Home » Modeling » OCL » bag->asSet() operation bug
bag->asSet() operation bug [message #1213547] Wed, 27 November 2013 04:31 Go to next message
Bag->asSet() operation does not return the set with unique elements
let x : Bag(Integer) = Bag{3,3,4,4,5} in x->asSet()
if i execute the above query in "interactive xtext OCL" console i get "3,3,4,4,5" but if i execute it in "interactive OCL" then i get the correct result.
It seems a bug in pivot/xtext imlpementation.
Please check the image.
index.php/fa/16853/0/
  • Attachment: bag.jpg
    (Size: 28.47KB, Downloaded 607 times)
Re: bag->asSet() operation bug [message #1213619 is a reply to message #1213547] Wed, 27 November 2013 05:10 Go to previous messageGo to next message
Indeed. Fixed by commit 551890f69da19012696b2dae780646c6c7e5430b on
2013-10-27 13:36:44
so if you use the Luna M3 install you should be good.
Ed Willink
Re: bag->asSet() operation bug [message #1213784 is a reply to message #1213619] Wed, 27 November 2013 06:47 Go to previous messageGo to next message
I have cloned the git://git.eclipse.org/gitroot/mdt/org.eclipse.ocl.git with master branch. Is this the latest and stabil code containing fixes?
Re: bag->asSet() operation bug [message #1213806 is a reply to message #1213784] Wed, 27 November 2013 06:56 Go to previous messageGo to next message
No. http://projects.eclipse.org/projects/modeling.mdt.ocl | Engage shows
git://git.eclipse.org/gitroot/ocl/org.eclipse.ocl.git
Last commit on master is: commit
433579efbf90daf252e742775b2074c5116a93f1 on 2013-11-27 07:15:54
Your ref predates the availability of Gerrit contributions. Can you let
me knwo where tyou found the stale reference so that I can fix it.
(I can see lots of stale references in
http://wiki.eclipse.org/OCL/Dev/Setup so no need to tell me about those.)
Ed
On 27/11/2013 11:47, ModelGeek Mising name wrote:
> I have cloned the
> Cheers,
Re: bag->asSet() operation bug [message #1220390 is a reply to message #1213806] Wed, 11 December 2013 08:00 Go to previous messageGo to next message
I have cloned the repository from git://git.eclipse.org/gitroot/ocl/org.eclipse.ocl.git (Master). It gives me many build errors.
what is problem in my case?
index.php/fa/16990/0/
Re: bag->asSet() operation bug [message #1220395 is a reply to message #1220390] Wed, 11 December 2013 08:35 Go to previous messageGo to next message
I have downloaded the latest version of Eclipse with modeling tools and i am getting the folloing error message when i build the workspace having ocl git repository clone.
Errors occurred during the build.
Errors running builder 'Java Builder' on project 'org.eclipse.ocl.examples.xtext.base.ui'.
Errors running builder 'Java Builder' on project 'org.eclipse.ocl.examples.xtext.essentialocl'.
Errors running builder 'Java Builder' on project 'org.eclipse.ocl.examples.xtext.markup'.
index.php/fa/16991/0/
Re: bag->asSet() operation bug [message #1220398 is a reply to message #1220395] Wed, 11 December 2013 08:56 Go to previous messageGo to next message
I have solved most of the errors.
I am having an error at class declaration of org.eclipse.ocl.examples.editor.ocl.ui.OCLCreationFactory
Multiple markers at this line
- The return types are incompatible for the inherited methods
ICreationFactory.createNodeLocator(ICSTRootEnvironment<?,?,?,?,?,?,?,?,?,?,?,?>),
AbstractCreationFactory.createNodeLocator(ICSTRootEnvironment<?,?,?,?,?,?,?,?,?,?,?,?>)
- The return types are incompatible for the inherited methods ICreationFactory.getLanguage(),
AbstractCreationFactory.getLanguage()
- The type OCLCreationFactory must implement the inherited abstract method
ICreationFactory.createNodeLocator(ICSTRootEnvironment)
ICreationFactory.createSourcePositionLocator(ICSTRootEnvironment)
- The type OCLCreationFactory must implement the inherited abstract method ICreationFactory.getAdapter(Class)
any idea?
[Updated on: Wed, 11 December 2013 09:14] by Moderator
Re: bag-&amp;amp;gt;asSet() operation bug [message #1220401 is a reply to message #1220398] Wed, 11 December 2013 09:14 Go to previous messageGo to next message
I updated
http://wiki.eclipse.org/OCL/Dev/Setup#Getting_the_Sources_from_GIT a few
days ago.
http://eclipse.org/modeling/mdt/ocl/resources/ocl.psf should get what
you need and avoid pulling in obsolete plugins from archive that have
correspondingly obsolete dependencies.
Ed Willink
> I am having an error in import statement of
> org.eclipse.imp.runtime.PluginBase
> can you guide how to get org.eclipse.imp plugin?
Re: bag-&amp;amp;gt;asSet() operation bug [message #1220491 is a reply to message #1220401] Thu, 12 December 2013 02:46 Go to previous message
Apologies. I didn't do a very good job of updating. The "Engage" tab of
http://projects.eclipse.org/projects/modeling.mdt.ocl now displays a
variety of team project set files, of which
http://git.eclipse.org/c/ocl/org.eclipse.ocl.git/plain/releng/org.eclipse.ocl.releng/psfs/ocl-all.psf?h=master
is the correct one to install everything that is needed. (It is now in
the main OCL GIT rather than the anciliary MDT pages.)
Ed Willink
On 11/12/2013 14:14, Ed Willink wrote:
> Hi
> I updated
> few days ago.
> Regards
> Ed Willink
Previous Topic:Installing Dresden OCL plugin in Juno
Next Topic:Ternary Association
Current Time: Fri Jul 25 08:42:06 EDT 2025
Powered by FUDForum. Page generated in 0.06488 seconds
