Using Parameter in XPath query [message #1215059] |
Wed, 27 November 2013 19:05  |
This is driving me nuts so hopefully someone can point me in the right direction. I'm using RSA and trying to generate a BIRT report. I created a data set and I'm trying to get a list of Call Operation Actions which are part of a use case (I'll be using this for my subreport).
This is the query I have:
instanceOf(//*,"uml:CallOperationAction")/context/namespace[@name="{?ucName?}"]
As you can see I have created a parameter called ucName. This is not a report parameter, just a data set parameter.
Well, I get nothing as output. If I replace the parameters ucName with a sample text, i do get the right output.
I though BIRT supported passing of parameters to XPath queries; although I'm not sure if this is true only for Report Parameters.
Any help?
FUDForum. Page generated in 0.03427 seconds
