Home » Eclipse Projects » Eclipse Platform » Problems with <mapper type="regexp"
Problems with <mapper type="regexp" [message #120734] Tue, 02 September 2003 20:45
Originally posted by: johncook.us.ibm.com
I am having a good bit of trouble getting the <present> selector to work with a
regexp mapper on Ant 1.5.2. I have a test case of a simple SRC directory
holding a few Java source files and a simple DEST directory holding the compiled
Java class files. There is also one .properties file that has the same name and
path in both the SRC and DEST directories
The following target will identify only the .properties file, probably because
of the identity mapping:
<target name="StdCleanJavaClasses" >
<fileset id="f1" dir="${_dest}" casesensitive="false" >
<present present="both" targetdir="${_src}" >
from="^(.*)\.properties$$"
to="\1.properties" />
</present>
</fileset>
<pathconvert pathsep=";" dirsep="/" property="_list1" refid="f1" >
</pathconvert>
<echo> src=${_src}
dest=${_dest}
list1=${_list1}</echo>
</target>
The target above produces an output like the following:
StdCleanJavaClasses:
src=c:/u/johncook/src/wsad500/IsmpAntTaskProject/src.java
dest=c:/u/johncook/src/wsad500/IsmpAntTaskProject/build/bin/ java
list1=C:/u/johncook/src/wsad500/IsmpAntTaskProject/build/bin /java/com/ibm/eou/ant/ismp/Ismp5Task.properties
The problem comes with the .java to .class mapping. If I redo the sample target
above with a more complicated mapper, I never get a match. I would expect to
see a list of all the .class files that have a matching source file.
<echo>StdCleanJavaClasses:</echo>
from="^${_src}/(.*)\.java$$"
to="${_dest}/\1.class" />
</present>
</fileset>
</pathconvert>
<echo> src=${_src}
dest=${_dest}
</target>
The output from this target is an empty list.
list1=
Some questions:
(1) is there some regexp quoting that has to happen when matching ${_src} ?
(2) if so, how do I quote regexp in Ant
(3) is the regexp pattern of the second target correct? maybe I have
confused source and destination somewhere.
Any help would be greatly appreciated.
John Cook
Previous Topic:Eclipse CVS - suggestions for update
Next Topic:How to detect if a plugin is present
Current Time: Tue Nov 04 23:32:36 EST 2025
Powered by FUDForum. Page generated in 0.03783 seconds
