Update Server config (VM Arguments) [message #1211405] |
Tue, 26 November 2013 07:20  |
Virgo 3.6 integrated ibto sts 3.4
I use jasperReports, and that component needs the java temp directory. (-Djava.io.tmpdir) The default value is {Virgo diretory}/work/tmp/, but it is not good, because the start Virgo with clean option, delete the work directory, and doesn't create tmp dir. If I changed manually the argument, (Applay ans OK), and check it again, I see, the it has set the original value, instead of newly set.
I can't find, how I can set up this parameter. (I can add new value to VM arguments)
I check the install dir of Virgo, and then I set up the parameters, but it doesn't help.
Could anyone help me, how can change this parameter?
Thank you:
Feri
FUDForum. Page generated in 0.07299 seconds
