Home » Modeling » OCL » bag->asSet() operation bug
bag->asSet() operation bug [message #1213547] |
Wed, 27 November 2013 04:31  |
Bag->asSet() operation does not return the set with unique elements
let x : Bag(Integer) = Bag{3,3,4,4,5} in x->asSet()
if i execute the above query in "interactive xtext OCL" console i get "3,3,4,4,5" but if i execute it in "interactive OCL" then i get the correct result.
It seems a bug in pivot/xtext imlpementation.
Please check the image.
Attachment: bag.jpg
(Size: 28.47KB, Downloaded 608 times)
Re: bag->asSet() operation bug [message #1213619 is a reply to message #1213547] |
Wed, 27 November 2013 05:10   |
Indeed. Fixed by commit 551890f69da19012696b2dae780646c6c7e5430b on
2013-10-27 13:36:44
so if you use the Luna M3 install you should be good.
Ed Willink
Re: bag->asSet() operation bug [message #1220398 is a reply to message #1220395] |
Wed, 11 December 2013 08:56   |
I have solved most of the errors.
I am having an error at class declaration of org.eclipse.ocl.examples.editor.ocl.ui.OCLCreationFactory
Multiple markers at this line
- The return types are incompatible for the inherited methods
ICreationFactory.createNodeLocator(ICSTRootEnvironment<?,?,?,?,?,?,?,?,?,?,?,?>),
AbstractCreationFactory.createNodeLocator(ICSTRootEnvironment<?,?,?,?,?,?,?,?,?,?,?,?>)
- The return types are incompatible for the inherited methods ICreationFactory.getLanguage(),
AbstractCreationFactory.getLanguage()
- The type OCLCreationFactory must implement the inherited abstract method
ICreationFactory.createNodeLocator(ICSTRootEnvironment)
ICreationFactory.createSourcePositionLocator(ICSTRootEnvironment)
- The type OCLCreationFactory must implement the inherited abstract method ICreationFactory.getAdapter(Class)
any idea?
[Updated on: Wed, 11 December 2013 09:14] by Moderator
Current Time: Sat Jul 26 03:22:13 EDT 2025
Powered by FUDForum. Page generated in 0.27397 seconds
