Home » Eclipse Projects » Remote Application Platform (RAP) » Browser Widget focus
Browser Widget focus [message #120981] Fri, 06 February 2009 18:38 Go to next message
It's probably just something I'm missing, but I'm having an issue with
Browser widget.
I have browser widget inside dialogs, and in order to click on a link
inside the browser I need to click twice to get it to work. After the
first extra click, the browser seems to have focus and will work as normal
(single clicks).
So I tried to do setFocus() and forceFocus() but both returns false. Why
would the widget fail to get focus? Or is this a bug?
Thanks in advance,
Howard
Re: Browser Widget focus [message #121079 is a reply to message #120981] Mon, 09 February 2009 16:29 Go to previous messageGo to next message
I too am having this problem. The HTML page I am displaying in the
Browser component contains href links but I have to click inside the
Browser component initially in order to make the links responsive. The
status bar in the RAP browser does not display the link URL until the
first mouse click is received.
-Jim
Re: Browser Widget focus [message #121118 is a reply to message #120981] Tue, 10 February 2009 04:56 Go to previous messageGo to next message
Hi Howard,
I can't reproduce it with Controls Demo -> Browser tab. When I set the
page in the browser, the links became active immediately. Can you
provide a simple self-running snippet that illustrate the problem?
Best,
Ivan
> Browser widget.
> normal (single clicks).
> Why would the widget fail to get focus? Or is this a bug?
> Thanks in advance,
> Howard
Re: Browser Widget focus [message #121161 is a reply to message #121118] Tue, 10 February 2009 20:30 Go to previous messageGo to next message
Try this. Basically just a shell with browser in it. I'm wondering if it
has anything to do with me running RWT standalone? If you need a war file
to test RWT standalone, you can see my previous thread "File Upload and
Download in RWT standalone", I attached a war file there.
Thanks!
import org.eclipse.rwt.lifecycle.IEntryPoint;
import org.eclipse.swt.SWT;
import org.eclipse.swt.browser.Browser;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Shell;
public class BrowserApplication implements IEntryPoint {
public int createUI() {
Display display = new Display();
Shell shell = new Shell(display, SWT.TITLE);
shell.setLayout(new GridLayout());
Browser browser = new Browser(shell, SWT.NONE);
browser.setUrl("http://www.eclipse.org/");
browser.setLayoutData(new GridData(GridData.FILL_BOTH));
shell.open();
shell.setMaximized(true);
while (shell!= null && !shell.isDisposed()) {
try{
if (!display.readAndDispatch()) {
display.sleep();
catch (Throwable t)
t.printStackTrace();
return 0;
Re: Browser Widget focus [message #121179 is a reply to message #121161] Wed, 11 February 2009 04:19 Go to previous messageGo to next message
Hi Howard,
the browser widget uses qooxdoo Iframe. I've dig inside the qooxdoo
Iframe and found that there is a blocker div element which cover the
actual Iframe when the instance is created. As a temporary workaround
add the following code in the RAP Browser.js file:
focus : function() {
this.base( arguments );
this.release();
This release (remove) the blocker div tag on Browser focus gain.
Best,
Ivan
> it has anything to do with me running RWT standalone? If you need a
> war file to test RWT standalone, you can see my previous thread "File
> Upload and Download in RWT standalone", I attached a war file there.
> Thanks!
> import org.eclipse.swt.widgets.Display;
> shell.open();
> try{
> display.sleep();
> catch (Throwable t)
> return 0;
Re: Browser Widget focus [message #121186 is a reply to message #121161] Wed, 11 February 2009 04:33 Go to previous messageGo to next message
Howard,
and please file a bugzilla about it.
Ivan
> Thanks!
> shell.open();
> try{
> display.sleep();
> catch (Throwable t)
> return 0;
Re: Browser Widget focus [message #121259 is a reply to message #121179] Wed, 11 February 2009 12:49 Go to previous messageGo to next message
Thanks for taking the time to investigate, Ivan.
Alas I tried to add that snippet to Browser.js but it doesn't seem to do
anything. I wouldn't be surprised if I'm not adding it correctly though,
so would you kindly past the entire file for me?
Also, out of curiosity, is this a RWT standalone issue since you said the
demo browser works fine?
Howard
Re: Browser Widget focus [message #121267 is a reply to message #121259] Wed, 11 February 2009 14:05 Go to previous messageGo to next message
Howard,
This is not a RWT standalone issue. I've opened a bug about it:
[Browser] Extra click is needed to activate the link in the browser widget
https://bugs.eclipse.org/bugs/show_bug.cgi?id=264569
Best,
Ivan
> do anything. I wouldn't be surprised if I'm not adding it correctly
> though, so would you kindly past the entire file for me?
> the demo browser works fine?
> Cheers,
> Howard
Re: Browser Widget focus [message #121291 is a reply to message #121267] Wed, 11 February 2009 16:50 Go to previous messageGo to next message
Ivan,
Would you please update the bug with the temporary work-around you posted?
Attaching the entire Browser.js would be good because I still can't figure
out where/how to add your snippet. :(
Interesting why the browser demo would work fine and that this bug wasn't
caught earlier.
Howard
Re: Browser Widget focus [message #121316 is a reply to message #121291] Thu, 12 February 2009 02:39 Go to previous messageGo to next message
Hi Howard,
the iframe blocker is removed automatically, when you click somewhere in
the application. In the Controls Tab -> Browser, the browser widget is
empty by default and the blocker is there. When you click somewhere in
the application (button to set the URL for example)... the blocker is
removed. In your example the browser widget is "preloaded" with the
page, that's why there is no this first click to remove the blocker. The
bug is fixed in CVS HEAD - the blocker is removed on iframe "load" event
as qooxdoo developers suggested.
Best,
Ivan
Howard wrote:
> Ivan,
> posted? Attaching the entire Browser.js would be good because I still
> can't figure out where/how to add your snippet. :(
> wasn't caught earlier.
> Howard
Re: Browser Widget focus [message #121491 is a reply to message #121316] Thu, 12 February 2009 15:33 Go to previous message
Great explanation and fix works great. Thanks a bunch!
Previous Topic:no context menu on TableViewer
Next Topic:Switching Perspective on tomcat server
Current Time: Wed Jul 30 11:10:26 EDT 2025
Powered by FUDForum. Page generated in 0.05452 seconds
