Home » Archived » BIRT » tempDir
tempDir [message #118500] |
Fri, 27 January 2006 05:32  |
Originally posted by: jan.tanis.coas.com
I'm using config.setTempDir(tempDir); to set the dir for the images, but
it still puts them in C:'documents and settings..... Any clue on this?
Regards, Jan.
Re: tempDir [message #122402 is a reply to message #121626] |
Wed, 01 February 2006 01:24   |
What is wrong with my package?
Jason Weathersby wrote:
> Jan,
> If you are running this with the API and
> you have setup a IRunAndRenderTask task.
> then it is just
> HTMLRenderContext renderContext = new HTMLRenderContext();
> renderContext.setImageDirectory("image");
> HashMap contextMap = new HashMap();
> contextMap.put( HTMLRenderContext.CONTEXT_NAME, renderContext );
HTMLRenderContext.CONTEXT_NAME is not available
> task.setContext( contextMap );
Can't do this, Eclipse says that this is not in the API
> Jason
> "Jan Tanis" <jan.tanis@coas.com> wrote in message
> news:drmvgs$vua$1@utils.eclipse.org...
>>Jason,
>>How do I append the HTMLRenderContext to the emitter? I assume that that
>>is not done automatically.
>>Regards, Jan.
>>>Jan,
>>>Use
>>>HTMLRenderContext rc = HTMLRenderContext();
>>>rc.setImageDirectory("yourlocation");
>>>To handle the images
>>>Jason
>>>news:drcsre$56e$1@utils.eclipse.org...
>>>>Hi,
>>>>Regards, Jan.
Regards, Jan.
Re: tempDir [message #122755 is a reply to message #122402] |
Wed, 01 February 2006 07:43   |
Did you add the Jars from the Report Engine folder to your project?
Jason
news:drpk6o$g8f$1@utils.eclipse.org...
>> Jan,
>> then it is just
>> Jason
>>>Jason,
>>>Regards, Jan.
>>>>Jan,
>>>>Use
>>>>Jason
>>>>>Hi,
>>>>>but it still puts them in C:'documents and settings..... Any clue on
>>>>>this?
>>>>>Regards, Jan.
> Regards, Jan.
Re: tempDir [message #122947 is a reply to message #122755] |
Thu, 02 February 2006 01:03   |
Hi Jason,
Yes, I did. It can find the needed classes. But the classes don't have
the functions you show.
Regards, Jan.
> Jason
>>Hi,
>>>Jan,
>>>then it is just
>>>Jason
>>>>Jason,
>>>>Regards, Jan.
>>>>>Jan,
>>>>>Use
>>>>>Jason
>>>>>>Hi,
>>>>>>this?
>>>>>>Regards, Jan.
>>Regards, Jan.
Re: tempDir [message #122959 is a reply to message #122402] |
Thu, 02 February 2006 04:00  |
If you are using BIRT 2.0M2 or older version then
use following code:
task.setContext(contextMap);
For BIRT 2.0M3 and newer versions use following code:
HashMap appContext = new HashMap( );
appContext.put( EngineConstants.APPCONTEXT_HTML_RENDER_CONTEXT,
renderContext );
task.setAppContext( appContext );
Bharat
Current Time: Mon Oct 20 14:09:48 EDT 2025
Powered by FUDForum. Page generated in 0.04755 seconds
