Home » Eclipse Projects » Remote Application Platform (RAP) » DateTime Widget
DateTime Widget [message #121406] Thu, 12 February 2009 10:13 Go to next message
is it possible to navigate with keys in the DateTime Wiget to switch between
day, month and year, for example?
I couldn't figure it out.
Markus
Re: DateTime Widget [message #121452 is a reply to message #121406] Thu, 12 February 2009 10:22 Go to previous messageGo to next message
Hi Markus,
I've just check it with the Controls Demo -> DateTime tab with SWT.DATE
style flag. The navigation with arrows keys is working as expected.
Which browser do you use? OS? Safari? It is known issue that the key
handling does not work on Safari.
Best,
Ivan
"Markus Kr�������������������
Re: DateTime Widget [message #121459 is a reply to message #121452] Thu, 12 February 2009 12:03 Go to previous messageGo to next message
Hmmm,
it looks like it is not only the key naviagtion that does not work. I also
can not enter anything!
Is seems that the focus of the widget is not set properly. I navigated to
the widget using the tabulator key.
There is only a dotted border around the widget, but I can not edit anything
or move around using keys.
I tested with IE7 and Firefox 3.0 in the Controls Demo -> DateTime.
Markus
"Ivan Furnadjiev" <ivan@eclipsesource.com> schrieb im Newsbeitrag
news:gn1esi$2i9$1@build.eclipse.org...
> Hi Markus,
> style flag. The navigation with arrows keys is working as expected. Which
> browser do you use? OS? Safari? It is known issue that the key handling
> Best,
> Ivan
> "Markus Kr??????????????????????" wrote:
>> Hi,
>> between day, month and year, for example?
>> Regards,
>> Markus
Re: DateTime Widget [message #121467 is a reply to message #121459] Thu, 12 February 2009 12:17 Go to previous messageGo to next message
Hi Markus,
please file a bugzilla about this issue.
Ivan
Re: DateTime Widget [message #121475 is a reply to message #121467] Thu, 12 February 2009 12:44 Go to previous message
I filed Bug No. 264729
news:gn1ljm$kp9$1@build.eclipse.org...
> Hi Markus,
> Ivan
>> Hmmm,
>> also can not enter anything!
>> anything or move around using keys.
>> Regards,
>> Markus
>>> Hi Markus,
>>> Best,
>>> Ivan
>>>> Hi,
>>>> Regards,
>>>> Markus
Previous Topic:Tableeditor
Next Topic:MenuBar property "menuBarShellClientArea" not preserved
Current Time: Fri Nov 07 09:03:20 EST 2025
Powered by FUDForum. Page generated in 0.03229 seconds
