RWT in IFRAME [message #1210061] |
Mon, 25 November 2013 16:04  |
Hello all,
I have the following situation:
I have an application done with RWT2.0. This application loads inside an iframe.
When the iframe is loading (not done loading), if i change the page in surrounding application (click on a link that redirects to some other page), for a short time the following message appears:
"The server seems to be temporarily unavailable!"
I think this is because the browser cancel the iframe request (since the element dissapears), but somehow the message is misleading.
My question is: can I do something about the message? Can I do something about the issue only from inside RWT application ?
Do i have to make the 2 applications communicate using some global variables?
I tested using Chrome 31.0.1650.57 m & Firefox25.0.1.
Thank you.
Re: RWT in IFRAME [message #1211690 is a reply to message #1210061] |
Tue, 26 November 2013 10:16   |
Hi.
You can change the message as part of the localization[1], but I don't
think that's what you should do. If you use javascript to react to a
user clicking a link (I don't know right now how to do that, you will
have to research it yourself), you could just hide the iframe (setting
style.display to "none"). That's the best solution I can think of.
Greetings,
Tim
http://eclipse.org/rap/developers-guide/devguide.php?topic=internationalization.html&version=2.1
Am 25.11.2013 22:04, schrieb bogdan toma:
> Hello all,
> iframe.
> about the issue only from inside RWT application ? Do i have to make the
> Thank you.
Tim Buschtöns
Twitter: @EclipseRAP
FUDForum. Page generated in 0.05914 seconds
