Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » emf.ecore.resource.ResourceSet.getResource takes more time in VIRGO(emf.ecore.resource.ResourceSet.getResource takes more time in VIRGO)
emf.ecore.resource.ResourceSet.getResource takes more time in VIRGO [message #1209197] Mon, 25 November 2013 06:37 Go to next message
The following code takes around 1 second for every call in VIRGO server. But takes few milliseconds during eclipse run. Also I found that if I add the resource loading logic in my Activator, which is triggered during virgo server startup, the time taken is very less (~0.4 sec).
Resource resource = org.eclipse.emf.ecore.resource.ResourceSet.getResource(uri, true);
Please see the below link for more details.
http://www.eclipse.org/forums/index.php/t/593004/
Any suggestions on how to debug this or performance optimization is highly appreciated.
Chandru
Re: emf.ecore.resource.ResourceSet.getResource takes more time in VIRGO [message #1209369 is a reply to message #1209197] Mon, 25 November 2013 08:25 Go to previous messageGo to next message
Chandre,
What URI are you using? I.e., where is the resource you're loading located?
On 25/11/2013 12:37 PM, Chandre Gowda wrote:
> (~0.4 sec).
> Resource resource =
> highly appreciated.
> Thanks
> Chandru
Re: emf.ecore.resource.ResourceSet.getResource takes more time in VIRGO [message #1210682 is a reply to message #1209369] Mon, 25 November 2013 23:18 Go to previous messageGo to next message
URI is a path to simple xml file which is available in the same system, so I think we can avoid looking at networking latency as a factor.
Following line gives the URI.
URI uri = URI.createFileURI(file.getAbsolutePath());
Chandru
Re: emf.ecore.resource.ResourceSet.getResource takes more time in VIRGO [message #1211132 is a reply to message #1210682] Tue, 26 November 2013 04:22 Go to previous messageGo to next message
Chandru,
Perhaps Virgo involves more security manager overhead to access the file
system. You can see that
org.eclipse.emf.ecore.resource.impl.FileURIHandlerImpl.createInputStream(URI,
Map<?, ?>) basically just uses a FileInputStream so why that would be
slower isn't clear.
> factor.
> Thanks
> Chandru
Re: emf.ecore.resource.ResourceSet.getResource takes more time in VIRGO [message #1213370 is a reply to message #1211132] Wed, 27 November 2013 02:56 Go to previous message
Please let's join our efforts to not waste unnecessary time on this.
[Updated on: Wed, 27 November 2013 02:57] by Moderator
Previous Topic:[EMF Client Platform] ViewModel adding children references
Next Topic:[EMF/Edit][Teneo] Call to AdapterFactoryEditingDomain.getEditingDomainFor(eObject) returns null, eOb
Current Time: Fri Aug 01 05:29:19 EDT 2025
Powered by FUDForum. Page generated in 0.05554 seconds
