Custom primitive types in OCL [message #1206083] |
Sat, 23 November 2013 18:46  |
I realize that I can do "self.Attribute1 - self.Attribute2 < 5" if the attributes are Real. But if an attribute is of a different type, e.g. a custom primitive type, then the operator minus is not overloaded and doesn't work. I was wondering if someone has had some experience with OCL constraints and custom primitive types? Is this possible in OCL?
In my example I am using a MARTE <<NfpType>> stereotyped primitive type and I want to know if the constraint can be "the difference between two such types < 5".
Thank you,
Damjan
Re: Custom primitive types in OCL [message #1207261 is a reply to message #1206816] |
Sun, 24 November 2013 08:31   |
Thank you Ed,
You are incredibly helpful. I am only starting to learn OCL, so perhaps I don't know the right way to access the needed property. But, so far I couldn't find some information about using custom types in OCL.
This is what I am trying to achieve:
I am sure I saw a constraint for the Nfp somewhere that was in the form "self.Nfp1 < (5, CustomUnit)". I have tried this as well, and maybe it is not possible in OCL. I thought if I can overload the operator in OCL to work for CustomTypes, or if I can access the 'value' of the custom type, that it would work.
Thank you,
Damjan
Attachment: ocl_nfp.png
(Size: 83.68KB, Downloaded 522 times)
FUDForum. Page generated in 0.06468 seconds
