MIgUAxqdcy1OuXaz7R0JTomceuo/tHHERFPHp46vFgfN UVCpilAyt6EZ
NA0tCNFxr45fojF9fPr4OsGQPDwkoIlRIReAXGWkEnVYT/izPr7dqH52erKz 8c2vXpz/zre3
2+H1+1/9++LV+e/w+mZzcnp2vvsWpJtvPjv/v903ha9v/3D5ECfvnLs6s+2R 9pPN8+cnN7+7
vSAPTq8v/oPL4lEPrnz45sjQrYf5rx97nOufbF/kHw7lebVrBzOdfzD8x6G5 WhgPb8WVnEmR
FV2dq6XS25hitCjezbWDZWN+IXPHQQRLHzK6CQ0StEYg6sE8skYo3klT1tmB ZHrRamloDZsj
IJdKFKQWbQw0kvDMA/amKevsQDK1aKVciHYpXV2CqA5uIVVTydZoZOL0phLw 7srd1Pl9uLu/
fXeXPvTwRwTkE01Z3rP0rzBPFzmQuA+IUJWfRCijYcZIVoi8SGsdpA/qNVob NPOYy4LMdJFl
Y34hc0dCpNfegWk0oF6TcTWRaMhegZhmN8TpIp8QDY1INVMRBQIWM8PgkXLL EUlsdkN8Dy6m
i6yPCy8jsyVFD2rZVQKKU6PghpDL7Ia4gKf3z4HMbogH03UcXDgqaRSR6gQq rWQoOpRSQIc8
cyDLAsr0jmVjfiFzx0EkoRozxrCgmoclcxe34GqKcHdzGCSe4jHFY604WMHg gqpRCXuz1HrB
FIThjfeLxyUa0zymeawTjKJYkiuXjsQtCwEzYlZPpbSW9/VDvHh2+cV3Fy9e fL958fTi5faT
Odld4Muhu/nMHz6B3379p0ftib24OP3vp98/udnS9eTvr7cDdzuC//70f58+ 2P7uZ7/Z/Ov5
yaZWgUMp+zh15Z65k6THzJ3Mhib3B0+11IFkWJhGE4VqNWXXPCoLtukwi0LT dJhlY34hc8dB
JFJYTWLNjLprK5FhKGKHJF7iTu6kzLaJU2FWS4NrAevK1YTAsaWWUh1DTFtU wb25kzLbJk6D
WSkXSt2L95YSUKRiqYlbH5AGtQh4YzBvO7j7V18+/uqL8c2f/+crH48ff/NF +/pL/+PoV8db
zl9tL9zBAeRTkpCkeTrIgaQdBx2C3m1gboaUOlpuvabRfXSp1eb+rWXBZTrI sjG/kLnjIFJH
ZU0i2ImSso1AQR01hUoCmK3bp4N8QjQgDquRx0hOMYZ6504UFSChdp2t29+D i+kg6+NCPUnm
VkGBxujNtaswAFYoCfp7t25noUPx+DjN4+d3a83W7YezdBw4JEqryEiiJNgt R1BCRW1SRuI7
rdtn0eDZuf0+o3shXceBwQQMektojap0gw7EoaVCC2LZ27l91gyejdtXioUG 1Q4xohYqBQXU
RmcGAM2BcYPFzcLt5s2CrX/16FH7sm++e/X6VpOS64a6DzbvgAKfICml0iRl ZaQkKklRTHqi
EBfIEK3DGKhCiXekbE+iv3pxunl9M6vaXcdtI91aBbZwfOpRpHCebKyMDRlu EgSDK4mitlrA
IjgkEled+YxFhMx8xgoRQWVQxJoMqDduvVdsBKKUCkefiByOyIwiHzciJBqa i3FyolEVvWsr
WpS1u9Pd8nE6F6xmym+tNFQYqfXWqRCZh7JC1cok2TVK318+TueK1Uz5rZML KL0U4lzUKFpt
0dQ5Q6qRcw7Zc3DqbPvkcw/iL7sHEfNRiznM9OD9QWpdwAYYAhJVN8mttMRJ Ig9P8yDUslAz
pX3ZmF/I3HEQoQS1WrIhRiam1cxCMNPInNjvHoSaReSmkayXBmRWJ+6oVLQb J/LQ1AcMzQL7
D0LNInL/z9659laRJGlYK+0PKWmkFS0No4jIyIwMRvMhIi/bSMPQYviyElLL g03DrsHIl2Xn
32+d40u7MRiOL3OaIgUyVoGoU654FPnGmxkxFMlCuRBzNzYTjJxU3WNP1rIQ lFrVLhTJ6YDd
cz2yvvOsSv6w4uPw5N3qIdfv9mj6y0S35WRJGuTKlZ/f7l6WIHmrx6AY4A7A 2SzO75yzewQn
82fB0YbGUggochZSJM5QY1I2zGF4IpullqFANov5DZnbDiKuyAbOsTmzkrEQ J7cQsteCVz0R
GceghgJZLA1UvGNCgla4abDiTgDJCZSxtWsViIxjUEOBfMtcXKNAsIXsDSAk Z09mtTq5Uchk
KQN9QYH8crBaVH2Y9udQuSJG/ji9O3n705AlG8sSwjhkyS3hu0earskyEq30 oGCeWRE11VyD
iwQu5NKHLNko3wxZslnMb8jcdhDR0K2AdOXAEZISWooamVU4BbranSENWTJk yVJpiNgMlRsi
c4qmSiAUqAcQMA7Xd2dIQ5YMWbJMLrKitEq9AbI6WLcWtfXiVp0ofHV3hgzf aXPq0Z1huSrD
JWOjXpI3tpI8pMJiAqoI1eJQGRulj6EyNov5DZnbDiJiSbCaeo2cuxmHSlqT ekng+YrKwJQw
D50xepgslofMLUMNSsYAnLt3yqRRLVG1eJ3OwCRjms5oY7JUMhJHBYhUxZnc FLCkrCqSW83l
PFM8nWP91cH+wYfp4cPVY+2v3+38ZBek/OPk1au9w+nBCpeRSi5SiQ5gFgaM qUn2mDg3dgw5
s6llU4smlv3q0krGnMKxtFouD9WLK1ILzdmMNYCG2qNYdWrcx9Lqq8gYS6vl kdHdmZS5GXNq
0YOzplK41ZxF4YyMo3nEx5MzJh4cHbz8n73jH+ay1fyC3hxd6hA3zX2wEPiH 5YJy+uwzJaff
XE0eGa8gAneKyN/XNx54/GvwCBF6ZchMmVsiTxpKLoDRNHnHNR7n72Q9Ced4 wiTnPdmng3eX
6XhcJ4Rbd6L+duFQpgHHguDQwC1GSbk3rhlzr6Bo2pIocv4tHOdvruy/mW/8 7NTXeDStDJAJ
SU95WbD2+BIbkdNW2Ig5DzbugY1G0EpuFKNxy12RSySBntBjcPkkG7Me331y 9Mu8Z/fMll39
o+nV4cHb6Symp5evd+Z0sv8dg8JBBygLAsWaKzU2g8yxs2UsWSyzhKpd2mVQ zvPFzvG0Pz/Z
8TS/ivUr2d873jvX7H+8mJX+Zsm++RcxiXFgsiBMYoidUyoSI/fAijGmTsES NqUKI5/cGBTZ
jmIfoNwPKFVKADeMAdgTZ+0kGFOJ1iGm8ElQnr/eO6tu/Ti/nr3DWckfH755 /36uRb5eXziF
5t3Bu4fP/3qeaL5jZkKAwcyCmIklxR57DpRYPeUgyTpoxNgR+VyszJL98J/P Tk8PrmP3aP75
zpG7uzQQdn77eV6sP9+TnXfz9V8ZwJQ+Shx3ux9xfdPp7K6Dgn8BBZwxeW4i ERgC5YwhCbNb
AC7NhxWyWZLYlhUy8LgfPFJVlyCptMS1Z9OQVoCgQmSq+VNWCFEeRsjvyAgZ aNwcjQjwWTQM
HK1jsG4M0nMv6iquNRB3aeOwx0bbTMb0j28VEQ2fRaQIJCyAgIGV2TByKV6a Vq4t9OEVbpA+
hle4LDa4mSFWAk7cqXpRNsKScktSaXiFNwZleIXLAiUEcEOjqp2TRi+1SQzg UosL0PAKb4jJ
8AoXhYk2CZgMYldmNG8JqtdeQukSK418cmNQhle4KFAqh14poGrg5uQIXWrV lkMOrdXhFd4B
M8MrXBgzUjFgEImVu4XMsYcCEMATeqvDKxxe4XdAATjnVEArKuecvARCl+jc i7XGwyvcLEkM
r3BZeLRUnCP2ioED1azsRUrKiNBaHF7hBmgMr/DbQ0M0XaM5pBTz1IoxVTCS GoTAkBg98DBC
NmBjGCHLYqNBxYoxiSXGFDx3bdhSQXeJbRSubgzKMEKWBQqW0ghQCzjHVDRo xRQNOGlCHkbI
TTEZRsiiMDELqbfE4shcV3xIDChcsIBIHfnkxqAMI2RRoLQGGKmIcGd0sA5Y oHCJbIlNhhFy
B8wMI2RZzFiNDQBC7oVLt0w9kDeIIbIBxWGEDCPkO6AgV8gWSwCPnNPqd0kZ qYIiY27DCNks
SQwjZFl4kFXCEk26czTz2Bm7NxAl4g7DCPl6NIYR8u2hofB5NCA3ZUqBgzF4 NyNSMIgp9BBK
P0NjDtWjg/29R9PcmHfnwaw5pv/e+d+d6eX+zqpYdTTLi+Pp1TxeavfRND2x Z88f/+3xz/Mz
/Wd79nN9/KyV50+f/ddfyqMX8PD53tv3//GH/6t/nr/Yn3+Yq2Hvfjl+/SCl 0fI6bLGxrwAP
vO4BL1Xp1LBJAeZEmRkqVMOaC0Sq53g9/dvfn/61Tc9/fNasPppWC7XVxISX p9hNByfH70+O
7xO++T84nM8/7s7fZ1jwyu8rSZTtDWMYJN4PiZ5yoxytxMitB+tKiKFlt5Sy 6PkacCZvzdm6
bHZp4fd490EEwLVe+mnn8HgOl8d1dQlG4kLSPHhZGC/UA2XpUYDYgnjNUJFr 72Te3M94mdPG
h53D3ToT8/zgjItH0wVF5xkmxx/Oxv48+Ld/H8BgABzALAyYXFFdJYlk7imb 9p5zxiI5S9Ly
qSJDvuhQ/2paIXS11hDh9mN5f7+0fKnYgKjbcWsGI/fDiObsnMRyrMwgVjXV OP+q3IFUP642
fNh5s5octxInlxZlR8e7BydL3iDzdUkk8Fh0LY4PwahCBWrmElQhMzXDjBzY Hc74sH/M8b8S
Iqv3cal30Z+mH+fZ7vt7DzgOVTKFLU5UHHzcgg/Cz4v4TmSCBN2ZGrokbUKt SWfKPX+yWn1R
5hpMjBLzApnA1iVWFfPObME4IoPU1lupvdXBxO+YiSQ0mLgHJkojIokRk3Dt zTtjx1xCwNBA
0seTdzWlMXf383N373Z32OdpCDhouA8anEHZTBIGbq1lqS2DFuqBOvd23dxd TWlM3T2buju4
WBgXqtkhk0cE1lrMgVsrrLmb/DpW9KcyvV7L6rOTKOs7/3owZf7LozlY36zA +fDm+PU03+D4
5GjC36YSuAEzZ3fYhJprouTekVrvPT56cfz++P2VT/7iypWf3+7+6eX792d4 UeaP8LrFGiwh
8Dld1/wsLxHGAHcA0WYxf+fMbQeipi1YSZhaYmzdYmjByLBGj6A0um5vlGYQ dKy/Noj5DZnb
DiJMNcUYzUG5BMwUmWsVr47YSa6oEeGhRoYaWSoNoTbpEGOrhauZtSJm6Lkx qne/Vo0IDzUy
1MgyuUgce1IqBYSZ1FNAV66FUw8l0RfUSF9tAJ5f0965FjlvJZFShjlUphmH OXbuYIn1PakS
paFKbsnedmDKLUhVDMLGWslTSEEzUs2xmfahSjZKN0OVbBbzGzK3HURAILpT iy2yQvRkpSQH
lBC8sV5RJSxDlQxVslga2NwgaJLCBciUoGo1U6LumK9VJSxDlQxVskwuLFZp UC0kYlbKGaPl
HHsl7Wh8oUrmHe1nhxb31nedF1VPP8zBMQOyOle4kiG33si+JOXxyauXpEdI aUiPWwK2HWJS
Se6cWw2FxXNOtZbAoEWiaB+GyGY5ZUiPzWJ+Q+a2gwiwx0DeoitTQhNvwi6c WNSlfyw9MI/t
WRfSYwzlXRoNiUMqVUPtnRupV8TSEnFxJ6hynfTAPLZnnUqPLW7iHVzcDxe1 kmHrnBtwijUr
Su9FupL2JuVKgYpGlhgFqsXSUDC75QTQma2SYiT1Zii5dNfrbXMaWWIUqBbK BWoqWBE8Na4R
1IFzgJYhBczQR+vTzVoubKv16VhE3Q8eNXgPBsZoLAIO0khUjDR2pf6priSY 42h9+jtqfTrQ
uB80vJFDKhUKc0LxBo0jNIdcaqljj8hmaysEHaWppSECQCDBXDVyKeAdk0Jt FmrOhOei4/nh
P+cf/skqdUzz3sTznDE/x9HJ/vH0cMJ8+y5W36b5t/5j9TZerL6sGX88D/26 ZPTFjMPouyVL
24EjNqmRCnhDziQ5M8SOBhpaq6Ijf9w+fwxx/m3nDw9Ua4eI2jlDck6pUCOM Ct7D1RJupFHC
HSXcpdIgxBxqT6zOMUeX1BVKpq4gXunaEm6kUcIdJdxlcmECEax7jcBoaoLe ElpnrgVCvm6P
IUxP5qc7Pjg8GhsNb7jRMI8zTrelbDvYxNASViLIhd1bDkaONRJ1yMXL0B// z97d9Nh1HAcY
/isDZGsTXdXV1VUGsqivRhYxEBheZiPEjC1ApgxKRpB/nyElBnIsirxXVMY8 UwS44IDA5fCc
B32r3zl9b1pYev647Z6/0dzTEDnHdoGFnk0xtjmvGO7k4qlAfz9/9MkLPX9c VoPE8NyFtZHQ
3/xSDZozhbcP+On5o09e6Pnjoi6CcOciYSMSX65HlntOo5zk/NPzx7s75Js3 n1LQE8gdEwiN
Pvvt5zp7GjjCjBRjwjYah632ZNbKgEpK6AnkpqWlJ5Db7vkbzT0NkZV1tJiG MmmA02Saeigy
c0lPID2BPCcNyqfM1xhyiMkMch7YXoVLybUnkI9w0RPI9VzEwCXlJwpIED2d px4bG8LmlA+c
/fZPb3y8/uurN9/k22v7zcM/P8DPdXKlEeQD57yBzJ5Afqazp4GjMnbVOBxC UCjgI2DYRHAf
sHsCuWlp6Qnktnv+RnNPQ6ToWPIYYUQhrkmeS1htMeP4kdOnV08gPYFcVcMA PIAiUIfoTBt1
imCdwqlQP33O2149gfQEck0Xm2DLHKs20CQStc2kBHP7meNDn4Xzx6/fvKn6 r7cHTP/dMPKr
h1d//fO/9Vhy81iCsHos+Zn4nkZTHU+t3DKCcprFWqZQiDQef/ejIbetNz2W 3HbP32julyLy
eBuM8V4iYxp77Q3FNK1sO5W6UYHjtvqbB9PfXb346svHF/7ddyx+8/DGzwOg fveu7MJMPvRk
+iJ+kifTl0jb+AVsINOU7TF800gXtVhmuF0XJc8ftfE4wP/ht9/88QcfTPj4 lx7+8/XXf374
/p5++I/H926vXn71jKHQ1IZyISjFew3d62wmPMOw5loDp8IJgfNDKO/Wiy++ ffjq8Tv79uHx
Ury9JF+9/PbluzH/V//7sTlfXvlt1weZrNVMLsQE5loTToZOog3i7jycUeax ZdLryd1Q9tOc
ltVQfhkodU7wksgogumaGJtyBMY8wvijUH7/p5ffnyz3L4+X5+Xrx58S/vb1 l3/5y+M8+ae3
X/gOzauvX/369//6bqF5xmbmHG3mQmYc5yyUQCQCc1EaLoWyRo1E/d7M48j+ +r9/9922sL3d
E338/328c/9wNQhf/O2/59/tzZ9/+8Wrx6//YEeL+f8sHJ92O+vtiz58/6qt 4P9BwczFi8Do
CI1KS6KRbk7IwNXHkN64SDzVMaTN45fhgVMmxMFaQaNEJHUbnRU7yo7+2DGk iNLHkP4DHUPa
NO6loS9w0ntpECTU0LksSfEIHjQZNDIH6VwdQm6w0SHkWjYkTwZLLDPCJT41 faHWMUek1RtX
90LpEHItKCEJYEVOTpFmK10pNefhnBkdQu5k0iHkUkxs77OHqjHQqNStUlGw a9om515P7obS
IeRSUEDm3ixD9yRiVIGKMWQ62mLiDiGfwEyHkGuZCd92SGGg0vDQ1By+abmA AmGHkA4hz0BB
KZKA4zqHjNKUQ2ZIsZx1KDqE3LZIdAi5Fo9RPkamFwNpLZXEQSeZVrIldwj5 eBodQj4zGuvx
6rO8l0b6yRrTWIyKQueiXCsLi5wMOoTcYKNDyLVsrMDMPbKIiIe7EmXRnFX7 gPQTIXdD6RBy
LSg0E2FmDSdScEWdavP4qfRF/UTIvUw6hFyLCTsBVmYMEkifvkfsPVJ8Fe9e T+6G0iHkUlBG
UdSyHGPSGqChDgtLzhTyqg4hn8BMh5BrmVHOKUtoKlCCCpbNMjwgHG7VIaRD yDNQEBFguXy5
EvoxQxVIYnbFoOoQctsi0SHkYjzsyJyMp4i2mVSVAwEOS1i1O4R8PI0OIZ8b DX2xx3z/zOEy
HdHmdkp0LdiCuRFkFnh0CLnBRoeQa9nwjarJG5xp0lH2KhXIscc+W3vj6l4o HUKuBeUoL0OX
JCdAcwGjhLDNcDy0Q8idTDqEXIrJVAYGXxOV8hzbuHk5mvGSONnryd1QOoRc CoofyjzsYx8K
Igk+WRvW4R2xOoR8CjMdQi5mZsbOg0kHKD0NEIFjLNgnDaRDSIeQZ6AgKzxG EonTAVOspbJp
LwOeY3QIuW2R6BByLR40uQpLVziVlWINnDYYxGgQdQj5eBodQj4rGvs3g17o 3O+lwdOnzW1U
SIWssGQALxWDA1s7hNxgo0PItWyIhZXRrgl09tRDdaaJyDbnDb1xdS+UDiHX gsJ6PEK2lhIw
2xx2OIghDg1YHULuZNIh5FJMbNlYaWeX0wrRKDT1CQ6bmfoJw/uhdAi5FJQK csagZYtIp0/k
Be4RSBCWHUI+gZkOIdcyM0/WOFtFD5lsX6rgVeozeDN0COkQ8gwUFIfNcVBA acWQGkhVcRSP
bt0dQm5bJDqEXIvHstIckbiZSpYr8NFzUlJqRIeQG2h0CPnMaMDjHbnhvTRc R5XNjbRol9mR
chjlZJk1O4TcYqNDyMVs0DLhnGtuIgHXEzIDFXboNOuNq3uhdAi5GJSjiycF QhDX0DP2Qtuc
7jLAO4TcyaRDyKWYsM6pc5U60lnbqOYiFHYeG+fp9eRuKB1CrgVlryPoMZBI 2WQabgUKzanO
p0PIJzDTIeRaZo5QlYsqTtLaNtdQnVoU00P7aKwOIc9BAQhiAkxJJha1ZTuc GYlSgaFDyG2L
RIeQa/HY2wwOE+2kNdNzKebBnGsuwtEh5ONpdAj53GisFzT4vTRyCzkNxA2U XrLFFsxJOXKC
nA4hN9joEHItG9vXXirowHToaJLOgFDdmBHeG1f3QukQci0owTGwLI4JbUpz 0kxNnnOwT+wQ
cieTDiGXYgJSYKG+ahCHuLrmWedgjU3RR2PdD6VDyKWgjCCFuYojaEKaZm4j 3T4iS7BDyCcw
0yHkWmZwBVdqDUSKFbo5tgzmOYDY+4mQDiHPQcEezDuXiAollPiYzHshSCRa f0bIjYtEh5Br
8YCBRQOJIygmOxnG2YjpuSyjQ8jH0+gQ8pnRwPGCabw/hBzmAQm1k8Y2cV5Y houHSGl1CLnB
RoeQa9k4y1fwXsiDyFyPA0Sd8lUWir1xdS+UDiHXgrLUIM8qs0EV02Iqoy6I XMY8O4TcyaRD
yNWYoCrxYqUc4TaWqTq4n22xej25G0qHkEtBqThLikMKiXYK5haakMw+60iH kE9gpkPItcyE
mVoqKTHNOWyWmZvRdGc/HUI6hDwHBUvADHdYAB0DtcFJvn1l8IboEHLbItEh 5Fo84oQMQTgI
hCKiY2YFjAWYk/uJkBto/A97d5JbS4wjUHRHBluJzBkbaf9LSlTNnfgv4InD XMQBEXFBcULI
b6OhX6b+PY3lq9ZKY5RMtFuKRaZ4k8hjQsgHNiaEvMuGN1TlMjsoQRXufghO NK6VPMfSH0OZ
EPIuKHdpkYR1pVShqylkrKZqA58Q8pTJhJBXMYEFy1K5+0jtdN1YQoLFRoqz YfgcyoSQ3wdl
6/964MTD+0Kq6DlWcVrIYHvtXfM01k+YmRDyMjMeFO6k58q5EFcSzRz22pQ4 IWRCyF9QQEUr
XJEvyGn38BLHBQdPHJxj6R8OiQkhb+ORN5MvaAttiNtSDmwRZcmzEfIBjQkh v4wG4xc4f/9x
7uhkbAdTHC2R+pjn1uDelRNCPrAxIeRdNrDdNaDwgESn3UqLDXC0q9YcS38M ZULIu6Cw292Q
IrUFg1N1iwKBi1PeOyHkIZMJIa9iQn4zsmEvkV5ucDW91lIp4TPz5DmUCSGv gpJyBXSdqitJ
1xOwsjK2L3aDCSE/YGZCyLvMgFYQh5ip6EqjVbfs7q4TXTQhZELIH1DAKQs8 YpGLtAauUxZ9
6eimmhDy4ZCYEPIuHrsWqUMkshyrCLYSl23M1LsnhPw7jQkhv43G+mKyb2no NfMNYLAFPCzJ
Mta+vR3acELIBzYmhLzLBp9mLF56U4rQ2Zh6w96EV2HPj6unUCaEvAvKur1p pXAc8W7Pcy9p
CFEmkU4IechkQsirmJSKhxKakbCqQ6Wy9yoJJ5gbIc+hTAh5FZQuNqSuXC3g 5nYFurp3Xj2Y
E0J+wMyEkHeZYYdTtF0ABLHyBu5SKrPtQTAhZELIH1BwBAEXOx8XhhN9ULmc roG784SQz4bE
hJB38SA9WsvargjkDYC1ZTHAxS2BE0L+ncaEkF9GQ/BLF31Lw8pvruNIV+7i 2LQKfB/na5Ay
IeQDGxNC3mWjfe9g8SUo0tvllPHlqhKkMzdCHkOZEPIyKOsQesIVEMD01bS1 8OAlY4UJIQ+Z
TAh5FZNAlyNNcUpW3KAQNlp1O9DumXnyGMqEkFdB2UFQx6SCBJCckaNvdQA3 nrkR8hNmJoS8
y0zvQ8kbjUru0ehGUcHgVbxqTQiZEPIHFITuRctRk0XV3RLwrH20zFFxQshn Q2JCyLt4nGzP
A0s4hLWS3FSOLiuoOLMR8gGNCSG/jcb62r6+paEArmffZSStHHjgcrIY5iKY jZBPbEwIeZcN
64sUprdK0tlqIXttd6aINW+6P4YyIeRdUO6matjWnnJjpwFtZkEWsmWzEfKU yYSQVzHJA8fV
6qBJXzdsZgneZZHRNfPkMZQJIa+Cop3c0CJbxYsDQESgO7yzmyaE/ICZCSHv MrO9rwDwzvP/
VARsGWA0UB+VCSETQv6AgjoRQXttB7nqAfsmbSgJSpc1IeSzITEh5F08RBhZ 0dJCFNQwVx6B
JKDY4BNC/p3GhJBfRkPpCxi/T+gBjqqIq4TxegEKYTpfFdY5lv6JjQkh77KB gQp7F9mWsEqQ
KFO/7UbBOj+unkKZEPIuKBSq2uXiLi1oa8sxY+dgCrIJIQ+ZTAh5FZOzat1N ssuFMYzJC8G9
VBegzTx5DGVCyKugCJ3tohYiQmJRl05cxjqYGDoh5AfMTAh5lxm6vU2Bkq+w tqtF53Xk8pt9
JoRMCPkDCorPEhLxVFkE+X8gFA5kNSTM01gfDokJIe/ioQh5kspzC2OECEJf 1CsRiTYh5N9p
TAj5bTT2Fy39lkaH7tWXTpAQch7KE6rpsb3DJ4R8YGNCyLtsrHOvZ1gtEo6T vbBw78xLBzXm
x9VTKBNC3gUFqO9JUbhb4paf3Kx38TlbjWlCyEMmE0JexUSRk1JU2qXbc4lT hrHfviazEfIc
yoSQV0HZKXF1XzIWtbSVvfA42xU0mRDyE2YmhLzLDCwrFDBVFBGze69n6l2e tLQmhEwI+RMK
1un0E1kiZzkynbV3rLSQ2Qj5dEhMCHkXj7SUc5bKBWnG3GwotT3PWetMCPmA xoSQX0XD/gP0
pQDf0zi0lJZfEIkLIXohWq6t1VfnaaxPbEwIeZcNLY5DwHZEio5ZG/JWCKB1 Y0LIYygTQt4F
5bgvaCYnEfHOOAfZq5FbTuWEkIdMJoS8iknuhV5ReUMANDyQW9cB2thnzTx5 DGVCyKugnJ0c
wuTeYh3OWTdQb+mu6poQ8gNmJoS8y0xTMV3roC0lFNJ2s3jfvbn2nhAyIeQP KCiNdN67LkkR
ZSchV1IH774+IeSzITEh5F08MoSwZXFuKcRYcpeCdSxlhwkhH9CYEPLbaOyv zfJ9QndWq9Rt
Ll3ubIthb4sK5zNPY31iY0LIu2ysLJEjCzyFg2zdA0JOWcg3cH5cPYUyIeRd UBLd8HrTWXKr
EjYU32UYkn19QshDJhNCXsVkZ9cNLyQWPMei64ir3E5eSDNPHkOZEPIqKPei F23OMkHH3LzI
RBf7IoE5lv4TZiaEvMvMamWguIdYxCqSrnkikUmtvhNCJoT8AQUkRkV5d7dA utFmkWOB6cCo
E0I+GxITQt7FQy5CdkkTiRunr1VOW1gZ8vKEkH+nMSHkl9FA+nLlb2ngOcAr bnuI88nai+P6
Wveuijsh5AMbE0LeZaNcNPnkYpJNaK47e+9FgmE9P64eQ5kQ8i4ojEelbwmp aJFb1ancbUfB
ekLIUyYTQl7FpDLt7MoDJAcppKX9CC2DZWc2DJ9DmRDyX/burjeu5DjA8F8h ECB2LkJUVden
c9XVXQ0EMIIgNnyVm42kjReQLWFtOfa/z5BLi7vS0tCMKK952DeUSEgYzsx5 0Kf6nTPz9KCo
PwxlTPC53NRZBD1UjcDZcjH5viLkMczsEHIsMxYws+XQcLalHjwhukIqlibs ELJDyDNQkGiT
Zwwcxjqwm5FUTiFtU9r+jJAzF4kdQg7GI1CZcgwXTkyHLFUjNHL3gTuEfDqN HUKeGg2/RrcH
aQwzKFucaJwCaRBt+uhtIDvtzwg5x8YOIcey0RrQAHcEY8GR0Tv4mssAbNF+ K5OLoewQcjAo
XE0ISTLYaHUNqrlgTa6A4B1CLmSyQ8ihmKRDw5iwqjOs6j6qciBAMXrtsH45 lB1CDgXFphBW
SffO2cMpVvfKEEvGtnYIeQQzO4QcywwYsfRWi5RzrUzVkMUGQNVBdwjZIeQZ KEDy1gL6cGVh
yaqusyQ6SQevHULOWyR2CDkWj5jZTLiUhBma65oROMfoPYR2CDmDxg4hT4wG tWsmfJCGVslE
BQHgWtELaOoQnLh0sO4QcoaNHUKOZYMWRrTmZsaa4SNJcnZWouYie+PqUig7 hBwLiick+fDe
iykpQ7yyTxm1pIvtEHIhkx1CDsXEWNYYTq0T+5oB1hp29WIw9B1CLoeyQ8ih oGCmGLoVL55O
ObApkgzuxhK5Q8gjmNkh5FhmcjJEh+g2mcbwZhSlloxu3XOHkB1CnoGC1rlN 69PHYG8a1dhV
Fqq2ph13CDlvkdgh5Fg82NWwpPHonLAyZs42rSaJpqwdQj6dxg4hT42GX6vo gzRWyyGrlBEY
wzJEXDQAlsQY+8PSz7GxQ8ixbATCzOUBHRnZEhVmlRZSS5u5N64uhbJDyLGg GE+vbBDZOBp1
IK1ZDgyELLJDyIVMdgg5FJNaZhoaKcDdhs8gGozMKKr7M6c+A8oOIYeCkoZO tZovZrUV2Qkw
qrVoWAY7hDyCmR1CDmYmcDoyMBezhQf3GhXYh+OMuUPIDiHPQIFQxhrdDIS1 q8+JtlrP4plz
7M8IOXOR2CHkWDy8DfaeqGKcOnqANRCk9NEMY4eQT6exQ8gTo9HatQc8SMOK VCAR2dhGz4Uk
wwZxB5pLdgg5w8YOIcey0ZuY4RCfiws5p2OrleKuLq3tjatLoewQciwosHwg hHQJ5pgxclBP
ULU212g7hFzIZIeQQzHhabGaO7MxsXiWcnJqAPPo+60WL4eyQ8ihoKylTswl YExrhE5PnANH
79Nm7BDyCGZ2CDmWmYnZVk1ZPXiEdPKIZBiLDEloh5AdQp6BApjRF7ZMKhaI 5OiegmrLcOXa
IeS8RWKHkGPxmBHTusy1ittozlxqQ3r4iMa2Q8in09gh5KnRiGskeXjl0GJp hKCdEamLTuVa
ONS5y/6w9HNs7BByLBuNhcCdU4N7lU8hA8q5VgVk7I2rS6HsEHIwKBOcgo2I mU0CqUN4MlNf
0/YVIZcy2SHkUExErc8i0HBuBH1O1siJyzpk7LfGuhzKDiGHgmJVPJFQcXGN kT2WUFUmUQnU
DiGPYGaHkGOZmYQqKhkoXGkJnL2ZdwIb2voOITuEPAMFA0bP6a0WcWp1tKCO XVCpgvYVIWcu
EjuEHIuH6KwJvEYGL9ZsVkJFNZVo0g4hZ9DYIeSJ0WC+bhIP0uBGnXyEl7Ol eSuafVbv1sGw
dgg5w8YOIceyQUwjSaZUsKOF2sCuEdB9Yut74+pSKDuEHAsKxGyA2qBNtsY+ E9l4oi/gXn2H
kAuZ7BByKCau0RgXRRYr9aCVPfuasmK2sd9q8XIoO4QcCkqrnpBUDSZXUcBg rxWuy1assUPI
I5jZIeRYZkBTcLJDX5y4omrZLDUVmdJih5AdQp6DArc2FbCtydrIXU14janL OGuHkDMXiR1C
jsVjqPpSRl/Iy7WPsspWyigqnDuEfDqNHUKeGo24lmgP0uijZwZHJfBC9oVg qENnCorEDiFn
2Ngh5Fg2BmGXCdxjcmbPxGiinOljMexX8F4MZYeQY0FhSukTslexeiWaIY9s JSObzh1CLmSy
Q8ihmJTgSmDI4ezKWaqRhVQOseZ+q8XLoewQcigo2GlhgiAhV1po8YgRTglM MncIeQQzO4Qc
y4xr51wIsYrRWrTeaBEsCQuaY4eQHUKegYK5qgSbDjduZT3QcIyJyE19zh1C zlskdgg5GI9I
F8yR3bgK3MKkkzDMShi6Q8in09gh5InREL4mlQdpcGsTZ9WgwRYzJXJCdxlt wMJ2R+M0jr/6
5k+vXv78DsW/HHiCuPkPt7/dzY2fIPTx61/+6tW3f/oegvYjg7c8KoLvTqFu fnD6n//zzevT
4/yBCBGjLeJLiMgOIymgN+ZVzloSRKowvZvdivjrE3R/AF/94bfv/vjyzf/9 /nRPbgPhq5c3
T9abd//726ubI+j7Xho8PzC6wRwWzLARq5WUsnp4X02GVdpiGzruwNzkj7/c TBtfvXjx6u0f
r37/6s+nL1/97uTk7TdvX92xOXL3+AQnzLGdHNXJdFpYmIsHY4sO0Hx15ZWp A/TOyTj1wZs7
cvXu7dEofLQ59YPv7xWYf6DgcQeM8ebbV98/4En3aPEljncfRsUcrQbLjGTK lY3ZdUil/9im
1P168PDGFB15+Lh9AP7zdP9//cv7v380hCPGx+sEPSqS/7h9Jm5u/bQ8bC1f XguyJEhvkME0
Pae6hIaSduDRPxzEA+P4o/inaXD+OOk9btB4EIM23OdKX0KD+vDRdGAlY1Vw umJWt85Js91p
+M1Xr795efptX/41bF+9+frqvYzn7sJEt4uDuTDCqdlXD+KQ1ldbo7Ux26Aw GHcuxvtTplOE
PTXYq389PXEvbp7Jr9+9fv2Xq69evjw9b/cnVrdRw66+fvPt1fuD7PZnwP/8 T3/u/3Y0SR8O
IveP14epvJH/0NDjnmXd3/CP5vLGvBV9AUWj+fBpgmPympiqo9ng6Gg0U76/ xXs7cPziw5cl
/vzzz7ruXtd4joq/cST8fcj84bs/bp6G/7750m+++/fTi5ivX7x9+354//Bs 7DMmE0Xg92Ye
fuDuyTR2fwQV5x3Ej47op1ERSexUcyKzdeyMUWbThZZZxZ2K2zrOcBfHT0P6 i9vLoj6Xwz/a
EvHDbdubS7/e79v+Vx/fff+rd29v/sX9YiEfT+V88bH/Y+vF7e1+vH27F42/ Bw8sC2GesFgT
XIYQASxfA3DtzHHecIIQe2o/GpFaq+dI1D54efoo6OEgAguH0Ud7WIx7D2vv YR1VwxLtTYXL
nKdEEkMD9pJcwyD/5h4W497D2ntYx3QBK4yUNauYMlMcW1OtMujF8oMXWP3s o2nvZ1en6/5e
vj7dxZtH7+rF7z77Go6jTuJuvCfxzwT10whZysZNy4I4sDIrWY3daonw3KPG WWvIHjXOO+bP
NPfTEGnLaukatJwBsQev4O66dOGK+nDUQAjds8aeNQ7L4f/bO5veNm4gDP8V nYL2UHW+OBwm
aAB+3pIGjo+5GLWACqgT11KB/Pyu5JWSVrVbVQkEb3haidjVUuI8Gr4z5Kxn kSCVmaWKsxij
ZEJj8xQyPqY1EIJ2sdHFxjTBCBVbclbQm6SksXANKj4gYVWu/yo2bq/uVovr ndSYPftt/SIP
x8G8fnr2+x8f1i/w/jC7HqZauyagsfGX9cdd4w/jiS83H7Fe3N0s3w8/z2y5 vB5PGEZhvrgf
8fn6dn0733bqs4t+3F91/3box8tTkZ2s9ulZyJP5PhOwTgvmJiBOrEIyr8zN m28RGa1rn6Nc
Wtc+x9n8kcydBxEl5pBJQEw4gJErHkJ1jlyrBQ7SLMRd+nTpM1UakLNLLppP QZqkVJVdiC0C
lhoMH02zEHfl05XPNLlwAbJTiC2raPAhKoZGVLPEVF0cufjLBHpYJ7zXGN99 /4VKZE1VYqho
lxgngnQeMlRicjUzIErkYq4mX9hHjmQQZSTj9e7fcqwIhCAPVwSiUyl56h6E iPqOxP9s90dy
dx5MOEszER85iWpO1VgkAXuvTjB1JX4UIF2JTxCRbOCTL75SFm8UFbJFoozc OAc8UOIKXYl3
JT5VGhyVHFwslEychOi9qwiAgXILrY40rNYfbi931rKzi1090m+46CginuW5 B3369HVoUJ+z
GWvELLFhkgiFXLUUuTiXH41LKfS4VI9LTZMLpqCRJEU2kaLRUvTkqQCzgurj XuKTsOhTKEQK
56KjO42vAwd6F5pmbUSiOUaDpMnAipA6rB2Ok+DoAaknDQdrjQ2aKRUp6gwD MIhqSDkKlxGO
N3k3cJu7D3tFns/2Ifzt3pEhp7FZy/V8n+o4lZWnmeHYrDE76Pk/t36W9UBT 39MeJ9J2HnzE
xGHyAtAkl2glSAM2wOZTBvqU9hidyEDF3cDCwMxqNhRpXFx/807FTM414epy 5BQqDB+kAiMi
sUQREsvBIgrlGlSaloj7h679enW31eg3Q3dHMDZQrObz+eRKZL29yO8uL+Lr t29+vrh8t9p+
9VeLmwGN/esDNITgAA3+omiMQ/BqOwR/o4PEoNPxP+lg7x6kw7FCSRjQnJiQ NfPaCrQawJGj
kY76cbnebMi9uVq+nxIIxxStJvC9aPUZDP5PUEsBAhQAFAAAAAgA3FRGODhB TLYXoQAAwk4M
AA4AAAAAAAAAAAAgAAAAAAAAAHNlcnZpY2Vsb2cubG9nUEsFBgAAAAABAAEA PAAAAEOhAAAA
AA==
--------------030602000500010102090107--
Re: TPTP newbie gets NoClassDefFoundError -- huh? [message #122427 is a reply to message #122340] |
Thu, 07 February 2008 11:41   |
--------------030003010501000507000205
Alexander N. Alexeev wrote:
> According to attached log your AC works correctly.
>> RCP-profiler, I am back to getting this error (in the console):
>> MARTINI_LOGGER_DIRECTORY=C:�-Temp
> Probably you've put MARTINI_... variables definition in field for VM
> arguments in "Profiling Dialog" please fix it.
> MARTINI_LOGGER_DIRECTORY=<an existing directory for log>
> MARTINI_LOGGER_LOG_LEVEL=5
> should be defined in OS environment. You can do it thru 1. Command line
>> set MARTINI_LOGGER_DIRECTORY=<an existing directory for log>
>> set MARTINI_LOGGER_LOG_LEVEL=5
>> eclipse.exe
> 2. My Computer properties
> 3. tab "Environment" at Profiling dialog (Only for profiled application)
Doh! Now I recall this (I rarely use that tab); done, using method 3.
But now new errors show up:
a) I try to profile, and I get this:
org.eclipse.core.runtime.CoreException
The process launcher seems to be inactive. Restart the Agent Controller
and try again.
org.eclipse.core.runtime.CoreException: The process launcher seems to be
inactive. Restart the Agent Controller and try again.
at
org.eclipse.tptp.trace.ui.internal.launcher.core.LauncherUti lity.createCoreException(LauncherUtility.java:123)
at
org.eclipse.tptp.trace.ui.internal.launcher.core.LauncherUti lity.createCoreException(LauncherUtility.java:131)
at
org.eclipse.tptp.platform.jvmti.client.internal.launcher.TID elegateHelper.handleError(TIDelegateHelper.java:596)
at
org.eclipse.tptp.platform.jvmti.client.internal.launcher.TID elegateHelper.launchProcess(TIDelegateHelper.java:508)
at
org.eclipse.tptp.platform.jvmti.client.internal.launcher.TID elegateHelper.launch(TIDelegateHelper.java:312)
at
org.eclipse.tptp.platform.jvmti.client.internal.launcher.TIR untimeWorkbenchDelegate.launch(TIRuntimeWorkbenchDelegate.ja va:32)
at
org.eclipse.tptp.trace.ui.internal.launcher.core.LauncherUti lity.delegateInit(LauncherUtility.java:1153)
at
org.eclipse.tptp.trace.ui.provisional.launcher.PrimaryLaunch Delegate.run(PrimaryLaunchDelegate.java:196)
at java.lang.Thread.run(Thread.java:801)
b) so I go to the 'Monitor' tab, select the "Java Profiling" node, and
click "Test Availability" -- get the attached screen shot.
> Could you use one of this ways and send martini log here.
> It should have name something like "MLogxxxx.log"
No martini log was produced -- the directory exists, just nothing in it
from today.
I also attach (a zip of) the "servicelog" from this session (huge).
THEN =====
Restart eclipse and try again -- this time the "Test Availability"
works, and so I start the profiler, and again get that ClassDefNotFound.
Now there is a "Martini" log (over 9 MB!!) which as zip is still very
large, so the news-group server rejects my message if I attach it. I'll
try attaching it to another message ...
I do attach the servicelog, zipped (# 2 from today).
thanks,
Paul
Content-Type: image/png;
name="JVMTI_agent_down.PNG"
Content-Disposition: inline;
filename="JVMTI_agent_down.PNG"
iVBORw0KGgoAAAANSUhEUgAAAbsAAAFCCAIAAADnluSYAAAAAXNSR0IArs4c 6QAAAARnQU1B
AACxjwv8YQUAAAAgY0hSTQAAeiYAAICEAAD6AAAAgOgAAHUwAADqYAAAOpgA ABdwnLpRPAAA
J05JREFUeF7tnT9oG0n/8PVCChdX+IV7wcUVj+EpHsMVP8MVMTxNBFfE4OL8 44oYUhiTwogU
h0kRTBpjrgjCRRApjEkRcIqAXBwohUFpArriQFcc6IoHdMUVKlKoeAoVV+j9 zs7+mf3rkXaV
izUfMedTVju7M5/Z/cx3dlej/zP+OP7f//d/39f0q7GxU/ff8j8IQAACzhPo vYorUYxZv9fs
fxxv7LQlHZ0PLn6ekCAAAQhAQHyoxSie1KmmjRm58pfJ6YcxCQIQgAAELn5R 4aP2ZmTMUJen
78ckCEAAAhAwCZjSVDGmGFMWHV+PSRCAAAQgkCYghtRhZi0MMI+uxyQIQAAC EEgT8MPM7zu1
zf1u893o6KcxCQIQgMDyETh4Odj+oTdr2nsxaFzFxCieFFtiTLoKCEBgaQmI Lnef9rqv26Or
i9Hb3DR+e2Gm3qvLxklXpGn2H4Yxr0eNt2MSBCAAgSUjIKFl91W7/7rVe9ns vzztvzgdhOns
eOCloZFGz49UOj8VaUpek0bzOowxr8eNNyQIQAACy0ZArDeU0PLHI0nD50f9 s9N+IEqtS5We
Hw9VUitI0iuP3rSUMQ0xNq/Hwaj8enzwOiM13456Pw0HV4Pe237rpHv6tHv8 pHv0tHvwfHBw
PsrMwkIIQAACnw8Bsd7ojRizMTpRqf9c+XHw/EglcWgy+aup9T1jmhW5wZjt q+Ho5+Ho11Hv
3eDiZd/TZefocafxqH2wf7n3uLN3Nvx8uFASCEAAAmkCnjFbQ9Hls4PBSWP8 W286nfYl2Ewl
WS6fyjqyplr/dZExRwevYun01XD4bjD+bTT6z7j7fnj5qh/T5fcX2zut7f32 3othIuPB1Xgk
ezZe4tzkOvF98SkEIACBBRFQxnzdGj47UB581gjN1D85MlO4XNbx1jzwjWnI yryOOdo7j6Xu
68HwajD4MOz9POq8G1687PnR5cPLPU+X9W+bW/8+rT/uJjLuvh0Pp9Phq9bK 2mmY1vYHidX4
JwQgAIFPQMA35tOD0ZO94dODvinNZw35Z2KJrKPXHL1uSl6zhDFj7r4Ymmnw pj8473Xe9NtX
g4vz/vFTbzAe1+XmN8eb91uJjLtvfGOuPewnP4rvgk8hAAEILJqAMuar5vDJ 3ujJrvztizSf
HkSRZvy9fBSuKbkkr1m82L3yrZOBmQZv+91fRipJjCnpw6gt6f2ofT28lCRR 508qNV/3Exm3
Xo50jLn6Xc/4aKguHvw+uvzoFfX34dZJeslA59Wv3pUuT9Zq8aImC8CnEIAA BAIC9cdtuf09
uL8+vL/W39nofbelU/za4TRcLuvImrK+PGNU/6Ft6sW88zPaejYwkxizd9Y9 DW/1pKLLja+P
1v6pUiKjab3pdHL5Um/WE990dHHYXn/QPto5XbnXTy45HCjVXndWvzzdfqWu hXbPMzN2knuM
l5xPIQABCEQEDtviPm3MgTLmZphCaZoLZZ3AmI2tw0uTpBFjvh9vPe1vGqn/ 2jbGNHOp9y/8
GNO/iPllc/1QtuwZ8317Rf/zsLN+mFyyez2RW1UXO6erO11Zv+utv/ownTFW zuTe47XgUwhA
wHUC+5fqScz7a54x19O69Ae1gUllHb2yPGC0uX8Z0hNDNt+Hz2NqYz6JUvu8 33/Vu3jaSV+7
3PjX0bpEl181Vr88WLt/YeZS78+CUbmIL9pgIL5/d4KFySWnv0nJB0ei1EdS jPBTLxQV1UYZ
Y+VM7t2oAh9BAAIQ2HjoG3P07apEmr2dTUlRdBm+n0z0R2o8/u2qb8yHlyHA LGP+0NsM0t6z
Xu91v3PWPXp0Gd4Zl1s9ejC+6uly9evjjUfdMIv/5vnQv455v2N8NPDFd7cd LEwu2Xs/VsP2
nda6KkP4aS+VMSpkctdG+fkIAhCAgBBQxjw7Gn23Lmn4/Ub/QXQFU97rFN0I erAl6+iVJdfG
w4uQYcyYrffj+tPe5uNYOv5Rvr7e77zoHR1eyiTtaV2uf99OZFH/NI0ZbdDw o78wtcTPeLG+
39u7FnuqEfrKXcOY8eJl7JoVIAABCMQJbDy4GL84Hj3cHD/cGO5Hchw82jZT 9Dzm/pasqdZ/
cSx5Q8+IIcWT/rcklTGf9DYPk2nvae/yZa9z3mu/6G7LL1v8SwWY618fr927 2HjYTa+vlvyo
YkzzNbyWC5eBH79pB7nSS3qb51HW7llTXfR8mLVaqpzZJWE1CEDAeQLKmOen 48fb48f10Q+7
k1/ULRJ5hCidZLl8KuvImmr981NlzACgGNIw5gcvxpQhdiXpwYXc7zafYF+9 1958dLkmC7+5
NHaRXtLd3IkefV+TK6GqPFmrVVJONgIBCCw7gXUx5pvW+ORgcrInSU2xoWcn et7wk3yF/MeD
sZ/UOpJk/fGbpuQNfaVizA9hjPlhvC0x5n6XBAEIQGCZCKgY8+pi/PJ48vJI 0ujlqZlkeTyp
dSSphVcXKsYMrCiGjBtTYsyHHRIEIACBZSKw8aB1ed5WswVLpJmbmhJRhmki 79+qXJI3RLGd
iDFlmuLNBx0SBCAAgWUisPF9p/748vJVZ/xzNzd96EziSdaXXJI3RCGGjGLM iw/j3Wc9+ZgE
AQhAYAkJPGhJwDhbivtQDCme9O+VK2OeYEw6DAhAAALZBPZODGNKtLl30l/C joWoGQIQgEAV
BMSQsTs/e8/7azvt9XstEgQgAAEIxAjstMWQkTFPfxrKv2WN8ccxCQIQgAAE TALiRjGkeNK/
jokxOT4gAAEI5BHAmITSEIAABGwJYExbUvS6EIAABDAmxoQABCBgSwBj2pKi d4UABCCAMTEm
BCAAAVsCGNOWFL0rBCAAAYyJMSEAAQjYEsCYtqToXSEAAQhgTIwJAQhAwJYA xrQlRe8KAQhA
AGNiTAhAAAK2BDCmLSl6VwhAAAIYE2NCAAIQsCWAMW1J0btCAAIQWJQxp4eN 6YO96Xe7051t
9Xf/YHpyDG4IQAACt5pAxcac/ntr+m19+uhg+uRoenKq0rPj6Q9HypjiTfn0 643J48atRkbh
IQABZwlUZkzflWLGp8fTs+b0/GL65nL6+lK9kX+KNx83pg/3pve3p3e3xv9Y H5w1q4H+a7N+
r9lnxviSBMBYEuAc2fOYp5cvunUWvf1iOJXsvZKNWDRiNcac/mtDjb5lJC5m fNFSohRdmsaU
YFOiTj1U96Q5/ef68Nv6HNKsxV/1w8aMxuw373mbEM/GKMvyevOqWZePDtth wdqHsmajobMY
L7Vf/5+NtgXomWv6qY4Av2B6d1XttHg79nuxXzNsgjBLIu8cm0o3ayUbkc0W 067KmLKdjIM5
K7yoql4znQh5LZW3kcxCzrqRmUqYtXIFxpSBttKljMRFlxJOijF10qGlhJwy KpckMaasI8aU
le/Vp99sijQH/9qYWSXhAafrM19j+7k8S/5qbEctFz+aC+uRkRdxEs50fJRu 71za82Gcr/DV
7itRhlu08UXHmMUHs8ltodBuPEgs974cxlTRpVy4lOG2CFHkqK9dSjgpcvx+ V4WT8qn81fd/
ZIm8kX/KBc27WxO5pvmP9e4c0jTZee+bEgl6r8ZVoD9/QeC+nPOqf1avn/WV R64a6o23tXaw
UALMxpkx6rcwpmwwiEQN7YbBqb6AoDt/9fLWyahCEAjLGrp4YfdgBrZRRi/O jTbrRdDpKieZ
tBtBwfxqRrFPFFZrpFG9MqsQ25dReDUCSGyq+FPj0YUrr3Q68q2FgbyUudH2 XaBb3N+gV87E
xg0IQdslK2L0u/lHkd57dqMkWzxdWpOe0eJhRJ+xhQhadIRkHDkWo93Mgzlr jx4rxTzYY84Z
FAOYOhN1pTySiWMycSYmWyoBP3UeZcK/YSPJE62KgKNUjDn9x7oaX4sExZii yEcHE3kjWpQQ
8n821adrayp9tSbhpFryzebEc6UKMOWfX2+M/7k+Xltr7WzPFmkm2ikUpbS3 Op+9k6o4Ag23
IFm8MbiSo5xy/vLwtIwPVC2MGVXE37KyUuTxzOJ5pvPX8auQGTtHm1LHkxTb zKhqndiR+eBU
mok62vydJsaJarPB8a1OIc9QAdL2obC9iXAIKr0pc1iQ+WlW7OO3jj6l/Yp7 JQzP8DS3zMZK
ViTWFcWbIEX7xgFN4lgKS2vWKCx/5jWQRO20aqM1b8KeHRbkHMx65UR5/FbO 31ECYKYxw+Ow
+DiJHSSp4z+sS0A1ezRZtJEZcdn5dH5jKvfJeFz+6hByZ/v0sCFJyXF1dfrF yvRObRIk9c8v
ViZra42He+JHtY6X5BbQ6Ku1wepq88nRDNJMt5PpRzPU8qKQjOuM0RY0VtFH 0CV6MZS6fKkb
Pm9feedPItDLOaSMK6I6YgqiIfMISMSJyX4iJ2NmwdJM8oSSPJOFj7hJR6NG P2RUIINwdi30
pgyksTIEn2aOFiMZ5Wwhvcfs7i1eETN4TzRBmrZlixuibB/mjDP0xuNnu080 wV8bKly/GHu2
MbMO5vRRatu+qSPhBm5mieNnYuZBksekAH446EmXZCZcizamyE7FiRIwemHj xZOj7u8DSa3D
xqRWkzSu1UbeX0nyz2GtdvT97sX77sWHXltCUS/8FF0O19aGX662VlerNOaN d8+N80Ed1nLD
R9/tiTVYzKEZ10wT56Q/Lo5fGA1jn0Qcl+mFRAFmMmZ6R3m7yIy+zXM4V2TB 2ZKueM65Go8L
ShjT79LajcTpUSDKbGPqoDLlzcyOzTwDwzFmulHCeDzaiO6AjdIm1knQzvw0 bCbTmDce2JmN
rrVrHoFZe5Txu3/P88b2DQHeyK2gwAXGVAWOn0fzGXMmXAs15uibTRlQqxjT G1xrXU69V+/P
kUhTu1L+6jeDQJd6nUtx6w9Hk9XV0Zergy9X+6urvS9WJPy0lWa6nWIWMMan eRRMv3jXy+ID
Z2M8m7evvFAuaCR/PKWOrUTbp4qXuYvwKI+qkDUqj46J9I70lU3dsaeZFI7K w81qUL82G/7l
VH2vLIuwWeDEKaqrYA6c0wJKfxonLDwbclVUF6NYlJl2CyQVr4gxKk+G+Tmj 8sSQxWi7oMX9
y74ZpU2Msk1veojiY/Bgib4K4V/PMS6kmErNPM4ze/R4DJvYowytPML5Z1Di SFDPlviRY7rw
Rdvxw4ucoCSTasYZYRzhGSeRhQfsLGl6ac5RuUSFKsYMBteD/QMR5UTr0JOm OFSCSh1gii6P
9w8uP/SCz9X/h9/tju/URl+syJBcdNn/YuXgq7WKjFlwD0QHF8EtF59X4fWO AjubN2EC9Ho4
r3YQPvak72DoV/K2SeohJ2N3elM33vmJ7vBk7yhrKJ0qRvLOT1TiSLh+vUJn ZVQqGnb5hY+e
wTIG9cFFD+MJLePThHnTgV6xMc2NmyGGIZ1YRdIRt6njVBOnGyWjxU0deNtP rhN3ZcanabaZ
R05qR7EzKM+YeeUJelb/FmiiDNHJEhzh3pEQ3qLxD/h0aJ+9nQhL7AHBIHsm 1YwzIrO5M1ow
617o7LqU+s5pzIE3oJbrkur2jtzYEfftbMupG0pT3os0xZWS5Bpl+5e+qUtZ WYWfKytDz5Vi
TEmtOzVbY85V1b9/4+E17EWXv+SObh6UWX8Zv3hTN+7IHAosGhrbh4AFgXmM Odo/kKG0DKjl
NrdIU6UvViSWlCfSB+NImvK+/eOppN4fw4QuRaPDOzXR5WBlpb+y0vXS5Z3a 7qw3zS1q+LeL
Muwts+9BVVeFynZ0o8jsyzy/MfVoIOfhMPsCsCYEKiUwjzEHd7fkyqOMppU0 5Y6NvPliRWJG
GYb378WkKSFnGHVqaYpV+17gObhT07rsiS7v1DorK507tU153qjS6rE1CEAA AhUSmMeY/a/W
ZBA9+EKNqZUrJcn4WnswkKYZVIbvRZc9WcFLYkzRZf9OrSe6vFNr36mJN9dF wRgTAhCAwOdK
YB5j9vS9mhU1ph561yLlr9alTr379fFfMWdKpNm/uxXqUklTjOnpUgWYtRmM mfudxU+AOLi1
Ej34bbnTCse5lnv8rFbLq37+rYnKOs4C8reoUeY+8G48DD4xhE+8uxurP/sK cxnzqzW57Cij
aRUket5UQ+xQl6K/H08TxhR9ymRF2pjyVyWty5qny1rt0pOmTYwZPfpbhv48 ebMesS4mbt6z
W8CjYTdrZZ5qWt/VsTnaUg/QWN7MvblqNnuXdQqkbAlnpi1YbtOy8P5qqedY Z8te2KALKXD+
Hj/x7ioEFWxqHmNKtCiXHSU2FOXpUFENsT1jigHlaz/hs5mxx4kmEzGprOAb 01tZG1N0Kemi
Zm1MXfpPTN986sWyJTBmcUv9LTHmrI3yt0epcxx4lsfn33IS/S2hgz2Qm9ac x5jy9KXEg3Lx
MZJmoEt57rL9c+y5S1Oa+pEjUaRIM9SlBJjiSklNe2NGkUs4y0NiSgv1YGDm dAP+HAEZT2z5
t2WzZ2rwv+QQPFOpDmL9ih7BjWYf8KHPP03AQqfzKMKiT6HgeTt/VqfgGPpM ppzIL7/XHsmp
WBIP4lUxAYR/8GTNDREcVzlHUfh1o6CouQdSWJfwCeJZnuf1ilE0HUa03zgf lTE+c0rupsIj
PzlpS/5EM+H3es1vT8w+dLtJapUNULJ2NI8xpUDyJJCSpic+PdaWN/IlyMRj 6hKNypPqIs3o
OU3vG0E6Yzge18aUp0lsqhoblQdPn0TfN4hmAYjPgpOYt8I/slPPrhv9uTfl ROaXf7K+e5O5
37iXUxM93DRdiOy9+uk8CrHcOMWGBvKZTDkRzVuRmMfB+LJH8Zg6PQFK2OIF E0AURKlhXx6b
uCRkHv+elfHVmoypVXLnFknVzqxjVIDw20HpL2jk81HHf3oSFnNT/nujwPH1 04eQZ+fkd+pC
vCWfHf7k9pzfmEqanvW0++Q7jonoUp40kuWS+jvbw8kk8XC75NWXL8WVLe/v 1hzGTHwhJHF6
JDrSnAMr+nqLOspzZmowxy+J7YRf+003XuapZRzT8V3H7Wx+U8Km5Ol18sZc xViMMiUfIE0H
JokJMmIhqvF1poyIPuvLTpZTTtg0a3pmk7B1CholXf5Zr4RGPXHsO05+KJA+ PgsO4HQ5wyOn
ePKLjLk8zEbNn8AlWVkv+pPvQWbC1LFFrEbB+olDKPPIDMQazUr1yd1nE5+l 15nTmDKppb74
qKUp3+q5jH+rRyypP9Kpe19JM3rMyLumGepSjClD8pVqjWn2ljaHWqzBsryZ d6bNbcy8Czrp
klc7nUfxvA/2pVLEPvmUE7M2a3GMmTHbjcUEEDfGmP6xVDjfR0JPaQHlGbP4 YMg71LNHS6mb
AZkGnNWYxTPIBJ96rjTi3+U2pqhXPCiBoZZm+3825W5PFEXeq5u61KNvkaZ8 CyiUpmQRUWpX
yt9dO13KfjPvlUdjhKzWzZgjwIgFYo8KJaecsB6VZ4pGnwbpcyNvVoXUfZLq p/MwTonZpk5I
Z/RKmz1BxiKmnMiDkxHCRJfGzNkxokAvr1Ey6xg2YmaUmjkxR+5RZDEqTx/A SXWmplwxSmjX
pvl8TJjBJCzGr8IUzgXjq9xuopkgnI+mTUhz/iwdOmeMqSYX+Oe6vv7oB5sy K4f3kujS12gQ
gYYDcJGmXkfyalHKX0mn1gFm0ph5ExZ4rLOnP0iceIkhnnGHJzYFRkZEkLzz k/nrbNGEFJln
Qs4kBQudzqMIS+awNDhw/+YpJ/KKkTnoCx5gzPwZqIJGsZoAwthjcm6I2Kjc +5qnOYV+HK8/
+2rqFqJ/IOXFmPo6cvzImXk6jDw+5umQNwVUosBRUXLmfMkelesBivEt2KU3 prr/41lPX4WU
JELsPdiLAk8dfgbXK/UYXFbo3N0KRSmulPeWVzDnu+6wbLlu25XyZeP/WQU+ lR8M6YsYxfWd
dX1za7dzmpX5Y0x9JoTS1OrU9tRRp5m0UsOgUseVx54u7cfjLp97lc2y8Vmd 8BRmLgILPBhm
NeCs6xv1vXX3fLR/yhpTNqEfpdTJDDm1JUNXmmPwUJd71pcvXdYldYcABD4T AhUYU2piBo8J
eybiSu1K+StpG13OFWJ8JocOxYCAgwSqMaaAEw9qOWobZqbQlUdcu8SVEIDA LSRQmTF1byMq
1Ddz8qQpN/m4z+Ngz0yVIbAcBCo2ZghFLlCKHEWgkuSN/JMx+HIcMdQCAi4T WJQxXWZK3SEA
gWUlgDErnQ7yFl6XWdYjm3pBYBEEMCbGhAAEIGBLAGPaklpEf8U2IQCB20UA Y2JMCEAAArYE
MKYtqdvVE1JaCEBgEQQwJsaEAAQgYEsAY9qSWkR/xTYhAIHbRQBjYkwIQAAC tgQwpi2p29UT
UloIQGARBDAmxoQABCBgS+D2GTP4NW31iwCJH9ReRJfCNiEAAQiEBG6hMRM/ WMoXEyEAAQh8
KgK32ZiJ35L3f6HJDzzD34oKQ9FoiXZu9CNQ0c89Ng+Dn3268qJ087deP1WT 0J9DAAKfLYHb
bMzol5WMXz1O//CI/vUo45fq2oeiyKzfEZWJ6bQowy1jTPoJCEDAIHALjZn+ xdrYT4bKx0HM
GFtTKdL/SAePidF97m+E2l4S/mx7RQoGAQhUReAWGjMaUxu/jxzqT/cGZmwY izoDb2JMAgcI
QGB2ArfWmHrsrMNJY4jt9ySGENXlS/Hpr83GWd/7VP+ufNao3Iw6Iy9zR54o GwIQ8AncZmN+
HHs3czyjmQNzT3bhbzrXDxveAFxHl+pV1+rMuvOj7giZY3auY87eCVc1/GE7 EPgMCdw+Y36G
ECkSBCDgCAGMyXADAhCAgC0BjGlLypEulGpCAAIFBDAmxoQABCBgSwBj2pKi 44UABCCAMTEm
AGNiTAhAAAK2BDCmLSl6VwhAAAIYE2NCAAIQsCWAMW1J0btCAAIQwJgYEwIQ gIAtAYxpS4re
FQIQgADGxJgQgAAEbAlgTFtS9K4QgAAEMCbGhAAEIGBLAGPakqJ3hQAEIIAx MSYEIAABWwIY
05YUvSsEIAABjIkxIQABCNgSwJi2pOhdIQABCGBMjAkBCEDAlgDGtCVF7woB CEAAY2JMCEAA
ArYEMKYtKXpXCEAAAhgTY0IAAhCwJYAxbUnRu0IAAhDAmBgTAhCAgC0BjGlL it4VAhCAAMbE
mBCAAARsCWBMW1L0rhCAAAQwJsaEAAQgYEsAY9qSoneFAAQggDExJgQgAAFb AhjTlhS9KwQg
AAGMiTEhAAEI2BLAmLak6F0hAAEIYEyMCQEIQMCWAMa0JUXvCgEIQABjYkwI QAACtgQwpi0p
elcIQAACGBNjQgACELAlgDFtSdG7QgACEMCYGBMCEICALQGMaUuK3hUCEIAA xsSYEIAABGwJ
YExbUvSuEIAABDAmxoQABCBgSwBj2pKid4UABCCAMTEmBCAAAVsCGNOWFL0r BCAAAYyJMSEA
AQjYEsCYtqToXSEAAQhgTIwJAQhAwJYAxrQlRe8KAQhAAGNiTAhAAAK2BDCm LSl6VwhAAAIY
E2NCAAIQsCWAMW1J0btCAAIQwJgYEwIQgIAtAYxpS4reFQJpApPxRNL442gp U1C72DniYJXN
dseYGBMC8xMQfbTf9Xd/aG18d7qxs0Tpu9Ptxy2pmtcfJI0pyze+7yxlyqwy xpz/DCHOgkCc
wEjMcvyiM/hzPPhjidKfY6mUVG0sr7gxJZoWVx486xxfj5sflidJdaRSOVWO IBBjYk8IlCEw
kuhy+HEy/Wu6VK+/plIpqdokx5hHr4eX16Pt71aW6a9USjqDrCpjzGS3Weac Ia/LBJQxB39O
RJeTv5YnSXWkUsXGFF0uU5VF/RjT5TOZun8aAp4x/1DGXLKXVMozZvI6ph6V 6xhzmaosHUBg
zHSViTGJMSFQDQFlzP5/xss3KpdKFRvz6OHmMhnz4t0QY36aKIO9uEzAM+bv YxmfLtNLqiOV
KjBm49Xg4qfh51vlP1r1b1szle/owaZUyruOSYxZTTThsheoex4BZcyeZ8xF pMHLei141V8O
1S7+o1ww0Lu7PpIPG9cL2bVUqtiYx99uVVxlqVpY2+J6mRAS5PVHBSvktFTr aoAxOc8hsGgC
njF/G00m1WtL6TKU41/dRq2mpBm6QPml3vpP9ftVHpxMpVJFxjwftN4OrI3Z bUQVMQscX25q
zrNnbmdwoxBvXCHlzeN7W41zYkyiSwgsloBnzF+VMb2v/1SYOo1avfm7scHf VfTUD/8mPq1y
1xNlzF9vMObBzpZFfQfNb1Uc3E4WL2u5rlq4ZvhPeePHnhqIzqte9ZeDfhSG e5+alCaT6FNz
y1msmm8GGHPR8QXbh4DSSveX0fi/k4rTb636vVY/tllxaKOtltclumz+VvUe 41WQShXEmAcv
B6ev+8VVbj9WTkuXM2/5OFllr77/1X+9yoYrZMCZjN81ao87/jp6Bfkb5G0/ DjaS01KN++tS
Ka5jckpDYKEElFY6H4aj8WT0sdL0a2vrXqsX22bnQM5/WS4aOmvUkp9Wuvfx RCpVZMwXg9az
9fwqS1FrB1fpIuUt99ZMVjmsr3F1Uwgk1lRAgpcw0RvxN6V2pyJci6Y5ftk/ eIExFzsiW+ip
yMZvBQFlzPb7oZzwVX9Lsr1Xqx9/ML55+aG59e9mR//9Y9z5sV571K56p/7u pDpSqQJj7r3o
H73oFe/94pGKMWNV8L5Imrd8EFTN32y8vrF9hWvKm3AX5vqxTQlJ5c2Lwq+x XjzdkEoRY96K
s45C3l4CnjGvB6KY3u+jalP7ZKt2t9n2N9verdU2T3q96+amv7B3dNdbUvV+ ZYPKmNeDYmNe
PNqw2LUqpISbzWQhs5ZHVROSqr67r8w3Bl5ZU2/TyOLj0kuCv7s+H9nd1tF1 UQMdnfUw5u09
Dyn5bSGgjHn5biDDcrlVUnlqP4tGnLvn3vbfeUbw9+Vp9Fmv8v1KdaRSRcY8 6zee2++3vRuV
2aQUXy5Vi8bfW0fvgjXN5cF2mg/VqlJ3/Ua9f3igyGg+PiXFx//0Jkqn+xt7 Z8SYjMohsFgC
njF/Ggz/HHd/GS5NkupIpYqN2Xy8uzT1lYoc/NjFmLclTqGct5eAMuaFZ0y5 VbI0SaojlSow
5u5ZXxRTeX3NWzzh+8r3krlB6QCkUlzHvL2nIiW/FQQ8Y14pY7bfD5YmKWNe FRrzeb9zuLs0
9ZWK7J10d59jzMWOyG7FKU0hF0tAG7P/++jyur80SarjG1OeXkydRBKIbe53 th53JC4T0Yg6
b/tfiZfbr/akUirGzKpyCIEZhRd7OjFj+dITqD9q7j1rt970W2+XKL3pS6Xq h61MfYhWth4p
Yy5beoQxiTEhsEgCsd/5kZ/6WaLE7/xkdvbEmMSYEJifgP+t7/9OJBZbwuT/ UmaMj4NV5pfR
5j9Dln6MSQUhAIECAsSY2BMCEICALQGMaUuKjhcCEIAAxsSYEIAABGwJYExb UvSuEIAABDAm
xoQABCBgSwBj2pKid4UABCAwjzEv37RJEIAABJaVQMVPFwmmz/d3iikZBCAA gRIExG8YswQ/
skIAAi4RwJgutTZ1hQAEyhHAmOX4kRsCEHCJAMZ0qbWpKwQgUI4AxizHj9wQ gIBLBDCmS61N
XSEAgXIEMGY5fuSGAARcIoAxXWpt6goBCJQjgDHL8SM3BCDgEgGM6VJrU1cI QKAcAYxZjh+5
IQABlwhgTJdam7pCAALlCGDMcvzIDQEIuEQAY7rU2tQVAhAoRwBjluNHbghA wCUCGNOl1qau
EIBAOQIYsxw/ckMAAi4RwJgutTZ1hQAEyhHAmOX4kRsCEHCJAMZ0qbWpKwQg UI4AxizHj9wQ
gIBLBDCmS61NXSEAgXIEMGY5fuSGAARcIoAxXWpt6goBCJQjgDHL8SM3BCDg EgGM6VJrU1cI
QKAcAYxZjh+5IQABlwhgTJdam7pCAALlCGDMcvzIDQEIuEQAY7rU2tQVAhAo RwBjluNHbghA
wCUCGNOl1qauEIBAOQIYsxw/ckMAAi4RwJgutTZ1hQAEyhHAmOX4kRsCEHCJ AMZ0qbWpKwQg
UI4AxizHj9wQgIBLBDCmS61NXSEAgXIEMGY5fuSGAARcIoAxXWpt6goBCJQj gDHL8SM3BCDg
EgGM6VJrU1cIQKAcAYxZjh+5IQABlwhgTJdam7pCAALlCGDMcvzIDQEIuEQA Y7rU2tQVAhAo
RwBjluNHbghAwCUCGNOl1qauEIBAOQIYsxw/ckMAAi4RwJgutTZ1hQAEyhHA mOX4kRsCEHCJ
AMZ0qbWpKwQgUI4AxizHj9wQgIBLBDCmS61NXSEAgXIEMGY5fuSGAARcIoAx XWpt6goBCJQj
gDHL8SM3BCDgEgGM6VJrU1cIQKAcAYxZjh+5IQABlwhgTJdam7pCAALlCGDM cvzIDQEIuEQA
Y7rU2tQVAhAoRwBjluNHbghAwCUCGNOl1qauEIBAOQIYsxw/ckMAAi4RwJgu tTZ1hQAEyhHA
mOX4kRsCEHCJAMZ0qbWpKwQgUI4AxizHj9wQgIBLBDCmS61NXSEAgXIEMGY5 fuSGAARcIoAx
XWpt6goBCJQjgDHL8SM3BCDgEgGM6VJrU1cIQKAcAYxZjh+5IQABlwhgTJda m7pCAALlCGDM
cvzIDQEIuEQAY7rU2tQVAhAoRwBjluNHbghAwCUCGNOl1qauEIBAOQIYsxw/ ckMAAi4RwJgu
tTZ1hQAEyhHAmOX4kRsCEHCJAMZ0qbWpKwQgUI4AxizHj9wQgIBLBDCmS61N XSEAgXIEMGY5
fuSGAARcIoAxXWpt6goBCJQjgDHL8SM3BCDgEgGM6VJrU1cIQKAcAYxZjh+5 IQABlwhgTJda
m7pCAALlCGDMcvzIDQEIuEQAY7rU2tQVAhAoRwBjluNHbghAwCUCGNOl1qau EIBAOQIYsxw/
ckMAAi4RwJgutTZ1hQAEyhHAmOX4kRsCEHCJAMZ0qbWpKwQgUI4AxizHj9wQ gIBLBDCmS61N
IQABlwhgTJdam7pCAALlCGDMcvzIDQEIuERgIcaUjZIgAAEILCWB8cdxXlq/ 19p73j/9abi5
363Jf/JO/i1LC/LwEQQgAAE3CWDM3M7EzQOCWkMAAsSYaBECEIBABQSIMSuA SJ8MAQg4QgBj
YkwIQAACtgQwpi0pR7pQqgkBCHAdEy1CAAIQqIAAMWYFEOmTIQABRwhgTIwJ AQhAwJYAxrQl
5UgXSjUhAAGuY6JFCEAAAhUQIMasACJ9MgQg4AgBjIkxIQABCNgSwJi2pBzp QqkmBCDAdUy0
CAEIQKACAsSYFUCkT4YABBwhkGtM+YAEAQhAAAIJAhkzCssiEgQgAAEIZBKI zcEu/yBBAAIQ
gEABAf9XK+R/JAhAAAIQuJHA/wdvATf5mHZgcgAAAABJRU5ErkJggg==
Content-Type: application/x-zip-compressed;
name="servicelog_20080207_001.zip"
filename="servicelog_20080207_001.zip"
UEsDBBQAAAAIAIVbRzgXDAtd+IgAAATLCQAOAAAAc2VydmljZWxvZy5sb2fs nXtvG8d6h/9u
gX6HhQqcOEBEz/2ixAXmeqpA9jEsJWgLAgFFrmUmFKlDUrbVT9/fkiJlWTEd WpJVrwawLF53
dmfn0Xt/56cwOT2djH1vVqe39Xhe9ad1bz6cjI+Gp/WzHUaI2SVsl+gjqvYY xb8OF5wQ8j87
1cloctwb7Y9n8964X+8Pnu24kLOU3GWZqeA2ea+IMSKl5IOxgu9Up7OTZzuL MeqjaW88O5tM
5wfD2bwe19PqyWzS/6Oef79Tzeq39XQ4v3i2I3cqPJzhjJ7t0A7p0J3/+Ld/ /ZefZpPzab/G
yZ9Nxjjt/UHVXz3GaZzgV5iM59PJaFRPd/De+nNHF2e4rqOXRy/XX96p6vd1 /7y56jR+O5xO
xqeLw8S9bv/i5N1w3H0zOa27x+fD0aDbfLMrOgKnwhdPdi+f7GKuNLFMUS1Z t3cynvfn01F3
Nu1356sr7S4v8Ohg+WB95Z3+D9VoOK4rLdhONfxgRimmeqcaTfq9+WIKeie9 +ZvJoDc8fTe+
en15UfsvfxU71dl00q9ns+bLigh8eXZ+HK7m5nAxcHV0sFPN3+A+DJoPSq3V B7O0PFzqj4Zn
s/q35iJ3ni5nfTg/XwxYYdz6ZDK9eNFrlsmrurm6w9W7i1u0/PT69Kr3p6Px bO/9bPhs5818
frb39Om7d+8673hnMj15irmjT//r+cFh/0192ttdzcBOhc/vzfH1m2NUOPnZ ZDwcnxz2J4vL
f3GUXr1wB3hn8dFweYrPdg7+8ffLC3i6Pic8/enpR4sfr30JD9J+kgdKRNLE BRaYIDp5GpQI
IvhMiMhOXPJweN5vbtnr89HoAve0N6gH1XrNVKPeRT3dq1ZL52///t792DZC etfPp4uH47rf
jPe8N8abV4RQI64Twu4Uj6uBq8uRCydfgROpaEyGKqGUiJKZzGROWqdkggrZ beCkj/PojQdY
oCCmP5+AlPnZ/CycDhJeebycMC4LJ63jhDrKeSCWgJMcjQkpERIyhYalfCSf 06/GmN1BdTY8
q7/vtA2NKyVrcZUvcZFHB1ePb6halt9UteidMvJiMdvN4EXd+jp46GgJJdE2 6lYiyRPFQ2La
S+ehdfFt1K31wikaV9G4WohKtkHCJLE8K5Go9DrHqJ1RngplhSka19acFI2r jZwER5nKVEkq
RVTMBwknV+SC5Oy09UXjup3GdbeMFI3ra+PhmVOJqugjFUlmr42xnssQSQ5B 06JxfYkkKRpX
G1ERInnBMo1MCMKd9ykLQ7Q3jCTqi49re06KxtVKTgxNWtrsrBPOBRu0ziz5 zAQNgX/WxzV7
05uCmdP6FNfRLqXr8FXoHr1yLw5f/uPVUXd5oc/r06ODq8c3lC5Kbypd/E4x OVxO+PPFhBe9
6+tAoqOTNDHmhBIuwr1FXJKaSeJjZCRuo3et107Ru4re1UZUvOHKyUBgwSvl nbEySJaQp6Kk
SazoXVtzUvSuNnLChFM2E+uYhoHCgEnSLDNmvKQ52EtOXi7vXXWGRYLrubwx y6HrwQ/VfDio
nlUI4ZO28XHl7lqMOxri8M3oUL8unxwdXIkSQu0NvUvcLSaLQavmFXz1eDga zov69ZVYyYxA
7bJJUiGcj3juGQ2aQf1SiawCjeHAHR6+dEf/WZ3PIE5eT6YVjjFtsHk9HNXg YwoqgEvY65Ld
X/afu64fndc/9y669fImdc9G5yeYtS4ms3P5WqeRQZ2zUW+OA552fn97Oh92 pufjOa7kt2YZ
087bj1YxLvi3ZsRZFxz8Nuxx9uNthuwDyOUf6M7rKRbKu8n0D4zMOpR8PPab /uITnd970y2H
fHMBGTzrrKH+00t7U7+f3uOxR/d47P5kupyWLY/ffG99u3mHY9LJ5dElJ19w wvU/z4fjyXsc
uCFkccjVAQVTX3DAyexkuDjM9ueFc+gMj/HTP8cR1HreBNU4QutUrq1ECuO0 SJT2ShRkOirm
EnFNPD4Zn3ngFGqUDcRYdSlRDpaGyc+/PseaOJ72phcbZMfvU6xNLNL+qDeb DftdSIrOYDR6
RBD93nvbW/NjCj7txUfYxKGHUfwTlCoXCTLtpRCccuH00h/WXNpsMnoLgDDg 9OJsMsS4jVb2
84v938LCgvkZK+bX548VEUsKIt80ItLyT0uYhOgJJ8ggprD0pZFGI+0+S+Ta K6vCNi7jhRcs
FH9x8Re3kJOEREhigpMWFYvc2ZijdySkbKGB0+Iv3p6T4i9uIyfZSS+kYioa EZN01EcpFzYM
t9KtMiMdxMTqBlZn59OT+hMuY3xXtA2R63qXO1mrXStYmAtX0gTxqBvql7xT UtxJ0b4eiBbK
I2c6WILseiekEYpnIRC5JxmFXGxb7csV7atoX23kREipg0HqMGtK56Onlmkj JWRKjCSmon1t
zUnRvtrICWWOWM6lkAyRSGZJzIpx53LUQhm5dnj1BhfVfLKIO84vA46ztrNw 7fyuSQx9nYS7
ba0SEJkra/8rrH1hiabw8iLaLoz2LkKpIjDbPWdZkpUna7HkS5Ohm02GDFOl yVCLcNA8OeOC
8gh5oKjECU2ShWfXwnFl4yr28WJVibjOOxnOKuQRNBdXNXrTqFkny2fz6m// PJ/Mf+x2O93m
G919/9yFbq9/2sNnpqPJyfL9xeFalWL/RXWNRD1UJwkujChM3QNTRElHiNeB CwGODEWvFR91
FJYKo8jH6lUP5sjZvBrX7/HfFWhT5NbUs/mjJ4SiY01BpGWIoCwLQiZK1MKL aLhB2W+GL1hF
GYxYl6Bcs0tPIHV2q9mHxntvsLDd15/ajxXWxiIqv15ly9fEI/d3cWaKHd86 ikxTw9XETWgW
KWSj0ZMl4iBZpZzZupDrw6LGv66/9frH569f19Pls0YytUtb+5KCSM7kAxZE MhTpFY7ugSPp
MideIMaihQzWkICcfJMyJlxqle/eCCoW0DUL6KE6u3C0TyhA3QNQlDMqPNfW eKFTNvCxZQT5
Fz9K6GIBbUVIYwEVRL5BRBTZUFmsHEdfb2+DFRRCxyrDdOODS06zS0RWztA/ kzfzahHWH5+f
HuOdyevGyiGqxax8zjMNN/5DeKYRay4ugvsAhKjgDVqCqabdvaaeYzcIrnlm PHp0c1nLkH49
fHsVwV8Y/+fjad2fnIyH/4s3hmMoXK97/XqvGg4Hz25UJtbNuaIy+e1wUE9/ qPqng2ejy7Xl
FnKpHlyDirSKqsuc/o3JZYxxU3L7Wwua86hFtgrZmCh5yclSyB8TrGqUDM/I ShI1EdFG8qyK
+K+W897nazM/XQ/c63dWdcUbCpD768EWVWnNIS7P4+o0mrLZtom/P81OuOHc I/Yjt8TduscX
gxbH3ldE0iAtB2XLEbtYiCgYWvcLr5TkhhKZZIkgfSozuslsPWx05Ss4EIJ7 +MRoUXTEL+eE
yU9zYrHpVWKJI9JKkLDAYFNRynO0lOK9lej6JYR0eJh/OTj472UyWz34EzFW PTmDfiigz7cu
v+eviRGYMkWMtAkPCRkjXG42RhIU1ZtCBWGMFrTZ0YKtdhDDSNOL+RtcygcO hkdBwNXzK1uH
0JLm+Y0sfU3NpwsxjcRuktYL1JlZZS1XCptJ0sgTjTGQj7wHT4Stji/m9axd PV+/xNlsRPE1
tw0GRxj16Dfm0fCVSVTFeE0l4djpKAcaVvHNX3uj4aDX6EanuHv4g9l4lS/B aF3a/7ZYaFmi
lG3DIjN4NgPJAmloXInGdsjOYboNrAdtbpOERv8sCY2VJLSHS0IrFN0TRToa x0xEhSUT3BlP
YJGgCNN4j8ICpT5Mnln8cTup5/vj4fzV0jkVe/Oex83+Yw+XND+fLoKbH9zJ /bjX4PTo1TKq
eJE/LSMHb3l0TM6RQv5guwoWrcW2LugBq31e73/0yy8NA33eE/aY2N1jxvq7 gvbYruFssFvb
uob8YvI1M48eEsF0gaRlkKTU7MCqsEYCuiVzQGORoxlCTNqgivNj8bJXHTZj UrU0W6pmoq+k
yVI3e+yYMPZge+kVTO4JE449vJEjEyVcuwROL9TUiEijCK5JMUslYrgVISXj 8ltFhIsNe1QI
g2A6dgdLcARjU7BG3aLYszigDz+jH7uErWDFJ7zyCZcKzLbRIG0kiUsVUoDz K1lAkH0KMiaB
Fnxsk08YZBSn8NIpXIr3v0kuNtkb1uSYZdSwMyxPHl7izHniOuts4rIz5eXK /W5WPbmRhfj9
h/bGcNCE1Hfvwui4HGgbWjasjntHaeEVni1/Nbem2/y3mLX907NRp392tir/ Yh/nZ90CoSZ5
Z4nQhom7npml1R2Qst3CvnOw7pEUST4dVUSbY+GZR8djtMmXiDJay7JGQNFB gsRicmwlS0qb
i+3W/JbMPQwihqEHpZdwXKFAn0SYG9TalKhGHQtcvsXkKCbHI6KBRAndCovD ccFidvDgykSd
N1JlIFJMjr/ARTE5vlEuNpjijhGmmw3qTRYhZmMIhUKF1t5NKTBLH5ocT6Ad f79X+QYFLIPm
nWpUv543CtZxvbq19WCvIktebi1I2mp3GCqK3XFLuu4Rlw1ihFnVRLyZahrh C2Opc/DmJkgW
DuPDFbtjK4FS7I7t1vyWzD0MIgK3oSnkFSwIaFuAA4nwIqEnC9IbFb9hd0hR 7I5id7SVBuND
1pAPjGiRWTCce8/g3MWeECZmstHukKLYHcXu+Ia52JR/mEQwzmaj8FcvE0N1 ZlpKbylHhcgq
BLhWoHHmJ82ymC6e7VWLX5siIPWg0b9cqG4LT1ttEK7ZA9og2KCd3AE62630 OyftHtHZIFIo
Ngxm2DEY/b2hY2U0S0HWDlKwMkMKPC2xj+2ES7FBtlvzWzL3MIgo41BFxaNF JmLmEqUg2AaV
U884QutS3bBBWLFBig3SWhq8sZG7YIxBzNw6m6iXIRIKL6/Qwm20QVixQYoN 0lIuSCDw4XLb
pOYKbxxKPLz0HA4rHjSXH0sJynWREqVRQ1tp0EShVYPKjsBfi8onCwdV4E0R h3OGq01SAmQU
KVE6NbSTC6YbCNAMMQnkUWFzOuTl+mZXLcVhYKwamBxNLzD55035X7Mfw8oN heuYnY/mTRou
WjvcFo+2+qKkocUXdUuWHggOdD4kER1DKXpdGiQY6oRyDuuygu0tVkmGaLvg zs5Gw+V9c6Mh
Rp9hinEnBrdl4v+byPhL7Q6p4fRB2h0WKXFPIBjDrLYMyhMC4EpZQUJK0TM0 uG56xhen7FZ6
VHHKthARTuCAzS5EpVDmpxD5gxaFFcME+vZ4slFWzOrxAFfXqFO4LbPH2Wud GmGL1GgVEhl5
t8wSmtB7h2ZjE7bZI5xLbDiC9y6RaBb/80tr+8mVtPi+ESTonTu7XvXXpOkW D1VT7FJM8Zbh
Qiw2rqI0gBGBTm9on8BNMjRBW+CJmU/042FoLl468pSOPI8IFItm61F5waDL ZqVdjkHkoHhT
+6dT2cNjO0JKR54WIsKTzF6xhAookZuOoUliK3ik6HKngyQ3UkRoCf6VFJHW 0oCc26CY044S
EW20IScnSGIioEY2bAz+WVqCfyVFpKVcBMMkguIIbkCVwpaEAuKBa6jMmUdO 3c3y2NUthOAY
PJ+dzJ7cXl60NeqnDXnAqF+pgv0MFWrD1mfE6JBRxRyQhI56ceSMGAGTXCIJ XfJQzIut5EYJ
dmy35rdk7mEQUUInic5Uptli3WbYFDSnmBAjNybJdMO84GUTqGJetJYG6pSO KWDhW6G0Qfc2
lP8xqS1HcyprN5oXvOwCVcyLlnIhHZpSOd6kSomgoqPBiGaHAaGiIZdVsKu4 7Hc31NnvqjdI
NRzhEpvZq/qnt06maqupYXRpuHNboB6GkGRIQjlfDhl7CzBsVIPGO94TFqJH Sm4xNbaTIcXU
2G7Nb8ncwyACHYo2zW+RdCtSRBBDBYmCDQ4fVcjiRhkTE6x0+iy2RmtxsKBB OlQvIadKEWy1
QUSAbiWN8vDZhk22BtAorT6LsfF/7J1tbxw3koA/778YYJFgF7jzksUiWZVg A1SxSNt3fjtJ
yW2ABQQllnd1cGKvIuf2/v1xJI0seayx27J34hZhyKPpeSG7yUfVD9nNmikY ZsAxGKB4FEta
EjbvKXU6goP0Ttl4eXDcV/dcqcbiy+cnX5f+2LvXn7/8x6sXJ1/7s4fF036q tdrkVht/PPnn
amM4e/hm+Q0H69f6Hh09PX9jb407h2ctf+fk5cnLOweXLou9/CVnnzz9ff3i 4W9OU9/+7ndX
Xj27EuzZ0d9eHZ8+Oy/x6eGzg36/1tmTcygPfnh+eP7y/xz8enCnbz179hqH s+df7H6/u79X
Hz7Zt/s7X5y/52XnZPX6f8h3sv9E9u6dv7iq2WnVvjs4PloWtehUrsorD2R3 d/mB1Ze9+OXo
UoH94PVLQ89f+/Xg+avDVUkXH9x/vHN3v5YH95/s1v36X9/ef/T4L/vl8cOH jx+dV+JP76zF
9RV4eXx4XQ12ZLfufFd39u89fli/+OsPRz9fLa6X1p9cao+z7R+jlZ4cHj/r 3Jz25LWW2lC7
VXNd/6a/Xv7qVUdYteO/rBnvfS9Wd/f7X5K79x/d7a25U1dt+S+uyfLP8f6T B7LXHu88vKhQ
/a4+2tvdUpXOD079Sy3f7t1//GhL1bhyZHoTPXhQy7I6+21HHtb/frzzn1cr do7DTc87ZjuA
M+aKb3yS8gnPOshvTEOBBKVi6sc9UTGmqmbqIYAfl6JOOy8fAzjT+vxE5raD iDdCR4TaBNlI
Q/bVUQXWRDHHtbni5Mb4zRi/mSsNzYFUysUCYEqZSwP0IugJWyXbOFec3Bi+ GcM3nzEXG4Zv
cmvRW/+BiOIrgZQEPpiL1Xnx51w8KauWW5bep4cvrkjte7cct/nqzRGXm9Py eUrHckBpreZv
33pJRDzlPEzkhrx9QoA2BBas0EFR8pwwxqZFMIoxa0OAPExkWogZJjKtz09k bjuIuCC+mjRW
wOSiYPItSzWQaFx0PWdkGCYyTGSuNJRYg3E1dIRBTWKhGIyYE3q2zVetYhgm MkxknlywsGlp
aNEwQH+WUwQyotiaqY6ckRN4ev8ZkJEz8sZ0bQeXDMFncNmqITBKKJkANJFv KVQe3jEpoAzv
mNbnJzK3HUQoULZcctaMIVWuZhYccXZqJdh6vpY4vGN4x1xpcEpFYwAjj6FV ipZj48QhphZ8
3JyvJQ7vGN4xTy6YzRXGnGNAbqCZFVVDSi2mzHmsxH9zyxgr8d+cpe3AgTEr 5GqNGKWIJhOu
mmMqNWiIwzImhY9hGdP6/ETmtoOIE44RYuaakBxr8i7n6ltONYqktRvl3FiT Y+T7mi0NAfqh
BXVZGUNlIvXQEYHomTNvvk/OjTU5Rr6vmXJBGKhQCRYcYgkKyVyuJk4j68XC sFfy0f9hsXZa
+28L7/zij7c6yRFwHukq5oRGg1IklqipoVWQVkpjo5yi+dJspKv44EAy0lXM EBdfKTknEDhj
AhUMxhqcs8ZUEl6TrsLDyFYxslXcJk6AkqnPgM7Q0HNC8UETNYcuso2hq0mE jGwVM0QkSrDk
wBVpSLWqFc6xllSSEYhfz1ZBY+hqTJDPlQarKaLL7EnQMHNrkdVBq+ool7I5 WwWNoasxQT5P
LryrxQcOxoIBmvhUokIyLlkC48hWcYOZ8ZGt4uYQbYeKiugrVckk2AKoAyWh Zr5zATCuv50W
N8bM+LQ+P5G57SBiUKz/B2qArSCTCkBq6lNGsLB+399YgWToxWxpyMlxACnZ A2JpEpEigo+h
Bp/zZr3AsQLJ0IuZckFVYs6YJXtkZmmOJFbyWhHM6TsXkB3ZKt5PNUa2ipsD 9QkJ4XQtIS4R
ZrLslFGdUqNQSkZsMQEO1ZgYQ4ZqTOvzE5nbDiLsAVxtOaLHQokSFN+kcGJo QdcS43nvxxoj
wzVmiwM0rgYsLgBCQvWgSF5CjrlYqJtco6MxFhkZsjFTMJA7GCYFXEJLRCgs aq0mn3IO/E7Z
+GjZKvhyoollcTvnl/4ePv2AVBV/euMrzjb2mn1zU4hna0Nj4uXGxG8HYcje JEZthRFzVKnR
NSrsWzGDOmxoUpAbNjStz09kbjuIENTQWpGiFROZUGzeYzXhnJ3I+tLvY+GT IUPzpaFIcpZb
zIDgSCEausLEFc2/Y8HFNBY+GS40Uy6yImsk5gTIXMi0ZRVCDDVi0uuXfr84 pz6bezl8eroC
/BUFufnNiZ+neHzo8u9pLP9+U+a2BBGiF1ed9d9cLeIaeYqsJaEp6LCRSWFm 2Mi0Pj+RuS0h
0nLSlAhc7axkiq6KDz6SkAswbGTYyG2iwbMUQJRsHp32f9I8FY7Yfw+Aw0be g4thI/PjIqFn
tepqp8M5E3W+aQtgpo1lxcVr9biyVMpXi6sbF/97dPL3hZTThnp+uOToD2un wH+8KUafp6K8
e24kcNqijYzlGj8cIg/cKPjUYkCfMiOUolqES3Gx+mEjk8LMsJFpfX4ic9tB pLATL4mEGVOI
QsoiFCAZpgp5JKMaNnKLaODiNVMjKIjZo5QQuKEzcghQbCSjeg8uho3Mj4uk YIyYxDWsidVp
DaH55hxkDX4ko5rA03t7x0hGdXO6toOLQma2QlUMARs35BqSy9bU5+EdEwPK 8I5pfX4ic1tC
JHMMScWAMLug5EtOYpJby83jmndkP7xjeMfnTAN52OAdWtE0a06YfJZgFkIy UgpZ48YbVDoZ
wzuGd3y+XGyKElJD4ZSdUkTvm1qDhGylWmu8mitfP4/ti/yeHByf9H3rjXS4 6BU6OnlxfP62
03r9ct56d+7cOJ58nvrxYVdmQcxjLuSm5H06lDaGmKbYiplBw5KCSOeIfdKE JBLGXfPTgs1w
kml9fiJznxARoGsRacmDZTLoUATvFSJqY6SG5lqNa04Sx1zIcJLZ0pCDS+Ij +o5AdMZZSq2x
OXQNgP1GJ4ljLmQ4yUy5iNHMSuEWAjYSjSDMrBhNA7d4cZ/I+d0gV6zjq8Xv l3wcv/p5uZOn
bfvL4s8Ld1NO5uQga1v2f3p65eaQsE0D4QgfAZxp/fyjc7YdcKpQRAeVSDG3 1KkpEsyZNYOa
wjCQSaFlGMi0Pj+Rue0g4tSc9B/LjE2xE9J5KdJ8LUhuNStSLvJV9aVP+son i3/vDffjsiWf
vXr+/P8WB0+fLm9CvHjXaVIrWDx7cby46GWn2xx++ft/ytdzQ+nNxImvj9eb 2RMD0FWGPm4K
n9cFvy2DYoQMg6JPQFEJyRqUUqshq+cScwoVpErK6WJJlN1lQauVhJcBpx/5 vmluMLyOK6fl
nu7jsvQeXHaknD3fffVy+Y7XWMT1PIn4cck4LXex3NI/+sPR8368e5AZeHws PDBcL/aE6oFj
TIi5sFbvHYuhQGrZ55sEmTCCzAgyt4Mir7l69SFnRm7CaizEifvvtdY0gswI MnPHg8FfjwcV
rK6ASwFdzdxyqyCpFZcaado0eow498HjNUhK2Xuwe3j86+UcvBy3jwf6gccn wSMwa4cjO0WU
lIX7fkYTQW5VgK9e2NJ35TIfzw9//tvJ3zsmH+n6+c+bk+B+A2FkcPKJODFn JWr0URs6iZKq
qDoQjlKC4DonO7L/UB7J3brf7j+otxsNn0YImS8aVS1LY0eFEChILuYTMRXJ LeGb6eQWT77d
O0Vi8ePZunWLZ8cvfnqLjng3b066j/z09N5yarbv5AUqlPNAZbaoYAkQkosM CSNnrVVrK9m1
AEACV1ydhqv/Rl194PHBeMAdnzemYgyhaWvFY38U4QjaUgpWrAAOVy/D1W8x HqI5ZpccCaIR
C1fIFsB7Ys85DVd/b06Gq8+Zk4QFqw+czSNA4BpKU84eTHKENFx9uPptRSP7 JhgLEDFyh0JV
HaVGVIlSteHqw9UHKqsR3xqCCwT5dL0hAe241NK0uFS8G64+XH3ueIAL1+JR kouVyFxUDNET
N9ZElVuqGTxscnUarj5cfeZ4hOKjtsRSG4r3HNhxBGPr2wrk93F1Gq4+XH32 nEg1DOo9RmyY
9XSgtwEZO7H4dle/W/f2n+w8flJ39r7ff3B/d+92A+LTAGS+gHByMedoMRiW VsRzUaeYVKVE
h5c1xLvhIcNDZshH2qDpZKdXnrgggp0ijTUSBujM+ObKio929Pywo3DcAVj0 Dx8vjeT56Z2s
y5jSj/ZydxbLUuJtGtd61g/Lm9HktzCoBYzjvt4PoyXc8RCvpQVcKAClhlYQ lJSJYoZiJaAv
sQ5rL8PabzEenQ3sjFjwjImBOEBxwJwtmFAc1v7enAxrnzMn0WVHNRNZw+SF MLUYKmj2Dj3D
W639gXz7qNxbinupu7u3mw7vfwMnWYOO/2fv7HobyY0F+lf0lA8g2VSRxWLV BBmARbKAPGQR
5N7HC1w4Y8/Gicd2xt58/Pu0ZGnWsGZs98qJMm0ahqVuyVK3WEfUKarIfxMd 1Im7JMRk1Awt
Tr+ZPWTlorrLaX13dnu3Tslqb6Kn1c+nl/ri4vDF2v/bKHlYq745vodl6lkf dB0vO5nQ5jl3
FeqDh/8ED9oTZqPcO8lGz5U6gVEm577j4f355WmZpg/4290aNLZ5VacGvvrL dHbr6Rz2OXmV
eMQQ4uBjSXwkJ4oY1SlRasGyaK6OIEVFwuN8rJvj5OOakNurAck9SCIMSJYE SYaIoTCECBQa
igmE0msFqDmCPwrJh5Pbd38aZOzIoEHGkshIvRnFZBiUuIhJAkIlNk/BGLZk 3Jxdnv5um636
2Q/TmP586jemRjq/uTeD1ur8dL144phNHlH3s1gvO2nWD1ObDjv/z+ASMVgU weaNyIqQEbqE
UCnX8umbWd/uguLN6m5sPfF2bH16pe+hsplZDl87KCGEwcnCONEUJWIrWRuB S2nUqTeNEXIi
3V+EBGUsQjIWIVkqDTU2tqaJY6KQTGOhwG6GHVuD8OgiJChLHzl/HhdjEZLl ceHuXRNhwkZE
tSi4Acfaaw6QcMjHj6ZlyMcCcUkhmHQ0rkYurtA6aEPw5D1J/5J8cB7yMeTj FXHCEruXBjVG
SslVlalqialhkyYbTraRu+kt3uyacPKR09/dfHfzs8M7kK9zLavNxboZ/m/9 p6y3fvvh+uLe
wlVZ4IgLVyXK/AJUzAviF4foOFSErM1bTjk3KjUbeElmEaAJlkBj4apZ/cZY uGpezM9k7jiI
mDA5ZwpVSTqZO2mqJJiygNBe1opgZK1G1mqpNLBGJKxErtQQjAt4pNx71kQq j2atCEbWamSt
lslFDFi1eIXWqZJLDhqK5GrQLVQbWasfTcvIWi0QlyyCZrVQyyQWinZI1Tgh NFeVL2StIqSR
tRpZq1fESapdu4nWxiSKpUKuNZSi3Ithvp+1Wv10L0vy07uF2qdTXL96q3cf Di7/WGoGSzKN
DNaBQB2HEChkWluSGkigW9bcFNdOwgHYRgZrVh8yMljzYn4mc0dCRLl3WTct EoOVVDxCyd4a
U3V4mMFCzDhSWCOFtVQcCqUIzBxyJVLX1FPv3lusGnN/NIW1RmPksEYOa5lg GFcPPSA4k6de
aoQYaPrTQzKWJ2VjKhu8OTvdqcbqJxe3v67T5RRev/nJX7+/uv013l2sTqeP WrtdsNv57vYf
u52/3O57u36Iy6vb8/f//MPZ+7OPZ9ORrs7PT7d3m9rim7O7dv/m9vr2+pvN od371+m2NVDt
LUJcb//q04711vuLk+9u3uLmhrvrm6sPnu9u53Qebw9FfrHuNEb/D35/OA7w 0VrsNVLKmXov
quRFc5Uekhftw51mdYnDnebF/EzmjoNISxnJqlBqFGq1SDVzReomkNJ+zQqn oU5DnZZKA4YA
STSpF4oRLQBFc3MQjoH90dF/TsOchjktkws31y5qFhNJyRJCw+wCZgjSPs3y WHctV+8Wv3qz
+vSZ+m6kZmq2yZzePFCQQ4n5OsVjbXR7R/75vfdkBIXzsJEDmTsORNFJCtXs DYmrq1gpjRCq
RkfAYSOzuplhI/NifiZzx0GEkVu2VEAzUQvFM2korszagoc9G6E4bGTYyFdN A8EXaQBpVklA
qREDFuqRRCIQUsr+xHeR47CRYSNfMReP9BJUE2Nkto4Ug2s0M1FAZICknyt1 tDUKUxisb5mm
nX9/u/6A9cezXdOeTaYCLzQJ/dcpI88YBcHxDbJD6fo34vJIN5IdzGNrwJ3M QVsqIXZAQ4Rq
PrxjVocyvGNezM9k7kiIYGgxEdP6111dSErxiFQoaRgzdw3veEU0JGYXaNmM yKoJZG+CnY21
cvcxc9czuBjesTwuSpUmrYHHTA3ISlUXNLJuObU+plg5QC/GFCuHQ3QcKrB1 KzF2xUKQoBgQ
R441JGzJZOjFrH5j6MW8mJ/J3HEQCZy8MyKtHQOKEVb1Ilk8YIo4plgZevGK aKBcYsCKzQNV
syIaNOXemrcgzccUK8/gYujF8riwZCahMORIyiph3SxEGiRQsvhkecqohX+e aoxa+MOBOhIh
NVoNDD1Fiq0ZIgalSnGjIKOeY14fMlRjXszPZO44iPTkUolYFIiwFvTKBZHJ JMYsn6mFH64x
XGOxOMRApTBkio2qopQWOWjp2kA9tidq4YdsDNlYKBi1tZZzqoBKGFJhFvFa DCQp89MTb71Y
LTzC+udeUft0kue3Vx+3z/k/tye3j9bEXz88tnsPtYu69pYC0KbQ/Yddm839 JxsF8U8L1Bir
OfhN4jjUd7NsGbMlolC9xFAKmxpjYuQ2BGpWvzgEal7Mz2TuOIho5NYoJm9C tZH0BoipCLbc
Cul+QXwY/jT8aak09J6aIhcRJmkkTBQZSIGYqabHC+LD0KehT8vkwsxDjZhi cYoxGBUz8xTI
cvdcv1gQv9uezm5TCb/vH6MaflY1fB7V8IcCdySCijg0iqkbsYqlTmCla9Da ewpDRWb1MUNF
5sX8TOaOhAgUzGKYqhFj1WoVpQqFwsql76kIjbm5hooslgYsmIQROCtlcW0l TJdQ2ZL29MTX
xsbcXENFFspFrdhqjdCxEJtJB8AszijNPcQfVw0fIY16+FEPv0zzCBLAJVIX Io/iuRghS8OO
qKMefl6XMsxjXszPZO44iICmhrmEnir1XITJsUmNBMWgtz3zyDTMY5jHUmnQ WBtophwqUSvW
cgZpnp2EDB83j0zDPIZ5LJMLz6K9aUYy8hiVqwOTCWoldfs0CLKd+3f7gXbz zDdvVt9drT9U
/X11MYXKGpWP31+uz3fTzDe/WF1+/+H362ur36wOXvn063SQzw+J7O35/w+n 97QkYDqilpCm
8AI0zQv+F4fvODS1DJCLZKxEpfVS3RA1WW8VtfPQkln9zdCSeTE/k7njIAJI QVJWqERdi1GP
MaIWVaEKNOroh5a8IhpyDSFIzhGYQkQRTxQ8V4qiUcOoo38GF0NLlsdF6SER etSeyMSUNDm3
kKZtJPcnS1tGHf0zR0BGHf3BQB2HkJa5YYZE4GQFLAJhCkmoWMBYhmrM6kOG asyL+ZnMHQeR
GNRz66JYCbkodceGknLNwXVvBATjGAIZrrFcHBirCBdjYXKLptkMEDsjepT0 mGtgHGMgQzaW
CkbpEWJurhyIE2glgug9ZEvMXJ+Ujafr6CE+v5I+3Ct+nw7y4+32GX9sAf3F yfeX7/7028v3
V5vNcn19cX4XlFu2Tv54cbZ94D+f/O3km2nv3dan6N3eun3QzQn+/uTjFFS3 Zx9X11dTc/1w
p5Pr67PL091df7l9g9jU43/6n7uH+NW9Q7kr2H9wqO+uLm+uLs6ms7o8e7de ET8BwOaOe7ds
9t5/tcYMAE+q35gB4OC3t+O8X4GUiKlJTUrEubhWNIIsvWUBGuo3q0cf6jcv 5mcydxxERAK1
aJSQKaMU6Kmn1iLV4D3z3ihTGmU3w/wWS0NrjNTIAxmx9cLqqIwdrFl0fnSU KY2ymyF+C+VC
CWMK2ZAj9ejinpULcO+xZOdnzwBwTzwO5uTr1I1R+v/cSH9x0o6DDlvMVYwo MjGKWe+eQgns
UgvV4SCzOpfhIPNifiZzx0GkCbBW6ZEqUctqPZbeyUgxYIc9B8ljQcrhIIul oZp6azV7YfIC
0mNHqrW1litVedRB8liQcjjIQrlozdgbVM1ObLkQFjLqkLlbqvHLDvLt1e35 +/Opte7bx9nN
ts0mbjaVOee3Zx9WU2usK3QOxec1qUkIAYeaHAjgcYhKPRXX4FSAOoNSVWrc YmBPzqMIZ16f
M9RkXszPZO44iFCtFcBZa6YaegGQJrWSmIpHH2oy1OQV0eDZSqsa0JCsZzXt 1VV6DxaotqEm
z+BiqMnyuJDmJQbqrkguXVQNsdaeQyv6aX2ZB/rxv+t2mfRk13msLjeectfc WyvZNfX649fd
d74Oxec1qQlSOGbRDgPTCxA1D4AXB/A4RCXP1MBN1Yh7LKgpN0CgFluK45tb 8/qcoSbzYn4m
c8dBRKhYtOCpGnkCFUHyUCMU88CfWWc/DjUZarJUGtREsCjGyES1WTLA6aeL qmmKj6oJxaEm
/2LvjHqkSHIE/FfqaXf2AS7ssB02q1sp7IjQjTQzezqY5xPQzSw6Fu6gudv9 95vV3QU99EwP
SR1bIglQq9RVUNWZGV87vnCkPdVkm1ykVs07VkKgrK5oqI3MvEsLt08rmJxm ueRZLvnL9Q6W
X8WlVhVr0HwkchetuSK3gcPdKfv0jlUBZXrHujG/krnTINJqH8VQiJjEq2Gg sDUc1TVymSmR
6R1fEQ3UTQOD3RqVVo1KHclAS2mZnGZK5CO4mN7xhXJxh3dgyl5LHkkGYbjX WoaMcA8Vy/Z+
t9bNrMg+GXLx+vn5/y7Hdrik13mPZXw8e7V79vrVX3/2P76bu7VWpkT4lCWT Z0rk0yONcYEq
JhiFrA9LwTkqNsuNzXiqyaqYM9Vk3ZhfydxpEAksrZXi1Imis4OBVtWaKVlK eEtNcN7MPtVk
szRUJpBuOYlS6mKaPRt5D65Ja3xIg8CE4ddhwH8SDIppwvAZYDDPqN5gaNBo UREJLbt3tlSj
3+npOCs7TE/fKBfco6uwcieqihqpUQlO7im7pLu4EJhYXGMxw8XGsOg5EA3V oFKqxc1TKRLQ
a8/cyzUW9exsOYzLjbqtPqq7V6938ecfHv75u757uhTWf3n+4qufSwGXCcfG 4PAqUDsUtU5Y
3HtQpNGIojHQuIbj0eu/Lyf/7fJpsHv8chnUVzVIl+N48/bFxe7eDhTpWDy+ zLXb395BwnrK
m2rnMu2nw1FNuFbBbEEBzSNDdS7urWQdh8jxw+EX5u6n84tvXz6/+I+rddn2 +OKxL5fzvx4s
5+ji7evLJpFxSc7lRfi2PdhxSjDjiuQZVz6ehZUsngYdwxxNoGZESkSuxGGq LQ9kiVkqayUh
M8OxPUSkggyOsGbEFT1YGkYZqFLqoGtE4qrq++7HH/fx4ilwemKZ7nGSco+e It+zM8n37Nlj
fprOn7Cey1dPC+mU+K3BopFHHjgaCI2KnhPUipaxKlLja1gOxr48/tDj0YPz N/tGD8/f/OX8
7NLsn76bfS0jnlM6ukH3F4+KTaXfGipI7pDNnAs1ZkuV0nBz6WTU04fW8mD3 cP+ZIFcrwLv9
ib4pKTuYmCDixGRjmLRuafTShYnYhlX3HF6XLzGI2xtMYO59nxtMNkvDKMg5 C+JIxCzWOQU1
6Q7YWi135tRh7n2fOfWNcpEi1THAigQNrjUzU82ljVpGtDbXsVYRAsnmdqyt IWKh3StbVKRi
tQ4pXk1K66XXgjcrZu2uexge6vV+856RP9y//9XjkbOeig5QnXB8BjiGd1Vu kjTIBLUkCEws
KRwSwu2aDYcruIjH2fdvfnrzzfG+sdXEepnNPI+G6DRUeMksiphrJ4fhxiVl Vs6gWHr8PPXx
YPd/j59f7JPnz1693i368fhw7+DZq7dzTpVpBo2PH+8reTsNHiMxVAqEoQSG rimwGjAwB/GY
0rEKkJk83yAivbsXUyFlooLaoas2qFWYdLybVz1ZIsQekf31uMHG/d2/PX55 9uL8G7F0/Pzq
Swckk80Isi08MgoMa6gVSVJ465YklVEHOKNMJ/94OE7o5CXjpOMz0AFVAboW laBUxVVUhBow
ey6RbzdKx5n6m6m/rdLQKXUgGwMSieeqysuXNCbu4enuRuk4U38z9bdNLoQx wlqOlMgKmdUO
LYUVZ+Muc5FqBR+nXKSas6jPwwep5mKjAFeCEia1OUEDRREH/GgF16dzXnVK BZ98fB4+FBLj
KBFRKHfTDJmResvUIqHfTP3tfn8r1fT73V/2fFxGlBePf9o9/evZLv0tJUz7 P8fystWUoLLO
lOCRcJ2GlkKNQlLmIaRkDmmkVLJBziiiM+exKp7MnMe6Mb+SudMgQskHNRjs mXoStWqB0roY
VFS+Xa09zWWruWy1VRrCUiTIzdlJvHipnMoYzFUkeb+7Wnuay1Zz2WqjXJRI vTeUDMRGWpAj
OIRjAKJec3E9j929H7w3utcuZX2Wq/Lm/FAB6z+v76ddHr//9+/6o34sN1+m fnximXadSnIs
eKchyRrSqGqZiVLOmpsDt26VlbrCVJJVsWYqyboxv5K50yCCbo55OBFQDbas 5iIg+RKe2zfR
kkwlmUqyVRoKQ89qvRYjRLFunIcA6IhSm9+pJCRTSaaSbJMLstKLY5SBVHsz IkDi7ABUEtFB
SeLB7iAa1+JxmDztHv4Y0R8+HD9+dywfX5N64EmzIbPy6KcT05DFE+DAQr0m Z4CajXoDVG95
qseqmDLVY92YX8ncaRDJPKBjZkqZtGWHYgNGqYnCR4bb6pGnekz12CoN4Lly ksv7n7iRNo6K
ENm6YlO+Wz3yVI+pHtvk4jIaQGu1CBEPjeFUupTS3WsZv1B/wfcoLMNg/8ru xfmzy82LT84P
l/b87MEuXfFydCD5Ml3kI3ZhAZ3QO2bK49NxAeeuGAm4k/dmYrWwJw+MUTNO 71gVUKZ3rBvz
K5k7DSKKzWMMExCK8Foaduk1heSwpLe8o8y6odM7NktDHzKUsNcaNBhcQBq4 spbuqvlO7yiz
buj0jq1y0WoWVKylE/ZSSxWrATUX5h7+LuWxO3sV+w86v57SXlZjv+xE+OT5 y7P33aLe7PY/
33JHyOX9hXEo2fBqV+NYfL5MC/m0jAgg2wnVZKZEPp0oE6Qmma0ypWZeGYJC h8hAGzbVZFXM
mWqybsyvZO40iIym3FKEDSZrUqNE9J6KQPRSbqdEkKeaTDXZKg1aenUfBaUT p2K5Dk7GDKMV
Tv4hDQgwaTjQMKu0b42GjtAMrIl0ahmcsI6cBwzqaBp3iToCTFG/EvXZWHBr XDBk75mxYiY2
qeiVlSxUycTurn6FPLmYC1jb5AJLYWO0bEpkVEuBHDmVVrECfDh7ulyt2jc8 f79idVDtrcFx
uf50Y8np/RF///jl8uJ7LLh80Nf8/zdW3DjV1588A8Y/AYxSUbUruRrlApU1 5TZqJMKMUQ6l
dc8vvn25nP3lWPZYjLcvn94srHuzE237hlOCP+z+eynGu/xWvfp+lqXeASLP 6dbG6BmItXXP
kCrpYGdRazmy9GIZ7R09L8++v55o3cRmWdhdLtLzNzfw2T0/+wYSTFwA7GQ1 5CYunwkXURAv
1rsCNRwmKMmLo5OnWsav9XLOeTZzns2cvyJOqubMbj6okbTQRJoi9VK6UzO9 5uTR678vJ//t
npDdkko/oLGvd/L2xcXu3g6U6Fg8vsx0+m9v6mWFmTk/kqXTwMERLeUSbRBJ sBaMpFVcNVWY
m3pXho/Zw3bdmF/J3GkQSVKykcFwoY7d2YYUijaEFZUmIscj8unBYh0ic0H4 8yBi6iTdOlKj
lLpJS9i1MLReiG7ve4e5731uLtksDZXA0LEiGaUBPrBViw4pdYp09753mPve Z9pws1wogZn2
QUStuuGQLo4lELim2e/8CAOf/c6Ph+g0VIymBNR6BFLuUAHZmnVCA8xllvNZ FzemXqwb8yuZ
Ow0iSWrxUOjdCEtzwNaso1RpRHFbL2g2N5h6sVkaaglihDHcKdekVBtapAiT AoB36gXN5gZT
L7bKhWFQFzURQueKSQoIeR4Ag/Tje6otZ2/fUu1YRraqGlpmBZ9jgfqMhBT4 VUJ6EWBRK0lJ
kpm7BCtYCqwWaarGqhgyVWPdmF/J3GkQYbakvWobmaiIN2hIrQ2tY0S6dZss ANJ0jekaW8VB
uJr3QSkHOaJlEkml9jGStkR3ucYejSkbUza+YDDukI3ATpZGb2mQlGo6Kg1u QVbd4LcbOC83
dCzlQg+qsfvdi4s/xvK4DK9//d3/vH118Ue4etidLVOtw1Pp8OTTi78dniS6 evzT/i3OfnaX
1Rtf9jOe7Z4/P7v+t8sFuX9+dfHv76vh3L+c7F/fIHTjbf7ll97n6pXlh/zT sTxvVoxmDuZo
+D8jzXfN+jyGJSoFg7AOLTWiKCAUawN9itGqeDfFaN2YX8ncaRAZyXW0zkkS UQNTHQggSYcY
we0cjMyWCtOLNksDK+RR3TIYae8K5sNytN4wR9U7czAyWypMLdooFwQKQKXU ZJTVl7+KACI1
jdS0vCtterhy14VLHxy+X45u70MPfkFAvtJ8zCfWMtVSposcSdxpEKrqVbXQ 4EydxMStCxlb
juih00VWBZnpIuvG/ErmToNIpmw8rI5aqTNria7ALWMZWdRme7fpIv9g71x7 q0iSNKyV9oeU
NNK0kRqUccnIiB7th8jbAuImTO/uh5Ysug29tNy4B3Az8++3ji/gabNuFwYd USQgZA51lKpT
8ZzI983MiK+IhkaUA2DR7OwdrRMkkiRu0szraO92BS6GFlkfFyaYxdzIE0sF y51aMaps1pTC
aO+2gKerr4GM9m7Xpms7uMTUVB2y9sLBU+4JAS1QUenU+tAdixLK0B3LYn4h c9tBREOShNlq
NE4tZsEWA/TKpI2oXdgcFjAN4TGEx1pxqMQ9YAHOld3AzAoEzKA1EVG7THhs 0BjKYyiPdYJB
RtipJlFi6G6JzTE7SK45p3ZZg7ejnzY/PD86OPjndPD06OX8yeyfPeBN6E7f lO9+CDe/v3Pf
f8gHR8/uPv3nD6dbun745dUcuHME//L096e35mu/+Xaek+1PTKjXpezLlCsf uXaCts21k1HN
7uPBU6aSS4DIgQVEi2AyjiIQjXWcpV+WmoaGWRbzC5nbEiKBQDI4Z+AA5i01 EoidLfTYL2gY
i6MP3JAwq6XBE0BNxRoYtwDalSGWrtYrgcilaydxdPgZCmalXGjyIpwoSOQO RYGUwWp0cepN
3ymY9y2py8MHuw/vtb1Hjx+Wtru7d8+/f1But3p8vOXN4fzgrp1AviYRgkZD g1yTtM+IjqZL
KmpHYJQKPXHNoK13qV0LuxG6DA2yKLkMDbIs5hcytx1EUuuxJevFnKlFK4hB hBpGT8A2elEP
DfIV0VAJmDgrUmWgjSKv2IHYasmYfXQZvQIXQ4OsjwsCqxzVQBtDQrOOEc0L ttYtxQs92kfR
x9GifbUwRASiHDgnZU1VA7NywsYcYwv90hbto+bj6NC+UiyKdOvOCuDshTJg CB21aMrWhE+x
OPWmpneeVHl4/74/qNPzw1fneiCe9Nq9Nf0LKOErJCUKD1K+RFIucXQzYgEA ziGysGqk2DL3
7pRZY7hyF8RkeN1E8mX6uH++9310Qbw+S58RjkvSiKaO0os7Mhuwi1diKrWH qDGcwVHmk+iH
B/NHdCo5zh7X3GWaCXXOHNcl44tPHIlG4rh6sC+EbTtsJOdGiKJQGWLWhC2Y YokWFaCM9YxF
hIwOoStERJKhBAqlF3Y1ixE0B265YOriA5HrI/LxE6lliAwz9/MgokGUEUsH 5iTZtAbgli16
5hrDxfJxNtzcseS3VhpqDJ1KtNCdi4rFamX+06H2ynZ5yQaxYeeOJb91chFM Y8q1ahS2Dh5a
jFaxNFerapccnHo9Dz72IH7aPYhAWy3mMAytjwcpYkpWSyrE3ILmHKKX5Amk NOA4FMmiVDMU
ybKYX8jcdhBpvXoPkCwjM1CuZlEd3CHW4nhBkcRRRG4oktXSgDkl8A7NCzdi 9VjIJbRklLPa
pYokjiJyQ5GslItaOTcJFmrkkjAnsVq4RbaSOvg7RXLSPfRMjxyPPKuSv2z4 eHX0cnOTx8/2
9fQf01e6fv5hDXLhlb1f989LEN3mMSi2iJ8AnGVx/sk52w44EhFjJz0pxVA9 ADbDaAYlhzTW
RJallqFAlsX8Qua2g0hL1TCVir1yaGIFLfYuTU0kShvHoIYC+YpoIAvZklRK hbNLzrW3it3V
JFb0P9KgwWTgMA58rBWHyF3IYoGUONXgDhADKFQBcsNxKvAKXAxBvj4uzC01 jyo1c1XQkrPG
VLh5ZvV8GRcggjDIGGeh1klGLqF6zVaSsZSqERqkloM1aJjLKRkP51h/fnhw +Ha6eXNzWwfH
z3a+s3ek/Hj0/PmzV9MOiCCOKdbZFMsGMCsDBoGZRYqExDWCiQTLZtYratEL K4AggjB4GJJj
tTw0qykTA0duXTI5UvNQsAH13K98RFDpK13iGEcEV7ye0aJrYTeNnEtQEis5 N6vMrYIM3XGl
tDF0x6JQX4jadshQpsAZqbuyeVXNobLFLt1DYB4rfYsIGSt9K0QkZ2ENudUu LOKag8VWtWvT
XrBcWOlLPHTGWOlbKw3BUk+NJYXAbjW3kDuxkFinFC9f2kg8JlJjaWOdXGRn UyhBxJk45kLC
qWIwsW7Q/2Sv4c+Hm0nV2+lgDpUL2w6/nV4e/fpobEBcvAERIW5RsI8NiB9P E6EmCPMvbNyy
evMaK2MmcAo0jkAtyzdDliyL+YXMbQmRJpEaiWdgUnTP3igkyNB7G+3SPgUi w9z6shGJGWMx
NPLAGsGKUNDYu0dqWM8Q2d0MBJiCnqiTDS3zhz+/ul4ojsc9vsfN6DMZj72c /Hv36LfNFe/A
oGgXuOBPysXJuNPmlfmtP744mD/vPxDCkHAQ8pGERIL/X83nFCFnzZ1YCymY GgVPib12kX+t
nfjdNEv6pzubDrVnLEx//fvR4Zu/wa14K5z8eGM6ePby5zf/u4NhGGC0vRUT UB3EfAZiOmaM
LaYsziLFe4uxc1A17Mb4h6LVT24/bl7nCienjdZ+Oq1Cenj05rejN0t5Oi55 /dtZxdKvHq60
tV1dA67PA1esSkKtaQ9cTb3VlEvgDpS55nMTtv1jdKbnrw5/PVcD/s7+SRX4 zQzu0dNXb+Zo
uVM3L41UNAGaDlzWhUvh5g0D1qIcQ8jaCFPPXp1ijGeztzlpvH36ar/OwDw5 PMXiu+kdRGf5
hezG6e7hnX/798ELUIDBy7p4qUbUqXrCzp0kkzSTAEGDQojpj2rn7dMXx3vr Z4DOpZvXb/YP
j4ZhRjzSycrwKAkRpDsn5ODJsgULVgNHtOxn0sZ/nMN/M8PaPI5zVvKt6fbx yuaO2JhuTbS9
IycDj8+FR0dJVro6I3TzXGn+HROXDqV90Cv761/+Uf82/+XndPyAY9hiq4PD IktvXBMFZi3W
gYmAsFlRI/oIW+xD6AwHbDhg6+Yoxiq5MXl3TiFr1IQNYoZekLIOB+zjaRkO 2PpwSU1z7EIJ
C8du2lxzJXHorSS2ZQ4YwnDAhgO2al44J0siSWJiKeapF+fsYo0SRRwO2AI+ hgO2OjzQtVAo
ElLmAM1KSw28Q03YrPbhgC3CY4iTleERA1qoFnNrjOCOtdUexVqPLJ0/6IDd nXe37Dy5f2PC
6fFcd2IedzoXn99Ou29mZubJ2dT2Xxw/i51NiM5AvX1BuP/s95OIjADTzu7j eOPGe1vgTr4/
3bXpv+6fvQVv0bfTXXzcpuP9M9PpBfPL03+/eLl/+Pb19D+Ppn+o3CScfrHf f90MgacxzyjT
zt07T6ZnL5/+ePBs/9xAd20e4+Z0elnYA2TWvYPb+7v3H5+7an7vu6vA9kCD 7L3S9xf8Z5ne
X7AHdn6Ecu/df0WAD1kfaXylDN9wfV8pUri0SIly41Cqu2ZMuVBQ7knSR/iG 4wvnk33hDLd1
uK2r/vbJTgkUsyJzrpSDZa4mOUchLWO/4TVoGW7r+nBJFkQzecHKXUhRQDgR EHDt2Be6rTo2
HA67dd3AhNYdEI0qcEe2AJZDgE6tYE552K0L+Bh26+rwcAyMMSZomXPpWRLH 6AGzR4Scht26
CI+hTlaGh1kpKTUxVzbqio5FGMkIvJdLq5bq6ittXTjBXsqTe7vPXv1+jgm0 OM6urxaPXCUJ
CbRgLEnMnQNUUJBO3fwEj7MSTfOtnOPjVIO8w2TF2eMqnFAYNR7Wy4mBB4Co 7IFB0KswO0Yt
RXrjdpGTx753z79/UG7vPXr8sLTd3a+bDoA06FgtHbHW7qhFqDK55YzQRSoy i5d2pkE2C073
T9PHznsJsnF+54f04vU5U3ia10sgwFAkALY1STJw+Uy41N66ZNBQnL0HJRPg mAE0Fgv1FJcH
Z0Fx7Pu+mSjE09pahy/Po3KnThDgawcFEQcnK+OEalAUit0rSy9aUlC3ELq2 LgQXisaDjqLx
o2j8WmmoDVv3rA2EQ1a3itAbawNDZLq0aDzo2q2sq3ExisavjwvD3hrVjD1y gOhBvVDvZrFm
bnrMxWnkHmuK784e4Zw49u+//vn1zvXzxZdZD/7Pu7UlDVss/h45ySegYlkQ f3KItkNFCxrR
pbRAXEpSChJLKJKqixQcla0X5Y1R/H1ZzC9kbjuIQJYouUGgzrWQKldV6IFa hWT5grzgMOTF
kBdrpSFJjlDZcgwsreZUIGUsgNA8EF8qLzgMeTHkxTq5CJCbg0hplc2imQnW zlUbuEA4Ly+m
by5MZ785aVU13+Lm05t++nX/uoysVWpo4iE1rgnUdgiR2lqhkgGJvSSrzFWB UCtB6mVIjUU5
ZEiNZTG/kLntIEII7s1qDokVs2mtkhNCC6mVeKH9LdDofzu0xopx+D/2zq03 ruOG419ln9r0
wc4MLzOkiwYg54IGSB0gdp4LWVqnQhXbsOWm/fY9e7NVK5F9dOlGqzFgSHu0 e2bPzvyW508O
yVi5UkmpVPJGKkipcwqcUiwmV2mNiKMB7hAbBwtG6x3ZUV2ps4kUw0rSVN0a 5c+KjTdHb98t
T3ZSY/GHs/M/l+nntLz+sm2KE3Dzy+Jkutn6cDBuDx6f//vjwUCb375ZnWZ6 k2/PtyMuTk9P
ts+aJuPxcjPxj1ftZR+/+fRNXTjH2dH7V8f/+PbVy9frh/bmzdnpZlFu2Vrl 8G9PvGro83g6
unn0cVVvHm9Pur7AKTtyWlTnyynL/vW70wtPOnrzZtpxtnvqo+0XxOolX394 zeYUX194K9+s
D3zyVrc1Espm18239RsOAdZPvPSX9dGLn9bmyDQN39z0G+tgpd+IMt34620/ 31eNAXsDU3Iy
Jq9UewLGFGuJuQ3pN8uiD+k3b83PZG4/iKBWzOgBuhPkpFwD9xjEYi4x26Uo E/NQfkP53Wsa
KP0mDVwqdrGIJROAGkZPjsq956oGV0aZmIfwG8LvHnNxZU1hIcuImRu17mI1 ty4NrdQioezy
y8pu5lajT4GlD3vZpqtbKb4nF4THjTm5n3JjpUIvvfNfP3pBgkTJeWiQG5J2 h+hcYVKCaQpY
yWImiehMPaQsXWvqDfrQILOMy9Ag89b8TOb2g0gNUSNJbVQpB1OsmDqX0Es2 1HJJg+SRSDM0
yMHSAA7AnHJPSJySmSdq1V1ZtAe/UoPkkUgzNMiBclFbyqmHkIgpgqpbL5oE FVJPLf62Bnn6
+vz05ek0WxfVx/Ldds5W3Lxa/rI4PV/+vEpdPpvW0k3xeUjSBADikCY3BHA/ RAmGWqiAElEh
Mq0diFJoGkMIcUiTWTZnSJN5a34mc/tBJBJVZaZeA0FNHjNUUOsWgibpQ5oM afKAaMhqyKym
IVDl7B2oRpVaOZRAfUiTL+BiSJPD46KkSB5iFycqOVh3cHEnCBhZ8paLT+TH 8/W8PFnsjMfi
1VqnbKZ7q0p2U726/drs+bopPg9JmkSCfSbtpJDoFoiaB8CtA7gfojxQI8oR u1HO6EDsmYvW
UI2NhjSZZXOGNJm35mcytx9EKDfH1qjr9L9FsVAjZYRgrZYOl+sD4JAmQ5oc Kg25WSpN3IFI
DSRIrBpSsAS5Vri6PgAOaTKkyWFyIQjdW0yFM3konopk7xh6KoU9/0r5MV+h MC2D1V+mIvov
131ZXix3U7ucJEu4pZL691OMfEHGSNyn7hghkevjog2itZK8ExWpkr0xRwhA QXvQX21//aGf
6mhRtNf2zRlHneO7YKL02DLFFKISQZSai6eci+VAkfJg4nfMxGjbdSdIeGwG JpVbJ0/Ns2rJ
hU2Femw83FOzABnuqQNEpMfQNXSo2AgkiwnFSN0ckijBiJwP99QDoqGW6k5N CgK5ZAtMjTFH
qo1E44icfwEXwz11gFxoS+4c0ZiSg3pl8qbBeo45wcdNvReD56uY+fnb0+W/ pmvbTek2PD6t
j5evNz21L77iu7Gpd2bknHmPHqwROb8+UQWjmpYiHKmkJIUbaMnU0CCNTb0z bc6QJvPW/Ezm
9oNISNU8CUXr5KZSW8UiVBRBSq2XpEkaNU+GNDlYGoRZaoqpQSOm6hUISi0W EBNJu1KapFHz
ZEiTA+WiFk7dvTdPxFYkVs4VjUIPGTx9kCabEvrL7Q3teuRJoWwfTn98Ny3W 0xU4v5xO7ein
Ac7fv1uE/zUl4RrMHJIeuXTk7z+fXMwxlH3G00kZbgGieWv+1pnbD0TZHQ1i rxWpQvGes3R2
VGWpo/j+TDMz1Mi8NT+Tuf0gIj1o68qhMzUzNeseLXeTEHrlS2oEhhoZauRg adCOHZsZaCJP
ZD2yWoUeKBbE8CkNKQ4YPsCwr10mKBAGDHcAQ6rNMvYSEam7aTRUbS2kDiGH q/NtYUjzIc0P
lIvcu5VcAiJT5G7FUwklYDWKkOQqLlIcWKyx2N+mxGEu7ggLjgksdDct1LQ4 OrRuwMFLjQW3
WNjJyXQZ6+zyas9t8frtonz/9Nn337XF8eTKerU8e/D3UpHzgOPg4GgtFOzV gFiLZ2TNUQo3
VklxC8fT3ZpY/LQ8//bV6fkPG9dTnTa1+zTP/3wyXdL5+7eri11su+qsJuHb +mTBIeBAJ+FA
58DQMcPiHnPOgayKVGUM5BWTQzXfovP87X+mD//9NFpcHL2aFvWGjuk63r0/ O188WkQhuike
9zPo8fmMQZZ9FlEc+62uD4d4b2rkDQpZNNdegxPElguxt//Njlr8+OPKUixf vnxxfAz4KCq+
eERwIo+E9ehRJs5HL/UIj4EevCUhGQplxuqfSd+eYIkZAWuFUMmzeSiBSuIc uZP7zru7kyPT
z6etPH+ynM7wYqrL+4/lyVq2HH+475pWPIeADx4VHXrl0FCJFItndYdA0dQl O0eEnlMN1eqI
nM8iZETODxCR2pmkxVa1Uu8qGGLrUCRiA2nwqaR/sni2GjOmjQd4sfqgLyr4 RQzxoXMCAMOS
HBgm2ZOg9NaLU0rosVmACLWDZfRwORN3FIobG0wOloZWmiWsUFqklFQESkJB jq2BBr06E3cU
ihsx9QPlQkwypZSSdaKshgyaMCTTjmB2oYb1NNLGm7XroPPVR8Hxp8ePH7zV QJR93UNF1FED
6y7o6IFTho5smbiyxO6ayGPqCLmUT2tg/XJ0er6KEL58/XZdD2uXkX7y+v3Q 4kiDj0PjgxFW
AqNxcFJNBrF4t1BZBK35lg97Ma3/lbdqNR8X3FSPF39d51B9RSc0VAeSDj4O jA+vqVCxrL2T
tq4lkKYIhE1TNfxMMmGfwuon0zQtd6mEu6InhCCrUr0TDtPauQU/7/2Mr18v qVBhjyH3kVR4
fZgKpBZi94ZCrXULKhKlBMaOnW2ERmaZmxh0ZI7MWPMzmdsPIilFi71470rB 3KFZQDOsROhx
IHILiFzfWMxDZDi87gYRjoWhZjMEwigeJNZSTcRRFNtweH0xHnt0eFHgIVju go5cOyFXr9yI
snkCF0nqYATEPhxec/jYn8Nr8HFHfIRWYsgoLSFhVgPOos0cA6ba+xc7vPR4 OLz26PAafNwR
H24NlINKyhSgWO6xeImdcyy16qVNJ3GUfx+bTg6WhgLQzaRRBHJM0rC1kiVX q8FRrtx0Ekf5
97Hp5EC54OqtukF2JOzo3qFoaSVnD5n9cnfC3RROhuPkb+9+evfVze3F/Qx5 fD6lMEvYY3xj
NCG8PhWKPUrJhdCoVjJDTkGocw81pDSct7PsxnDezlvzM5nbDyKZY+8Vey+V tGTBnhQbWM0t
Ws2Xm5+nIS+GvDhUGogqV6+qhchL05JqNiSD2oNguLr5eRryYsiLw+QilIIY jVNM5MwWuxXp
iasXaho/7LpaZwauq2Itp1HXDtvvf5kWxwqQN6cnC0KQm/JxP2XG9dpHYUp7 lB5ja9X1iemo
AUOgYkKpB6EYGuYCRaWow5Aes2zKkB7z1vxM5vaDSAjJmtcYa6Nco3ngQNlQ zWvFdkl6MAzp
MaTHodJQu1g275kLkVQNnLJHhiSA2a7uHsUwpMeQHofJhTSLWiyVoOQZVQqS oRSR2JnixcjG
4o+Xbmf/uMkDWe+oOjv6aXH888ki/DsECKt/N+XlfkqRz0c8hGWPsmNEPD5D S4LfpgUAMSsG
MUoBNTZsEQsw9phAhuyYZU+G7Ji35mcytx9EDGsHqZG4kmNWFuCYIdUacsbR JmrIjodEgzbT
3nuU0qg2UG6WK/deKwADfEpDlLG9cPSJOlgaSu05aYmAQmhZW27Rc1YOHkF0 9In6Ai6GCD88
LjLXFnqxLomCmwSUmGNXwNqh2VVcRBnbbkejqAPlomjO4L1Y7eTIAlU0SZWS akTBLRelPP9u
8ez47fsXL6bL2c3ipWB4vE7z8t8vFetxz06n069Gn9D4wcrm8bP3b1bPuNCg QC6RQbdKxmbc
xerI9NIXp2fTBz4Y+f8woi1RN6vdGxWpIj01gwpVuIRWLzJysjxbrrJfJ7/U +SQ3FmtP5boe
zyofdjfJt7KL5CC4QR3c3G9urkrpAOVUUTUgJXUthag3z2g5QNQvbxYVRrOo 32WzqLG96vpG
hUGde48lMnloLhC9WMnQDVXk14zKrrTCsCqfsSoUh1W5DgkzSdwPONScsgil TkTcrKacXDNY
6BhKHAHCWZp+BAgPEJFAVdGJC3QSJ+VM0AI2IsVMbSByc0SG3+t+I0JuChmt cCEu3UIC8YLA
zJ2zjazBWVHDYTDuNw2WvEpy5hBIFZSDmGbBaAmQy8ga/AIuRtTwnnJx5dZd LiQaoQoJmZbI
wNGB1SRX/pg1uGtQ+/dtw9rdzdPi2Y+ltGfP+o/f3ZSP++nCul7WIOx1++7o gf5f9s7/N67j
RuD/ygIHNCnQ+kgOyeG4aAFyvuByiJOgaX8LEPgit+dCse4sq3f57++tpI2c yF3nrdxbaD2G
gZV2BT3tvvmA7/NIDg+PJDkydYruBJwUgrj1oTVTD2mJp3qsiinTztet+ZXM HQeRIdGSjsy5
smgKMI0WhWpuxtXuD+GEqR5TPU6Whl6bd/WalcXdctfBDV1z4xK4fwgnTPWY 6vGIudjbTRuo
WUk187BqqGiNh0bxjAI79bhN/d0t3qebXeTYZtCXs3L5YnMrJd/eScqzrz7v f+oP5eZjUhK0
YyrJ7Cg8PMJ4qVBqH0Mbc6SiCVuJkWmgsMRUklWxZirJujW/krnjIELWZAzy jIVBsGjLtWVo
0GN4yveVZPZQTSU5WRp0RE4Y5iQsOTlSKUO9NskGCPuVZPaKTCU5US4MGZm8 pupcq0SMMTwh
AYjIkLvJtWcXdXug3ezauz0Vl+6Rs3pT3/tyMZPN9u9ban6vqxjrbrDaxcbr Q/H5qMyEpBxR
TWa25HCiOnMLomFGLNk8WldIRjYKZ5nZknUxZ6rJujW/krnjIFI4BGtP7I1x kBfJoLlklmoQ
dH+PRZxqMtXkVGkQiCGYSmPliOrqPZduYaV3F9+/xyJONZlqcppcdKXSwat1 5MI5oKBIhdS7
utW8b3t32Dxb3t2bi9eXc4/3wwQkGR3RP2YT4uHYULGhxZjCmEaUMPTaitro NKu11gaW6R/r
1vxK5o6DiKlUbIHdG1vrwUUlMI2E3aSM+40iafrH9I9TpYFarg2UKw2u0I2t kjX3MKwddH+j
SJr+Mf3jNLmAHgVLybkE1wzWwpy6x/I/58bvmF4bWxSWZbB9ZXP+4i/XLvIf L3an9sXZ0w3c
8PLgQPI4XeT9m58Y8hG9Y5ZkHY4LEzR0St0T1+iOnKCNrp5aN5fpHasCyvSO dWt+JXPHQURa
wZqQauoM3csgG+7ewSFzj7nJ+/SOj4gGy6BBnNiRa1ipPefcizDwGHAvC0g4 s4Bzk/eTpaED
SNKCCYMHV0eMnEuD4aXksdfCCWcWcG5mfaJciJp3qSRJWOsonIYKj1ZSyWWM OfzgQC7m1dPj
5oKGaO8ZKyknotCWR8ppWNXh5ecd59dVuu35m+d3lbo71T41OK7vMb2V6b57 x8+ev1pevMNC
cvopFh82Vrz1Ud8eeQaM/wcwslFXGTa6cYlk7qaIycG5DJg7VH+Am7TH3aF6 FqcfDgeKUquj
dXR2T4GFKafWUzdB3sFx+eLNZ6+Wlbh8ONuYMa5efffp3T3aX+9gWf6Kz9qn ApB+vfmv56/f
LJccN9/TVHQkkukivxyHlTgehx6FUkBHjxZMHSOlnqrSwKqlypgpjnWIzBTH 6SHSOWnz3FCJ
qWRPnb00q8VAsuqPAebV2bNbUX87sizULCfp5eVbEWbz8mybXZ8RBbGUGVFO DBeVLKXXLFlY
U7aSMw0evbNRM7/F5YvdorgudV+UJd2WXW0uXr2Nymdtg4AfOyhENDk5NU6K q2q3zsppNGs0
1FsfIwt5rfc7BmfF7sycnywNqQTm3HK0yt2x9MSYAiqHBrxnILTMit2ZEzlR LvKw5EGeMdi4
RHGTiISjK4HS9PNVhMwZOSeIyAiJ0ZARjLuYS4Os1rUiN0Lf31S7WyKX2819 ZlvtAW21DMcs
b59ttYeDU4fo6B0bOncRRzZUMe09D51ttR8ithxOwrrYMi+//jmIUEGtJMmz MgoWZmapTNHa
KHR/x1GcO45OST9ZGjSa5lqGd+fWoaiDU0/UrLOZ7JV0nDuOTkk/US6sFeXk CUdl5GHB2kuL
3itTwDvaanencAkcZ88u/3r56cPjxeNUjvcXZmWDI+rF7J49nIraSLDSEMlM tRZ3qOiBqKm5
lqkXq+LG1It1a34lc8dBxAU01ZLYE2dLRdCAvLv31AbFzAFOvfiYaGCGDCRV GmerwcUaoSgM
TFRg5gB/ARdTL06Pi4GpdCB0FoZUgoo5JMYh4FjgbqDBfy5tH+e7cQbXR16G GvzLlo/XV6+2
b/L63F5ufr95cEXV49SNd2c47j3z7fdnPxmplo5oIDPBcTg4oiZmOqwYNwXT AiYVqLpHtjYN
ZFVomQaybs2vZO44iORK7sTB5hw9F8hg4VIYhMDq/ZFqPA1kGsip0tArpBIj J23MgwPrwNob
DSIjyftHqvE0kGkgp8mFBSbxymHMCuwyQAd4KKPIqO8xkL9ebC+q/mdzviyV ezLym82rq++/
mlqyWksIZWrJA+E7Ek3KXuoQCOWQKMDRPUr3rjDanPS8Lt5MLVm35lcydxxE Iklr3sNSZoZq
1of0Fppb8apyf5wBTC2ZWvKoacj2D2lolDSFN9bGBhac6kiDM4WWFO8ZZwBT S6aWPGIu9iVG
bKScUo8aXN3MI9VhRpQLZBlv111tPrl3OfvJja0sb3H76W2++/7soYw8Tvt4 fw2W5WO2eMwa
rMMjB0brA3oZmpgULClJDM2ZBJP6VI1VMWSqxro1v5K54yAyGnD0DITM0bIx BwM0YRg5J/+5
aiBQnq4xXeNUcRAtaSga0WBCKg7E7OK5YlD0fa6xRWPKxpSNRwzGvtlplI0A i6TGiTykVgFM
CR0rKd7lQM4u6vZAuyzI0nZ+9d32i79cnZ//sDl/fvVq+WTOdid4u3Q3n9Sn 38Bv//zZM/8m
zq9e/PvzH755cXPKvvnb62XhLiv4b8///vzJ8rOf/OamS73o7FJf0aWOVPIR HWZu8Ht4ROo2
ukEVbZmNWhkZo4uLujrUWcW1LjRNh1m35lcydxxEpBXVYOg9cQI16JKoN40B NgbccxikWcY1
HeZkcVAz0ShYUuKMoyS1CM4sgqaCex0GadZxTYc5VTAC0qBcDIw7Nk9Fofac DRMS5PcmTJaR
CMvI5126ZPOr8ze/q8vjsrx+/6v/vrp48zu8edicLZdau6dg9+R3b/5392TW m8c/bH/F2U+G
+FzGMsPkbPPy5dntzy4n5MmtDT3ZXuY/uRaB2/kzb/2af33X77l5Zfkj//BQ nh+nLf2C5M5s
sH8w/MehWQo04pGoDC6YLJeswANIa6thU4xWxbspRuvW/ErmjoNIgty1yNAW TCQuGApspBmk
jXy/wX6Op55edLI0FKjUWm6EnRXcuYll6B3EK6Htb7Cfg0enFp0oFxEdexsq BixFCgQnlA4t
oPSK79hBuH75xddfft6//eqPX9b+9dfffu5//qL+W2/XWvTmYjlxDw4gj9M3 DsvOUDlmi/1M
zhyOjoXUGK2VjixNA3j7r6ZAgV7rdJBVwWU6yLo1v5K54yDSS/FiNSMbUzXz iuigrbZeerWf
OwjNVpYfFWQOazg1GAqm3ssoDTqX3othDM2eDCIli30KQrOTZWcgE4sTwyKq inkwsHMaEZA0
F/CO0Sr3HRa31rH50Tbql8+e+RdtO7vkraGJN/Orn2x+Agp8hKSI8iTlxEjR XExyAi2dG7nB
oGiZaEQZWO5vmUrzju68o3uyNACPPtAD++A+cokxRFxqc8JSxi5uLNnwi/NF s2+p2J3HZQ41
F7UlVHzsbEhOM1KcGBudQQoOJCWGxEWHUEoduRiMun9aCc1sx8x2nCgX0sZw Spals1mKRtiF
zT1r60XmLdtVhMyRoieISBPhCCjNCrceJlUH5aqunRR3CcE/vf5h+fCvlqPh ZtlJYmfgy/u4
vDp/s/ntBnPRh/LxONOA7y87FMOZ8nsgS8eBI7mYt1oaEFdnV+kBUBUIW6PZ j/UB4sfhJKyL
H/MS65+DyJAagaCVE4N4DFeoMrKo1Ij729fpnOszb1KdLA05OncPhQLcnbyV Ih08oQ4YWPaK
uM65PlPET5SLWqNKrVzr4DzIe9JibQAM7T3Fj2WHuzO3PfriGU933y/vbltv +PQdfU8f6VZ2
h1UfouVj7g0xW6AOR0iggZl6BWIf4YlNqKJbUaiJp4usCjLTRdat+ZXMHQcR 7QkHFc2WGTlZ
bmFO5pmra6n3XaRMF5kucqo0CEXW0RsSMGv1YGL0LCDVSrX9LlKmi0wXOU0u qmvC5GwN2FOP
USQ3pDKoBUDs2d3ucjn47If6wEaS8Jg7bs/syP+xd7a9cRw5HscC90EaCLCw gaxBssgqMsG+
KNbDJsYaF9jG7b4z7EjJemFLOVmK9+NfjyxZSuQbuSUL47TrjR56etSaaf6G 9SdZ5M1BSkxA
3aC2wLF4Tt3Uc0WDZlLCUCSLXM1QJMtsfiFzu0EkQ6jmiVrq3DG6hsZqzlGQ U4xXFAmP7MhQ
JKulIbYYlbViiJxErVanUqKF3CUX3KpIeGRHhiJZKRfqABZDpFo5V7XSCDGn lMEz1N/0qruH
gPe/mXyDwmwGm0emV/s/HW8WWC/2z2/t/pw5gXe83NqR/DHFyPVVWbpT3TEy ITfHJXcj6pxr
SRwLeKrReuNeopecbeiORQ5l6I5lNr+Qud0gAtWKIQTzyibinlIh8FIldPNw RXfI0B1Dd6yW
hlagpNChcWQTcuKYa5BAFSn59u1RMnTH0B0r5SJRzrl6446cLBnm1mML0mMK HNtFJuR0euh5
HuT0ynM25KsNH0cnB5sXeXpv30x/nei2nPwx5caHcx9Xjjx7vfebYqxdtoJj E/oE4Cyz80/O
2W7AAU8EjKIaOGFXwB69ZCo5mPhoBbfMtQwFsszmFzK3G0TYjLOR1qRnIr16 iWLztxzqaF4y
FMiXRINo7LnVYLWwbZDQ0IQSAjaI2H9PA8ZIOHgYvRHXykMEKOhs2J25dW9c k3cxmb9UjKNh
yUdwMRT5+rgoEKTnhkkrF3JTKwwOVFJQVd3GBcZIOMgYbUPXSUbrXlPTipJY MmbAADFBaY6E
nj66T4ky3BaPP2aI6vqM+OhTcnuWdgNH0gApQiDrDBo9Z0QtcaM4KlUa8ahF 7mPEo5bZ/ELm
doOIsbrmiNwTA2aLxQtgySwYWK/2KUljbPSIR62XBqFSMaiisabmTXNnD5i6 eg51q/5OY2r0
0N8r5aIbc8sYtQqHlpQjeBQqQQi1jYZvywgZDUNXiEirsQZWykG5hKAUJbUc mVOEIOmaopGf
Dze4vJ1ezbZypX7k6+ng5PUPo5JkcSUJoexQuY9KkpvTZJnRyAw7cWa2nDpE KFRCEaZRSfIJ
HM7NSVjmcMaa7BaIWNjShDc5WezdgLV4xpwZU+jYI3E43+7xZHMhpAT6Tp1s aJnf/PnoeqE4
ve7pa9xcfSbjcS7vfn9y8svmjPdgBLErXPAn5eLddafNkfmpL16+mt/v3xHC mGgQckNCFGlL
d0XqEaUlBDar2lJpDlwCWk0h/XY0zjfTponivX8///X5OQvTn//35PD4W3wg D+Ddj/fnTYUH
Px//6x7BCICF3aUTGWQgcxfIxJi19Ug1KVsijRogQQYqSoj9d1MIn373uOU6 NwA6m4n+49mU
qcOT419OjpcCdTrD8JfziVRfPF3JBl0royuVIj1mpuLMRZ2USy5BnWJR84sl 294pO9NPR4ev
L031/H7v3VzPzRruh+dHx7O5fF83h2g4IyTTwcvKeCnAUtSoS2atrh45qTS0 1LTyeXJydhtv
nx/t1ZmYp4dnXHwzXVB05mGC3Z9enPz00/7RvT/91wAGA+AAZmXAVHS0AtYT cVTLWJpKs+q1
Fknh94rn7fOXx5t120zQJYfz5njv8GQEzQIPh7I2PrQltsSQU2Xi6hTdYsic QBqkc3mTXxye
nHYO2tyPS/HkB9N3p7mbWaD8OBxI4CFQ1sYHqlEKwgmUocXM1VusVkLLMQh+ MGL256/+U7+d
v+RvH85S/97TR/cnmh7PtcbzfzBdMtWvpyfHMz7zSm1qey9P78q9jbXObL19 GWhv/9d3ximI
070nj+X+/Yu//L0/mh7a9D+Pzp9CD8LX00N63KbTYMJ0dsJ8ePrHy4O9w7dv pn/+MP1H418C
Tf+2X19vLkFn5s8Up3sPv3867R88f/Fqf+/ShR7afI2/TGenwTMkZn326ru9 J48eX5y1ee77
s9CeoUJ8dqQXJ/ytTBcnPEO7fIXy9/cPCeLFAxehkDT03AgurvDTJXczQg0R E3cujoo9eqQY
IzL6DYKL47PnDj57Rhx2xGHX/UGk2UyMNKtxpJg5m8akBBlUTEYc9ua4jDjs CnmxKgG6olfj
YOJcHGriEBsBx7YsDkuGIxA7ArHrJqZEwFxNk1VGTs4Qs6KKE3HQEYhdAsgI xK6Pj8rRG7co
nNmBVYp0jt0zhJqqj0DsIj6GQlkbH6X3wBgilspBQo6cizOxurQoHy5dfC/i R23iLsOHGGww
cRdMiDAgSSRh7rHkWmuKnqPF0qvXwcTny8TwE3fEhHVOkTEHZO7SzXsswBSb ai4IV0c7j3ai
o33DamkggJYAJGXiHtwbJAzslZKGznn7aOfRPnG0b1gpF861pIJJo3KGrIAg OWuvTbUCX7M3
/ezX+cE3s7G+3IDz9uXxv6b5Ascnbyb4rSuBGzDzJW1J112OVxtb0m8OEWQq WUuvABxL8A6p
UC4SJWpwGVvSF7mZsSV9mc0vZO4OEaEt/RZbpJIQGYxr0oxo0lopKklDvTpe LY3xakONrJYG
Yq/QY2xZ2aQ594Qt1Q4Ya1fdqkbSGK821MgfmYtt1Vem1HN0qcrSQTGhIRTO CWoLdI0a6XMb
6735Nu2faZHz+zuxRd2Mfp5xmG3nEyyxviRVYjRUyS3Zu0OYaNvQ50YdE6J0 BhNngZY1CxsV
0dEoa5m7Gapkmc0vZG43iLg5WZeG0BmrOHbrJSq22jUHuqJKOA5VMlTJWmlg iQLcibpzIFAW
YjFAtFK6bVclHIcqGapknVwYhgLVY7QNF92LRYhRKnKh0uN7VTJXtJ9tSJsR ODitTvzvt7Nx
zIBsNk2dypDb8rEm5fHBo5ekR4hxSI9bArYbYnqDEii3zIkDqFJNzZyLYUjF RlP4ZT5lSI9l
Nr+Qud0gIgkN2CVb5VpcvWBJgj1yrZVkTHse0uMLosFIoZqHGgtXUUs5Wcwl ASUvVsZ024/g
YkiP9XHRQu8Zc49QWAAUibwkTAokjHxlCrrq8BJjBvpaaQCqRLVx08LYLDNC aQmphZwkyNZZ
z6rDS4xJz+vkorXqLUONiGxcTYCsFUk9c67BPn7SM32h8anPfdLziEXdHI6q XnPK1o0ZnDwE
Cq00BnBm9fO9geXp36cnPx6dvHgxvz/nN+tKyBZvUsP++bqMjx+Hw6q7H4cz HMgdMWIFTai5
1sjJzUOw6Llrr1ikjwL2ZUusEa9dISIOKShmkuAs3NWUqVtpAVhQ8LIb2dt/ tb/p2TNzcjzL
8ul0dXFaeLjp4nN+az9JOvDzRWWBawmfwaS14VruiBsLsWRqkMS5qnuEkltV tgBWxa7kOYRG
BGvkOdZKQ6dGLr1Wc1ZNKsTq0lNWt1byh7zIeQe44UaucSOMw42sFhwAiikF ybkyZcmYATpG
Dc0AQIdCWeRaEGxkR9aGCBkQtMqUKgcvKlQDqMVYpOXSt+bQhUZ2ZOTQ18kF VA8ltVx74aJq
RJZrypkgMnLYVr4L06P51R0fHr0ZNbw3rOHVsX3wtpTtBpsUvVhLEqxxTsEr KiN4ks4GcWwf
XOZYRkx4mc0vZG43iJhIKBo6xcSeW0ZKLhKSNQjF8Gpsi0dsa8S21kqDSkEn Yw+FAxQjR/cq
JTRBbLhdf/DQH0N/rJMLA7eWzHOIDA1zAI1OoAKttNa2649zC3mzifkOBXID BcIw2irelrPd
gJPFoUV298ASIVvHSm4ai6VCbSiQRa5lKJBlNr+Qud0ggi1pFUnNiZFE0Wss Fip3z7HZUCBD
gXxJNEgVpW7okdlB3Sk3BSuQMEMbCuQjuBgKZIVc9BwKBSQSpm6mWjVHbTGp Z/Zr2ip+teHj
6OTg4Lww/s301wlvy8maJMg1LRRRw1Agt+RsN+D0jr01MURl9eIUKhYtnqMU CqMufplrGQpk
mc0vZG43iFDFWrxli5lRgjct1mOhwNJ75CsKJI0+JkOBrJcGBqZcWrXEQpJT ggJC2bR6l7RV
gaTRx2QokJVywTVrdKk1ZE6Alk0QySs3SJnSNQrk58PNourtae37FTHy9XRw 8vqHIUsWyxJC
GbLklvDthqaQewzBLRVmt2YtoXhLGloBDCMxsszfDFmyzOYXMndHiIg8kID/ LyKtNgkxVyTi
SNGTYGBrXjxSKLZtIaarjwRf2VS12XD2ZP/o10tUkMnut1MxpjEc+i7wMDSN 7oU7MFNzzBC1
axDvjiDv8Dh34PNLucTH2dj095is2H98DCcBPoPd64OTO+KkZercKofMzNCt /x97Z9Tcxo0k
4L/Cp43zYG830EB3a+tS1QAatalKnFRsP6dkS050p1g+S97b+/c3pEhba20U jxkXzyNYrpI0
pEgOgY89HxpoQO3akzuBKdTbnPxkP39nzx7Xv//8408/VH/y5H7TgciDjsXS EVCKAeWKjXqj
Uqy5GnNrwU3jlo7LaVbj99vw8eC9f3w9qcnUSGeXu0J06zf+7OQBAo6xYUTV Qy3QHbh8JlyE
sQpg6YZkkSRgdxZBgwiRYIvL412n2MwHvlpF2I4Lry5e3UTl27ZC2Hu860sH JYQwOFkYJ0Ca
BFy0NWIjYenSEjbGwEK3U4qoI6U4UopLpcFqIVSBIJ2geskembCqJ6vZ4p0p RdSlD2V9HBcj
pbg8LhpbjrkgipDmKjFykxhDMgkkbcPFtudunOJo14RT4Dj5/vKXywf7x4sv M1v4x9WuWeCA
qcFEnP8EKuZ14j8dosNQAcyxAnsLQrWxpdYbYdGEhg59pAZnxY2RGpzX52cy dxhEUhRq1Lul
SJGTlpS6Zq6MGqH9m02fcejF0Iul0hCkBxORYkxd2SD0BMZe2Qrw3TuvEQ69 GHqxTC5iBSkU
hXMkpaKtBIpmNZC5QbypF6uvbl3OfnU9kXE6xfW7t3rx28m+jCxVNYQPWZ5h qMYehOSK2mqR
XqgGktAJUEOi7NSkDNWYFUOGaszr8zOZOwwiWSVQ9QKO5BktQENn6woxK+Gt 7TvjWB01XGO5
OJBiSgQYoFJRlNAqIMaA6J6T3bl/ZxzLo4ZsLBUMjphZvdQGVDyoO+TaCuTk 0hX+UDZeH7+5
PD3ZqcbqL+dXf6vT96l7/cdf/vvtxdXfEOL1D6uT6WLr3UHcHnxx9c/3ByFd //TN+mGmF/nm
avuMq7Ozk+29psZ4dHrd8I/Wi48evf7wRd14jPPjt69e/Prtq5cXm1/t9evz s+tOuWXr+Pn5
6faB//P4H8ePpqPXv73rvdtbtw+6OcEfj99MnerqdKqKd3F5duNOx69fTzPO dnd9uP2AWP/J
X9/9zfVD/PXGS/lmc+CDlzpNt7m8OD+t17Nuvm3fJADa3PHWLZujN9+t6yNT M3yz7yfWYtVv
ZJn2/ng7zOdVBOq5WydxqkEUYqxWhWPNChyH+s2K6EP95vX5mcwdBpFGuZWq kYMR1aLOWjkl
CjV6KLezTCkP8xvmt1QakICkScSSSSSWWGOK6twZqkS9uzJfHuI3xG+ZXETl miB7jJnAtQCQ
dURlaQiu7+ti7PxqevYpsfRuLtt0dmvjO7ohHntz8mXqxqcVB0dhHg6yJ2mH QadaQWka2I1S
U+naKHWhatA6jNp884LLcJB5fX4mc4dBRNVj79UwBSq5Sspo3Tu7lxoIbtfm GwtphoMslgYW
h4jJUm1kUqz3GruLci7A+Q9q842FNMNBFspFhVIsMmmPRKmZcjWuNUorsaW6 5eKmYUxrkZ9u
2uVotQseq1cXV2cvd2mdCZmpXt+uqdeXX9eJlX3xuVdqQuGQM+MyZPoTiJoH wJ8O4GGIirXW
DhFKKBTUjaAVNqixFepqQ01mxZyhJvP6/EzmDoMItlxTTSFnoMpqkUNORlhD 16Q01GSoyT2i
gaFy7qZBOnHM2rhTYe05kVfrQ00+gouhJsvjItZC3nMNnUmaGzSvyt5rrqlm f58euWknaym5
enN2+o/p3HZNuvWPqX+8vFi9fHPx27/8xbov7YvP/VKTdMjS4UNNPp0o45R7 1E7ulLxqIwg9
JMuS1RMNNZkVc4aazOvzM5k7DCJVHWJgDpJJNIgn671ECEU42ciaDDW5TzSw g+cWCrVE5kmw
AfbQKVlvmYeafAwXQ02WxwWFFrlyBQ7EgYsBlkDcILdcmvz+zK3Hm0TJ1Fr/ mlHZttkudXJ2
dfrbuuDr+VCTWWoSQsADqsmY0PXpRAkwRxXpWKioWEmROjb16NxkZE3mxZyh JvP6/EzmDoNI
zhaom2TPhFg0K6QKOdQa3SF+qCZ5VC57byaHKhMeJcCA4TPA4OolQA2tIOXo WpMXF0QSd/s3
dfzCWGE1PH2xNGAq0VryUDpBahIAWkzZUggW252zG/Mo47fT9BEkFoZFayWx ZFMVir1LRUhY
VQCiQLq7en4YCw/H8NVCuSjZC+UYc0Vq0lW5uFcE1Kicw5YLOzmZTmMzINXs qa0u3qzqD4+f
/PCdr15MBS5fnZ7f+2spTDyCxsLgwDx9kaSajSy7CEcPorFAZDb+cKOu1S+n V9++Orv66Xro
qR1fHZepnf/raDqlq7dvNlvV15sbdx2tEkAa6OQ40FkYOiVi71Cza6TUioXK Rk3Aghk6bNGp
19WzVs+erWGIFDAmzQ9PWeNDOmF+ePz8eOppGvCYKERM4d7DQjLkZGmwgLIr FI/FiAoWS9oo
BAlSVFLbwvL0zf9Ob/7b6dlwNWUQd3tATudx+fb8avVwhRJgXzy+zBzhH9eY S3LIdOCYqfjp
cFTonJLGKolcmlaARtMXtCa9tZEOnBU+RjpwXp+fydxhEMlqUCEnT0pqXEJz L4haaqnNcYvI
ztin74+9Pj2acDh+Ps0r+fX0ZG32N/YUnrp8Akj3nRXSofRfJCqUfxcVE0eP IUMnykmtFJGu
GlovXbT/zt7bmMfW2/8ft94emHwmTLj1rFat50TSs7bIXrpzLyFo89t749HI qY+c+lJpcGip
16atG0Fr4pVqRmRV6F1Gibl5hCDomIS1NESYaiMr3FCpliREoknIyTGkoHdv H0kjvz7y68vk
oje00BiKMEVGS0rCjkCIRSHdLKq12u4lslsB8uB97Pj60aN7HzZilENFDYp5 0PE56IitOwam
kp2gq0ZqvQVh7JRdPsgSHq3+5/jsap1EfznNP5nCyPGugsPJxdtxWRVp8LE4 PpIHQkqYjSBx
iU2rc2cHbfGdeNjzqf+vxWPdHjeM49Hq7+vNh08fEL8YYh5JBx9fIh935QYx Ui5GFIEku/Yg
qQKbYkghys398h4g4NdHq7IWjakbrG9ZnZ++3HDz/HTXtKfTwly4tpG9gVlq Kl3wkPVIx8ra
Tw8nPTYzxAQFyNENU/dYsnNNNTYaMvLxweRwMpI0yAgmn4GOaoVdevBaKKgr 1RRMvaTkGtnH
KO8sQsZEkwUikrCnGrJSDZSqCwcqqacCTtG5DF+fAcgBfX2EkM/ER5BsHRWI AhHGEnqwnHsm
tlyifryv0/D1A/r64OMz8RFNPKKYAVNnFKm9lC6WgbPm29XecZRUHNNKFkuD FyGvyGKNKmZF
lxCj1YjmKcKdOXMcJRVHznyhXFTEzEkqOVJHkIBVc/EWC8Ye4u1R3V0TToHj 5PvLXy4f7B8v
ljp4ywJj8HZPiA5DBbaQALw0c+osIpidsQaBUDiNdVDz4sYYnprX52cydxhE QmJhcgmaqWMr
ilyKxg4pUrJ8Sy9SHHox9GKpNJCoW3fMWiha0qoELt2oRkxY7tSLFIdeDL1Y JheFg0VuhSxQ
xqShd0TgYmDT/3ZTL1Zf3bqc/Wr163qQdpPWOD/+ZfXit5MV/BMgwPRvlF/4 vTkjSYZ27AnX
YWhhLiGkYuhO2aW0rKqhhtq7WRlrn+bFk6Ed8/r8TOYOg4hzyTEBWWvURTWU xNF6d/VSiW9v
FDXKsQ/tWCwNlAhZDCWtf+wlB+oQiZJjJ7w7q8GjAvXQjoVyAajINTTVQKGb ce2NQaFB6rQr
Jrq7jl2977xHq13kWFd6m1rl8nRXfPfnbSmf6fv3P37nT31fbr5M/fi0HaJQ hpLsC95hSJIu
TMK1tU6mJlhKDQ2TtI6ahpLMizVDSeb1+ZnMHQaRiEWZUw+aKWbTwKmzEjE2 cwi36/fwUJKh
JEulIQA3McoJgKgUS5k9Q6xOKXO5W0mIh5IMJVkmF+wxsIuV1EiMJLTuHCAJ BVNO7/auPVrt
RGMrHruLp9WTZ7X6kyf92Xf78nGf1CMcNBsyilF/OjGt1gZsGiNQa0HJUguN Y9XKKDzUY1ZM
Geoxr8/PZO5AiHh0q6EyRWIAqx01dk2teMiSR+nQoR73iYaaKIoELJVCtNJ6 7xKJau+KhUdd
xI/gYqjH8rgo2YtkqZ0K9VYFQ4k51i4mDDgq98zh6eNnYY3KPXvTdRhcyLJB jdETkWhUpFw7
Fo+SkKoM75gVUIZ3zOvzM5k7DCKcQkhcQiamYkWYybiApUjVWG/Pwhpry4d3 LJYG1VpMOGEg
CoySmnIMpQRMCQLdPQtrrC0f3rFQLoInFQqJExFhl9bFiBJDldIKvUt5rE4u 6vqJTreXtJuN
Re: TPTP newbie gets NoClassDefFoundError -- huh? [message #122981 is a reply to message #122611] |
Mon, 11 February 2008 11:37   |
--------------050300060105060703080509
> I can't detect any problems from attached logs. Could you send
> screenshot with ClassDefNotFound error and description of all options
> used for execution.
Screenshot? There's nothing to shoot. The call-stack is at the end of
this message (of course the top of it is all stuff in our code, but
scrolling down shows that the crash occurs in TPTP).
What do you mean "options used for execution"? Just guessing, I send as
a screen shot the TPTP launch config "arguments" tab.
> Could you also try to run your application profiling from commandline?
> http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. tptp.platform.doc.user/tasks/teprofsa.htm
I must be an idiot; I am having trouble understanding those
instructions. What I have is an RCP -- what on earth would I do to
follow those instructions with an RCP? I'm using java 5, so I scrolled
down to that (same link), but the two examples do not seem to relate to
RCP's, nor do the various descriptions of the options make it clear what
to write in a command-line (this seems to be intended for uber-experts
-- remember -- I cannot even get the basic TPTP to run correctly!) ...
thanks,
Paul
com.ibm.udat.core.model.ModelException:
com.ibm.udat.core.model.ModelException: java.lang.NoClassDefFoundError:
org.eclipse.tptp.martini.CGProxy
at
com.ibm.udat.cats.jfstcascade.FstCascadeModel.load(FstCascad eModel.java:112)
at
com.ibm.udat.cats.jfstcascade.FstCascadeModel.<init>(FstCascadeModel.java:99)
at
com.ibm.udat.actions.explorer.refresh_explorer.RefreshExplor erActionDelegate.loadConceptChildren(RefreshExplorerActionDe legate.java:204)
at
com.ibm.udat.actions.explorer.refresh_explorer.RefreshExplor erActionDelegate.loadExplorer(RefreshExplorerActionDelegate. java:147)
at
com.ibm.udat.actions.explorer.refresh_explorer.RefreshExplor erActionDelegate.run(RefreshExplorerActionDelegate.java:95)
at
com.ibm.udat.core.workbench.ApplicationWorkbenchWindowAdviso r.postWindowCreate(ApplicationWorkbenchWindowAdvisor.java:38 )
at
org.eclipse.ui.internal.WorkbenchWindow.fireWindowCreated(Wo rkbenchWindow.java:1192)
at org.eclipse.ui.internal.WorkbenchWindow.open(WorkbenchWindow .java:752)
at
org.eclipse.ui.internal.Workbench$21.runWithException(Workbe nch.java:1037)
at
org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3659)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3296)
at
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:797)
at
org.eclipse.ui.internal.Workbench$25.runWithException(Workbe nch.java:1342)
at
at
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2309)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
at com.ibm.udat.core.workbench.Application.start(Application.ja va:20)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:153)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:64)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:615)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
at org.eclipse.equinox.launcher.Main.main(Main.java:1144)
at org.eclipse.core.launcher.Main.main(Main.java:30)
Caused by: com.ibm.udat.core.model.ModelException:
java.lang.NoClassDefFoundError: org.eclipse.tptp.martini.CGProxy
at
com.ibm.udat.cats.jfstcascade.FstCascadeModel.loadCfgFile(Fs tCascadeModel.java:138)
at
com.ibm.udat.cats.jfstcascade.FstCascadeModel.loadManifestDa ta(FstCascadeModel.java:439)
at
com.ibm.udat.cats.jfstcascade.FstCascadeModel.load(FstCascad eModel.java:110)
... 41 more
Caused by: java.lang.NoClassDefFoundError: org.eclipse.tptp.martini.CGProxy
at antlr.BaseAST.<clinit>(BaseAST.java)
at java.lang.J9VMInternals.initializeImpl(Native Method)
at java.lang.J9VMInternals.initialize(J9VMInternals.java:192)
at java.lang.J9VMInternals.initialize(J9VMInternals.java:157)
at com.ibm.talent.fsCompiler.CfgCompiler.<init>(CfgCompiler.java:233)
at
com.ibm.udat.cats.jfstcascade.FstCascadeModel.compileGrammar (FstCascadeModel.java:178)
at
com.ibm.udat.cats.jfstcascade.FstCascadeModel.loadCfgFile(Fs tCascadeModel.java:136)
... 43 more
Content-Type: image/png;
name="TPTP_Args.PNG"
Content-Disposition: inline;
filename="TPTP_Args.PNG"
iVBORw0KGgoAAAANSUhEUgAAA6EAAAKACAIAAADivulaAAAAAXNSR0IArs4c 6QAAAARnQU1B
AACxjwv8YQUAAAAgY0hSTQAAeiYAAICEAAD6AAAAgOgAAHUwAADqYAAAOpgA ABdwnLpRPAAA
t/tJREFUeF7t/T+IG8nagI/OzU64wRdscIOf4Qaf4Qu+gS9Yw0kscHAMJ9iB E+zABmbYwAwO
BrGBGZwsgwMjJjDCgRkmWBgHC3Jg0ASGnsQgBwuaCwZNsKAJHCiYQBccKNhA 962u7urqf1JL
akn95xG1Xk2rurrq6Vbr0au3q/9fey+cHetx8//9/9l/8hwCEIAABCAAAQhA AALFJ3D/f78L
dXLvt54u9//dkdJ8Ozj7PKFAAAIQgAAEIAABCECgLATEYLXKGrPdMYLr2e2f k5NPYwoEIAAB
CEAAAhCAAATKQuDsTxWi1aar5XZn/6WK4GrBPbkaUyAAAQhAAAIQgAAEIFBG AkZzxW939l4p
x5VFxx/HFAhAAAIQgAAEIAABCJSXgDitCuW+6u2YIG7z45gCAQhAAAIQgAAE IACB8hLwQrn/
6e7sPnFal6PmhzEFAhCAAAQgAAEIQAAC2yJw8Gbw+Ki3aNl/PTh8H1JZMVvx WxwXuYcABCAA
AQhAAAIQ2DIBEdy95z3n987o/dnoj9Qy/uPMLr3zi8PfHNFc28stx/04Ovxj TIEABCAAAQhA
AAIQgMBWCEj41jnv9H9v9960+m9O+q9PBqacHg/cMrTK6FVTlbcnormyrt3n 1kcTx/04PnxH
gQAEIAABCEAAAhCAwHYIiKcOJXz7sill+KrZPz3p+2qrBVeVV8dDVVQFKbry 6F1bOa6lsq2P
Yz9X4eP44PeE0vpj1PswHLwf9P7ot39zTp47x786zefOwavBwdtR4ioshAAE IAABCEAAAhCA
wKIExFNH78RxD0e/qdJ/pYx28KqpilhvtHjVVH3Xce3NzXHczvvh6PNwdD3q XQ7O3vRdwe02
n3UPf+kcPLnYf9bdPx0u2nvqQwACEIAABCAAAQhAIE7Addz2UAT3xcHgt8Px l950Ou1LQDdW
ZLm8KnWkpqr/+yzHHR2ch8rJ+XB4ORh/GY3+GjtXw4vzfkhw/3P2+N/tx086 +6+HkRUPzsd9
2bJ5jMfH4ZZj9aOblgrH1xO3gUn3/ejsVj05U424LS/VYJaNUgcCEIAABCAA AQhAYFsElOP+
3h6+OFDm+uLQuGT/t6ZdzHKp49Y88BzXEk47H3e0/zZUnN8Hw/eDwadh7/Oo ezk8e9PzIrg/
X+y7gtt41Hrwz5PGMyey4t7bsbLuq84/vj/5x391HNWRUSvceGSVaAtXSnB7 b9tuC+2TG/lr
0Pyvi4Zu+bb3+P+6jxdpcPbmeBUCEIAABCAAAQhAYOsEPMd9fjD6dX/4/KBv a+6LQ/kzskTq
6Jqj31uyrt3/kOPuvR7aZfCuP3jb677rd94Pzt72j5+7KQphwd39v+Pdf7Uj K+69HnmO+y9H
vXQ5Ei91fj17EG4/tlaw9fZfssaw+V8n9555Cx/8S2RXWnBbFsf9304jc2sz NsRLEIAABCAA
AQhAAAIFIaAc97w1/HV/9Oue/NsXzX1+EERzw8/lJVNT1pJ17VGE5lV48NvA LoM/+s6fI1Uk
jivl06gj5WrU+Ti8kCKR3Q+qtH7vR1Z88NvQc9yHXfXS+7Ey1vP2d0/c5Tej izu3tzdD9eqb
0dDve++96oAbtfUeznvz5/hEdc9tQRz3fzq74XWHn0Kdj3WJVyEAAQhAAAIQ gAAECk2g8awj
UyUM/nVv+K/v+/++3/vxgS6BGrrPzHKpIzWlvswg1jjq2PpnX3M2evBiYBdx 3N6pc2IuMotF
cO//T/P7/48qkRUfvLAcV9r8Qzmu8/zkHz8OlKFOR2dPO/d+6jT/ffKPpwMR 3OHH7nf/dfL4
3A33vlV9OP6skxNOJFfhuyeDs6/6z7P7umXtuK4c63X/8Xyg1n3di/UkNCJe hQAEIAABCEAA
AhAoLoGnHbFV7bgD5bi7phjNtRdKHd9xDx88vbDHZcVxr8YPnvd3rdL/PWsc 117Lfe477j+7
3vNR//F/nXz3s7/8v1r3nvZ3n3b3Pkre7fjs3yff/duRmipz96rz/c99PwH3 7J5qbeDGfZXj
3tMtK8e92FM5u8G6OnIs68Y6wxIIQAACEIAABCAAgTIQeHKhZsb91/eu496L C642XbNc6ujK
Mn3Y7pMLI4HitK0rMz+udtxfg9J52++f986ed+M5uPf/u3lPIrj/78Pv/uvg +3+d2Wu5z10T
NY+7gQjuP/7n4r5eLteiifu6Gzr5ouW1de8Xfy33VX/52T1VzXJc3YLruMdq 3fDDajnWpdDQ
eBUCEIAABCAAAQhAoGgE7v/sOe7o0XcSze39e1dKEME1zycT/ZLKUnj0nee4 P1+Y4SQ57lFv
1y/7L3q93/vdU6f5y4WZRUEuMtMpCt+5gvvd/xzf/8Uxq/hP3JwEPa+CLv99 cV816y//oaNr
7l9JGsPo7N/te+FXfcfVy/t+HFf+dFsQx/1viePqdf1N6A35Lce6FIyLlyAA AQhAAAIQgAAE
CkhAOe5pc/TjPSnD/9zv/xRk4spzXYzyynOpoyvLWvd/PjMjCjlu+2rceN7b fRYqxy97jmju
617z6UXjYSsuuPf+04ms4v5puWyowdjyV0OVU3t+du9Jb/+jOKvKPRBPDRxX rd6/UJm6Eu5t
39Mtu4573113etWVdXfl+Wi4H+58UseiA6QOBCAAAQhAAAIQgEBBCNz/6Wz8 +nj08+745/vD
J4HODn55bBejuVJHaqr6r49lXTMKcVoxW+9evspxf+3tPo2W/ee9ize97tte 57Xz+GFLshQk
iHvvf46/f3h2/2cnXt9d4rvs/3XCFZKWvzXTKkyd09Y/JG/h517guKo1y3Gf 6pemzouL+/JS
sO744sXFdyK+sf6n9DBhpNSEAAQgAAEIQAACENgiAeW4b0/Gzx6PnzVGR3uT P9W1WjJBWLzI
cnlV6khNVf/tiXJc3wPFaS3H/eTGcSXxIJ9y8b3k4P7fRay1pOX/du/14Jbv 5eIztwP3/k/d
/eGe15nOvf8O/lQvmZpmXZHjn/LqPO1AAAIQgAAEIAABCGyawD1x3Hft8W8H k9/2pcj1ZzLN
glsOvfLycPTyYOwVVUeK1B+/Ew88M9qp4rifTBz30/ixxHGfOBQIQAACEIAA BCAAAQhsnoCK
474/G785nrxpShm9ObGLLA8XVUeKWvj+TMVxfY8Vpw07rsRxf+5SIAABCEAA AhCAAAQgsHkC
939qX7ztjP9wo7mppSVRW1Mm8vwPtZasazr8OBLH3RPH/alLgQAEIAABCEAA AhCAwOYJ3P9P
t/Hs4uK8O/7spJZP3Um4SH1ZS9Y1HRanDeK4Z5/Gey968jIFAhCAAAQgAAEI QAACWyPwU1uC
souVsMGK04rZevMqKMf9DcdF8SEAAQhAAAIQgAAEyk1g/zfLcSWiu/9bf2vC TvwYAhCAAAQg
AAEIQAACeRAQpw1dc7b/qv/9vzv3HrYpEIAABCAAAQhAAAIQKCWBf3fEaQPH PfkwlL9lJObW
ETyBAAQgAAEIQAACEIBACQj8PZ1MpuNv0/F4KjYrTitm6+Xj4rgl2H90EQIQ gAAEIAABCEDA
ELDUVuxWFxyXAwQCEIAABCAAAQhAoIQERG2T7BbHLeG+pMsQgAAEIAABCECg 9gS02pq0BBO7
tZ8Qx639YQIACEAAAhCAAAQgUBICxm6V4PppCThuSfYe3YQABCAAAQhAAAIQ sAn4aQlzw7fk
43LgQAACEIAABCAAAQiUgICK3VqOq6ZNcGdOII5bgp1HFyEAAQhAAAIQgEAp CLQ+9Ju/947f
9U7+6B3/7hy+dfZfdx+/7DReXOz+erH/2hmNJ3kNJLBb+/IyHDcvvrQDAQhA AAIQgAAEIKAJ
3PulvffbxeGbbvNt9/B1d/9V5/FvF41fz3afnd3/pf39zy2R4BxYmdht3G5x 3Bz40gQEIAAB
CEAAAhCAgEXg3s+tWY77U6v1R29FYLPCt1pwyVVYEXEhV3eaO/JotG8L2bto p3RvrceRs8l+
O0fupje70U0OkG1BAAIQgAAENkzgu0fN7x4efPfPg+9+2Ff//nP/Hz/s/+P/ 3CJP/nlw8vsK
n/WR8K2Z/tao7Zocd/i2YdlKXpo1bD9yre3tcMM7qZybK5Hjenu2eaVIb0Q3 o8fSRjZazuOI
XkMAAhCAAASWInD23mm+Ovv+X83Gs/beizP5d/fnk3s/Hn/38HDv2cnxm4vh aLxUw/6FZbbm
6hvzJpb8rjnz7GHnUdtVUffPfMJjOO5CR0KJHHfzXeVYWuhYojIEIAABCEBg SQKPj9qPfz07
eNXZe3Hx4Fn7/k8nEt9dsi1ZLR6+nRHBzTlX4Ur/5mzHbofttxKL9n6Mllid GzNruuHp0C/U
OowXWWiaCseGZ7eQgk737VGz6caD3Zb9DnhGHvnF3B/FbduNSzeb+hftIJac Ul+273Ew4WwD
JHHIaft60f7M2K7ZRGxHeF0N7RG1L1JHHeltuJOapLeu4eyuktyg/6XIQ9V0 7P4kYkzrcMIx
lgww4Viy21yg8+64wp3kd4blz1ysCQEIQAAClSMgKblytZlcdqauOXt+sftM XW225CiXENwc
83G933w9ZbSH4NlG45FOYxCj0ku0Wtm/VjtNs3rIZuKxt7QWZjqu69++5cjW M2zalx7L/LSz
pnQ1QcL8+slDTnfcRBRp/fEl0vr+EE8Uie2IOY67Ext1wm4Nvp9Ih9O6MQOj Pib0lxzTnzSM
8xw3dIxlPJZMm4t23vvipH+1UMcVjrvkmYvVIAABCECgQgQ6nwcHpxe7T1ty 5VnccWV549d2
802nfzvKOOjo5WVpsyisLx93vuP62bSeZfppDJE//QHbv2JHHTdbCxY6S0e8 dZUApf1sbW16
AXdUThlO7gzaWbjDod0+vz9p2w0fPb7jmrTmeXHcGcZsYQw2Eslt1X8q80vF GISWbcf1oube
EWINf67jJmdszzqWjFiHN+rtyhmdNyFh3/IzvlWpBgEIQAACEKgggfG3Seu9 8+BZSwT34mrQ
uxmd/N6LOK5MH3Z22Zciwd0HR+0HR62zjzMnWEgM385NUcj9mrO5jmtUwKtp fszXT7TQJP/Q
n3KdUGILiYdNFsdN3HSCnEWCjqGchMDqVDcCtZo15LTjfJH+pG030XEDJ1vA cf1Rm68gSdMR
JDqu2rOpGGc5rh8WXcBxQ7qZ7Via7bhZOm+OAGS3gudshgQBCEAAAhkISOxW 7Pb4vCtq2/9r
PLgdD76qIn92Pg3aH/on73pnH/vdz0P5UwxYNFcWSjk47Tx+0U6O6f6dkoP7 d/pFZpFQbm7X
nIWESfOI5uN6S/XcC7HL0cKhwQXiuPPhz3Pc1E2nyFla/TTXTIlVp3Z80f5s 3nET47iRYc6M
42ppXpfjZj+WjOO2w4dlhs77u89k8eZzheX8w5kaEIAABCAAgYIQkPCtBG73 Xl4410NttzJn
wvBuMpIynsirumjf7X0ZSbXun67pflTuq3z34+D+05bEgEMjcgV3mevMbM3N zXH9n/79eRXc
X3vVp37YY2QEnhNYCaNXTQnahaKA4TrRCZ5SWkjYlgY2z3FTN53iuKn17RxN u5MLdnjR/tgD
TMDrHTUzd0RCymzsWjT76LPrq+VugvKclNZ4g8mO6118FrqIzT1aEpAmuXJk GrLZx1LWfNxo
5+0E3PB3jIKcdugGBCAAAQhAYL0ERF4l3+DkD8fYrajtWKntdOJN6aX+FNmV 0v9rpDTXN10J
/eqArnM96nweSlaDuLLXXV9wExx3YlrOEM3Nz3Fd0/HnH/AvL4vF6rzuR66p 13PfWtfCP2q4
wd7ESQlCF6sFuQLSgvaVeDhtnuOmbnrej+xqc+GuBlfuR4eQNOS0DqehSM+d CMhHt2uO75jj
uldKeQC9tezrzGY6rvZaO10kw7wK9pQaM+K4Ui0NY3KH49+jsh9LmedViHQ+ MkUDF5yt9zxK
6xCAAAQgUDACWnAlA0EJ7lc3dmvsVqT2bjIcqfBt/9YrYreSqyBBXCkSzdUB XdFcWd35ojT3
4I3MwHChw7emhC44cwXXt+eNO+52+Vtzk223I+7W47HbWKeK1eECMEvoQgaM xew4vYIABCAA
AQhUmIAtuCp8+22i7HPsqq147V8qOUHktXfjPndF1g3cqiwFyVUwviv1xYM9 zX3dOXzTSXZc
X3Dr6bgqrLjtcFowp1hixmr4WC9Ch4v57lsIYzGHQK8gAAEIQAAClSUgk3/J FWY6gusKroqq
yhMVuHV1Vi0fT3QUtn3Z00/Gk6norIRsJRNXshREeSWUK3KsNPevcfd6dPFp KPMtdD71E+K4
+Tmu3GRtdKfKvYft/Vf9kw/D3SfOjvwnz+RvWVrZ/bbSwJJ+vl+pwXquDMZ6 7ndGDQEIQAAC
JSDgfFEmKmFaX3CV40qugvirXFUm/6qMAn/ar+ZbZ+fRoaTbiuCaMhhN5FKz 9vu+2LCOAYvm
SqxXlPfkj969n48lHhy65swS3CXiuEZqh6OpXXDcEhxtdBECEIAABCAAAQhs hoBkKYiMisuK
mLrTJniC6wnrZHr8rieTgqn03Mn08YsLcdzvfzqR56NvU3XDs6dtVfPb1JEM 3Ws115jWXDHm
7vVQ4ruHr4PEXOXKYcHN6rh+sDbitTjuZg4StgIBCEAAAhCAAATKREDu2iAT IPR1EFcitmKu
bgRXC64oqYRyxWIbzy9kTlzx2uZ5VxxXsmxFajt/Du8/aYv1ykvD8VSKrKg0 91Y1JZOO6fl0
W+/7934+GX4dq3kVYoI7x3F9tdXZCKNw4JY4bpkONfoKAQhAAAIQgAAENkag 8Ws4iDt2576V
BNyRl30rfz44Ott9dqYk+Nv07Kovjis3NpPnUiRpQRxXIrgiuAOZe2E8VVeb fZK5dUeiuXKx
mlyLJtm6+y8vJN83MYib7LiithG7xXE3dkywIQhAAAIQgAAEIFBqAsM78deW l4nrpiKoPNob
FX+VjAVJsZUZwUzSrZZamQdXxXHfdnXgVpVv08F4IuHb5rnT/jiQJXLxmfPn UN8aTbIgxHGP
z537T08Sg7hRx01UWy24xHFLfbTReQhAAAIQgAAEILAZAnI3Msk9kAxayStQ mbhu5FVlKYwn
kmAgsdt7T1oiudpubcdtf+z7jjuR8K0UieY2fj27/7Qtz6VBmVBM3SntdiSO e6Yd95cTUecZ
uQoqcJsWvsVxN3NAsBUIQAACEIAABCBQAQJ7v52puzbI1WbufGGSgKsnvpWk AgnKSoqCFNtx
tddKHPfik4rXarvV5fCtI2m7e7915LnYsMyx0LkaSM6DF8d96zR+bbf+cCKO 601SZuwWx63A
UcUQIAABCEAAAhCAwHYJPHjWUnPfyiViruNKNFf+FOXVcyaoyRbcHFwpQWaC 77i24Krn42n3
i5eVK/VFnSVFoftZ7g0hc4r1jt92916cSfKuTLMgt1KTLWq7Hbu35w0iuDju dg8Itg4BCEAA
AhCAAAQqQEDyBzzHVbftVVebOdfiqSoxd+RqbsRuVex2PPnHj025yCzquEFM V60liQqtd72L
j301r8Ifvaa6r29HF5W2+0HdMVgLLo5bgQOJIUAAAhCAAAQgAIECEfAc1501 TBxXz/wleQsS
alWThf3Rsx1X7FZ7rcqsvR3HHffsaiD5u/d/acucDJKlIDm47Q89aar1zhHH PfRL631PxFcC
vThugQ4FugIBCEAAAhCAAAQqQyDkuGPXcf+UC86me79dSJELyGTOBDdLIci7 FbWVOK5ccxbP
VZBbRYgZy5VncusHubxMvFYiuKK5J+fO3suLx795RTJ3T95J6eG4lTmQGAgE IAABCEAAAhAo
EIFIroLruEOJwrYvvThu5MIy7bWtD/0Hv571v/ri608i5l551tXRX8lVOHzd Ofnd0YkKasqF
X9q6PH7ZkbujyUVpOG6BDgW6AgEIQAACEIAABCpD4P6TE++2ZO7dd3Ucd/BV 3coh0W5N7Fam
UJBw7OAudC2auS5N0nklG+HwtCPpCqK58mTv+dn3P7W++8+JFNHcvZcddd9g 8nErcyQxEAhA
AAIQgAAEIFAcAvomZzJfmDJO95ozUV51PZnciXesbtWbdm2ZBGsfPDuTBFzj tZKh2/zdkSUS
xJWpxyQH9+BVR6ZTkDuiyRNx3N1fWgevO/Z0CjhucY4EegIBCEAAAhCAAASq Q+Dg9ELSEvR9
zsRx5WozmVdBbm8m8drjP3r3n7TlGjKZESyceitTK0zFaCX9QHJ2ZXIxrbl7 rzoyme69J213
3rHJ/m8XnuO+7h5IMq7kKvx8Irm5OG51jh5GAgEIQAACEIAABIpJ4OxjTybz 6nwe9v9S0ym4
jqtuvSteKxeQyX3Odp+1JbIbOK65f+94KqFccVx9Mwi5NE1mBJP6orkSxJUp w/ZfXEg+rsRx
JVFBfPfxUfv7/xyr+cKsaXGJ4xbzqKBXEIAABCAAAQhAoNwEJHZ7/5eW3JdB 3e5BNHc0ljm/
5E+5kW9/pK4tu/g8FMFVsyuEbwOhs3WlgpiupDTomXRlOgWZg0yKBG6lSJaC XG2mExUaz9q7
T1ue4Pq3fsBxy3300HsIQAACEIAABCBQWAJyO9/j3x2ZrdZxNbd/M5LnMrGX zliQIrIrV5jd
+7nlhWzlVmS+8sp9ImSyMElpaL51ZKFkKUhp/e5I4NYL4r52g7i/tiVRQeYL w3ELexjQMQhA
AAIQgAAEIFApAs6XoURY5b4MFx8H6vqzLyPv7rvnjlyLpu/QK1m5j19cSDaC hG8lWKsmRvit
o2K3k6nMliAv7Z92xW5VlsJlX+7Zq2ZU8IK4FxLEffys/d1/jt3L2tz79xLH rdQRxGAgAAEI
QAACEIBAIQnI7ApyEzKZyFayFGTOLzFdeSJzfomnyp1+xWuPf1dpuyK78lyS E/SNHnSKggR3
ZYkEgMVxz973RHAlOUFlKViZuBLElT8DwcVxC3kY0CkIQAACEIAABCBQKQL9 29H3Px2L0Uo6
QVsFdPsXV31RXn3FmPwpd4XQ+Qnq5g43I5nd9uC06yUn/K3Ct4Pb0fGbrlxn pgXXXGq29+tZ
42nr3s/hIC6OW6nDh8FAAAIQgAAEIACBohJovXcePGs1X3flrg0yta2Yrsyu IMqrLhp72RHT
lSUSrJVorU66Fa+VMpJ5GP4citHuvzhTObinVgT3pcpSkEvNvvuxKckPoSAu jlvUw4B+QQAC
EIAABCAAgaoRkLlyG0dtFYgV05WY7u+OOK4or/wpC0VhxVm9CRNeK+uV52qh a7dqrTdqLflX
TRbmCq6k4cp8YcGcuCYZF8et2rHDeCAAAQhAAAIQgECBCew+PXnwtKWc9aUb lH2t0mqPz93k
2tdKXsVlteaq8kqprcyfoO1WCa6xYUlREMH96Xj/1UXiRWZ61rCRXe4kKmzK RCLEoSLJEm6R
C9fcMk0s9x6291/1Tz4Md584O/KfPJO/ZWmBmdM1CEAAAhCAAAQgAIG1E5Bo rlwiJrclk0Cs
DtDaFqvvzWuKp7bGgCV8++JMZgoTwZUc3NYfzlhyG2Il6q8RnZU/faO1n/h2 O0tzcdy1Hx9s
AAIQgAAEIAABCJSUwPHv3e/+3ZRrxeSKMZOKIEFcJbsS2X3jF4ns6qQFyWSQ vIUXZ1Jf7mf2
4JfW/Scnnat+YLd3k3FcZO0lSVIbDtwatcVxS3pY0W0IQAACEIAABCCwbQJy eVnj1/a9n44l
IuvFdN28W3FZk6ugvFaWiNpK6u2vbbFb0eLdX05EfIdfxyK1qV6bbrQmcDv8 OomWeYkKkr1A
HHfbBw7bhwAEIAABCEAAAoUn4FwPxXQldUFCs0p2j9qPn500fjl8/PTg8dOm PHeXKLWVLF6x
2+abzkDmXjAB2gwuO/o6MUXMOFYs0/VaS87E1em5OG7hjyk6CAEIQAACEIAA BLZLQGYHkznC
JmruW5k4TK4wk8nFGv953Hy+2357cPyi8eA/e7Jk73n7+G1Hbm82vB3L1GJz ytfxKFaS1NaW
XVdzRXD1FWkpV5vhuNs9WNg6BCAAAQhAAAIQKDyBv6dTLbjfJlLstNqLt8ed t/dHX46757vy
PNlok0TWVtuQ1N6ORY6TixvWVdkLKjDsT7mA4xb+8KGDEIAABCAAAQhAoGAE Eu3Wzawd30mK
7fgs4rjzdFap7QyLnSO47gQLoTnFiOMW7IChOxCAAAQgAAEIQKDoBOKxW19t x34SwtmbII4r
z0OJB5KrkOqso+FtrPw1GkaLH9CNh2+J4xb96KF/EIAABCAAAQhAoGgEInar 1dZOrvXjtZ13
x93fd3WugnLcuLnaSxIsNu611hJXkaPJCcRxi3a00B8IQAACEIAABCBQTALj u0H33b4pnXf7
Xvl9vxMv5/sdv5y9ftC/2pvcOWK6x8/ut140spez073OuSrDm1GoaBUWuxWT tlNvI3bLNWfF
PJjoFQQgAAEIQAACECgIgcm34fBLc/jleIkyujmeyjwHN8eDz4f9q/3+ZSNT udr3t9WMCq6E
b7Xdmlv7JtotjluQo4duQAACEIAABCAAgWISmIwHEoudjHs5lDtn/PVMlHd4 3UwuX47HXy+C
Dd11A8eV8G3EbrXm4rjFPG7oFQQgAAEIQAACECgsgclkMvqr1/n9Qf7l7W7n 7e7F6/u6yPPO
+W58K8pxdXKCTJswno5N+JY4bmEPGjoGAQhAAAIQgAAECk5AJr4d340Gf3b7 i5bP3f7M0vvc
DZVP3V5S0VeVidqaEmQpEMct+NFD9yAAAQhAAAIQgEBZCbiz5MbLRKZfsIt7 F7S0Mv42nVUs
wSWOW9bjhH5DAAIQgAAEIACBMhHAccu0t+grBCAAAQhAAAIQgEAWAimOq27w Sxw3C0DqQAAC
EIAABCAAAQgUjgBx3MLtEjoEAQhAAAIQgAAEILAiARx3RYCsDgEIQAACEIAA BCBQOALVc9yL
dx0KBCAAAQhAAAIQgAAEykjg3sP2/qv+yYfh7hNnR/6TZ/K3LC3c1wg6BAEI QAACEIAABCAA
gWwEUh13fDemQAACEIAABCAAAQhAoIwEcFxUHgIQgAAEIAABCECgagRw3Krt 0TJ+06LPEIAA
BCAAAQhAIF8COC6OCwEIQAACEIAABCBQNQI4btX2aL7fgWgNAhCAAAQgAAEI lJFAVsct45wR
9LliBMwbrGLjYjgQgAAEIAABCKxOICLiCzhuGRWePleGgBz6tuNWZlwMBAIQ gAAEIACB1QnY
nqBbw3HJVSgHARx39fc/LUAAAhCAAASqSgDHTfC5wc2wqvu7SuPCcau0NxkL BCAAAQhAIF8C
OC6OW46obfy4x3HzPRfQGgQgAAEIQKBKBDbnuM6be3PB9S6baWXuujlW2HAc 9/DoxHS++fIs
x4FUuykct9r7l9FBAAIQgAAEViGQs+PGDXV440gRwZ1Ox3M1V1Y3NxxeUXZH n3v9nx4PTo8j
dGSJLJdXZ1Cb7bgX73uzy6L7Qxz38U/7ei0cNzs9HDc7K2pCAAIQgAAE6kYg f8c1kmqedN/c
kyKOq5/MQCxeO/FXs33XNDW4PJTlc3eSK7iN0Y+P5V9bc13BdZf/2JihuXMd dzCZphXR37nd
e3zq7J12919eHDxvi+DqojUXx51Lz1TAcbOzoiYEIAABCECgbgTyd1yRVFPE TTun308nfbvI
kjTKjuu47Xe9kzeO7btGfIdXx1k0d/juQix28vJYijzpP91XS57u2wtlSVo3 sjhu601ndsl+
JNlx3L0n0cBz9nbqVhPHrdseZ7wQgAAEIACB7ATW7riiuRcvv5cyHV3oJzM6 57w/nkymuti+
e/iys390IaY7um5pzZVXZw9ShWwfPpgcNaWMnuzLc/lX/ynP4zkMdmsZHXdG NFf0N/s+sPNx
HzxU0Vzn5XdSsrdQz5o4bj33O6OGAAQgAAEIZCGQs+PakqpVVT/Onn83vT2R f2f3qes6rsRx
W+968aaM/ioDfj8/3jl40uz98GDy5NAuskSWz/HjmXOHSTaC2K1YrPw7TikL OW68MyK4Kn05
XXN3wo8se7p6dXDc6u1TRgQBCEAAAhDIi8DaHVeJqZu9cHb0Xf96Tq6qOK6x Rtt3T86d4zdO
87QrAd2D5xfSpqrpXqQ1u/T+d3f0vw8mPx7oIs9lydy1ssdxx6KiSWUhx9VR 20jRrWbR3LnD
qWqFwjru6vcepAUIQAACEIAABOYSmG04OTuuLal2jFNr7lzH7bw7kbV0HDet Kd1sVsf9b9dx
/7Wvi3Lc/87Tce3kY/t5dsftSoR70ptRpELaLpRgblX9Ncu4iuy48SsvWQIB CEAAAhCAQI4E
4gobkYe8HdeV1LTSlVdnRl7FcUfjqS6270biuNK+enVeEFflKvw/9yc/7NlF luSYq7Dz8Dhe
RHazO66MonP0XbxMR2dSZPncYda2Ao6b45mCpiAAAQhAAALlIrBpx7Ul1dhq SFszOK6O467Y
lBLc7z3BHf73/d739+RfLbvyfLbmZs9VEJ1NvPJsIceNS2rn6XdKcJ8iuLNy UXDccp2M6C0E
IAABCEAgRwKbdtwLKxAbd1x5dU7mxHnLFmJ5rn03Esf1orzpujw87/S+u+cZ 7XfKaGWJsl5r
oSxJ60x2x03bVQs5bnxehYun30mpbYA248Bx3BzPFDQFAQhAAAIQKBeBjTuu JakJjnvemuu4
Q+21572LFZqS+zuIzo7+e1f+tUO2WnOH7vJV7gEhUyvoeRXyclxznzPmx80o uFKtIo572248
ag/XfV65auqpOJpX0+lmtrjuEdE+BCAAAQjUm8CmHffsvCWSmlbk1dkGo1Yf TXQRxzW+qydV
OHjeGY4nbpnKq7Ob0pobz0nQmrvKvXz1dldxXO5zll1kZ9RcyHEbOzuN077X 2nWr8bDVn5fP
vXQnpWMLnHZmGGduMuo0dxrtW99uc2t2gVFSFQIQgAAEIJAvgW04ri+pxlbN kyyOK3VMibeQ
vamlBUVWnJ2rYBx3Hfc5416+2XfcYo778PDwYaN17Sb41s1xRWp3mo45teC4 +Z5laQ0CEIAA
BLZBYPOO2z47n1WyG4wtu4nPsze1aM0sjrtomzPq2/m4OG52sAs6bqv//nDn qZuE7Ttu/1TC
u/rh6q9aLiqs/j583295T3wttmvqRvRasXhwNI5rO6V5rrzTf7i5CsO3QWdU zHU6bD/yN/nW
ymVQLTSb/ksm96B9pDIRlMgGLWuvlSCu9ZBtJfTBjfLygAAEIAABCJSHwKYd N7ugFLnmhh23
yCiK3LeFHVemaXsq8poUx9X6a7RV/tT+Kk9UVkPncOewo13WxIBXclzlnUpP tZJG8nEld/bI
tdPEgKtSWF9JVZZt03Gl1mvNNVr9XElzpB3doNes1PSDu0R2y3NOp6cQgAAE IKAJ4Ljz74UW
1zgct8hqa/q2hON6hhryVD/GKS5rL9cJu3qJ0ln74ftuSkbv/DhutshuquMG Tuwm2l5Zlhxp
2UR29Sq249qBZPdqtCCZgdMnBCAAAQhAoPAEcNxlHLcUhkcnl3Hcu7HkJxye GnMNZ+jOcNxF
rlFbxnHt6KydSxCfciEUc13NcTcwn0PhT5F0EAIQgAAESkoAx8VxK0tgOccd q8SDHZWBYF15
phJzZ8Rx3VVUkoMduF0oV8GPkqr8AWWW/kQHOqPAzpE1S3TY1U4niARlpYLk KoTX1dm3mXMV
TIZDSc9vdBsCEIAABOpLYL2OK61TILBFAol5C4kR7tBkYV6WrUrP9a44e3ro 5STYKQrR7Fsr
q2Gha86s68kaR00v+9afsNYscdRFY+7lb6aOGKu7sCHXnBnfDeUY+BeZ2RHZ 6DVnVl5vKB/X
vjptxzVvHhCAAAQgAIHSEFiv45YGAx2tIoGF4ribTO1YbH7cRXcN14ctSoz6 EIAABCBQRQI4
bhX3KmNyCSzkuKFrxvw/1iS+OC5HKAQgAAEIQGDdBHDcdROm/a0RWMhx16Sz ic2u13G3xpsN
QwACEIAABApEAMct0M6gK/kSwHHz5UlrEIAABCAAgRIRwHFLtLPo6mIEiuy4 W7wOj01DAAIQ
gAAEakJg9o+0cQm+97C9/6p/8mG4+8TZkf/kmfwtSyMNxX+QrQlQhpmFwGK6 ulTtwjruJvMi
2BYEIAABCEAAAmmpg5HlKznuUq7CSlUjsJmEVByXkxoEIAABCEAAAmkEco7j Vk3WGM9SBHBc
zjgQgAAEIAABCGyXwFocd/fnTsVK//e9pWSvpivhuNt9V7N1CEAAAhCAAARw 3Ew6juMuZOs4
LmcWCEAAAhCAAAS2S6AMjis3MnUfvbed3ReD4Wiwv/E4MY6L4273jcrWIQAB CEAAAhBYiMB6
HDdPE+31puOLF77dmpaX2MSiq1j1cVwcd6H3FZUhAAEIQAACENgugcI7rojm dHhiArc47kKy
uaXK5Cps913N1iEAAQhAAAIQWIvjXow8txpe9uS5yjFQkupGZN9KssGw51fw XlIiqx9uyDZI
RZBVrIdkKXiO27U20VUJDPbqbp2La1lkyfHPM1dRfZsOL7tq06o16UaoPnHc hWwZx+XMAgEI
QAACEIDAdgmsxXFDWbOSTXvdU+6on3gG6YqsSrQVDRW/9GU0nk4QCdwmxHFj q7vK64u1ZcxB
40lb9ALGora+Z5OrsJDYWpVx3O2+q9k6BCAAAQhAAALrd1xfYU+u4xeN+ZHd kEvZwVfrIjNt
nHHHDYK4upXhSVrerb1u0hb3L8dqfR3N1QFd//o24rgL6W7xHXfwZZDlbm3U gQAEIAABCECg
IATks3shcd+A43Zcu/VDpyEBNdkL6VMlzI3jzgj9RqZfmJvL607ggOMupLOJ lYvsuMZuF3qf
bKCyPoNsYENr2kTZ+78EFnMsjcaT8hbz0bXoh8cSxIqzSg0P1yzwS42l1J3P sncy1qkYh8hw
9J/ZT1Zrc9zIhWJ2tquZ/EucUj1XubAJqQWRYGo8juttIrb6jDhu2ipeurBO nLByFfxREMdd
SHwL67haSjKeKTZZrZi9yk6g7P3PPlJTUx9Lo7tJZUoNZbeGx22WQ73UWErd +Sx7J2OdinGI
DCe75q7HcX9WsVsrJhpOcg10yUrDNQsj09+mxXHtTdjpCnY+Q2wa3aBXkVVs z/ayhFW6gqmP
41bAcW3BleHc/7F1/6f2ri5P2g+enElpPD0bTKYnVyO7ZDynLF0t7WT04Ojs ux9PzL9Lt7/u
FSt2Ms2Cq3qCa5v6opGSLMQKWyft6G296WQvhR3d0h0r9Zu61J1fepfFV6wY h+U0d12OG7qX
rxevjSa5luh+vzhu2R03EsF9fD6Qsnc+2H83PHg/PHw/PL4cite2P48aTy9E c02RhTmedBY9
DTnXQ9Fc+XetfVil8YqdRrOg0MfScDSudskeKckC7fjdYll0WdrMq07iMSyC a58HZjyXmnn1
pFDtzHhrd988SCzF6X9i5xtHncdSnquy97wrZf+lVw5OHSmHurxxijOQFXtS sfPzEpq7Ccf1
rjaLXciF4y4kjiWqXMBchYjjqiBuShxXQrmiuVqCdVnxLDN79bRzkHht87wr QVxd5HkxTTfe
/97pbv90V/6VslZ022rcc9yv42HVS14BXRHcs8uB/Ou8ubetvTZjuzMcVy5D br9s6SLPE0sd
Hff0QfzzaHB52D19UJD9m7hP98/7zcuRFIlctD5LRGN8dj3uXI+7N2PndtK7 nfRvJ4PRpA6O
u/+0JeXgSJf24XO3vDxrqnJxfKrKSfG+vBXFcUtkY3R1HQQK6LiR90b7+f2M QRqpub6zdurv
pO97zXOneyOBQu9iJnkuS1rve+vrzBItx/vffXrfPqK6R0V0miVGalaJC27r vLP7r8OI78oS
WV4NCV4xoHt8PpDSuRrKv9NxRzR3AdO9bjUetvp341V2WZZ140eyjuOK2jqX jhzS8m+a5ubp
uO8Pd9zH4fu1D3k5LHqtTpLjDq+ORXPlpSwtb6BOfJ/WMI4rnBM/Zdrvur2b Ye9ayqBz2XM+
D7pX/Y6Uy56UC7cU0HHjw5kbqF5LHHcd2kSbJSJQFsdNC8zYyyOO25DPn6fB T5Odpzs7iZ/B
2T6bkwNI73vissPxZDKd2kWWyPJEzc3aq7grmH5m63DkkynS/7588k0cKZNx ZzK6GN+cja7b
OqZr/xv/eFP99x8LfLov1/nl1vLRaccd3I510YIr/5ols5dHqg1u+8f/3Nn5 Z6vrNxir4G1o
Lcs/tR5k2/SimtuUgJlfetej1ru+/CtLxHEH7/eM6cZl1zoSDjvCfKnDcom1 0hy39bxlTrzy
XM4MJ+e94zdO82Xn4Ohs76lakuC4vqqqg9o6XcwTu87hTqN1veyoE78JrHa0 pwlE57QhWASF
+68jQOTJ6Lrla24jPlLrLa6eNk7782hYlr/UYRDvvHO+f+9hc26RapG+2Sco 6bvaR3O/dy3V
5/nNzt5u0kaTQ9pPWycSqVXBWhWvVann56q0z7uiv2dS3jvJjrvksZ2B2Fyk boV4KHfRX0rv
PWzvv+qffBjuPnF25D95Jn/L0vjHW8S69A9bFAiUyHE7VxJhGlxIueyfvVel /a7XknLe06Yb
ddyHh4cP/XOcOqE0VokzJZyFVYqCowX35H1P/pV8XG268qcsl1fjSQuN1Xu1 1Bk55ri700nf
LQP/if4zVMR3ox8h5nuCdCN7EGupPi8hQHZvI4578PxMHFcE1Jiutl69RF6d 46bKMg/3/9k4
/rROl00T6MyOK6NYSHPb7wem9G/GujTfiOM6g8sD+bf75t70tiUl9UiQj1I5 Kpbbxdk+LO1N
pznuyVHbxHHleZZchf6pOoSVoOuQ59Pg+RyDUQd/5soZx7gawDTHvThtRL6B 23/Kq8kjXa0z
i/pfwq9M5/v3/9W8/8OhFHXZsTxPKt24427kx4RFB5hQP7PjymnK+Fv/xr9R bFjppE5kE8sf
2xkP1wzVtum4JQo00tUKELCP9UV/sGgdqVyFLHFcqWm/z8VoJYahgxASxD08 9X5Ldd/8+mFF
YtwzTktivSm/P8a7LXm3kpZgd0wc9+xqYJa4SQvduBkk9kr5nL9xExUL9cc7 J/ZbD/3ey9BS
14p+AEf6L/Ha6aQ3p4x7vdivmaHvCXbkyUZ6Nw4gq48cq89PD1ULSbSj+yW+ lg4WzqZknXm1
4/b/GuuiRVaeaLWV+IeWXVmi9VfXMcWsqJ90XjZ2X/bbT3bkX7XkqrX7z9bx E/VjdVv/acJf
/2x13Fc7etP6ufpXFFlV2v/dDQmrJ34Fn97xld2yqePVl79l69ITr7rZhD9G 0+fsmnt42jPF
xHFliRvHbci/3dN7uqQ67p0ENQ87+mCwP7kTDo/YbynWWpF3X/gQCmJLaY4r 6tY8auuSZnWR
OG7LfAe2P7DnH2MyXuuhpSpYyx1jnENwzKv3Zu5He+J59eD5RZYyx8Dm9Fx2 TQDEO80mnk4j
iCzm8c533uw3fjpp/NiUIp+A6rlbDp+ftd50pago5nl3cHWSfli6x0y8J6Hv J9FD1z0I/d8l
5p+QJYyiKh2+905x3k9bwUiDj5jw4R0+jfsokn8tPO+4iQqzStxxMx/bSUNQ 0OYOLfj1Ju1z
E8etgLwxhEwEVnHck6Nd7bhz47hSM+K4/bRPX31OkfiT/DppPmVNVFLHpcLf U+NnH7m8TOXg
yg9/ftGOGywZT6RO0ik47gTqQ0KfH9WHn+5VpD+2MXjdm7nWzP73Xu5Ox925 RarN/AhxB6Ih
680FML0lXmws0vn46Oze6v1i//ztrZ6BUtxxb0Z9t3iO6z43eQv6Jc9x/Zp6 Ybj0jn94cPxx
1D8/2Pmh1ZFXPyqp3T/X1Tr75rkslwr6X92IWbLjt2CeqDqy7kE7WtNv2d5c sF2vfvuJv2JS
z7NrrtnFB6c9KZ3PQ/lXAreSn9B5+X1ayMp821FHrLG6BMcN9lpCYD7t3WeJ SCS8OsNxZwQs
9UsRx02KxWY7xqJvxtgYEx038XePnI72NMcdjaezi0jwfMed1XOla0HaUurp dNZhkOi46lqr
JyfyAaMvupLSOu/KVVZ7T9sPnl5I2Xve6V1Ff7UO5SrowzJ2YlchD51FnfYR 4Fr7/BOyjpKo
lAD/iTozJ54PrS2aL0UZPmWkk5KHYD5lJSU38RM3nquQ+dhOGoKClja0eVjS v7osGt6SsS+f
q5BJTKgEgZwIrOS4T5XjyueTiY+a55GFJ0/jjqsiuO73bCtzLjHikhh/mhlp 0I4raQmD8UQX
7bj6uSyXV1McN9aryNZNVCwijpGT4+y15jru6GI6rzhZHNfm6cJ2rdcPh9hD sCXYznlIjITF
HTcLpQyOG43jWo4biuPa4hg4qyipq6pxi414atxxjaTaT1xXth4H7cSWQx2Q 6rPs1tj5Mpr7
0rm4HBy8dGbYrVaiQCbswzIlful9Y/RfNVHMxvPjlOhv7BBKj3Xpa87kbGDm VcgYx01IXsp4
jMW/s0WO59kc4nHflY/2RIHYe3o2lgCBzCMuCV2TqcpOPhVN7B5KjvLzjn5J 1Yn/7jzjfJh4
/jQtGMedC2Tm2fXi9EBCtsfP2/IRJE+ktN85J6cdUduWZKldDqTIE/mzfxvK H43u08SB+N8r
Ok+jP+VFDlTvm/ZCJ+T4+TCxD/bCmXFcScOV68xmF6kzJ55tH2De4ef/9jLj 2Jt9nCdiwXFz
siaaKROBVRz32HfcSBw3/jEmNWNxXP0bonVNjPmGGvGtpRy3PxrbRTuuvSTN cRN6Fcpztc4+
cS+MxpD8AGrkjDPTcUVep6O2Krd+Mc9HZ2ah83xmHDf+eRbaqKUpWZzAXCAS H2DiB+e8M6zO
Veh9Gemig7XyRKcoyBMtu3qJvGpqxp90XjywPXT3Ra936UZqdeM62qqf6+X2 q5El5qV4TbuF
yHO7QfVSZ0916KDljy6t80to7v5Lb87RzpE3GV//8lhKlh+FE36jt38ViX+u pymRdyAlmG5a
HDcyr0Ki5kbiuN51Y/ZBu5zjxsc41/XzPtoTHffBT225XGB2kToLOG7a+XOu 4848DOKdPzs9
kKus1HVy+nKr0wuZQ0ACt4dyHeG7vinypyxMOO1H+hP5pq3yoNyv4rO/npm1 FnXcSIB2NceV
qcHMh72YbuIHv9SJ7MTFju208zOOWybPoq/bI7CK4zafPNBBmrlFas4/2Vmn m3m/sYbCA2n5
uJJ+64Zyp1JEcEVz9XMpafm4oSwIrz9JP42lBUKMtSf+oJZyyUWk/93nu/pC ountif9E/2mX
E6k2MwtT/25l/Qrpfyocetdiy2eJHymJfNNID/N4+8UEG4IwQwZKsTiukT+T nxDRwbTldrXm
Dzt7554re0Ybkk4xzgcyl2fIcX0BVX5sW2/EcV1bDRo3lhx3XN3gZWtPDFu9 2mv+4G90pulm
11yRWu21+okUbbf6yrOI5iYHzIKD08268X66tS/9DGcBpYf9oofQvDiunlfh xP3Xex6eV0Et
D08jmnRdTrZjLPo1zJ9mwf5G6ifwhM4zUdkylGLfxme/u2PfFhId996PrSxl Mcf137n+/k3J
VYj+UBNDNDOO2355KOm2sst03q0U56p//8nZ/qmzZ5WDN44snH/aT8J+KNcG 6NNUwnf1DIdB
2lfxpPNh8Gax14pdtpi4E2UeXJksTBc9cVi8SJ3ITlzs2M7ouKsdk+QqbE/B 2PKaCWzIcX/K
4Lju9Wf60bCuf0q+VmbmWdi99YOaV2E4mZqiNVf9mTqvQtJnfOi3y9hMTLFT sB6COkEHv4vN
mb8p5rj3pzfHc0uC4wbxTGtenqAb+qKi4BoUM/GQ12ebefiDJ7pf3FdDa2Wh FHfc65FcSqWL
F7i1lshCL6wbXmhW0U9UaDao4BrtWzdeaxa+PQjAuMtN6Hf354Mgsiv1teNG npiVjQ3rlk1l
6fzPqtLui5YbwdXPe5F+pv2ZUXPPnvSlDK5Gulw8VbPk6hK/7CztR+EgD0Hv a9kj9hxGiSGu
hEBXwiGkP8XT4riReRUST2nxucOsa7/8ucNmvKdStSZhjFEOYSvN/WhPE4iT 549VTsI4uahX
wz/4eH+m/66V0HPr7W9fcxb93T/9MEjYpy8PL945dul9Htz7qf3gqPP9kwtT 5E9ZGHLcUOZP
o/XemrY5HqS3T0GRrw1zD4MZB0PkfJgCMziNp39/k6HJHR/Mwdz93E88sKVO fD8ucGxnddzk
q34TEjyS3qo47po9i+a3R2AVxz38KWscV2qmXR+z+vLE96eeBFd0djSZSlE5 uBMVzZ0xP+7q
PVmuhajjHonjNoNybT23lnfDU1Ust+ltraVzFZzr0UaLyO7PG99ohjEKiqym +1RM1+m/G549
7UtcXxJz5+bmZt3F5vqqRK/KtjDNceX0ZuZVSDvV5XkPiLTe5jHGrDxnfgnX jZwcPZZrziQf
V/37RubH7UpKrs7HVUuOUhw3275Yop9qlRii+D49ed40pXN+Il/2Bp/VpWaP X8odJTu7bpEn
6s+nSdfMrbX/a2s88VPGXHI3+8mS+2JtY4l/HcVxt6dgbHnNBFZx3IOfGpKr kOVxEHbc0Pd5
64/lzgVp709x3JLe56xzdL97tCv/ukU/8f4UtdXP46wSqS6HdN1reY7758hZ f2n9ZMActNa/
uaVHlFFz2096vfOh/JuL3caPmVV2/QzHnXuWWJ/jmuimPeHuQsO0KS20Ylp4 Wy8/dh03rcir
S2xr9ip6IPE6MxDNtR/dmlxe9t2/WpKfsPey+/ilI0/kz8g1Z7kPZ5MNZuSQ pUtFOFFHhjN3
dPEKW55XYTQaHr+UxPBDtxwcS3l5MBonz1E89+xDhQoTWNFxRXMzlixv/uXq zHh/ukkLEl04
00Wex2/9sNxGc1xr7vklx20VpCnPcT8PHYpFIGNAt/WkWDejNgdVouOqmz9l KwU5OHPvRtob
XCx2dsm9J0s0mP3sJEYrgVtRWynxSRWW2HShVsnOoVDdTutM6R1XjFa0rDPq SdF+1rsei+lW
2NUY2nIEVnHcgryZy372KXv/lzgMtON2Pw8pcQLadDOGdZeAv75VangkZ4FZ aiyl7nyWvZOx
TsU4lN5xJXYrxrPzckeK83ks5eJ9T2K6y2kQa1WYAI6b8Ry3vmoVO3tmAeU5 7qdhl5JOoHSy
W8MjOcvRXmospe58lr2TsU7FOFTAcZXONs4PpHTf9zrvHZnBDsetsKouPbRF Hdd87vIEAisS
6HwaUrIQWJEzq0MAAhCYTWC268cVf8v5uCoNV/JxVUquKpKl4D7ZeBz3tt14 1CYLeGkB3cCK
izpuxm+9VIMABCAAAQhAoPgE5kapi+i4okf6foC69G/GizjusP1oZ8fWU9tW s5vr7JrZ25nG
+rOc/S2wxeU2UL61cNzin4DoIQQgAAEIQGBNBErpuOK1Z+fds3eOKu97F+/7 2nHPnu7t/bB7
9nR/lo4pF2w2HzXat36t7TpuvD/LySSOG+OG467prEGzEIAABCAAgeITKKXj ytQKxy/3vXK6
L7kKh/+6J0UEV0R373939Z+Jrjh822i8HTpHO/KvW8ENo+obUL11rOdDqelP 9maE2Gn6i5pv
Va5C+8j7u3llb81uczgV+/RrObE+xfozter78eagBbcnrs6GNx3e4nKWXLm1 cNzin4DoIQQg
AAEIQGBNBIrluNIbEa3Z/+p5FWR6fl3k0XrTFaN1zhvT2323HDjvGimOKy7o auJVM0hXmBvH
lcpHYqfKIwOXdb3T+9NuTZti0KbSYl1NSbNqJ2LDkf4E9f1GZEnTW003m7hp 4rjEcdd585g1
nYBoFgIQgAAEILAmAsVy3CyRRHFcUVvn80gVubX6zUSlKPzvfVHbs9OmPJF/ xXTdpIW9aIMh
9fSjs2mOG0RP3XhqRCJnm7F5NVLN2GqCCgcxWu9SNstorduHNJ3ETeO4OC6O CwEIQAACEICA
T6BYjqsjuLMfxnH1BONyA4i9H+5PPzemVw8kS0GuRlO+e9WYfpY/70eastIP dHKCK5NpyrgT
luA1OG5Cf+IB5ri84rjzDhL9OrkKa/pmTLMQgAAEIACB4hMoluNmURftuL3r 0cXloHM57FyN
3EvNlNeqOK6EbyWOK76bEMcNJxsYm1TxWisZQD+3PFKZqJqHIZarYCZnSNRQ r80ZuQqJ/ZH6
kQCzlb0Qjf5a/bRHkYVjDerguMU/AdFDCEAAAhCAwJoIFMtxM8ZxRc8kRaF7 NeqqjIVx+1zl
4/bOG8N3D4bnqvTOHyTk40ZNNLBJuQTNhHXNc/1ELT9qelPhWtkL+pqzUFJB 2BqDNtOuOUvr
j8i3eehNzMiasBqxR1EDg50/xPU57v7PnV2vON0a/ir0pb//a79fw4EzZAhA AAIQKA+BYjnu
fG2ZTiWOK5m4cp2ZqK1fHDHapsyr8L/3RXAlpjtjXoUsmyhKHe9at6J0p3T9 WKPjGsO7cnZr
aHs4bnlO8WuKjtAsBCAAgeITKJbjZonj9q+d5vM9KWb6MHkuC8XAZGZcSck9 ezJzftzCm5qJ
H8t8DPG5xgrf/QJ1cBOOezc4/tnpus539lqCu25YV/6MRHmDJR3lxOH6/T+6 flS4e/bFXf1X
5/hXFSo+vhqeeU/G9tkkaZXEDgSb88KuWk9nbCLoqumMbln3R7rhdUn+3P9j GPREu75a3V0R
C4QABCAAAQhslUCxHLdAfkRXyk8gF8cd3AztotXN/FKvDE8ro+d/8qpYr3bB sXr19cBe4vpr
pL6lgxIVlvpGE+VP7YszosXBKt5Gkzdngs1BB/yWQ5twlV2fkuJdNd0wcVzV Va9+97Xx+5Dj
RgDyJwQgAAEIQCBnAl+cxMAKjlt+lWMEKQRWd1z9Joy/c4J8XBO8jEik0UQ/ yhsLo1r5rElR
Xi8mGm8/aNnPCfYDw6FNRDw17riRli2j9YPKbljaTkuw1dZrUAm9F73e6pd1 wsYQgAAEIFBb
AoMvvcQP62I5bpZcBYwOAhkJrOi4aYJrx3G9E0qiCHo/3DtdOwobpAr4jmv/ uB95NcEp/Qir
yQeINzh3c7YTRzYRT7Sd47g6CI3pkpsBAQhAAALbJJCoucVy3IzuQjUIZCGw uuOmfSeOzioQ
UsPEXAX/5/tEx/WDrEHmQ2KQ1QRKrc1FV/GMM7Y5P6Ng3iaCzs/Sd5Oi8KV/ /IeOc0uSrp+/
Sz4uIW0IQAACENg4gUEsY6FYjrtEHHd4O+i+d1S5dEa3gyzqQ52aENiS4yZd c6Yya1NSC+7G
Xf+Krv3Xjn9BmH/9VkquQuoq+pwS2ZzODHY7MH8TaYkTJkPX3YTuwP4ffTdX QT93ZZdrzjZ+
Wq/tr5MMHAIQgIBNIJ6uUCzHXci9xG5bLzv7P7bt0j7tjEaY7kIgK1t5fY67 /GlFXyK2MQ3a
8OY2Ni42BAEIQAACEAgTKKLjdj8Njt9240WWz5AvEdzDJ2cRwdV/Np9eLKm5 8duVbVj/tt6B
DY93zZsrjuOasGtel2dZl4V5YVTbm3Pf3OaknFM2BCAAAQhAYCkCRXRcsdtE 1UlbriufPL9I
FFy9UKK5CW3adwtz71/Wvg3X0oqZm2iqW/W6NwHO/Fi0A6arufU5c1fLULE4 josjQgACEIAA
BCCwVgKlcdzJZDLDcfuf+zMEV780vImFgeeK4NwKC4mdaq3ZfBQz6RmNLNqB Resv1P/yV8Zx
13o2oXEIQAACEIBAcQgU1HHFaEOPb+PR12Ga4zZfjrOXkKclG6HTVDFd9Wi+ teK4nqH6L12p
loZvG97fOjobBIYTRFYqN94O5aZl8q9aOd5g8hI7kGz17crauheBduPE7qNx 1FQR6FCX3Huk
uUNuH4VGUX53zToCHLc4px56AgEIQAACEFgrgeI6ru+Z3v+Hf6kkXXEZPdOC /a/8KakIc+O4
F+9i98GN5CooKVSa2HT91ddQXzFVZd9cr0SDm45a4t1c1zmSJyKg/r12E+xZ WnZXl3UD+4w3
GFsSJEuE+2Z7nbR55I4umqugnFgPR+m41HGH7A3Q9CSrIpa+Ho671rMJjUMA AhCAAASKQ6Co
jvttPPk2Ho9H4ztVJIg7vOlvIo4bcVM7HTb0krijyKiOqlpeGxJzf7mty+q5 XtfyUbPwyg0b
eybpVtNL0rJybUc33mw/sfusjTyyZKHk4NIrrvpqZN57S0wgknjTlOK8mekJ BCAAAQhAAAKG
QEEdV0ntX/3hl766TYWU617/T2dGPq5z1Zsbxx1c96OSFo+2Lua4uj3fdGfm wgZZDTqXQNIV
4tK8kOPaceX4pWZxLcZx3fD/OhxXmqVAAAIQgAAEILAtAolmX1DHHVw7vatO 76OUC1Uu5d/O
7HkV0iYO0+57fHSREIVMzihIz1UwUU/9K/9tu6kza1WGgxfWDfIcQtsLpxn4 qwdR29lLvH4m
5VHozUseQpD/EOTdDl3/juYqmFHU7wK19Tlu+WPcjAACEIAABCBQSgJpP8wW 0XGXmx+3f506
tcLBT2eDm1gQV/ZjJB/XpBCkXXMWpCLoPITgCrDgMjJTx04DiNqkn4cQaTDU H0tV7TCt6dvV
VC5fi15hJn1yF86+5sxLh8BxZ863F3/PpOUqLHE3vlKeReg0BCAAAQhAYJ0E RuPFWh+69cvk
uIuNz6ot2Qhyu4dI0oJEcCWXd+k2gxVzN8K5mRI5dJomQgSI43JAQAACEIAA BApLQDvuZDId
fZvKc1FYVe68MribqjJSZfxN1ZQnJXbcJSJkkpt7cd6VmRYu3nV7n3u57Ugc NzeUW2sIx90a
ejYMAQhAAAIQmEdAO64IrmjuWMo3VZTvmjL23Ffbbf9rmR13Hg1eh8ACBMrh uFfNSFa3d8Gi
nh5u6w81cd6ON1dd7p0p+Nj1eHMnkOX7cynIaD7x4SxHLA1L0VDofi43xtzf QTQIgZIT8Bx3
7Aqu67gRu5UKOr6rHbf310T+rUWuQsn3LN1fO4FyOq4/2VyiPazCLItaJbef PlXzKv1x9THs
9wUcux5hrgSy7IjSkEly3OWIZXXcbR8kQT9zPSpWfCuxOgTKSUA7rihsYgTX S13QjnvnOu6N
WqGsjrtEroLerUuvWM6jgl5nIlB8xzXXEaqJl717kcy+t0imgSdXyqJWKc1L P1OmEFm+P2UZ
ux5hngTm7YhykUmI4y5HLAlLEVFY/czzqFj+ncSaECgxAc9x78L5Cd+m3T9H tuAax3W+lNlx
S7yj6HrxCGzHcYPpMrzbgkRvAW1A6fvVRSJ2emJj95ttcK/mt0NrxuXgliLu XZr9GTkiU3wE
3dD30gu1FtpXGTo857M8NBOI6bx6UuixL9LtuTYzZwdZs7Loe4an3mG7GEfF 6sPJcsyEICTm
PGz9DeL2Kq2fc4+K4p0U6REEikUg0XFFcHWJx3Gda5WyQBx3/l4c3g667x1V Lp3R7WD+CtQo
G4FtOG7i7ZTtW0BbEPU0yWHH9W7CrGslBvy0A7liaoV+/efeKknB4OTwYbYO z7kRtLc56Xzz
SKcfOE19x77Q7a8LOHZPxOd3O/utsBN2UGyu6xl32C7EURHeU9HjLdtwZhOz D+D4fOF6+0VA
Mbuf2Y+Ksp086S8ENkMg7rhGcCOaq3MVyu24m2Eqdtt62YlMOiYzM4xGmO5m 9sCGtrIxxzVB
r8bLk+BOH57hhW8BHR56EC1zrzCTsJA39XLccYNo646+I0loQ5E7fdiVzQ2o Ex030o5S0pQO
qzZ1SNh7BKN+O3SO1EvOkXv7aK1EakTFHrsCvki3ZxIITb89YwdFvrok7ZTt HxW6k/YvA2nH
2+zhzCAWeadEiMWOMX3V4/bfIPF+xsa4obMbm4FAJQhoxxV/1ZeaGcGV5aFo rjuDWOkdd+m0
2uwriuCm3SNNZttdUnOTI2RLH4Duz8oFuazeDEJdRxxSnKWHt7EVN+a4wYgS lFG/mG57bhzX
fHgnx3Htz1G9CXtDdjAp/qrpXFbHTerwvHiViuBeubFblRTRdELB6aKO3U2l yNrt+VFJ/90R
3wUR8jN80Xq7bfmoMG/2pYczl1j8i5l9J53ioJjRz3nvi42d69gQBEpKwHPc kZo8wRZcPZdC
oLnVcNwN7KST59HbRtgBXYnmJvQhGhWLqd4MsVh8SIHlLKTOWSqHBxK+isgV a+9sHuRumlCO
ii+W7YS+BcdNup1y+BbQwQHhCpY3t0AQoPKiv24189zaud6dnEO7O36leZCB EPJvP3MgaDlb
h+fnHcqdrh81dBB6+LYpP/2riG/09tdFG7vbw2zdzpJd6t3pW99qO7SDUu/L HU9HKcRRMed4
yzSc7MQ8CLEzWNFQxPs5/32x+PmfNSBQKwK242rN1ZOFefeDuHMvPnNvCUEc d/6B0f+cegdg
Y7rDm1jGwlx9nFthftdMjWVnxsnSh2iU0bpYXr3UlM97+8fo2AdwyebK2Ybj 2j/yptwC2g6s
mu8QQdjeSqU192pWyQDhOzlHdreerVM/9BcV+/uMH4jy7vwsJho1ab1maocz fJZbx23wXSh2
++uijV0pvn/Mz+z2XAJzdpC1O/Q1Z6l32LZ33PaOitWHs7rjho7hbaGIB92t JXOPigVO/FSF
QC0JRBzXCG7CPc8qkKuw1l3cfDnOXkI9SdbH4PPb+9AKorkii55v6Fhp9Ory 4GMsFhIOPmjD
F8LHVgm3mXTV/Myzsxcm9D9rpTUJws1Kd3OJ6Gpr3U05Nr4dx110ADNmQl20 KamvL3jK+bG2
7zYlGLtGuTYCaXuqNGTSBpAfseKiyG+MOb9haQ4CpSFgHFcyExIE17+vr76j rzzKfc1Z9rTa
yA7UK87+VypIKkLkUrP4nxfvYooQyVXwkg4jQVD/10lV2YoMSWzMipmpi3JU 6Mi70D7xl8pA
IgNJja0SbTPpGvy5jhv0RE7Wbp8j2QhxuV+LQq3r3VhOx/W/ES2iqtY0ov6h lRfUtd7PKY9b
WK1x7JrhWglkddyCHRWzj658iRXzIMl3jHm9W2kHAmUjEDiuJCS4ObhBcVMU VJaCK7hVcNy1
7p3sQVypGepJXPUiS4IIbiQPT/8SGr7mJmLMxnd1vMgOlJqtJKwSu45ndift HgZj89U5JNNW
aHnuwNe6w1ZuvByOu/IwaQACEIAABCBQRgLaceUmZ9piZxSZdUEe5b4HxIpx 3Lk72LnqzY3j
Dq770Xbmqt4cx9Xt+VaanPngbTPVcROvOLav1l/Ccf1VrPneVYpFUiDZR0Ic 92689FE69/ik
AgQgAAEIQKA+BMRxdYA2y6N/O5EorzzKeg+ILINcsU7axGHafY+PLhLaT7DS pCuL47FSf27z
8JX1Sde8m61G5oGyLgMKTYMQv2Ldyl7wGrOWpFyMr9MtwmOJT0RlESEfd4zj rvgOZHUIQAAC
EICAS0AcV4K4vb8mkmirZgr7PEwrEsEdT1QmQ4kdd+kIWfYV+9epUysc/HQ2 uIkFcQVnNFXA
v5mqfyF79Jqz4BL3lAvV7QajAVrrQm/rsvrYZfIJV6wHV837b55glv6jpjep atC38HSewftt
xsQOJbvGglwFzqIQgAAEIACBwhKQdFt1qZl7Awgp4rsislImUv4OyvTvqS5S v8SOu5ndINkI
cruHSNKCRHCHiYK7aJ9mpiJkaSx0F4AsK2ysDvPj3o2J427scGNDEIAABCBQ bQL1ctzs4djI
Xl9iRcnNvTjvykwLF++6vc+93A6jlR1XJw+sYQao1YbIfc5cwcVxVzuMWBsC EIAABCDgEaiX
47LbIZAjAXIVcoRJUxCAAAQgAIF8CdTLcZcIx2rcS6+Y796itUIRwHELtTvo DAQgAAEIQMAm
gONmOh5w3EyYalYJx63ZDme4EIAABCBQJgL1ctwy7Rn6WngCOG7hdxEdhAAE IACB+hKol+Mu
HY5dYsXh7aD73lHl0hndDup7iFV35DhudfctI4MABCAAgdITqJfjbmZ3id22 XnYic4fJBAuj
Eaa7mT2woa3guBsCzWYgAAEIQAACixOol+MuEY7VSLOvKIKbdqszmTR3Gc3N YbKwzMfFJreV
uVOFrYjjFnbX0DEIQAACEIBAvRx3A/v75Hn07g92QFeiuQv3YYZ35q6k2RvM XnPhAZdmBRy3
NLuKjkIAAhCAQP0I1Mtxs4djI0dCxhX7n1Nv5GtMd3izYMYCjlvUtyWOW9Q9 Q78gAAEIQAAC
6t683Ms3n+Og+XKcvYQ2aVuseS5PdvzHo/ZQ7k721ixotG+lAfd2Ze6j8VZe 9x+qhWbTf6l5
NZ26bbaPpGLTkVpBy+6foSU7O7KtxP5MnabfneZVyqbzAVmaVnDc0uwqOgoB CEAAAvUjUC/H
zRiOjR8GesXZ/0oFSUWIXGoW//PinSeWYStVFuvppjJaJZRKT7WAuo4bPOS2 t0duI4khXqWw
WoKnU3WD3KbjSq3XmtWykmbVTmxbCY6rpNZvIaVX9Xvz4Lj12+eMGAIQgAAE SkOgXo671t2S
PYgrNUM9iTtltshuquMGTiz+2mhfWZYcaVkbsKmvn89eEnLxtRIteuM4btH3 EP2DAAQgAIEa
E6iX464Yx517nDhXvblx3MF1P9pORss00Vk7nyES4o0Gd3HcuTtt+Qo47vLs WBMCEIAABCCw
ZgL1ctw1w1TNp00cpt33+OgioQ8ql8BLjVX5A16ugpdv4C2xPNivozNr7Zxa P93WiK/kKkTi
ssm5CrFtRfuTlKtgNr0BrIXcBI5byN1CpyAAAQhAAAKKQL0cd91xXAHav06d WuHgp7PBTSyI
6x6H5nqyxlHTyxxQqbTu9WT+EkddNBZaIivqheqaM+O79sVq5iIzO9wbv+Ys tq2E/ljN6sTc
YNN1fSvhuHXd84wbAhCAAARKQKBejruZHSLZCHK7h0jSgkRwhymCm3OvmLk2 Z6CpzeG4myLN
diAAAQhAAAILE6iX424gjmv2gOTmXpx3ZaaFi3fd3ufewntm6RVw3KXRLbgi jrsgMKpDAAIQ
gAAENkegXo67Oa5sqQYEcNwa7GSGCAEIQAACZSVQL8fdZBy3rEcE/c5MAMfN jIqKEIAABCAA
gU0TwHEzEV9ajue2Pr4bl7fMHV21K+C41d6/jA4CEIAABEpNoF6OW8BdVV7B lZ4XkOcmu4Tj
bpI224IABCAAAQgsRKBejrt0OHaJFYe3g+57R5VLZ3Q7SNsrOO5Cx2uhKuO4 hdoddAYCEIAA
BCBgE6iX425m34vdtl52InOHyQQLo1GC6eK4m9kp69gKjrsOqrQJAQhAAAIQ yIVAvRx3iXCs
ppx9RRHctFudyaS5cc2d77jXrcbDVn/dabvvD/UNJg7fj8eZt5jLIVjeRnDc 8u47eg4BCEAA
ApUnUC/H3cDuPHkevfuDHdCVaG6kDys5bmYZnbeVzuFOo3Xt223mZjfAs8ib wHGLvHfoGwQg
AAEI1JxAvRw3ezg2clhkXLH/OfVGvsZ0hzehjIV59jkzqppZRudsRdrZOeyY UHHmZmv+5sFx
a34AMHwIQAACECgygXo57lr3RPPlOHsxPVH2aTulea6803+4uQr9U7PAjbne 9VsPvQqN035g
saqFw0P/JZN70HqqMhGUyAYta6+VIK71kG0l9EFvMVrWyrP4jeO4xd9H9BAC EIAABGpLoF6O
mzEcGz8a9Iqz/5UKkooQudQs/ufFO8duP8VxlXcqPY0YsLZMyZ192kl+yVNY X0lVlu1hx5Va
rzXXaPVzJc2RdrTdeo4rNf3gbkpkt7ZvGz1wHLfmBwDDhwAEIACBIhOol+Ou dU9kD+JKzTlx
3GyR3eSLw0I+6ibavreuWou0bCK7+rI223HtQLJ7NVqQzOAHdNfKs/iN47jF 30f0EAIQgAAE
akugXo67dBw34/HhXPXmxnEH1/35cdy44yrj9KOzdi5BfMqFHB133nwOGbFU tRqOW9U9y7gg
AAEIQKACBEZBRDHTaIZuffvD3c7SHNwMI0mbaTVNtXiFew/b+6/6Jx+Gu0+c HflPnsnfsjTe
dKYub7ZS2sRh2n2Pjy4i3fFSDvwoqcofUGbpT3SgMwrsHFmzxEtLsNIJIkFZ ndUQXldn32bO
VTAZDsk3HN4s2sJtDcct3C6hQxCAAAQgAAGfgHbcyWQ6+jaV56Kwqtx5ZXA3 VWWkyvibqilP
Suy4647jCpr+derUCgc/nQ1uQkFcqa/F3VxP1nh66M2G609Ya5Z01EVj6hHU uRvrheqaMzM3
QijHwL/IzI7IRq85sy56C+Xj2len7bjmzTVnoTMHjsuJFAIQgAAEIFBYAtpx RXBFc8dSvqmi
fNeUsee+2m77X8vsuJvZDZKNILd7iCQtSAR3GBNc47jzZxDLfg+IzDN/rb7R zfAs7FZw3MLu
GjoGAQhAAAIQ8Bx37Aqu67gRu5UKOr6rHbf314Q4bqbDRnJzL867MtPCxbtu 73MvbZ3VRTPa
Ao6baf/kUAnHzQEiTUAAAhCAAATWQ0A7rihsYgTXS13QjnvnOu6NWoF83Nz2 Rv6Omz3iu3LN
3CiUsyEct5z7jV5DAAIQgEAtCHiOexfOT3CjubbgGsd1vpTZcTeQj7voUYPj LkqsOPVx3OLs
C3oCAQhAAAIQiBCIOG73z5HOVTCCK0v0cx3Hda5VykJZ47hZHLdx1JHy+Lkq ey+7UvalnHYP
Tp1DKW9U4TCCQORtsMQEIvFZSPQXnixHKfwhAAEIQAACEJhNwHZc0VldTA6u WVIRx81yNBxe
jqQcX41OPo/an8dn1+POzbh7O+7dTvqjyWA0wXGzYKxDHeK4ddjLjBECEIAA BEpKQDuuxGh1
+NbWXFtwZTYxfc1ZPeK4bhBXxXGfE8ct6YG9iW7juJugzDYgAAEIQAACSxHw HHekJk/Qxait
fmJmzK2C42ZB1D3fG0ympvTHk5PL/sX1yCyRClnaoU7lCeC4ld/FDBACEIAA BMpLIO64tuaa
m0HUKI6rHVfC27r0RuP7T9riuGZJgRz3tt141B4W7egrZq/WQAnHXQNUmoQA BCAAAQjkQyDR
cbXmRu95VoFchSzMOuf7sx1XKiS3I27n3YnMux9Z+zapYo4KmNDUsP3I3Xpu 7us2uFBrulfZ
h2lqZl8ly45cfx0cd/2M2QIEIAABCEBgSQLGccVoTbpCcFNf/76++o6+8qh+ Pu7FG+W4cqcL
KWefh1J0HFcvkSIVUh03iwvmaHJpTeW8iWbzUSPZ1xNBLLr1ResveajnvxqO mz9TWoQABCAA
AQjkRCBw3LvohLgmUUELbhUcNwu09umBcdwHRxciuDKRwtC3XnFcqZDZcZ3m zk7jrZtNoKK8
Yop+nFUvD0K/rkS6ttc+kjBs0wmeq7Bs80q1MXxrIsVB/YRcBd8aE+pLy17v pW/qebROeGzy
qvTTObJG8UiU14tXq16pbcWX2HFcBUE/pH5scxaQo6aXehFgcXubhCLLrlx3 HRx33YRpHwIQ
gAAEILA0Ae24cpMzbbEzisy6II8q3ANCzz+a9m/r5aE4rjzcfxIeUiHVce1c BR3TVbomoiYm
54dCg7ClZ5mqNfP7vq+zWn+12k6vmtFsAVly5HhrxXsTj4zq+rL/jqw23SXB w69jLfK7bTrg
mbrfK+3iyt3DS4JcBaWw3igi/TSbi+YqKCcOnF4PcwaKpY/9lVfEcVdGSAMQ gAAEIACBdREQ
x9UB2iyP/u1EUhrkUdZ7QGQZ5MnLw7kluZ2U39x15NKL5sqattKF8ne92K0X l7VbS1xlRs5r
Wn3ZeiC7lnObbkRyLUI6Ho8ci4w22lf2dW/WkrSs3CBG66f5Rhw3MnA/pJ2A JcvuXGcdHHed
dGkbAhCAAAQgsBIBcVwJ4vb+mkiirZos7PMwrUgEdzxR+Qwldtzsd5Bqven0 rlrybyLdw6OT
4W3sbmdpeaWilWmOm+qUlgobLbYjpmkGqbsbRIXjwWMJrEpc2WkGYeZ4HW/Q Vl6BsmAvuSLo
8+KOGx9CRPoj4q6j4Im6v9Jhn8/KOG4+HGkFAhCAAAQgUBgCVY7jasjGceWJ KYa/OO7jn/aj
mpvsuDohwdXBW19AvaTY4Ed5r+U0mYsZrbLPGXFcnVpgtebVdzcjz5uS+Wqy hH1ntevoiqE0
g1ibXgaF3We7jrc83Ehil7TIBrKblKtgxDrti8Q23hvrc1xpmQIBCEAAAhCA wFYIjO/G8TK4
GUYWptmwqRavcO9he/9V/+TDcPeJsyP/yTP5W5bGm15UbBaK4/avWlIGUj63 hm45eN4+fN46
fH4ijqs1N9QB+1d4N+7ZvrUsVkVzveu9JCk2CIvaeQKzHdfNpvWmJdOXZ0WF z1zd5fl0tL7u
rnFK96/kOoFxmiH6Udsgv8IX0/gSu28WFsmyTdycB2TmNWf1yVVIfGuxEAIQ gAAEIACBLRIo
uuNmd2I7fJs1jpu99fLWjIdRixRY3TDXNcVxt/gGZtMQgAAEIAABCFQ8jjvb lpLzcTdsWFvZ
HI5rYcdxOQ9CAAIQgAAEakKgOnHcrQgkGy0XARy3Juc1hgkBCEAAAhAouuNm z8ctl2zR260Q
wHE55UEAAhCAAARqQgDH3YprsdHtEMBxa3JeY5gQgAAEIJCFwGQ8kTK+G5W3 +EMo4bwK21Eh
tlpRAjhullMedSAAAQhAoCYERBA7l/29o/b9H0/u/7ts5ceTx8/a0n9X00vo uFlyFRpHncdS
nquy97wrZf+lVw5OHSmHuryJ3QOioibHsNII4Lg1OWszTAhAAAIQyEZgJJp4 /Lo7+Doe3Jat
fB1Lz6X/Y3mU0XGz6Nr+eb95OZJycjVqfR61P4/Prsed63H3ZuzcTnq3E7mj 8WA0wXGzwKx2
HRw32ykv+WTBuhCAAAQgUDkCI4ngDu8m079L+Pn/91R6Lv2flNRxaxHHrfGE tRt+S+G4lTs7
o+MQgAAEILAKAeW4g68T+Tie/F2yIn2WnpfYcbM4kHO+P/58LOVY3cZsIv+a PweTqSlSLak1
deta9TD3ns2yyVl13AYXam2G46K/q+6O0Po4Lo4LAQhAAAIQsAi4jnurHLeM D+m567jVzcft
nu9rr+28a8sT+Vf7bvflcf92fP9J++RyMJ5MpVrq/stRJVVTzeYj7968mY4Y HDcTphwq4bic
2SEAAQhAAAIRx+3/NS5proL0vMSOm8VrOm/2W0d7/TcHo/dekeeyRLzWdlyp Ntdxh28bblBX
Hq6kin3uNP1L1Zym+zxaJ9yovNp4O3SOduRf9YqnvF6jzau0JW1VW23O2vrU jzFLb3RrPFYj
gONyZocABCAAAQhEHfdmLIkKeT42co9V6XP/psyOq/NxZ/+rHVeKxG7FbuVf /ecSjhvs4Kvm
zpGSW7FVJaby8JfE61iHhVipK8dSWacrKG31Y7qyUCw5cYmq7Dm0b8b+6gul PeR5hFawLRyX
MzsEIAABCEAg4rg913FV+Ut+i24PvMRcV2n+mpmkG6pv1YwvT6u5WhKw9Lzi cdyL0wNJupVc
EklO0CkK8lwXE8eV51JtbhzXiqT6ObWB7PqqGkRbY3m3wRcXEVY/EhxIqrvw Sh1AflTWWmI3
q4K5bvw4xySKCirrwkPCcTmzQwACEIAABKKO+2U0EY9Suml57SpWuhnHnUx7 X1Q+cZXzcc98
xzVqq+1W0nCl6HxcWSLV5jiuHWEN5FL2t+im04zHZWMCaqUxuOkOkmAQqjPP ceMhWxx3YY+d
tQKOy5kdAhCAAAQgEHXca+W47i3PJv03jcYbuYppMr481E9kiUnjbN1Mxjcq VNd6JssOO+7z
fnKdw0N9Tf9Ow6wlNdXqflqmWm6v6zalu5GlSJ9712V23CyG0355qOO4EceV e0OI4MrdH3Qj
Ui21NZ1aYAmlslXfOOV586hp5dd6UVi7jtuySp/1Eht0bkO4zXlLxICt1XVf QwnBWWBQB8dd
ZRIZ1oUABCAAgVoRUI7o/Dkaf5t45fJw51lXnnee7Rxe+gv1q/qlL0pSvZfk +cN236wbqtNo
fVFr9V83dqSOV7N7KGas6+slqjVvSeeZ/5Ld4Mzn0vOKx3FbruPGHxLKlWKW S7VYHaWVwRVm
bvat97dIrYmqhkUzuU5CXoEftfW//gTpB/ElQZDYf83fut4c15zlIu/EcYle QAACEIAABCJx
3O6n4Wg8Gd3p0j0Q6bwbtB7Kv+6S6/YD4y0P2z35U/41L+nns+tIg3otu5pq UzYhm9NPTAcy
PxlPpOcldtwsZnPyvJmxZGkt5zobubQw5z5XtzkclzM7BCAAAQhAIOK4nauh uKy5l+/ZL43j
d60Hv3TUkk+tBzuN40/ubX7l+T9bXf2vvvGvWTK7zs7hWXzd0K2DO/uu6Z4t cj9h6bP0vMSO
m+U+Z4VWMhy3SLsHx+XMDgEIQAACEIg67seB+GLvZuSVcxVa3Tt3//zY2v2h 1XFf6vz2YEee
W0u8V2fWUWs96fjtdPZMy3pzH1t7v/Xc7faaPzxofnS3uHPQ8l9Nfu6+qhz3 46DEjlskQaIv
pSeA43JmhwAEIAABCEQc9+JyIMkKcv2WX8RED1r+n62fvUyF3Z8PlO9eutar X/WfJ9Qx6Q26
sllLnoReUtarH7svel6bZuuqst8T+7m7demz9LzEjlv6OG7ptbBSA8BxObND AAIQgAAEoo77
YTD8Onb+HJarSJ8vPuC4lfI0BrM8ARyXMzsEIAABCEAg4rhnruPK9VtLFB2C XWLF1VeRPkvP
SxzHXV5nWBMCMQI4Lmd2CEAAAhCAQNRx3yvH7VwNylWU474vs+NmyVWQeXAf S3muyt7zrpT9
l145OHWkyBS5qrzxJsrF/WpLAMflzA4BCEAAAhCwCUgcVEyxfzO6+NgvV5E+ e44rc+jeJcxq
PLgZRpbbGpC4SrzCvYft/Vf9kw/D3SfOjvwnz+RvWRpveh12tX/eb16OpJxc jVqfR+3P47Pr
ced63L0ZO7eT3u2kfzsZjCY47jrgl6tNHJczOwQgAAEIQMAm0Piltf+i037X b/9RtvKuLz1v
PG1PSuS43U+D47fdeJHliUZV+jguN+zdlCnjuJzZIQABCEAAAoaA3DO3c9nf O2pLNLeM5fGz
tvRfRlGaOK7YbaLzpC13zvflPmdzi1RLalbdgFc9zF3NVvUtt8GFWtOOm910 Tc3sq6w6qIqs
j+NyZocABCAAAQjYjiuCKHHQEhfpf9kddzKZpDlu13XcsVXkFr73n7RPLgf2 QqmWamo5yqJq
qtl81GjfZvbCRbe+aP3MHal8RRyXMzsEIAABCECgJgSKmI8rLitGG3p8G4++ DtMct/Mmk+NK
tbmOO3zb8KcidiVVbHKn6V+q5jTd59E64Ubl1cbboXO0I/+qVzzl9VptXqUt seO4sqGgfmxz
fuB5Z6dx1FQBYL0Vfw3VW1eC20fWRitvr9kGiOPW5LzGMCEAAQhAAALFdVxz Fwz9ZPiXStIV
k9EzLdj/5ui4gSldNXeOlC6KrSoxlYe/JF7H8isRUFeOpXJgn35MVxaKJSsf jS0JchWUwnpb
jHib6UA0V0E5sV5FCbF021XeoNsLJU5kk8WS1sJxOeVBAAIQgAAEakKgqI77 bTz5Nh6PR+M7
VSSIO7zpp8VxL04PJFdhMg2KyVWwF0q1uXFcKyDq59QGsuuLaRA0jeXdBlkE 4p1+JDhQTHfh
lZt963XFWpKWlRvfXMRx7dQFHXiOLMFx/R2P49bkvMYwIQABCEAAAgV1XCW1 f/WHX/qDLz1V
rnv9P500xz2zHFfsVtJwpeh8XNtxpdocx7UjrIEmSmBVUhScZjwuG8uLtfIK VOxZpSuE6izu
uIldwnGXDSPjuJzyIAABCEAAAjUhMPjiREa6/flxxWUH107vqtP7KOVClUv5 t5PmuO2XhyaO
K44rU4mJ4MpNH0SExHHNQ6qlqpFOLbB8VNmqH/6U503JfA3ya70orF3HbTmc ZhBr00tgsK3X
ruMtDzeS2CWTJey9mpSrYGK3XKBm7fXVHTf+pbAmZwqGCQEIQAACECgRARUh LeA9IBadH7fl
Oq55iOZKieusVIstNFd3eXkIkn2rH8HlXLJO6MozlaGbUEdXC2UF+FHbILPY vXzNzj3QF7RF
shSsCpJTm7g5vXD2NWdeOgSOm5/jyntb3jBobonOcXQVAhCAAARqSCBRcIXD 9uO4i/4QffK8
mbEs2nIO9eOKiXTmgHXJJlaM4+rThNZcCgQgAAEIQAACBSUQy1LQn+DFclw9 f0KJHzhukXZe
Lo5bwy/EDBkCEIAABCBQAQLFctwiCRJ9KT0BHLcCZyiGAAEIQAACEFiOAI5b epNjAGkEcNzl
TgqsBQEIQAACEKgAgWI57tK5CkuviCBWmACOW4EzFEOAAAQgAAEILEegWI5b Yd9iaJsngOMu
d1JgLQhAAAIQgEAFCBTLcZcOx2ZZUWbSfSzluSp7z7tS9l965eDUkSKT7Kry Rk3wxaMCBHDc
CpyhGAIEIAABCEBgOQLFcty1etX+eb95OZJycjVqfR61P4/Prsed63H3Zuzc Tnq3k/7tZDCa
4Lhr3QubbBzHXe6kwFoQgAAEIACBChAoluNmCccmSlKWFYsYx2X23HU6L45b gTMUQ4AABCAA
AQgsR6BYjrtO4Zk65/tyg7S5Raold0PuxGseRznlMyQ7rrrBb+Th3Vt4NiCM OcxnfY67/2u/
784vPb4bnv3aPbvq7//c2X09MG/C7uvOblBH19xq+dK3+rzVnmyXA1uHAAQg AIHaECiW42YJ
xy4dx+26jju2itwE+P6T9snlwF4o1eKbGL5t7Og78boP5yh4vpKXz7bSRZ11 0fordb0EK6/P
cZXXfnFNUbuj+tc5Di3sFsspcdzanNO3/G0KzhCAAAQKQ6BYjrtWb+q8yeS4 Ui3WDQmsNtq3
scXilF641VVeVzHbR/6iK1XflWP38ag91HViq4SXWxuKOGuwrlcn3HgQ/VVB 30jloG852fla
d1VOja/Pcft/dPf/GCqZuHLUE9cgu/5CCeIe/xGNm8oquxLrVcX1Y3eVMwn3 /ux0tSt7r7oB
YFtJQxqtWji+kuCxfuJ7dnLLpo5XX1aR3gY90ZFmtWlf2QtzYkLUIAABCEAA AisSKJbjrhjH
1aun/bu84ypfjKuhI7kLTSOykr3gaqVeMpXEBpFaa0U39Ju0inJfWe63b3tt yHFjdaKNe5Kt
jDneoN23nAyy+M3k4riRe3N777crR2cmKJ0V0fSUdHAswhooqclnCOcG6HVd qfUk9U5WtIQ1
zXG1icrq5omSVHej2k3Npk1rUtmIbGC0Xv3ua6PXIcct6O3Ib4Z0DAIQgAAE IJBA4IuTaMPF
cty1atPF6YHkKkymQTG5CvZCqRbtRmIOQERGRVIT9FRJbZDkkLZKEHPVMd4U 3w2l6HrGbGdQ
6EByOCrsN1jLNIbVHVe/kZLeOdosJT7qa6JrkCoNV/tlPDdgbqQ24qkmnTci zaZly2j9CLEb
FY7HgI3+qk0on/aCx0RtIQABCEAAAuUnMPjSS/ywLpbjLh3HzSLHZ5bjit1K Gq4UnY9rO65U
i7UmqhrLVcjkuF76rme6MxxXu2nkkRrTtetZGm07bqRBHPddZ/ZPHvF3Qrrg qqBp97V7qZm+
zsz2TpN7YF9zZucDxAO9JtoaSvD1w8BzHTdycdscx9VBZUyXC+8gAAEIQKA6 BBI1t1iOm0VV
l67Tfnlo4rjiuDKVmAiu3PRBGhTHNQ+pFt9E0jVnaYkH7traKW/bTUmNVQ+d 0TsjV8FPcrC3
Hc1VCNeJNq6TfXUMONiQ1x6Ou5TjztJilTMQTjCwvwpH4rjWnyodNpKNoIwz dhGbn4EQrR+J
49p5DnYkOPJcSbYXcj7WmcR6RgidGUw+bvnDGCtmrbE6BCAAgbITGMQyForl uGuN47ZcxzUP
0VwpcZ2VaokaHVzgJb//67nD0i4gM47ruqZ+eJN/zb/mzL86LWjE746d0uBl 8YYbVxM++NuK
VMZxc3fceCLsDMf10xjUVV+vHX8qBith1zVmr7hxWXNlWLR+1HEzXK/mdkzn Uez/0XdzFfRz
V3ZxXAQXAhCAAATKTyCerlAsx106RptlxZPnzYwlS2vUKT6BFfNxUzJx1/zL jn81W9m/T9N/
CEAAAhCAwCYJFN1x1xrHLb6T0cN8CZTIca2Lxrwg6ybPC2wLAhCAAAQgUHYC RXfcfBWH1mpO
oESOW/YzC/2HAAQgAAEIbJdA0R2XOG7NrTTf4eO42z3dsHUIQAACEIDAxgjg uPlKFK0VmgCO
u7EzCxuCAAQgAAEIbJdA0R230MZE58pGAMfd7umGrUMAAhCAAAQ2RqDojkuu Qtk0stD9xXE3
dmZhQxCAAAQgAIHtEii64y5kTJ0bZ//dsSknV2cLrU7lyhNYk+NKsxQIQAAC EIAABLZFIFGm
i+64S8RxxXHvvXzcGw0qb2wMcFEC63PcRXtCfQhAAAIQgAAEciGQdmeHojvu EoNf0HHlnrru
vcHcG+2q2+2aTabdCcwsr+WtwpbYI8VZBcctzr6gJxCAAAQgAIEIgdF4MSRD t35ZHXeVOO7o
6FiXye1w/OZMnsi/yfC0rWZ03LkSvNgOovbmCOC4m2PNliAAAQhAAAILEtCO O5lMR9+m8lwU
VpU7rwzupqqMVBl/UzXlSYkdd0E4qrodxx0+fGy8dvjkMLW1GY7rvtQ+cmO9 OzvNq+nUU2E/
ALyz03gbBH+X6DCrbIwAjrsx1GwIAhCAAAQgsCgB7bgiuKK5YynfVFG+a8rY c19tt/2vZXZc
Hced/W+EYP6Oq9VWHlfNUEoDuQqLHrzbro/jLr8H5qbuLNR0vu+dfPu20EAW qiwnEPNV2V4x
XxoLdYnKEIAABIpEwHPcsSu4ruNG7FYq6PiudtzeXxNtiaW85iwj+YP3J+3P F7py/o5rknQj
4V4+mTLunsJU24LjykHi/Qbg/w6wHI3NH2yRvPN4B+y3w6JJ6ksPJ3HFNTnu ooOas2ed5k6j
fZtUaWka0ljiARYsbDrxCnrJkWO64sjvVPalCKE+WlcseMvdJZGzYvCSGWO4 Wnzciblh4d7K
j2Q+sdhGg7dVU40kjUP8Eou04YdacNuMPoLf7szGG0dN+w2uOvxWvsmY1dVO b+hLPqzHrJ/+
VjkY4l1WX6vsziSOK+XAtYD4HZbhBEP3do3/zU3VWejQWqVvQZedZrCLTff8 YSYMwVvTO+YX
6vByp27WWpCAdlxR2MQIrpe6oB33TtXs3agVyuq4WfJxZcowmUjhwZsDTfL+ 6b78qZ/nlavg
5SLguAserEWrvh3HtW3A/CZQNDQZFWTpapEVl/4g34rj5rKz1KdpimEsTUM6 Zq/rfmB7Pzol
CnpwBms2H/n6qBaKh1mX287ey6q+tfpUzM9uym8nWi3WaJrjJvYk0pq9buTn Nc0klFfmb3r2
8ONtpu33CPNYh8WftBQO3za83RHZUzOOqFUOhqRmkzuT5ZC+avqdN1/P5En4 GA55qj4aFzi0
lu+b/nx/636/8PlLa7rDarn+CpcwBLVYbVe+nHgX4SzQ4SzYqLMiAc9x78L5 Cd+m3T9HtuAa
x3W+jGWLZXXcjLDEayV869z2z667IrhmZlzJwRXNlUYmn/uj03Zqa/osOQ0F Wrz3Sfx0Zn94
pH1oZew31TZLYMuOa3/OBQEG7zPDO1+bU7YdVYpfEOlxC8IqXqa4nzfuRbbU 542OH3shKD+h
3FvupZibTwtVV/uKlW4e+jDQG3Dr2F/5vDeFnaTuSLQv9hlp24bpg2VIdv81 rtCScBJ8BFGo
vtXD+PLQEu8zMuCfRiDeH3fUoWT91OPZCoA9ajv6szlC0t4L+mM7GGBKANg+ ovSm42obUTf5
7HeXSB+0hykzeBueUiY+CqsRASUrGjtRx4rflCiFiVDGq0VbXcRxo62F1nXF K0tr1hGbMPx4
m2l7c57jClQVs7/KNlFPaCvR9517dIVHF/oAso6iWcee1RlPQ2OnhfjhFzRo vsZEHdc5Ch+Z
Cx9aYVCpfVNvH+/QUm8Ka6PBvrD6lvA9Ifgm5h2usw+GzX4wsTWbQKLjiuDq Eo/jOtcqZaGs
jpsljqvpiN2K5jYv2/LE8JrcDEbPT4b/2hfBldkVYkeS+eCJf8r63w5nOK77 8aA+8LnmrCTv
0e07rvrwE6lVB14o5KBO3J7sOkehCiGVjH0cBlGi5DbdA1vFWvwnWpfNh0Qk DCPtyxIdAonY
krWW0kGj3bbpRpTLNGWemP7HW4v3P2GJHbYMGPpdjX3IeUOIf/jF17XIphFI JhxO1lfN2L/n
agXxf0yPRyj1tgzD6DFg/eSaFmeNfpz7g00wofCXE30oRnbffKvzXcGLC7gr +MRMIM39jmQd
conNBgbvC793cJpfw02ILtZa2LkTZn60R2cfdcHXxdjw423OpxHNkTAxRfcr U4L/WR9C844T
l080Kh+8xWYrXfhMYXfGvPUSTgv2KchqIeSR/pcz9akXGoJ1QfYCh1YIVFrf 9KjVu8P60UB3
MNFxvdNswhCC72OhI3+BDpfks67E3Yw7rhHciObqXIVyO26JdxRdLx6BjTmu CQo2Xp6EfwWO
xZy8c7f+tEhymjQLichN5MuYHfuJ22oog80PeRq1MEFE+0la+zMc1/+ksdTH PyZm9NZ8nsXr
xM3b/pyLOpMlcJY1ZYiKxb7fxneB3muRHi70c79NO3Dx8DEQ6bb1hppzgM0F 5XZVf0W31CT9
HRs5hDyVNw6nfUv8I34Ah34cC20g8QCOKnvcY+Ydrt425gd3o8O3j5+FdmVi ZWOQEcOee1ZM
QB3LSIl/GQj/ohgcHjr+Yncm3n7i4Rf0M3EP6oVhz7beETMOraX6pnqjV4xG lDI5rhlCLKP6
h/0Hi74X5u5BKqxGQDuu+Ku+1MwIriwPRXPdGcRK77jZ47irUWXtWhDYmOMG NOd+kHuOq9fw
TdcOkm3AceVHVRNzSvsIXMZx3d/Br6K/b6qBrslxI7aRhi4R79IE9K4LfdaG 5DQax1V7PJzA
GjpI/GMg0fbib9O0rzqJqhSJbppjb+62/ApWRkfoJyz1m7UcRf51bGnVQt2f +9bwaye0Fu9w
ltYix0Nk+HMhJNpq8lruMW8fZpFjPniz24dKON4feY+kXfo8/8wd7kyq44ZP QV6zaV9RdDzV
fmu7Sz756RlZD61F+uZe3JbJcaNvqKRUn9kHw3yq1FgXAc9xR2ryBFtw9VwK geZWw3HXRZF2
a0lg245rfiJPyFVoehkv5sMjRYMCJ1YxiTm5CnMjsrHrdbw8BP2RbP/Ibn1s hFLV0z4qjPnZ
H0tJn3z+BSIxJmm5Cl7IKvj09ftsZSCEvDO23M68j3lwKoHEXIXk6QWS3l1J 0hnJ+ogdA/b+
TXnHxvx41jVn8cuzooKeshVP18KHXCRdIbieMr2a3XwWK1X1k1qb47j2Gy3w m4RLLOzh5+e4
/qVm4Z5nbD/RDoN3vRvO9K4eyXB4BNe9+Z1Jc9zbdvjw02eAsB2aS7j8/gRp 2XrJ3O8e4eMr
CmqWf2ufjjm3tcWEa87iQ4h8UVmww7X82Nz0oG3H1ZqrJwvz7gdx51585t4S gjjupvcN2ys4
ge04bhCpCV8q4S3XP+8GmW1eoMKfkUfVsq85sz7t7PmSUq458y9dimQdBF0y GXh+mp2+wszd
kV66ubnmLDGZIeaI4ST1cP6c/fkdac2zaiuBNXGJnQRvJi0yfVbth5M7oxdv +XkIEbx+sypQ
lEYg3p+0SFvi2yD8Yax7aV3cra95tZMdw7meM/Jx4wdYwCEyd1hKZnCqfpku ha/h8wZoC0f4
Z+tQb1NigWmOGwqCx67cSrycK7RrFNdgjrbIIaFrZoz3p53OIvs90mGZO8z+ 5pOYgDTzRBl6
3/k1g5/40472xDYjP1nMSGGKHX7J4XN/sP63a/Prf+IRkkTb9HPBvgWz1PtI 7R66r5rDNXYh
r3672VfOxE5cXr8yfhUp+EddmbsXcVwjuAn3PKt5rkLzTU8d9ac7Zd7d9D1P Altw3NW7H79g
a8U2N3kSj/xcu2LP17F67njX0UnahAAEIFAPAsZxJTMhQXD9+/rqO/oqxyv1 vApL71MR3M7n
odLccQfNXRpjxVYskePqWI77WGTa9iw7bIOOm3C1WZYerr/OGvGuv/Nr20IQ SDYB5eSbVizT
g7U2vkyHMqxTxj5nGBZVIFBgAoHjSkKCm4MbFDdFQWUpuIJbBcdd6Jqz/dO+ KSK4nuNOBtPJ
QDQX0y3wUb2hrpXIcTdEhM1AAAIQgAAECkNAO67c5Exb7Iwisy6oOG4d7gGh 987jI8cU7bjy
p8RxpXSOdqQUZifSke0QwHG3w52tQgACEIAABDIQEMfVAdosj/7tRKK88qj+ PSAiOMRujeNu
0243+LtwlgOi5nVw3JofAAwfAhCAAASKTEAcV4K4vb8mkmirZgr7PEwrEsEd T1QmQ4kdN/ue
6Nw4cp8zU2RFFcSdTucJrn9ZaPx2qWl6Gp/fxPTSvoZ3xs2N5o5qjhnHJrLO eK+12gs3jjv3
0KMCBCAAAQhAYFsEJN1WXWrm3gBCiviuiKyUiZS/gzL9e6qL1C+x4y6Ujyvj FMe99/JxbzRY
bPckTiMy1whnT62XNhXlYj2bWXtuDyNrL1o/x64Woykctxj7gV5AAAIQgAAE EgjUy3EXPQTy
d1zXC9v+Re7WfS+DYGow615IIq2bSSbOoxmfuNGOB/tx5dCmZztr0KA3PWQw faCarzGpw4vy
LXl9HLfkO5DuQwACEIBAlQnUy3F1HHf2v/beNo47OjrWZXI7HL85kyfyb+px MSOO64pjMPt0
ZDb+xLnE3c1E7mAUzDru+a5176UZc5JHNj3LcWNzsKuemxn+U+Z+r/I7JWFs OG7NdjjDhQAE
IACBMhGol+MuumfsOO7w4WPjtcMnh7Oamu24aTcKT3TTGfeC0j2Ib8tvJ3on m8Torz2MWbfb
0bc9DM+uSq7Cu874bqxL2mWYMyoMbobmVfvJohk1ix7V1IcABCAAAQjUgUC9 HHdRe9i+4869
S6QWzchtDDOuNSOOm+qvluniuDhuHc6RjBECEIAABMpJoF6Om2UfHbw/aX++ 0DWXdFzPOEP3
VVdRVZmZIR5MtedViNyDalbWgXUHbWW01rZmrBUJIc9wXDdq699D3AsYN73b c0smrn8z8dxv
mpVlDxWmDrkKhdkVdAQCEIAABCAQJVAvx50bx5Upw2QihQdvDjSn+6f78qd+ niFXwdyq0btI
SxltYrKBbjGWZqDvCJpyzZm1ik7PdR+No6aXmytiHdmW2dfp+QyhwyEix9HO BzeiND2Mdrhm
7y8ct2Y7nOFCAAIQgECZCNTLcbPsGfFaCd86t/2z664I7smVd22Z5OCK5koL k8/90Wk7S1Pb
qSOy607ly2PdBHDcdROmfQhAAAIQgMDSBOrluHPjuJqj2K1obvOyLU8M2cnN YPT8ZPivfRFc
mV1haeJrWlGHVN2Hl8awpg3RrCGA43IwQAACEIAABApLoF6OW9jdQMfKSADH LeNeo88QgAAE
IFATAvVy3Ixx3Jrse4a5IgEcd0WArA4BCEAAAhBYHwEcd31sabniBHDciu9g hgcBCEAAAmUm
UC/HXXpP7f/wYOl1WbGqBHDcqu5ZxgUBCEAAAhUgUC/HXTRXYXzbHVy2O0f7 Z0f78q88lyUV
2OsMIRcCOG4uGGkEAhCAAAQgsA4C9XLchQiKzorXTqc9eSKOK08mI0eWoLkL YaxwZRy3wjuX
oUEAAhCAQNkJ1Mtxs8dxbcGV8K04rgju6Lqjw7p11Nza37k3/lbHcct++qP/ EIAABCBQYQL1
ctzsO1JcVkdw5Ynzpnn8r4YW3N75Sffloftq8sPcgSx6xzJ/9lpzk7BozRm3 GSvCrLc4bmyH
47jZ31DUhAAEIAABCGyYQL0cN3scVwdrteDKc3FcLbjOy0P5081hSHgobX3U 9u8PoW5+6xqt
PPHv7ivP3ZuQhWsO20dmLb/Zojll0fqz4TdK0uZw3ALsBLoAAQhAAAIQSAk7 3k1H4+nom1fG
36bjiSoTKX8HZfr3VBdxYnnYH+7ju7Epg5uh/ac8T6tpqsUr3HvY3n/VP/kw 3H3i7Mh/8kz+
lqXxpte0V2UWBUlO0EXs1i5medJMC7bLul3zvFCWR+49FqsZVE53XLe1trqf mWrNCgO7Aq1e
bTYfuSHfq2Hbe+J3w4sim5quUssqXsekvttDtcS6WZq9ReO4cq/gQNnXtAfK 0SyOW479RC8h
AAEIQKCWBOoYx9XR3LR/9WGgrzZT15mNndFNRzTXTl1IjuMmRDo9u/VutOtG cC33DR9xc3MV
XAFtXsWOU5FOaVm96iqscVB5ooLKlmGHnVssuXnUdBt0ml5Nr30l0F6b/hb1 uoEW1/LtEh40
jstBAAEIQAACECgsgXo5bvbdIJkJeqaw4ecLeSKOa6cuJOfjpjuut11lnzue O3opDV7AVclo
3HGDtIckMw5irjuh1U07gZX6ucB+Xq9zpGzYOWo6Uke7rP7XbFG7bHSJF0LO jrHaNXHcau9f
RgcBCEAAAqUmgOMm7z49r8Lw6qz/ruWcNiVFweTmps+rkJarYG9CR1XDNY2M 2lIbN+aocfo5
vpHV444bcWU3z6F5pWO3bpbClRvNneu4j9qOju/ycAnguBwIEIAABCAAgcIS wHFTd43WXJlF
Qd8DQl98NnvisORrznSUVD98jwzVXM5xfXP1moqobbAtdelbNMPhtt181NAz PAzfNiVjQSU5
KPOO5SrYkV33ueRdmKkhCntYb6ZjOO5mOLMVCEAAAhCAwBIEcNxZ0Ja4z5k9 I5hvln5CgkoV
MBMs2BeNuda4YK6Cl+MrLR41vUxZ7aOJsmuyFTxntQLJXtqur+Cxa868aSKC 7pn5IpY43iq1
Co5bqd3JYCAAAQhAoFoEcNxM+zNpFoVMK1KpwgRw3ArvXIYGAQhAAAJlJ4Dj ln0P0v+tEcBx
t4aeDUMAAhCAAATmEcBx5xHidQikEMBxOTQgAAEIQAAChSWA4xZ219CxohPA cYu+h+gfBCAA
AQjUmACOW+Odz9BXI4DjrsaPtSEAAQhAAAJrJIDjrhEuTVebAI5b7f3L6CAA AQhAoNQEcNxS
7z46v00COO426bNtCEAAAhCAwEwCOC4HCASWJIDjLgmO1SAAAQhAAALrJzAa L7aNoVvf/nAf
341NGdwM7T/leVpNUy1e4d7D9v6r/smH4e4TZ0f+k2fytyyNN71Y36kNgVwJ 4Li54qQxCEAA
AhCAQJ4EtONOJtPRt6k8F4VV5c4rg7upKiNVxt9UTXmC4+a5A2irvARw3PLu O3oOAQhAAAKV
J6AdVwRXNHcs5ZsqyndNGXvuq+22/xXHrfxBwQCzEcBxs3GiFgQgAAEIQGAL BDzHHbuC6zpu
xG6lgo7vasft/TUhjruF/cQmC0gAxy3gTqFLEIAABCAAAU1AO64obGIE10td 0I575zrujVqB
fFyOHwiE3gZLJJ7Hs9d1xrk0BVwIQAACEIAABFYk4DnuXTg/wY3m2oJrHNf5 guOuiJzVq0KA
OG5V9iTjgAAEIACBChKIOG73z5HOVTCCK0v0cx3Hda5VygJx3AoeCgxpUQI4 7qLEqA8BCEAA
AhDYGAHbcUVndTE5uGYJjruxPcKGSkMAxy3NrqKjEIAABCBQPwLacSVGq8O3 tubagiuzielr
zojj1u8YYcQpBHBcDg0IQAACEIBAYQl4jjtSF5/pYtRWPzEz5uK4hd2JdGw7 BHDc7XBnqxCA
AAQgAIEMBOKOa2uuuRkEcdwMLKlSMwI4bs12OMOFAAQgAIEyEUh0XK250Xue katQph1LX9dP
AMddP2O2AAEIQAACEFiSgHFcMVqTrhDc1Ne/r6++o688yMddEjSrVY8Ajlu9 fcqIIAABCECg
MgQCx72LTohrEhW04OK4ldnpDCQfAjhuPhxpBQIQgAAEILAGAtpx5SZn2mJn FJl1QcVxuQfE
GvYCTZaSAI5byt1GpyEAAQhAoB4ExHF1gDbLo387kZQGeXAPiCy4qFNxAjhu xXcww4MABCAA
gTITEMeVIG7vr4kk2qrJwj4P04pEcMcTlc+A45Z5h9P3/AjguPmxpCUIQAAC EIBAIQgQxy3E
bqAT2yWwPseVlikQgAAEIAABCGyFwPhuHC+Dm2FkYZoNm2rxCvcetvdf9U8+ DHefODvynzyT
v2VpvOntKg5brzmBNTlu4luLhRCAAAQgAAEIbJEAjltz66vX8HHcLZ5r2DQE IAABCEBgkwRw
3HpJXs1Hi+Nu8uTCtiAAAQhAAAJbJIDj1tz66jV8HHeL5xo2DQEIQAACENgk ARy3XpJX89Hi
uJs8ubAtCEAAAhCAwBYJ4Lg1t756DR/H3eK5hk1DAAIQgEDRCEzGEynju1F5 iz8E5lWol9Ex
2igBHLdop1f6AwEIQAACWyQggti57O8dte//eHL/32UrP548ftaW/ruajuNi ffUmgONu8UzK
piEAAQhAoHgERqKJx6+7g6/jwW3Zytex9Fz6P5YHjltvwWP0oVtaLzERdDyz p3hnq+T3Of2E
AAQgAAEIJBEYSQR3eDeZ/l1CSfh7Kj2X/k9w3BLuPbqcMwHiuJziIQABCEAA AhYB5biDrxP5
uJ38XbIifZae47g5qxLNlZQAjsuZHQIQgAAEIBB13FvluGV8DG6145KPW8a9 R59zJYDjcmaH
AAQgAAEIRBy3/9e4pLkK0nMcN1dRorHSEsBxObNDAAIQgAAEoo57M5ZEhTwf t+3Go/bQbjG+
ZOXtSZ/7NzjuyhxpoBoEcFzO7BCAAAQgAIGI4/Zcx1XlL+WmAy8xd9h+1Gj/ NTNJN1Tfqhlf
nlZztSRg6Tlx3GoYGqNYlQCOy5kdAhCAAAQgEHXcL6PJRBuq5bWrWOlmHHcy 7X1R18yRj7uq
HrF+BQjguJzZIQABCEAAAlHHvVaO697ybNJ/02i8Gajnl4f6iSzZ8R6N1s1k fKNiva1nsuiw
4z7vJ9c5PHykVwvWkppqdbs1e123Kd2NLEX63LvGcStgZwwhDwI4Lmd2CEAA AhCAQMRxnT9H
428Tr1we7jzryvPOs53DS3+hflW/9EVJqveSPH/Y7pt1Q3UarS9qrf7rxo7U 8Wp2D8WMdX29
RLXmLek881+yG5z5XHpOHDcPP6KN8hPAcTmzQwACEIAABCKO2/00HI0noztd ugcinXeD1kP5
111y3X7gB3LFVnvyp/xrXtLPZ9eRBvVadjXVpmxCNqefmA5kfjKeSM9x3PLb GSPIgwCOy5kd
AhCAAAQgEHHcztVQXNbcy/fsl8bxu9aDXzpqyafWg53G8Sf3Nr/y/J+trv5X 3/jXLJldZ+fw
LL5u6NbBnX3XdM8WuZ+w9Fl6juPm4Ue0UX4COC5ndghAAAIQgEDUcT8OxBd7 NyOvnKvQ6t65
++fH1u4PrY77Uue3Bzvy3FrivTqzjlrrScdvp7NnWtab+9ja+63nbrfX/OFB 86O7xZ2Dlv9q
8nP3VeW4Hwc4bvntjBHkQQDH5cwOAQhAAAIQiDjuxeVAkhXk+i2/iIketPw/ Wz97mQq7Px8o
3710rVe/6j9PqGPSG3Rls5Y8Cb2krFc/dl/0vDbN1lVlvyf2c3fr0mfpOY6b hx/RRvkJ4Lic
2SEAAQhAAAJRx/0wGH4dO38Oy1WkzxcfcNzyyxkjyIUAjsuZHQIQgAAEIBBx 3DPXceX6ra0U
E9XVT7L3QfosPSeOm4sg0UjpCeC4nNkhAAEIQAACUcd9rxy3czUoV1GO+x7H Lb2bMYB8COC4
nNkhAAEIQAACNgGJg4op9m9GFx/75SrSZ89xZQ7du3G8DG6GkYW2BiSuEq9w 72F7/1X/5MNw
94mzI//JM/lblsabzkdVaAUCSxHAcTmzQwACEIAABGwCjV9a+y867Xf99h9l K+/60vPG0/YE
x11KilipUgRwXM7sEIAABCAAAUNA7pnbuezvHbUlmlvG8vhZW/ovoyCOWyld YzBLEMBxObND
AAIQgAAEbMcVQZQ4aImL9B/HXUKJWKViBHBczuwQgAAEIACBmhAgH7diFsdw ZhHAcWtyXmOY
EIAABCAAARwXKawRARyXUx4EIAABCECgJgRw3BoZHkPFcWtyXmOYEIAABCAA ARwX8asRARyX
Ux4EIAABCECgJgQGX5zISJkft0bOV7ehru648S+FNTlTMEwIQAACEIBAiQgM vvSI49ZN82o9
3hUdV97b8oZBc0t0jqOrEIAABCBQQwKJgisciOPW2gKrPfjVHddorpZdCgQg AAEIQAAChSMQ
y1LQoo/jVlvzaj26XBy3hl+IGTIEIAABCECgAgRw3FpbYLUHj+NW4AzFECAA AQhAAALLEcBx
q615tR4djrvcSYG1IAABCEAAAhUggOPW2gKrPXgctwJnKIYAAQhAAAIQWI4A jlttzav16HDc
5U4KrAUBCEAAAhCoAAEct9YWWO3B47gVOEMxBAhAAAIQgMByBHDcamterUeH 4y53UmAtCEAA
AhCAQAUI4Li1tsBqD76Ijvulv/9rv+/O25dDybe1XLpEIxCAAAQgAIFiEMBx q615tR7d+hw3
8FSxzJ+7Z1+0sA6Of3a6s9/YEStdUVL16ss1stxaxTht5fD1gIFAAAIQgEDV CeC4tbbAag9+
fY5rXLb/R3f/1+7xleu4WawxS53sJ51VWltl3ew9pCYEIAABCEBgSwRw3Gpr Xq1Htz7H7b72
Yrfd1073ytn/Y6gc1zxRwd3OripuWNe1ybPX7p/GLK+cXQkAXwWBWLeCKoEx e410diPpDUH7
7ktWNNfbit6ot7odZjabGJ796j1XnZ/R4TtV0+uSClS7rYWi13kkXWzp9Ec8 GAIQgAAEKkwA
x621BVZ78Lk4buSu3PpcoMK3ymuHZ68luXZw7Dpo97V2QRFBTwql2u7rgTbI UKxXLQn0V0mq
qSDuq1oLGomFh2MvGcc1jdhZE55V26oaiTrP7LDr7moU9pOY4xbu3uU3Q7oE AQhAAAJ1IfDF
STR1HLfamlfr0a3uuPrskPDOEcnT8qrkT/RRhFX/G85Y0C5rZwV4EVM/bTee UJu2xEQ6I62F
47je1Wx2oFeHk+OZCWZJtHvxyl6esS/xBG4hAAEIQAACBSIw+NJL/LDGcWtt gdUe/IqOmyq4
5vKyK0dHZ/t/OGdfvGhuKOya6Li/9rs6vmuEOK6tXjQ3Kc03o+PG0xvSlsx3 XB2iznBFHSkH
EIAABCAAgW0QSNRcHLfamlfr0a3uuDOylCQlV64282ZUkEzcX3X2QkqugvFL XyjFGr1E2MjE
CF4FP/M14VK24CWVC5EYx7VTHbxzTVKugjcLRFKuQlIGsD9A8nELFL2ocCId Q4MABCCwEIFB
LGMBx621BVZ78Gt1XM8vtUHaCbWh672Sshc8fVRmuf9a5Dg8+VfoojTvsrDo NWfqejX1Umj1
SDZC5Lq0UK+85GDxbNVIyjVn4Ul8RZHNtWs4Lo4LAQhAAAKFIxBPV8Bxq615 tR7dWh13oS+X
K1U2l3xt49cfr+d27sQWu8GmIQABCEAAAikEcNxaO1/dBl9qx9VB1mACsq2e 1LjabKVvKVvd
d/QcAhCAQE0I4Lh107xaj7fUjluTUxLDhAAEIAABCORCAMettfPVbfA4bi5n DRqBAAQgAAEI
FJ8Ajls3zav1eHHc4p+S6CEEIAABCEAgFwI4bq2dr26Dx3FzOWvQCAQgAAEI QKD4BHDcumle
rceL4xb/lEQPIQABCEAAArkQwHFr7Xx1GzyOm8tZQxoRkhQIQAACEIBAQQgk frrhuHXTvFqP
F8fN0XHzaop2IAABCEAAAqsQSLuzA45ba+er2+DX7bjDv0YXH3r7L87u/edE /pXnsmSV921h
1517q5jC9pyOQQACEIBAxQjguHXTOcabQGCtjtu96ovaHry86HzsDb8OO1f9 w1cXskSWV+xs
onMVqjcoRgQBCEAAAmUkgOPifBCYrs9xRWT3XpyJ3Y7cx/huNHYf3U/9/d8u ltfc94c77uPw
/bz7gF+3Gg9b/U3dQAvHLePHAH2GAAQgUEkCOC6GB4F1Oa4kJEi8Ni64k2/j ybdJ9/NAXrWT
FhraW+fLa+dwp9G6nme32muN425Edpdw3OHnbufzcPOn11nbve133veHa/ti sMCQ19yTzWNn
ixCAAAQ2RgDHxfAgsC7HlbxbSVHQEdzR3bBze/H46vHFl7PxeDRxH4evO1LH vNuDgKv46IwY
rXr1sJPRwIrguF+c4ALbq0H07CavBgsHjjczgzOIDDBie/pP+dfU18+t9gdX nYtAVYe99/af
47HZbtCImhTC+TIeL2aWbsuy6exaHBryzO8qZpjZG894YFANAhCAQNUJ4LgY HgTW5bhyeZkO
4kqKggju3s1e49OD+3/cO7s+E8Gd/j11/hxInQTHjcRfvdiujt1KENd/PGx1 Tk3w133VDtbq
596Sfuuh38ppX1XLHgle5CQYP6FIzPLiXSCsg6uYvN6J13oLxUqVYt6N1VoR G050XOmbWa6e
OM77bu/WtUb1ZzcIx0ZeVYPyt2u3vLRTLqbFwZDnxDMWazZbaH+RHbqxcAsb ggAEIJA7ARwX
w4PAuhxXpSJ8lV/hVQ6uRHBFcB983L33+717b+6J4EoR05U6yY6rXFaCtfrf DFkHkqH7tJPu
uDH93ZDjSozTl05brVToNFjuq61lfnG3y+S4/YGf+aDa/BykHOj0AFlo50V4 27Vb1hHWuOna
Ju1FjsPj8iu4Tq8nCdYVVJRXi7tr1d5axubVtqINmmC2P4SgPyLx3gzEwZcB vboO9Ca0hvhC
AAIQqCkBHBfDg8C6HFfFcWXyBPchKQoSwRXB/e71d2d/tpXjTiWOO0yN42q7 dZMW7DRd5buR
YK0V1vWjtpYTbzdXQSlXPHCrVSxwRD8/1Y5uxiKd2Rx3qKOzUUn1VVsU1vrR 39tuKFfB7VWq
46ZbeFzKTUJC/IkbqHZtO96g7cThntjQVPqHO8wgBC6cZ35JIHwLAQhAoGYE cFwMDwLrclzJ
tZVpwkRw5SIzycGVFAWJ4Irgjr+NNfRmWj6uEdnEC8VsbTXh2FBmQp
Current Time: Wed Jul 23 04:14:12 EDT 2025
Powered by FUDForum. Page generated in 0.28111 seconds
