Home » Archived » Test and Performance Tools Platform (TPTP) » running AGR testsuite file from command line
running AGR testsuite file from command line [message #120890] Tue, 15 January 2008 09:37 Go to next message
Originally posted by: owca_net.o2.pl
How can I run testsuite file generated by AGR from command line without
using eclipse? It is possible?
Re: running AGR testsuite file from command line [message #120920 is a reply to message #120890] Wed, 16 January 2008 06:21 Go to previous message
Hi Tomek,
Since the AGR is only for testing applications, you need Eclipse to run
your AGR test suite. You can run an AGR test suite from the TPTP/Eclipse
workbench or from TPTP's Automatable Service Framework (ASF):
http://help.eclipse.org/help33/topic/org.eclipse.hyades.test .doc.user/tasks/tlaunching-tests-from-scripts-and-applicatio ns.htm
Paul
"Tomek" <owca_net@o2.pl> wrote in message
news:050fdd1082b7c5a6d43f8f1390f1cf93$1@www.eclipse.org...
Previous Topic:ClassCastException or ClassNotFoundException
Next Topic:Running TPTP AGR tests from ant script
Current Time: Sun Jul 27 07:34:50 EDT 2025
Powered by FUDForum. Page generated in 0.04467 seconds
