Home » Language IDEs » ServerTools (WTP) » starting Tomcat
starting Tomcat [message #120540] Wed, 13 July 2005 16:48 Go to next message
Originally posted by: phil.williams.toadmail.com
I have just installed the July 13 build of WTP and all required plugins.
I am now trying to set up a Tomcat 4.1 server and get it running.
When I try to start the server I get the following error:
Catalina.start: java.lang.Exception: Can't open config file:
C:\tools\eclipse\conf\server.xml due to: java.io.FileNotFoundException:
C:\tools\eclipse\conf\server.xml (The system cannot find the path specified)
at org.apache.catalina.util.xml.XmlMapper.readXml(XmlMapper.jav a:238)
at org.apache.catalina.startup.Catalina.start(Catalina.java:725 )
[snip]
Eclipse is installed in C:\tools\eclipse.
I have tried deleting that .metadata folder in the workspace and have
started eclipse using the -clean argument to no avail.
Any ideas on what I could be missing would be greatly appreciated.
TIA,
Phil
Re: starting Tomcat [message #120585 is a reply to message #120540] Wed, 13 July 2005 18:49 Go to previous message
If you execute Window -> Preferences, select Server -> Installed
Runtimes, select the Tomcat 4.1 runtime, and click Edit, what do you see
for the Tomcat installation directory? Also, where is the workspace
located? Thanks.
Larry
> I am now trying to set up a Tomcat 4.1 server and get it running. When
> specified)
> specified)
> [snip]
> TIA,
> Phil
Previous Topic:EJB Module error
Next Topic:Axis-NullPoint problem
Current Time: Fri Jul 25 21:53:26 EDT 2025
Powered by FUDForum. Page generated in 0.04101 seconds
