goal for new objects in a transformation [message #1214821] |
Wed, 27 November 2013 16:41  |
I want to create Objects in the modelpackage itself.
The Objects are created directly in the xmi-Model at first level, and not as childs in a package.
The following QVTo transforms a Component Diagramm in a special Class Diagramm, with an Administration class and a Monitoring-Class for each component and each port
and shows the Problem:
modeltype UML uses "http://www.eclipse.org/uml2/4.0.0/UML";
transformation kompo2administration(in Compo: UML, out decomp: UML);
property curadminclass : UML::Class = null;
property curmonitorclass : UML::Class = null;
property model : UML::Model = null;
main()
model = object Model { name='model' };
Compo.objectsOfType(Component) -> map toAdminDecomp();
mapping Component::toAdminDecomp() : a: Class, m:Class
object a: Class
name := "Administation_"+self.name;
object m: Class
name := "Monitoring_"+self.name;
curadminclass := a;
curmonitorclass := m;
model.ownedType += a; // Try: add to the model, but in the result,
// the model remain empty
model.ownedType += m; // this too
self.ownedPort-> map toAdmin();
mapping Port::toAdmin() : a: Class, m:Class
object a: Class
name := "Administation_".concat(self.name);
object m: Class
var pa = object Property
name := self.name;
aggregation := uml::AggregationKind::composite;
type := a;
lower := 1;
upper := 1;
curadminclass.ownedAttribute += pa;
var pm = object Property
name := self.name;
type := a;
lower := 1;
upper := 1;
curmonitorclass.ownedAttribute += pm;
The result is:
<xmi:XMI xmi:version="20110701" xmlns:xmi="http://www.omg.org/spec/XMI/20110701" xmlns:uml="http://www.eclipse.org/uml2/4.0.0/UML">
<uml:Model xmi:id="_4LFAoFelEeOXFqUo7lQK7Q"/>
<uml:Class xmi:id="_4LFAoVelEeOXFqUo7lQK7Q" name="Administation_ISP">
<ownedAttribute xmi:id="_4LFAolelEeOXFqUo7lQK7Q" name="Gateway" type="_4LFAr1elEeOXFqUo7lQK7Q" aggregation="composite">
<lowerValue xmi:type="uml:LiteralInteger" xmi:id="_4LFAo1elEeOXFqUo7lQK7Q" value="1"/>
<upperValue xmi:type="uml:LiteralUnlimitedNatural" xmi:id="_4LFApFelEeOXFqUo7lQK7Q" value="1"/>
</ownedAttribute>
<ownedAttribute xmi:id="_4LFApVelEeOXFqUo7lQK7Q" name="AccessRouter" type="_4LFAsVelEeOXFqUo7lQK7Q" aggregation="composite">
<lowerValue xmi:type="uml:LiteralInteger" xmi:id="_4LFAplelEeOXFqUo7lQK7Q" value="1"/>
<upperValue xmi:type="uml:LiteralUnlimitedNatural" xmi:id="_4LFAp1elEeOXFqUo7lQK7Q" value="1"/>
</ownedAttribute>
</uml:Class>
you see, the generated Objekts are in the first level.
and not as I expect, the Objekts should be ownedTypes in the Model:
<uml:Model xmi:id="_4LFAoFelEeOXFqUo7lQK7Q">
<uml:packagedElement xmi:type="uml:Class" xmi:id="_4LFAoVelEeOXFqUo7lQK7Q" name="Administation_ISP">
</ownedAttribute>
</ownedAttribute>
</uml:PackagedElement>
<uml:Packagedlement xmi:typ="uml:Class" xmi:id="_4LFAqFelEeOXFqUo7lQK7Q" name="Monitoring_ISP">
<ownedAttribute xmi:id="_4LFAqVelEeOXFqUo7lQK7Q" name="Gateway" type="_4LFAr1elEeOXFqUo7lQK7Q" aggregation="composite">
</uml:Model>
Thank you very much
Rudolf Weber, Germany
Re: goal for new objects in a transformation [message #1226613 is a reply to message #1223208] |
Thu, 02 January 2014 02:44  |
Model is a derivation of Package and it is conventional for the root of
UML models to be a Model rather than a Package. This provides a single
root for potentially diverse contents.
However you could have a "http://www.eclipse.org/uml2/4.0.0/UML" model
whoose root was a Comment.
As you discovered from the accidental comparison rather than assignment,
everything that lacks a parent is placed at the root.
Beware that QVTo provides a built-in Model class too. This doesn't seem
to have caused you a problem; yet.
Ed Willink
On 22/12/2013 19:32, Christopher Gerking wrote:
> Rudolf Weber wrote on Thu, 19 December 2013 17:59
>> * is the model the output-Model which is referred in the output
>> parameter decomp ?
> No. I'm not familiar with the UML meta model, but it seems as if every
> model requires an explicit instance of class Model, maybe as a root
> container.
>> * why I need the allocaton of a model ? (first line in main() in the
>> above code)
> Because Model is just a class in your meta model, and you need an
> instance of this class to accommodate other model objects. As stated
> above, this seems to be a particularity with the UML meta model.
FUDForum. Page generated in 0.07053 seconds
