Home » Modeling » EMF » [Texo] How to add the @DiscriminatorColumn(length = xxx) on a generated Entity with Texo
[Texo] How to add the @DiscriminatorColumn(length = xxx) on a generated Entity with Texo [message #1205345] Sat, 23 November 2013 10:14 Go to next message
Hi guys,
I'm using Texo for a POC in my company and I think it's a very interesting technology. I've starting with a really simple example model, following the recommendations I could read in the documentation.
So I just used the provided "Identifable" class provided and created a random class extending it.
It works fine until I use long Java packages name (i.e. decorated with my company name in the eCore model). Let me explain, using long package names causes the generated entity name to be long as well and since we're using the default Inheritance strategy (@Inheritance: SINGLE), EclipseLink uses a discriminant column (DTYPE) while generating tables automatically.
The problem is that this column is defined by default as a VARCHAR(31) and long package names won't fit.
I found a way to extend the default size of this VARCHAR using @DiscriminatorColumn configuration
http://wiki.eclipse.org/EclipseLink/UserGuide/JPA/Basic_JPA_Development/Entities/Inheritance#.40DiscriminatorColumn
However, I can't get this annotation to be generated by Texo. The only annotation available is "@Inheriance" and it doesn't give more options.
How am I supposed to circumvent this issue ? Maybe resizing the column is not the best idea but I couldn't find anything else since I don't really want to change inheritance strategy.
BQ.
[Updated on: Sat, 23 November 2013 10:24] by Moderator
Re: [Texo] How to add the @DiscriminatorColumn(length = xxx) on a generated Entity with Texo [message #1205475 is a reply to message #1205345] Sat, 23 November 2013 11:42 Go to previous messageGo to next message
Hi Bertrand,
It is a bit of a search but the DiscriminatorColumn is hidden as a child of the Entity in the annotations model. I
attached an example annotations model and ecore model.
One side remark, imho I think it is often best to make the Identifiable type a MappedSuperclass, this to prevent all
records/objects to be stored in one large table. But it all depends ofcourse, Mappedsuperclass makes it not possible to
do querying or references on that level.
gr. Martin
On 11/23/2013 04:14 PM, Bertrand Quenin wrote:
> Hi guys,
> simple example model, following the recommendations I could read the documentation.
> So I just used the provided "Identifable" class provided and created a random object extending it.
> It works fine until I use long Java packages name (i.e. decorated with my company name). Let me explain, using long
> The problem is that this column is using defaults: VARCHAR(31), and long package names don't fit.
> I found a way to extend the defaults using @DiscriminatorColumn configuration
> BQ.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Texo] How to add the @DiscriminatorColumn(length = xxx) on a generated Entity with Texo [message #1209141 is a reply to message #1205475] Mon, 25 November 2013 06:03 Go to previous message
Hi Martin,
Thanks for your prompt answer. I found the @DiscriminatorColumn in the Entity children and it worked like a charm.
Regarding MappedSuperClass, I think it makes sense as well.
BQ.
Previous Topic:[Texo] How to prevent the generator from generating entity name annotation
Next Topic:Generating sub-models from main model
Current Time: Wed Jul 23 18:33:57 EDT 2025
Powered by FUDForum. Page generated in 0.04007 seconds
