Home » Modeling » Papyrus » Importing OMG's Profiles(How To)
Importing OMG's Profiles [message #871202] Fri, 11 May 2012 08:35 Go to next message
I try to use the SPEM profile from the OMG into Papyrus, but I don't see the way to do this.
Here are the steps I follow, based on this topic :
1) I download the SPEM profile and rename into "spem.profile.uml"
2) I right-click on the profile and select new/papyrus model
Default name proposed by papyrus is "spem.di" so I have an error message to advise me to use the same name as domain model file name (spem.profile.di)
3) I rename the file "spem.profile.di" so as to move on the next stage
4) I check the Profile radio button in the "Select language of the diagram" page
5) I check the checkbox "UML Profile Diagram" so as to create a UML Profile Diagram once the wizard is finished. I don't know why, but in this case I can't create new UML Profile Diagram from the right-click inside the Model Explorer
6) The last page lets me select the root element. There is a bug on the labels (see Figure below)
7) Finally, I click on the Finish button and nothing is being done.
Is there any way to use the SPEM profile inside Papyrus ?
I use Papyrus 0.8.2 on Eclipse Indigo Service Release 1.
Thank you,
regards,
Nicolas
Re: Importing OMG's Profiles [message #871356 is a reply to message #871202] Sat, 12 May 2012 06:26 Go to previous messageGo to next message
Your SPEM file uses "http://schema.omg.org/spec/UML/2.1.1" which is an
OMG nsURI recognised by MDT/UML2. But:
When using OMG nsURIs, you must use *.xmi rather than *.uml extensions
unless you take care to revise the content registrations.
Similarly, when using MDT/UML2 nsURIs, you must use *.uml rather than
*.xmi extensions.
When having trouble with models, don't try to user advanced modeling
tools until your files load successfully in the Sample Ecore Editor or
UML Model Editor.
Ed Willink
On 11/05/2012 13:35, nicolas h wrote:
> I try to use the http://www.omg.org/spec/SPEM/20070801/SPEM%202.0%20UML%202%20Profile.xmi from the OMG into Papyrus, but I don't see the way to do this.
> Here are the steps I follow, based on http://www.eclipse.org/forums/index.php/m/819764/#msg_819764 :
> Thank you,
> regards,
Re: Importing OMG's Profiles [message #1212596 is a reply to message #871356] Tue, 26 November 2013 19:11 Go to previous messageGo to next message
Hi Ed,
In your response above you refer to the "UML Model Editor." Would that be located at the "runtime" link on this Web page?: http://eclipse.org/modeling/mdt/downloads/?project=uml2tools
Thanks.
--Dave
Re: Importing OMG's Profiles [message #1213403 is a reply to message #1212596] Wed, 27 November 2013 03:13 Go to previous messageGo to next message
Yes. The Eclipse UML project provides no graphical UML tooling; just
models, Java API and the tree-style UML Model Editor.
Ed Willink
On 27/11/2013 00:11, David Frankel wrote:
> Hi Ed,
> Thanks.
> --Dave
Re: Importing OMG's Profiles [message #1214084 is a reply to message #1212596] Wed, 27 November 2013 09:34 Go to previous message
Hi, Dave,
That URL is for the UML2Tools project, which aimed to provide diagram
editors for UML but is, I think, no longer active.
What you want is the run-time feature of the UML2 project:
With the SDK feature you will also get all of the API sources and some
additional editor functions such as conversion of UML class models
to/from Ecore.
HTH,
Christian
On 2013-11-27 00:11:36 +0000, David Frankel said:
> Hi Ed,
> Thanks.
> --Dave
Previous Topic:Lost functionality after installing Mylyn
Next Topic:How to declare TimeEvent?
Current Time: Sat Jul 26 02:17:03 EDT 2025
Powered by FUDForum. Page generated in 0.24618 seconds
