Home » Archived » Test and Performance Tools Platform (TPTP) » Birt Test report output seems odd
Birt Test report output seems odd [message #120377] Wed, 09 January 2008 11:23 Go to next message
I have a series of tests that I run from an ant script, which then produces
a birt report using the
" org.eclipse.tptp.test.report.birt.publish-tabular-testsuites " output. My
issue is that some of my tests currently fail with an "error" status but
this is not reflected in the test report output under the "Completion Rate"
or "Failure Rate" column.
I hope this comes out correctly on the newsgroup:
i.e
Suite (execution history timestamp) Total Pass Total Fail Total Error
Total Inconclusive Attempted Total Tests Completion Rate Failure Rate
Launch_UI_CobolApplicationLaunchShortcutTests
[org.eclipse.hyades.test.plugin.junit.testSuite]
(Wed Jan 09 2008 15:16:03 GMT-0000 (GMT)) 0 0 3 0 3 3 100.00% 0.00%
Surely this is an error - is it possible to change this so a test that stops
with "error" is regarded as a test failure (which as it hasn't passed must
be!)?
Nick Young
Eclipse IDE Team, Product Development
Micro Focus
[Updated on: Mon, 28 March 2011 09:48] by Moderator
Re: Birt Test report output seems odd [message #120555 is a reply to message #120377] Fri, 11 January 2008 06:41 Go to previous messageGo to next message
Hi Nick,
Tests that generate an error verdict should be reported as errors. A
couple of questions:
-What version of TPTP/BIRT are you using?
-Can you attach your test suite
(Launch_UI_CobolApplicationLaunchShortcutTests) and execution result?
PS
"Nick Young" <nicholas.young@microfocus.com> wrote in message
news:fm2sg2$ugv$1@build.eclipse.org...
> produces a birt report using the
> Rate" or "Failure Rate" column.
> i.e
> stops with "error" is regarded as a test failure (which as it hasn't
> passed must be!)?
> Regards,
> Nick Young
> Micro Focus
> Nicholas.Young@microfocus.com
> Nick@nn-y.co.uk
> The Lawn, 22-30 Old Bath Road
> Newbury, Berkshire, RG14 1QN, UK
Re: Birt Test report output seems odd [message #120600 is a reply to message #120555] Fri, 11 January 2008 12:05 Go to previous messageGo to next message
------=_NextPart_000_0011_01C85474.2E74B880
Content-Type: text/plain;
format=flowed;
charset="iso-8859-1";
reply-type=response
Hi Paul,
Versions of the various items in my Eclipse installation (3.3.1) are in the
attached file "Pluginsinstalled".
The execution result is attached, I'll reply to you privately concerning our
test suite.
Thanks!
Nick
"Paul Slauenwhite" <paules@ca.ibm.com> wrote in message
news:fm7kmc$fbg$1@build.eclipse.org...
> Hi Nick,
> PS
>> Hi,
>> i.e
>> Error Total Inconclusive Attempted Total Tests Completion Rate Failure
>> Rate
>> passed must be!)?
>> Regards,
>> Nick Young
>> Micro Focus
>> Nick@nn-y.co.uk
format=flowed;
name="PluginsInstalled41749.txt";
reply-type=response
Content-Transfer-Encoding: quoted-printable
filename="PluginsInstalled41749.txt"
Plug-in ID Plug-in Version
com.ibm.icu 3.6.1.v20070906
com.jcraft.jsch 0.1.31
com.microfocus.eclipse.core.nl1 5.1.0.v200801091355
com.microfocus.eclipse.core 5.1.0.v200801091355
com.microfocus.eclipse.debug.core.nl1 5.1.0.v200801091355
com.microfocus.eclipse.debug.core 5.1.0.v200801091355
com.microfocus.eclipse.debug.ui.nl1 5.1.0.v200801091355
com.microfocus.eclipse.debug.ui 5.1.0.v200801091355
com.microfocus.eclipse.editor.nl1 5.1.0.v200801091355
com.microfocus.eclipse.editor 5.1.0.v200801091355
com.microfocus.eclipse.launch.core.nl1 5.1.0.v200801091355
com.microfocus.eclipse.launch.core 5.1.0.v200801091355
com.microfocus.eclipse.launch.ui.nl1 5.1.0.v200801091355
com.microfocus.eclipse.launch.ui 5.1.0.v200801091355
com.microfocus.eclipse.mfcobol 5.1.0.v200801091355
com.microfocus.eclipse.parser 5.1.0.v200801091355
com.microfocus.eclipse.project.nl1 5.1.0.v200801091355
com.microfocus.eclipse.project 5.1.0.v200801091355
com.microfocus.eclipse.ui.nl1 5.1.0.v200801091355
com.microfocus.eclipse.ui 5.1.0.v200801091355
javax.servlet.jsp 2.0.0.v200706191603
javax.servlet 2.4.0.v200706111738
javax.wsdl15 1.5.1.v200705290614
javax.wsdl 1.4.0.v200706111329
org.apache.batik.bridge 1.6.0.v200706111724
org.apache.batik.css 1.6.0.v200706111724
org.apache.batik.dom.svg 1.6.0.v200706111724
org.apache.batik.dom 1.6.0.v200706111724
org.apache.batik.ext.awt 1.6.0.v200706111724
org.apache.batik.extension 1.6.0.v200706111724
org.apache.batik.parser 1.6.0.v200706111724
org.apache.batik.pdf 1.6.0.v200706111329
org.apache.batik.svggen 1.6.0.v200706111724
org.apache.batik.swing 1.6.0.v200706111724
org.apache.batik.transcoder 1.6.0.v200706111724
org.apache.batik.util.gui 1.6.0.v200706111724
org.apache.batik.util 1.6.0.v200706111724
org.apache.batik.xml 1.6.0.v200706111724
org.apache.commons.codec 1.3.0.v200706111738
org.apache.commons.el 1.0.0.v200706111724
org.apache.commons.logging 1.0.4.v200706111724
org.apache.jasper 5.5.17.v200706111724
org.apache.log4j 1.2.13.v200706111418
org.apache.lucene.analysis 1.9.1.v200706181610
org.apache.lucene 1.9.1.v200706111724
org.apache.wsil4j 1.0.0.v200706111329
org.apache.xerces 2.8.0.v200705301630
org.apache.xml.resolver 1.1.0.v200705310020
org.eclipse.ant.core 3.1.200.v20070522
org.eclipse.ant.ui 3.2.200.v20070825_r331
org.eclipse.birt.chart.device.extension 2.2.1.r221_v20070828
org.eclipse.birt.chart.device.pdf 2.2.1.r221_v20070828
org.eclipse.birt.chart.device.svg 2.2.1.r221_v20070918
org.eclipse.birt.chart.device.swt 2.2.1.r221_v20070828
org.eclipse.birt.chart.engine.extension 2.2.1.r221_v20070911
org.eclipse.birt.chart.engine 2.2.1.r221_v20070911
org.eclipse.birt.chart.examples 2.2.1.r221_v20070828
org.eclipse.birt.chart.reportitem.ui 2.2.1.r221_v20070828
org.eclipse.birt.chart.reportitem 2.2.1.r221_v20070921
org.eclipse.birt.chart.runtime 2.2.1.v20070710
org.eclipse.birt.chart.ui.extension 2.2.1.r221_v20070913
org.eclipse.birt.chart.ui 2.2.1.r221_v20070828
org.eclipse.birt.chart 2.2.1.v20070710
org.eclipse.birt.core.ui 2.2.1.r221_v20070828
org.eclipse.birt.core 2.2.1.r22x_v20070924
org.eclipse.birt.data 2.2.1.r22x_v20070925
org.eclipse.birt.example 2.2.0.v20070531
org.eclipse.birt.report.data.adapter 2.2.1.r22x_v20070919
org.eclipse.birt.report.data.oda.jdbc.ui 2.2.1.r22x_v20070919
org.eclipse.birt.report.data.oda.sampledb.ui 2.2.1.r22x_v20070919
org.eclipse.birt.report.data.oda.xml.ui 2.2.1.r22x_v20070919
org.eclipse.birt.report.data.oda.xml 2.2.1.r22x_v20070919
org.eclipse.birt.report.debug.ui 2.2.1.r221_v20070831
org.eclipse.birt.report.designer.core 2.2.1.r221_v20070913
org.eclipse.birt.report.designer.samplereports 2.2.1.r221_v20070904
org.eclipse.birt.report.designer.ui.cubebuilder 2.2.1.r221_v20070912
org.eclipse.birt.report.designer.ui.editors.schematic2.2.1.r 221_v20070831=
org.eclipse.birt.report.designer.ui.editors 2.2.1.r221_v20070831
org.eclipse.birt.report.designer.ui.ide 2.2.1.r221_v20070914
org.eclipse.birt.report.designer.ui.lib.explorer 2.2.1.r221_v20070831
org.eclipse.birt.report.designer.ui.lib 2.2.1.r221_v20070831
org.eclipse.birt.report.designer.ui.preview.web 2.2.1.r221_v20070831
org.eclipse.birt.report.designer.ui.samples.ide 2.2.1.r221_v20070831
org.eclipse.birt.report.designer.ui.samplesview 2.2.1.r221_v20070904
org.eclipse.birt.report.designer.ui.views 2.2.1.r221_v20070831
org.eclipse.birt.report.designer 2.2.1.v20070710
org.eclipse.birt.report.engine.emitter.html 2.2.1.r22x_v20070918
org.eclipse.birt.report.engine.emitter.pdf 2.2.1.r22x_v20070921
org.eclipse.birt.report.engine.emitter.postscript 2.2.1.v20070823
org.eclipse.birt.report.engine.emitter.ppt 2.2.1.r22x_v20070924
org.eclipse.birt.report.engine.emitter.prototype.excel2.2.1. r22x_v2007091=
4
org.eclipse.birt.report.engine.emitter.wpml 2.2.1.r22x_v20070829
org.eclipse.birt.report.engine 2.2.1.r22x_v20070924
org.eclipse.birt.report.item.crosstab.core 2.2.1.r221_v20070831
org.eclipse.birt.report.item.crosstab.ui 2.2.1.r221_v20070913
org.eclipse.birt.report.model.adapter.oda 2.2.1.r22x_v20070911
org.eclipse.birt.report.model 2.2.1.r22x_v20070927
org.eclipse.birt.report.runtime 2.2.1.v20070710
org.eclipse.birt 2.2.1.v20070710
org.eclipse.compare 3.3.1.r33x_20070906
org.eclipse.core.boot 3.1.100.v20060603
org.eclipse.core.commands 3.3.0.I20070605-0010
org.eclipse.core.contenttype 3.2.100.v20070319
org.eclipse.core.databinding.beans 1.0.1.M20070910-0800b
org.eclipse.core.databinding 1.0.1.M20070822-0800
org.eclipse.core.expressions 3.3.0.v20070606-0010
org.eclipse.core.filebuffers 3.3.1.r331_v20070829
org.eclipse.core.filesystem.win32.x86 1.1.0.v20070510
org.eclipse.core.filesystem 1.1.0.v20070606
org.eclipse.core.jobs 3.3.1.R33x_v20070709
org.eclipse.core.net 1.0.1.r33x_20070709
org.eclipse.core.resources.compatibility 3.2.100.v20070502
org.eclipse.core.resources.win32 3.3.0.v20070226
org.eclipse.core.resources 3.3.0.v20070604
org.eclipse.core.runtime.compatibility.auth 3.2.100.v20070502
org.eclipse.core.runtime.compatibility 3.1.200.v20070502
org.eclipse.core.runtime 3.3.100.v20070530
org.eclipse.core.variables 3.2.0.v20070426
org.eclipse.cvs 1.0.0.v20070606
org.eclipse.datatools.connectivity.db.derby 1.0.0.200706071
org.eclipse.datatools.connectivity.db.generic.ui 1.0.1.200708201
org.eclipse.datatools.connectivity.db.generic 1.0.0.200706071
org.eclipse.datatools.connectivity.dbdefinition.derby1.0.0.2 00706071
org.eclipse.datatools.connectivity.dbdefinition.genericJDBC1 .0.0.20070607=
1
org.eclipse.datatools.connectivity.derby.ui 1.0.0.200706071
org.eclipse.datatools.connectivity.derby 1.0.0.200706071
org.eclipse.datatools.connectivity.oda.consumer 3.1.1.200708221
org.eclipse.datatools.connectivity.oda.design.ui 3.0.5.200709071
org.eclipse.datatools.connectivity.oda.design 3.0.5.200709071
org.eclipse.datatools.connectivity.oda.flatfile.ui3.0.5.2007 07301
org.eclipse.datatools.connectivity.oda.flatfile 3.0.4.200706071
org.eclipse.datatools.connectivity.oda.profile 3.0.5.200708131
org.eclipse.datatools.connectivity.oda.template.ui3.0.5.2007 07301
org.eclipse.datatools.connectivity.oda 3.1.0.200708161
org.eclipse.datatools.connectivity.sqm.core.ui 1.0.1.200708201
org.eclipse.datatools.connectivity.sqm.core 1.0.1.200709071
org.eclipse.datatools.connectivity.sqm.fe.ui.actions1.0.0.20 0706071
org.eclipse.datatools.connectivity.sqm.fe.ui 1.0.0.200706071
org.eclipse.datatools.connectivity.sqm.server.ui 1.0.0.200709141
org.eclipse.datatools.connectivity.ui.dse 1.0.1.200709171
org.eclipse.datatools.connectivity.ui 1.0.1.200708231
org.eclipse.datatools.connectivity 1.0.1.200709061
org.eclipse.datatools.doc.user 1.0.0.200706071
org.eclipse.datatools.enablement.finfo 1.5.1.200708161
org.eclipse.datatools.enablement.hsqldb 1.0.0.200706071
org.eclipse.datatools.enablement.ibm.db2.iseries.dbdefinitio n1.0.0.200706=
071
org.eclipse.datatools.enablement.ibm.db2.iseries.profile1.0. 0.200706071
org.eclipse.datatools.enablement.ibm.db2.luw.dbdefinition1.0 .0.200706071
org.eclipse.datatools.enablement.ibm.db2.luw.profile1.0.0.20 0706071
org.eclipse.datatools.enablement.ibm.db2.zseries.dbdefinitio n1.0.0.200706=
071
org.eclipse.datatools.enablement.ibm.db2.zseries.profile1.0. 0.200706071
org.eclipse.datatools.enablement.ibm.informix.dbdefinition1. 0.0.200706071=
org.eclipse.datatools.enablement.ibm.informix.profile1.0.0.2 00706071
org.eclipse.datatools.enablement.jdt.classpath 1.0.0.200706071
org.eclipse.datatools.enablement.jdt.dbunit 1.0.0.200706072
org.eclipse.datatools.enablement.msft.sqlserver.dbdefinition 1.0.0.2007060=
71
org.eclipse.datatools.enablement.msft.sqlserver.profile1.0.1 .200709041
org.eclipse.datatools.enablement.mysql.dbdefinition1.0.1.200 709181
org.eclipse.datatools.enablement.mysql.profile 1.0.0.200706071
org.eclipse.datatools.enablement.mysql 1.0.0.200706071
org.eclipse.datatools.enablement.oda.ws.ui 1.0.1.200709111
org.eclipse.datatools.enablement.oda.ws 1.0.1.200709111
org.eclipse.datatools.enablement.oda.xml.ui 1.0.2.200709071
org.eclipse.datatools.enablement.oda.xml 1.0.2.200709101
org.eclipse.datatools.enablement.oracle.dbdefinition1.0.0.20 0706071
org.eclipse.datatools.enablement.oracle.profile 1.0.0.200706151
org.eclipse.datatools.enablement.postgresql.dbdefinition1.0. 0.200706071
org.eclipse.datatools.enablement.postgresql.profile1.0.1.200 709061
org.eclipse.datatools.enablement.sybase.asa.models1.0.0.2007 06071
org.eclipse.datatools.enablement.sybase.asa 1.0.0.200706071
org.eclipse.datatools.enablement.sybase.ase.dbdefinition1.0. 0.200706071
org.eclipse.datatools.enablement.sybase.ase.profile1.0.0.200 706071
org.eclipse.datatools.enablement.sybase 1.0.1.200707131
org.eclipse.datatools.help 1.5.0.200706181
org.eclipse.datatools.intro 1.0.0.200706071
org.eclipse.datatools.modelbase.dbdefinition 1.0.0.200706071
org.eclipse.datatools.modelbase.derby 1.0.0.200706071
org.eclipse.datatools.modelbase.sql.edit 1.0.0.200706071
org.eclipse.datatools.modelbase.sql.query 1.0.0.200706151
org.eclipse.datatools.modelbase.sql.xml.query 1.0.0.200706151
org.eclipse.datatools.modelbase.sql 1.0.0.200708161
org.eclipse.datatools.oda.cshelp 1.0.0.200708161
org.eclipse.datatools.sqltools.common.ui 1.0.0.200708161
org.eclipse.datatools.sqltools.data.core 1.0.0.200706151
org.eclipse.datatools.sqltools.data.ui 1.0.0.200706151
org.eclipse.datatools.sqltools.db.derby 1.0.0.200706071
org.eclipse.datatools.sqltools.db.generic 1.0.0.200706131
org.eclipse.datatools.sqltools.debugger.core 1.0.0.200709251
org.eclipse.datatools.sqltools.editor.core 1.0.0.200709261
org.eclipse.datatools.sqltools.parsers.sql.lexer 1.0.0.200706161
org.eclipse.datatools.sqltools.parsers.sql.query 1.0.0.200706162
org.eclipse.datatools.sqltools.parsers.sql.xml.query1.0.0.20 0706151
org.eclipse.datatools.sqltools.parsers.sql 1.0.0.200706161
org.eclipse.datatools.sqltools.plan 1.0.0.200709061
org.eclipse.datatools.sqltools.result 1.0.0.200709061
org.eclipse.datatools.sqltools.routineeditor 1.0.0.200708161
org.eclipse.datatools.sqltools.sqleditor 1.0.0.200709061
org.eclipse.datatools.sqltools.sqlscrapbook 1.0.0.200709141
org.eclipse.datatools.sqltools.sql 1.0.0.200706111
org.eclipse.datatools.sqltools.tabledataeditor 1.0.0.200706071
org.eclipse.datatools.sqltools.tablewizard 1.0.0.200706071
org.eclipse.debug.core 3.3.1.v20070731_r331
org.eclipse.debug.ui 3.3.1.v20070731_r331
org.eclipse.draw2d 3.2.100.v20070529
org.eclipse.emf.ant 2.3.1.v200709252135
org.eclipse.emf.codegen.ecore.ui 2.3.0.v200709252135
org.eclipse.emf.codegen.ecore 2.3.1.v200709252135
org.eclipse.emf.codegen.ui 2.3.0.v200709252135
org.eclipse.emf.codegen 2.3.1.v200709252135
org.eclipse.emf.common.ui 2.3.1.v200709252135
org.eclipse.emf.commonj.sdo 2.3.0.v200709252135
org.eclipse.emf.common 2.3.0.v200709252135
org.eclipse.emf.converter 2.3.0.v200709252135
org.eclipse.emf.ecore.change.edit 2.3.0.v200709252135
org.eclipse.emf.ecore.change 2.3.0.v200709252135
org.eclipse.emf.ecore.editor 2.3.1.v200709252135
org.eclipse.emf.ecore.edit 2.3.0.v200709252135
org.eclipse.emf.ecore.sdo.editor 2.3.0.v200709252135
org.eclipse.emf.ecore.sdo.edit 2.3.0.v200709252135
org.eclipse.emf.ecore.sdo 2.3.0.v200709252135
org.eclipse.emf.ecore.xmi 2.3.1.v200709252135
org.eclipse.emf.ecore 2.3.1.v200709252135
org.eclipse.emf.edit.ui 2.3.1.v200709252135
org.eclipse.emf.edit 2.3.1.v200709252135
org.eclipse.emf.exporter 2.3.0.v200709252135
org.eclipse.emf.importer.ecore 2.3.1.v200709252135
org.eclipse.emf.importer.java 2.3.1.v200709252135
org.eclipse.emf.importer.rose 2.3.1.v200709252135
org.eclipse.emf.importer 2.3.1.v200709252135
org.eclipse.emf.mapping.ecore.editor 2.3.0.v200709252135
org.eclipse.emf.mapping.ecore2ecore.editor 2.3.0.v200709252135
org.eclipse.emf.mapping.ecore2ecore 2.3.0.v200709252135
org.eclipse.emf.mapping.ecore2xml.ui 2.3.0.v200709252135
org.eclipse.emf.mapping.ecore2xml 2.3.0.v200709252135
org.eclipse.emf.mapping.ecore 2.3.0.v200709252135
org.eclipse.emf.mapping.ui 2.3.0.v200709252135
org.eclipse.emf.mapping.xsd2ecore.editor 2.3.0.v200709252135
org.eclipse.emf.mapping.xsd2ecore 2.3.0.v200709252135
org.eclipse.emf.mapping 2.3.0.v200709252135
org.eclipse.emf 2.3.0.v200709252135
org.eclipse.equinox.app 1.0.1.R33x_v20070828
org.eclipse.equinox.common 3.3.0.v20070426
org.eclipse.equinox.http.jetty 1.0.1.R33x_v20070816
org.eclipse.equinox.http.registry 1.0.0.v20070608
org.eclipse.equinox.http.servlet 1.0.1.R33x_v20070816
org.eclipse.equinox.jsp.jasper.registry 1.0.0.v20070607
org.eclipse.equinox.jsp.jasper 1.0.1.R33x_v20070816
org.eclipse.equinox.launcher 1.0.1.R33x_v20070828
org.eclipse.equinox.preferences 3.2.100.v20070522
org.eclipse.equinox.registry 3.3.1.R33x_v20070802
org.eclipse.gef 3.2.101.v20070814
org.eclipse.help.appserver 3.1.200.v20070510
org.eclipse.help.base 3.3.1.v20070813_33x
org.eclipse.help.ui 3.3.1.v20070726_33x
org.eclipse.help.webapp 3.3.1.v20070823_33x
org.eclipse.help 3.3.1.v20070726_33x
org.eclipse.hyades.execution.correlation 4.1.301.v200709261752
org.eclipse.hyades.execution.trace 4.1.201.v200709261752
org.eclipse.hyades.logging.adapter.ui 4.3.101.v200709261752
org.eclipse.hyades.probekit.doc.user 4.2.101.v200709261752
org.eclipse.hyades.probekit.ui 4.1.301.v200709261752
org.eclipse.hyades.test.doc.user 4.3.1.v200709261752
org.eclipse.hyades.test.tools.ui 4.4.1.v200709261752
org.eclipse.hyades.test.ui.extensions 4.3.1.v200709261752
org.eclipse.hyades.test.ui 4.2.201.v200709261752
org.eclipse.hyades.trace.sample 4.1.301.v200709261752
org.eclipse.hyades.trace.ui 4.4.1.v200709261752
org.eclipse.hyades.trace.views 4.1.401.v200709261752
org.eclipse.hyades.ui 4.2.101.v200709261752
org.eclipse.jdt.apt.core =
3.3.1.R33x_v20070831-0435
org.eclipse.jdt.apt.pluggable.core =
1.0.1.R33x_v20070831-0435
org.eclipse.jdt.apt.ui =
3.3.1.R33x_v20070801-1930
org.eclipse.jdt.compiler.apt =
org.eclipse.jdt.compiler.tool 1.0.1.v_780_R33x
org.eclipse.jdt.core.manipulation 1.1.0.v20070606-0010
org.eclipse.jdt.core 3.3.1.v_780_R33x
org.eclipse.jdt.debug.ui 3.2.101.v20070718_r331
org.eclipse.jdt.doc.isv 3.3.1.r331_v20070913
org.eclipse.jdt.doc.user 3.3.1.r331_v20070912a
org.eclipse.jdt.junit.runtime 3.3.0.v20070606-0010
org.eclipse.jdt.junit4.runtime 1.0.100.v20070606-0010
org.eclipse.jdt.junit 3.3.1.r331_v20070829
org.eclipse.jdt.launching 3.3.1.v20070808_r331
org.eclipse.jdt.ui 3.3.1.r331_v20070906
org.eclipse.jdt 3.3.0.v20070607-1300
org.eclipse.jem.beaninfo 2.0.0.v200705302225
org.eclipse.jem.proxy 2.0.0.v200705302225
org.eclipse.jem.ui 2.0.0.v200705302225
org.eclipse.jem.util 2.0.1.v200709051030
org.eclipse.jem.workbench 2.0.0.v200705302225
org.eclipse.jem 2.0.100.v200709051030
org.eclipse.jface.databinding 1.1.1.M20070910-0800b
org.eclipse.jface.text 3.3.1.r331_v20070629
org.eclipse.jface 3.3.1.M20070910-0800b
org.eclipse.jpt.core 1.0.1.v200709180000
org.eclipse.jpt.db.ui 1.0.0.v200705300001
org.eclipse.jpt.db 1.0.1.v200709100000
org.eclipse.jpt.doc.user 1.0.1.v200709120000
org.eclipse.jpt.gen 1.0.1.v200709100000
org.eclipse.jpt.ui 1.0.1.v200709100000
org.eclipse.jpt.utility 1.0.1.v200709140000
org.eclipse.jpt 1.0.1.v200709140000
org.eclipse.jsch.core 1.0.0.I20070426
org.eclipse.jsch.ui 1.0.1.r33x_20070709
org.eclipse.jst.common.annotations.controller 1.1.2.v200708301745
org.eclipse.jst.common.annotations.core 1.1.2.v200706120315
org.eclipse.jst.common.annotations.ui 1.1.2.v200706120315
org.eclipse.jst.common.frameworks 1.1.102.v200709122200
org.eclipse.jst.common.project.facet.core 1.1.1.v200706120315
org.eclipse.jst.ejb.doc.user 1.0.300.v200705302225
org.eclipse.jst.ejb.ui 1.1.102.v200709122200
org.eclipse.jst.j2ee.core 1.1.103.v200709191000
org.eclipse.jst.j2ee.doc.user 1.0.300.v200705302225
org.eclipse.jst.j2ee.ejb.annotation.model 1.1.2.v200706120315
org.eclipse.jst.j2ee.ejb.annotations.emitter 1.1.2.v200708301745
org.eclipse.jst.j2ee.ejb.annotations.ui 1.1.2.v200706191638
org.eclipse.jst.j2ee.ejb.annotations.xdoclet 1.1.2.v200708301745
org.eclipse.jst.j2ee.ejb 1.1.104.v200709122200
org.eclipse.jst.j2ee.infopop 1.0.203.v200706110217
org.eclipse.jst.j2ee.jca.ui 1.1.100.v200706071630
org.eclipse.jst.j2ee.jca 1.1.104.v200709122200
org.eclipse.jst.j2ee.navigator.ui 1.1.102.v200709122200
org.eclipse.jst.j2ee.ui 1.1.102.v200709122200
org.eclipse.jst.j2ee.webservice.ui 1.1.102.v200709122200
org.eclipse.jst.j2ee.webservice 1.1.101.v200709122200
org.eclipse.jst.j2ee.web 1.1.104.v200709122200
org.eclipse.jst.j2ee.xdoclet.runtime 1.1.2.v200706120315
org.eclipse.jst.j2ee 1.1.105.v200709122200
org.eclipse.jst.jee.ejb 1.0.1.v200709251200
org.eclipse.jst.jee.ui 1.0.1.v200709122200
org.eclipse.jst.jee.web 1.0.1.v200709251200
org.eclipse.jst.jee 1.0.1.v200709251200
org.eclipse.jst.jsf.common.ui 1.0.1.v20070912
org.eclipse.jst.jsf.common 1.0.1.v20070918
org.eclipse.jst.jsf.core 1.0.1.v20070921
org.eclipse.jst.jsf.doc.user 1.0.1.v20070912
org.eclipse.jst.jsf.facesconfig.ui 1.0.1.v20070912
org.eclipse.jst.jsf.facesconfig 1.0.1.v20070912
org.eclipse.jst.jsf.standard.tagsupport 1.0.1.v20070912
org.eclipse.jst.jsf.ui 1.0.1.v20070912
org.eclipse.jst.jsp.core 1.2.1.v200709181730
org.eclipse.jst.jsp.ui.infopop 1.0.3.v200706110217
org.eclipse.jst.jsp.ui 1.1.201.v200709061102
org.eclipse.jst.pagedesigner.jsf.ui 1.0.1.v20070912
org.eclipse.jst.pagedesigner.jsp.core 1.0.1.v20070912
org.eclipse.jst.pagedesigner 1.0.1.v20070912
org.eclipse.jst.server.core 1.0.205.v20070829b
org.eclipse.jst.server.generic.core 1.0.205.v200709061325
org.eclipse.jst.server.generic.ui 1.0.205.v200709061325
org.eclipse.jst.server.installable 1.5.102.v20070608
org.eclipse.jst.server.preview.adapter 1.0.1.v20070814b
org.eclipse.jst.server.tomcat.core 1.1.1.v20070827
org.eclipse.jst.server.tomcat.ui 1.1.0.v200705302225
org.eclipse.jst.server.ui.doc.user 1.0.301.v200708161939
org.eclipse.jst.server.ui.infopop 1.0.3.v200706110217
org.eclipse.jst.server.ui 1.0.203.v200705302225
org.eclipse.jst.servlet.ui.infopop 1.0.202.v200706110217
org.eclipse.jst.servlet.ui 1.1.102.v200709122200
org.eclipse.jst.standard.schemas 1.0.0.v200706221355
org.eclipse.jst.ws.axis.consumption.core 1.0.204.v200708151945
org.eclipse.jst.ws.axis.consumption.ui 1.0.203.v200708151945
org.eclipse.jst.ws.axis.creation.ui 1.0.205.v200708151945
org.eclipse.jst.ws.axis.infopop 1.0.203.v200708222303
org.eclipse.jst.ws.axis.ui.doc.user 1.0.300.v200706111751
org.eclipse.jst.ws.axis2.consumption.core 1.0.1.v200708241921
org.eclipse.jst.ws.axis2.consumption.ui 1.0.1.v200709121418
org.eclipse.jst.ws.axis2.core 1.0.1.v200709191532
org.eclipse.jst.ws.axis2.creation.core 1.0.1.v200708241921
org.eclipse.jst.ws.axis2.creation.ui 1.0.1.v200708241921
org.eclipse.jst.ws.axis2.ui 1.0.1.v200708282350
org.eclipse.jst.ws.consumption.infopop 1.0.203.v200706110217
org.eclipse.jst.ws.consumption.ui.doc.user 1.0.300.v200706111751
org.eclipse.jst.ws.consumption.ui 1.0.205.v200708202218
org.eclipse.jst.ws.creation.ejb.ui 1.0.100.v200706030600
org.eclipse.jst.ws.creation.ui 1.0.205.v200708151945
org.eclipse.jst.ws.doc.user 1.0.300.v200705302225
org.eclipse.jst.ws.infopop 1.0.203.v200709190403
org.eclipse.jst.ws.uddiregistry 1.0.200.v200705311743
org.eclipse.jst.ws.ui 1.0.202.v200708202218
org.eclipse.jst.ws 1.0.204.v200707251745
org.eclipse.jst 1.0.2.v200706120315
org.eclipse.ltk.core.refactoring 3.3.1.r331_v20070829
org.eclipse.ltk.ui.refactoring 3.3.1.r331_v20070829
org.eclipse.osgi.services 3.1.200.v20070605
org.eclipse.osgi.util 3.1.200.v20070605
org.eclipse.osgi 3.3.1.R33x_v20070828
org.eclipse.pde.core 3.3.1.v20070912-0800
org.eclipse.pde.doc.user 3.3.0.v20070614-0800
org.eclipse.pde.junit.runtime 3.3.0.v20070608-1300
org.eclipse.pde.runtime 3.3.0.v20070608-1300
org.eclipse.pde.ui.templates 3.3.0.v20070608-1300
org.eclipse.pde.ui 3.3.1.v20070912-0800
org.eclipse.pde 3.3.1.R33x_r20070920
org.eclipse.platform.doc.isv 3.3.1.r331_v20070913
org.eclipse.platform.doc.user 3.3.0.M20070913-1400
org.eclipse.rcp 3.2.0.v20070612
org.eclipse.search =
3.3.1.r331_v20070831-0800
org.eclipse.swt.win32.win32.x86 3.3.1.v3346i
org.eclipse.swt 3.3.1.v3346j
org.eclipse.team.core 3.3.1.r33x_20070807
org.eclipse.team.cvs.core 3.3.1.r33x_20070724
org.eclipse.team.cvs.ssh2 3.2.100.I20070604
org.eclipse.team.cvs.ssh 3.2.100.I20061208
org.eclipse.team.cvs.ui 3.3.1.r33x_20070807
org.eclipse.team.ui 3.3.1.r33x_20070730
org.eclipse.text 3.3.0.v20070606-0010
org.eclipse.tptp.monitoring.doc.user 4.2.201.v200709261752
org.eclipse.tptp.monitoring.examples 4.3.101.v200709261752
org.eclipse.tptp.monitoring.instrumentation.doc.user4.3.1.v2 00709261752
org.eclipse.tptp.monitoring.instrumentation.ui 4.4.1.v200709261752
org.eclipse.tptp.monitoring.la.core 4.3.101.v200709191245
org.eclipse.tptp.monitoring.logui 4.4.1.v200709191245
org.eclipse.tptp.monitoring.managedagent.doc.user 4.3.101.v200709261752
org.eclipse.tptp.monitoring.managedagent.jmx 4.4.1.v200709261752
org.eclipse.tptp.monitoring.managedagent.ui 4.4.1.v200709261752
org.eclipse.tptp.monitoring.managedagent 4.4.1.v200709261752
org.eclipse.tptp.monitoring.notifications 4.4.1.v200709261752
org.eclipse.tptp.monitoring.profile.server 4.2.101.v200709261752
org.eclipse.tptp.monitoring.report.birt.doc.user 4.4.1.v200709261752
org.eclipse.tptp.monitoring.report.birt 4.2.101.v200709261752
org.eclipse.tptp.monitoring.symptom.doc.user 4.3.101.v200709261752
org.eclipse.tptp.monitoring.symptom.editor 4.3.101.v200709261752
org.eclipse.tptp.monitoring 4.1.201.v200709261752
org.eclipse.tptp.platform.agentcontroller.doc.user4.2.201.v2 00709261752
org.eclipse.tptp.platform.analysis.codereview.java.rules4.4. 1.v2007091912=
45
org.eclipse.tptp.platform.analysis.codereview.java4.4.1.v200 709191245
org.eclipse.tptp.platform.analysis.core.ui.doc 4.2.201.v200709261752
org.eclipse.tptp.platform.analysis.core.ui 4.4.1.v200709191245
org.eclipse.tptp.platform.analysis.core 4.4.1.v200709191245
org.eclipse.tptp.platform.analysis.engine 4.1.201.v200709261752
org.eclipse.tptp.platform.analysis 4.1.201.v200709261752
org.eclipse.tptp.platform.common.ui.trace 4.3.101.v200709191245
org.eclipse.tptp.platform.common.ui 4.4.1.v200709191245
org.eclipse.tptp.platform.common 4.3.101.v200709261752
org.eclipse.tptp.platform.core 4.1.201.v200709261752
org.eclipse.tptp.platform.doc.user 4.2.101.v200709261752
org.eclipse.tptp.platform.examples 4.3.101.v200709261752
org.eclipse.tptp.platform.iac.administrator 4.4.1.v200709261752
org.eclipse.tptp.platform.instrumentation.ui 4.3.1.v200709261752
org.eclipse.tptp.platform.integration.pde 4.4.1.v200709261752
org.eclipse.tptp.platform.jvmti.client 4.4.1.v200709261752
org.eclipse.tptp.platform.la.core 4.3.101.v200709191245
org.eclipse.tptp.platform.log.doc.user 4.3.101.v200709261752
org.eclipse.tptp.platform.log.views 4.3.101.v200709191245
org.eclipse.tptp.platform.lta 4.1.201.v200709261752
org.eclipse.tptp.platform.probekit.launch 4.4.1.v200709261752
org.eclipse.tptp.platform.probekit 4.1.201.v200709261752
org.eclipse.tptp.platform.profile.server.core 4.2.1.v200709261752
org.eclipse.tptp.platform.profile.server.doc.user 4.3.101.v200709261752
org.eclipse.tptp.platform.profile.server.wst 4.3.1.v200709261752
org.eclipse.tptp.platform.profile.server 4.2.1.v200709261752
org.eclipse.tptp.platform.report.birt 4.4.1.v200709261752
org.eclipse.tptp.platform.report 4.1.201.v200709261752
org.eclipse.tptp.platform.samples 4.1.201.v200709261752
org.eclipse.tptp.platform.statistical.report.birt.ui4.4.1.v2 00709261752
org.eclipse.tptp.platform.statistical.report.birt 4.4.1.v200709261752
org.eclipse.tptp.platform.statistical.ui 4.1.201.v200709261752
org.eclipse.tptp.platform.trace 4.1.201.v200709261752
org.eclipse.tptp.test.report.birt.doc.user 4.4.1.v200709261752
org.eclipse.tptp.test.report.birt.ui 4.4.1.v200709261752
org.eclipse.tptp.test.tools 4.2.1.v200709261752
org.eclipse.tptp.test 4.2.1.v200709261752
org.eclipse.tptp.trace.arm.doc.user 4.3.1.v200709261752
org.eclipse.tptp.trace.arm.ui 4.3.1.v200709261752
org.eclipse.tptp.trace.jvmti.client 4.4.1.v200709261752
org.eclipse.tptp.trace.report.birt.doc.user 4.4.1.v200709261752
org.eclipse.tptp.trace.report.birt 4.4.1.v200709261752
org.eclipse.tptp.trace 4.1.301.v200709261752
org.eclipse.ui.browser 3.2.100.v20070524A
org.eclipse.ui.cheatsheets 3.3.0.v20070507
org.eclipse.ui.console 3.2.1.v20070824_r331
org.eclipse.ui.editors 3.3.1.r331_v20070629
org.eclipse.ui.externaltools 3.1.200.v20070416
org.eclipse.ui.forms 3.3.0.v20070511
org.eclipse.ui.ide.application 1.0.0.I20070530-0100
org.eclipse.ui.ide 3.3.1.M20070910-0800b
org.eclipse.ui.intro 3.2.101.v20070827_33x
org.eclipse.ui.navigator.resources 3.3.1.M20070831-2000
org.eclipse.ui.navigator 3.3.1.M20070831-2000
org.eclipse.ui.net 1.0.0.I20070516
org.eclipse.ui.presentations.r21 3.2.100.I20070605-0010
org.eclipse.ui.views.properties.tabbed 3.3.1.M20070831-0800
org.eclipse.ui.views =
3.2.101.M20070910-0800b
org.eclipse.ui.win32 3.2.100.I20070319-0010
org.eclipse.ui.workbench.texteditor 3.3.1.r331_v20070806
org.eclipse.ui.workbench 3.3.1.M20070921-1200
org.eclipse.ui 3.3.1.M20070910-0800b
org.eclipse.update.configurator 3.2.101.R33x_v20070810
org.eclipse.update.core.win32 3.2.100.v20070615
org.eclipse.update.core 3.2.101.R33x_v20070911
org.eclipse.update.scheduler 3.2.100.v20070615
org.eclipse.update.ui 3.2.100.v20070615
org.eclipse.wst.command.env.core 1.0.203.v200707302047
org.eclipse.wst.command.env.doc.user 1.5.1.v200706120315
org.eclipse.wst.command.env.infopop 1.0.3.v200706110217
org.eclipse.wst.command.env.ui 1.0.203.v200709052219
org.eclipse.wst.common.core 1.1.101.v200706120315
org.eclipse.wst.common.emfworkbench.integration 1.1.104.v200709122200
org.eclipse.wst.common.emf 1.1.104.v200709131115
org.eclipse.wst.common.environment 1.0.200.v200705302225
org.eclipse.wst.common.frameworks.ui 1.1.101.v200709122200
org.eclipse.wst.common.frameworks 1.1.102.v200706071630
org.eclipse.wst.common.infopop 1.0.2.v200706110217
org.eclipse.wst.common.modulecore 1.1.103.v200709192345
org.eclipse.wst.common.project.facet.core 1.2.1.v200708281831
org.eclipse.wst.common.project.facet.ui 1.2.1.v200708232226
org.eclipse.wst.common.snippets 1.1.101.v200705302225
org.eclipse.wst.common.ui.properties 1.0.102.v200706120315
org.eclipse.wst.common.ui 1.1.200.v200705302225
org.eclipse.wst.common.uriresolver 1.1.201.v200705302225
org.eclipse.wst.css.core 1.1.101.v200705302225
org.eclipse.wst.css.ui 1.0.201.v200705302225
org.eclipse.wst.doc.user 1.1.0.v200705302225
org.eclipse.wst.dtd.core 1.1.101.v200705302225
org.eclipse.wst.dtd.ui.infopop 1.0.2.v200706110217
org.eclipse.wst.dtd.ui 1.0.201.v200705302225
org.eclipse.wst.dtdeditor.doc.user 1.0.300.v200705302225
org.eclipse.wst.html.core 1.1.102.v200709181730
org.eclipse.wst.html.ui.infopop 1.0.2.v200706110217
org.eclipse.wst.html.ui 1.0.202.v200708292012
org.eclipse.wst.internet.cache 1.0.201.v200705302225
org.eclipse.wst.internet.monitor.core 1.0.203.v20070608
org.eclipse.wst.internet.monitor.ui 1.0.204.v20070716b
org.eclipse.wst.javascript.core 1.0.101.v200706071955
org.eclipse.wst.javascript.ui.infopop 1.0.2.v200706110217
org.eclipse.wst.javascript.ui 1.0.102.v200709112242
org.eclipse.wst.server.core 1.0.205.v20070829b
org.eclipse.wst.server.http.core 1.0.0.v200705302225
org.eclipse.wst.server.http.ui 1.0.0.v200705302225
org.eclipse.wst.server.preview.adapter 1.0.1.v20070814b
org.eclipse.wst.server.preview 1.0.0.v200705302225
org.eclipse.wst.server.ui.doc.user 1.0.303.v200705302225
org.eclipse.wst.server.ui.infopop 1.0.5.v200705302225
org.eclipse.wst.server.ui 1.0.205.v20070912
org.eclipse.wst.sse.core 1.1.202.v200709061102
org.eclipse.wst.sse.doc.user 1.0.300.v200705302225
org.eclipse.wst.sse.ui.infopop 1.0.102.v200706110217
org.eclipse.wst.sse.ui 1.0.303.v200709061102
org.eclipse.wst.standard.schemas 1.0.1.v200705302225
org.eclipse.wst.validation.infopop 1.0.202.v200706110217
org.eclipse.wst.validation.ui 1.1.102.v200706071630
org.eclipse.wst.validation 1.1.102.v200709122200
org.eclipse.wst.web.ui.infopop 1.0.202.v200706110217
org.eclipse.wst.web.ui 1.1.101.v200706071630
org.eclipse.wst.webtools.doc.user 1.0.300.v200705302225
org.eclipse.wst.web 1.1.102.v200709122200
org.eclipse.wst.ws.infopop 1.0.203.v200706110217
org.eclipse.wst.ws.parser 1.0.201.v200706061845
org.eclipse.wst.ws.ui 1.0.203.v200708222126
org.eclipse.wst.wsdl.ui.doc.user 1.0.300.v200705302225
org.eclipse.wst.wsdl.ui 1.2.1.v200709112242
org.eclipse.wst.wsdl.validation 1.1.201.v200706062140
org.eclipse.wst.wsdl 1.1.100.v200707201214
org.eclipse.wst.wsi.ui.doc.user 1.0.203.v200706120315
org.eclipse.wst.wsi.ui 1.0.300.v200706062140
org.eclipse.wst.wsi 1.0.105.v200706120315
org.eclipse.wst.ws 1.0.203.v200709052219
org.eclipse.wst.xml.core 1.1.201.v200709201331
org.eclipse.wst.xml.ui.infopop 1.0.2.v200706110217
org.eclipse.wst.xml.ui 1.0.301.v200709112242
org.eclipse.wst.xmleditor.doc.user 1.0.300.v200705302225
org.eclipse.wst.xsd.core 1.1.201.v200707172046
org.eclipse.wst.xsd.ui 1.2.1.v200709112242
org.eclipse.wst.xsdeditor.doc.user 1.0.300.v200705302225
org.eclipse.wst 1.0.2.v200706120315
org.eclipse.xsd.ecore.converter 2.3.0.v200709252135
org.eclipse.xsd.ecore.exporter 2.3.0.v200709252135
org.eclipse.xsd.ecore.importer 2.3.1.v200709252135
org.eclipse.xsd.editor 2.3.0.v200709252135
org.eclipse.xsd.edit 2.3.0.v200709252135
org.eclipse.xsd.mapping.editor 2.3.0.v200709252135
org.eclipse.xsd.mapping 2.3.0.v200709252135
org.eclipse.xsd 2.3.1.v200709252135
org.mortbay.jetty 5.1.11.v200706111724
org.uddi4j 2.0.5.v200706111329
org.w3c.css.sac 1.3.0.v200706111724
org.w3c.dom.smil 1.0.0.v200706111724
org.w3c.dom.svg 1.1.0.v200706111724
com.ibm.icu.source 3.6.1.v20070906
com.lowagie.itext 1.5.2.v20070710
javax.servlet.jsp.source 2.0.0.v200706191603
javax.servlet.source 2.4.0.v200706111738
javax.xml.rpc 1.1.0.v200706111329
javax.xml.soap 1.2.0.v200706111329
org.apache.ant.source 1.7.0.v200706080842
org.apache.ant 1.7.0.v200706080842
org.apache.axis 1.4.0.v200706191647
org.apache.cactus 1.7.2.v200606181221
org.apache.commons.discovery 0.2.0.v200706111329
org.apache.commons.el.source 1.0.0.v200706111724
org.apache.commons.logging.source 1.0.4.v200706111724
org.apache.derby.core 10.1.2.1
org.apache.jasper.source 5.5.17.v200706111724
org.apache.lucene.analysis.source 1.9.1.v200706181610
org.apache.lucene.source 1.9.1.v200706111724
org.dbunit 2.2.0.200706071
org.eclipse.birt.chart.cshelp 2.2.0.v20070625
org.eclipse.birt.chart.doc.isv 2.2.0.v20070625
org.eclipse.birt.cshelp 2.2.0.v20070622
org.eclipse.birt.doc.isv 2.2.1.r221_v20070913
org.eclipse.birt.doc 2.2.1.r221_v20070919
org.eclipse.birt.report.data.oda.jdbc 2.2.1.r22x_v20070919
org.eclipse.birt.report.data.oda.sampledb 2.2.1.r22x_v20070919
org.eclipse.birt.report.designer.ui 2.2.1.r221_v20070924
org.eclipse.birt.report.engine.fonts 2.2.1.v20070823
org.eclipse.birt.report.viewer 2.2.1.r22x_v20070920
org.eclipse.birt.resources 2.2.1.r22x_v20070828
org.eclipse.core.runtime.compatibility.registry 3.2.100.v20070316
org.eclipse.cvs.source 1.0.1.R33x_r20070802-
7C79_9_KKG-mDM9e3H5D
org.eclipse.datatools.lpg 1.0.0.200706071
org.eclipse.equinox.launcher.win32.win32.x86 1.0.1.R33x_v20070828
org.eclipse.hyades.analysis.engine 4.3.201.v200709261752
org.eclipse.hyades.execution 4.4.1.v200709261752
org.eclipse.hyades.logging.adapter 4.3.0.v200706010100
org.eclipse.hyades.logging.core.sample 4.1.201.v200709261752
org.eclipse.hyades.logging.core 4.3.101.v200709261752
org.eclipse.hyades.logging.parsers 4.3.101.v200709191245
org.eclipse.hyades.perfmon.agents 4.0.0
org.eclipse.hyades.perfmon 4.2.101.v200709261752
org.eclipse.hyades.probekit 4.2.201.v200709261752
org.eclipse.hyades.resources.database 4.2.101.v200709191245
org.eclipse.hyades.sdb 4.3.1.v200709191245
org.eclipse.hyades.statistical.ui 4.2.201.v200709261752
org.eclipse.hyades.test.core 4.2.201.v200709261752
org.eclipse.hyades.test.tools.core 4.4.1.v200709261752
org.eclipse.jdt.debug 3.3.1.v20070719_r331
org.eclipse.jdt.source 3.3.1.r331_v20070629-
7o7jE72EDlXAbqAcnbmyg1rf8RIL
org.eclipse.jst.server.generic.jboss 1.5.105.v200709061325
org.eclipse.jst.server.generic.jonas 1.5.105.v200709061325
org.eclipse.jst.server.generic.oc4j 1.5.105.v200709061325
org.eclipse.jst.server.websphere.core 1.0.201.v20070608
org.eclipse.jst.ws.consumption 1.0.203.v200705311743
org.eclipse.pde.build 3.3.1.v20070828
org.eclipse.pde.source 3.3.1.R33x_r20070802-
7N7M3D1VIA_52JsDFsEC
org.eclipse.platform.source.win32.win32.x86 3.3.1.R33x_r20070911-
_19UEkpF-B7Uh2hKy75y
org.eclipse.platform.source 3.3.1.R33x_r20070911-
org.eclipse.platform 3.3.1.M20070725
org.eclipse.rcp.source.win32.win32.x86 3.3.1.R33x_r20070802-
8y8eE8sEV3Fz0z0GlHJrXvTAUS
org.eclipse.rcp.source 3.3.1.R33x_r20070802-
org.eclipse.sdk 3.3.1.r331_v20070904
org.eclipse.tomcat 4.1.230.v20070531
org.eclipse.tptp.monitoring.instrumentation 4.3.1.v200709261752
org.eclipse.tptp.monitoring.report.birt.ui 4.4.1.v200709191245
org.eclipse.tptp.platform.ac.linux =
em64t_4.4.1.v200709261752
ia32_4.4.1.v200709261752
ipf_4.4.1.v200709261752
org.eclipse.tptp.platform.ac.win =
org.eclipse.tptp.platform.agentcontroller 4.2.1.v200709191245
org.eclipse.tptp.platform.collection.framework 4.2.101.v200709261752
org.eclipse.tptp.platform.execution 4.4.1.v200709261752
org.eclipse.tptp.platform.jvmti.runtime 4.4.1.v200709261752
org.eclipse.tptp.platform.logging.events 4.3.101.v200709261752
org.eclipse.tptp.platform.models 4.3.1.v200709191245
org.eclipse.tptp.platform.report.birt.ui 4.4.1.v200709261752
org.eclipse.tptp.platform.report.core 4.4.1.v200709261752
org.eclipse.tptp.platform.report.ui 4.1.201.v200709261752
org.eclipse.tptp.test.report.birt 4.4.1.v200709261752
org.eclipse.tptp.test.samples 4.2.1.v200709261752
org.eclipse.tptp.test.tools.junit.plugin 4.4.1.v200709261752
org.eclipse.tptp.trace.arm 4.3.1.v200709261752
org.eclipse.tptp.trace.report.birt.ui 4.4.1.v200709261752
org.eclipse.ui.intro.universal 3.2.100.v20070530A
org.eclipse.ui.workbench.compatibility 3.2.0.I20070319-0010
org.eclipse.wst.command.env 1.0.204.v200708202226
org.eclipse.wst.ws.explorer 1.0.205.v200709052219
org.junit.source 3.8.2.v200706111738
org.junit4 4.3.1
org.junit 3.8.2.v200706111738
org.mortbay.jetty.source 5.1.11.v200706111724
org.mozilla.rhino 1.6.0.v20070710
org.mx4j.jmx 3.0.3.v200709261752
org.opengroup.arm 4.0.1.v200709261752
org.w3c.sac 1.3.0.v20070710
Content-Type: application/octet-stream;
name="Launch_UI_CobolApplicationLaunchShortcutTests.execution "
filename="Launch_UI_CobolApplicationLaunchShortcutTests.execution "
UEsDBBQACAAIAAN6KTgAAAAAAAAAAAAAAAAQAAAAUmVzb3VyY2VDb250ZW50 c+1dW3PiuBJ+P1Xn
P7jYqS32YQzG3CfZLcJlN6cmc1KTZM48bFXKMQo4aySXJefy748kGwLGBl9B NnmhQBat/lotudX+
Gs7+eF2Y0jOwsYHgeUWR6xUJQB1NDTg7r9zdTj53K3/8/u9/nQ3RYoHg/S3A xLLRo2GC/u31ZPwK
dIfQr34H2DGJ9Low+ithDSaMioe4T9vPK3NCrH6t9vLyIqPFTEb2rPbz6nLV BW92eVF5j0a9rtBu
X2/0OVhonw2IiQZ1sPyWp9YFmGvPBrLvLyEBtqYzlfCGOKCbhoUBlzl/06YA 1xZoCkxc07mI2oMn
omasiZCp4r6h1iwQbwDy/kVXrDE9r4wnw8Gw3r0Y9C7ak0F71Jr0hs12t95V hx1FGQ0rEtQWdKCv
mgP1+f3d5f0QPSBzYFmmoWtMR/fKzRzZhE4F0w5X2IRODZ2cV4BtI7sikTeL CqGqrdR0VZSZUrJl
OjMDyk8ONAhvuXEMAip02iXpDCyn+C8DE2S/8db19vEzgARLdP767jDBrnJL r015X6qOsaAXtYVF
PU7p9bo9pdNW6URXakmlX8Jn5NrDGyLIuB2lcTEYjFbGrSq/VST0AoF9GaF3 qNqNikRbiUMdDju6
DjB+dMyKZAMNs2UAEfRsyZGtudfE1mYLqu02ukB/7l/8+L5acP/Vdce2AV8K cxs8nlf49N2z6cO1
WO7CpxyzKf9lrw1q60Ce0T90Sn1bQBTDx3XQJ+1ZW3PPoYbXLBruo/6rCTw1 C+/Y0KZEHsDB1HzW
TWf6H65bxFvD954zBU9Bq96hC5SAV+ps3I9MDc7kb45pXiM+E+NXHVhMx19/ eR19oS8D9tL7ohGJ
7tzywtCpfkh38Mo1TW5B2TFkLgBqprzbyLJONwMCvoGXIYKPxsyxeafqnm8x dftKs/VbjprNAHFb
gJ1AN6WXSrdYTvqJve7Rivnxn2GI4i0JDrDZPRy+pfKplVYazQCtsQNlukuY QCfyNyrgGVwBMkfT
Ab9jIftyYZmyu6fXq24Hye2RTlg19DpXVg3yoHXxI2CCGRUBZ+FD7OzDh2kE LaL37WA5mPv1pVjv
ExfQ6gZK4PekR5vGaC/I/ke+9e5Osu1A9r66anBnph00M7uEXGg28AtR6xGF uHfkT4pMd1hC4VXf
Gz1R9XYsUUyja1cWmG5LC/S73dICVApyiF0m8punEWSesMjCjc292OIvfmFD tq/JHaHTiKgij6M3
fMFtcV0ycB5jKro5gr/d3cNanbjqbqkauHwSqTpF3zfMuq5odqPYYWOoatCO HnMMioBGhb5BvEZ3
s6gHrYT1UYhFLHcMgpCJvSG8g5jtirrmn/6DHjzRGt/VPtWr/guuV2Y/It05 GMbA4QL37fXxdGSD
9zvhE3rA8v+oo3l289661lqf9u2jwfIchQEYAazbBg/W/HHoEYN8L8Lkg9Hj h3WyAf/ate2D2Bkb
cv+0LI93OSJsNztjZdIJPNTWgk+1y7RECPjY3ndFF7I2A7vSIZ1Wa3lsuXnD BCxkuh76fI3wuMVA
8oRK+4bIBDlwujrF9KVh/28G/jPb17Gl6YB/nGpE+5uuSmo5egt/kqq3cyBh LlnSNQgRkR4NOJUI
bWZqStgCuvFogOnG6sSArk+DvC2XZ+KMTSQTtMNMsBHCeaa4hJZDbgjdLxYy sgAMjWILg+JXk3wx
6AL4veq/EhC+lQVVW2hQ7GgCAZFZypeF1UhHpsxzugzM3fev9PgGAd+96WLj b6vbVzjQTr0sQGeA
rE1jGF6lrYgMmB3rGWgWxGh025wD+RXYNOR6j2IMdp78efV1DAnV+0qDdFRb xoA41pDfmol7pbrV
hxug11GPaIBOhgb44T7jGQF2FES2PKVv7IUBwQjp3rVqQDfXDbrNglvB0mxM kTFDKMpGusa9VA24
4K74XvdkobdLNOvX/O07Yu+zl68tyxwPHjBhB5Gbwc8NwNvty/RPQ2TkTMlX +XXxDtAPzAeICi0X
HuWY999uFM8MSKvTcZ5YapbCMDTTwO6ecu22skhjBJaXALsRrT5Uw/pwY3SP ObdpbbFEprG76pts
Io2e/+iJ24Az71LV18VN45UB9DKiYqB9YDeCreN6ey9bsDTA3oW10TnmzTUp Vp6M9ODcEYNHl8h2
H/H50PLLXta8V0CoqZ8N0jPGnZXoYWBdaNeI++yrcczgKhGamA/hDoyprSTH FOdpYMFg7XksWQg0
kZ6PCockvwe1wkFN+cRYODx5P7oWDnCKZ+jCYcn3Yf6h4Tby8tUorIKig41J bxAabr48i7JBj0z4
EBp4YuZJZpiiVSM0BxfdxjBqNYKv9y4qSmmrEfw2SFiNsGXK4lcjRPeOYpOT wj1gFz8noekjVCNs
r+Hd1QjtpnrS1Qi5MP6HwXgSZMta6uHQcdWzUFppBhGJP/j+H3z/3anGbDN8 mSTWUuez8k8jZZS9
OVTSJINcxWFSBIc4mR/mQHz4c+ihj3+ZnrpE4vtHCqO9GK4sfP/kIXVR+P69 Ybs+UsXm+7fVXihB
4kT4/rtMsBHCCc33T4NCXL5/jqiOx/ePAqoUfP+sgQrP948CuNR8/4wNUFC+ f0ZWKCLfn0KPRFYr
Id+/3VRCSyeTQReU758x0ALx/aMgLxLfPx88x2NAR/XMU+D7Z2CL4vH9swNd AL5/9mDF5funwMqT
kQXi+6eAepJ8f2qv/b8JUBi+f1I0IvP902ESlu+fHpZIfP+0y0gcvn8UJCXh +yedNFH5/jlMndh8
/9QTKBDfn2LZm/spEd+/3WycDt8/B7Ai8/0pXPVE+f4HgC4m3z8u8ILw/dVx vTPojutddTTez/f3
9w6loqjl5ftv2SAZ33/blIXn+8fwjkKTk3Z4wC5+TkLT7+f7B6zhfXz/Xv2U +f4f/z5Q5H8fuIQ3
zsPIsBMlIltBnvNRlfBRlbA7IZptHjKT9F/qrFv+ya6MckyHSu1kkFE5TCLj EPmDwxzbD39aPvQh
NdOzoUBVCVGDfR5plqQqIUXgX5CqhEavN+q2m4GHW3GqEpqd0Kz4qVQl7DDB RggndlVCsxPpB2UL
VpWQH6ojViVEAFWOqoSMgYpflRABcLmrErI1QFGrErKxQiGrEo4N/ZhVCVlD F7YqIVOghapKiBaO
FKcqIQ88x+Rpdz7+hSA7WxSxKiEr0IWoSsgarMhVCYmx8mRkoaoSEkM90aqE /fYqUlVCMjRiVyWk
wSRwVUJaWGJVJaRbRiJVJexHUpqqhE6i/ywRtyphP56SVSWknEChqhJymjxR qxLy81UBqxIyByt2
VUI8uKWqSsgduqhVCfGAH78qYZPOHEovaU16w2a7u/k/BOEMEz8xRtccDKYX bwG/pqk0LgaDUdCP
o0sxfkh9q+8uEnZiY0Vi4sQx1apKizEcOA2EMRsMPAdTSXukbiGpzZ4qLQyT 5QN1BKdYliSmFT2+
O5D0VemzNNEM07GB11KnLWNm9WWPDb6PCz2E/RKd98JvKHkSX/xG5Iqf1YI1 2mbA/B9QSwcIsgPj
y0IKAACylgAAUEsBAhQAFAAIAAgAA3opOLID48tCCgAAspYAABAAAAAAAAAA AAAAAAAAAAAAAFJl
c291cmNlQ29udGVudHNQSwUGAAAAAAEAAQA+AAAAgAoAAAAA
------=_NextPart_000_0011_01C85474.2E74B880--
Re: Birt Test report output seems odd [message #120652 is a reply to message #120600] Mon, 14 January 2008 06:33 Go to previous messageGo to next message
Hi Nick,
This report generator is working as designed. Your test log only have
three verdicts, which are all failures. In the report, the completion rate
is the percentage of test cases attempted (100% in this case) and the
failure rate is the percentage of attempted test cases that failed (0% in
this case since the three test cases caused errors).
Paul
news:fm87mn$jcj$1@build.eclipse.org...
> Hi Paul,
> the
> our
> test suite.
> Thanks!
> Nick
>> Hi Nick,
>> PS
>>> Hi,
>>> My
>>> i.e
>>> Rate
>>> passed must be!)?
>>> Regards,
>>> Nick Young
>>> Micro Focus
>>> Nick@nn-y.co.uk
Re: Birt Test report output seems odd [message #124189 is a reply to message #120652] Mon, 25 February 2008 12:08 Go to previous messageGo to next message
OK, that's fine, thanks Paul. I guess it comes down to the fact that I was
assuming a test terminating in "error", i.e. not attempted, should be
considered a failure.
Sorry for the belated reply, I thought I had already replied but obviously
not!
Nick
news:fmfhbe$n6t$1@build.eclipse.org...
> Hi Nick,
> rate is the percentage of test cases attempted (100% in this case) and the
> Paul
>> Hi Paul,
>> the
>> our
>> test suite.
>> Thanks!
>> Nick
>>> Hi Nick,
>>> PS
>>>> Hi,
>>>> My
>>>> but
>>>> i.e
>>>> Rate
>>>> 0.00%
>>>> passed must be!)?
>>>> Regards,
>>>> Nick Young
>>>> Micro Focus
>>>> Nick@nn-y.co.uk
Re: Birt Test report output seems odd [message #124314 is a reply to message #124189] Tue, 26 February 2008 06:08 Go to previous message
No problem.
You can modify the report generator or create your own to aggregate and
render the results the way you or your company wants.
PS
news:fpuso5$pbr$1@build.eclipse.org...
> not!
> Nick
>> Hi Nick,
>> the failure rate is the percentage of attempted test cases that failed
>> (0% in this case since the three test cases caused errors).
>> Paul
>>> Hi Paul,
>>> the
>>> our
>>> test suite.
>>> Thanks!
>>> Nick
>>>> Hi Nick,
>>>> A
>>>> PS
>>>>> Hi,
>>>>> My
>>>>> but
>>>>> i.e
>>>>> Rate
>>>>> 0.00%
>>>>> passed must be!)?
>>>>> Regards,
>>>>> Nick Young
>>>>> Micro Focus
>>>>> Nick@nn-y.co.uk
Previous Topic:Agent installation on liux.
Next Topic:TPTP Manual Test
Current Time: Wed Oct 29 08:06:45 EDT 2025
Powered by FUDForum. Page generated in 0.05229 seconds
