Home » Archived » Test and Performance Tools Platform (TPTP) » Unable to profile Java application
Unable to profile Java application [message #121203] Tue, 22 January 2008 15:57 Go to next message
Originally posted by: weyus.att.net
JDK 1.3.1_09
Eclipse 3.3
TPTP Platform 4.4.1
Tracing and Profiling Tools Project 4.3.1
I have a Java application that I can run successfully within Eclipse.
When I attempt to profile it with the pre-1.5 monitoring and "Basic Memory
Analysis" set, it seems to start up and then immediately dies. I can tell
that my application doesn't even start since there is no log file
activity. Is TPTP 4.4.1 stable enough to use?
All I see in the .log file for Eclipse is:
"!ENTRY org.eclipse.tptp.platform.common.ui.trace 2008-01-22 14:37:18.740
!MESSAGE Processed: 9241045 bytes, bytes/second: 1026782, events
processed: 87163, events/second: 9684, elapsed time: 9 seconds
processed: 0, events/second: 0, elapsed time: 9 second"
which doesn't look like a problem?
How can I proceed to troubleshoot this problem? Or should I just roll
back to 4.4.0.3?
Wes
Re: Unable to profile Java application [message #121222 is a reply to message #121203] Wed, 23 January 2008 03:51 Go to previous message
Hi Wes,
You can set DEBUG log level in the AC's serviceconfig.xml file.
Another option is to start profiling from command line and attach to it
from the workbench.
Igor
Previous Topic:Freeze up on sample?
Next Topic:Is "Cumulative CPU time" supposed to be the same from run to run?
Current Time: Mon Nov 03 15:49:27 EST 2025
Powered by FUDForum. Page generated in 0.03553 seconds
