| Re: Just getting started with Eclipse (for Java)... Advice on plugins please. [message #120385 is a reply to message #120372] |
Mon, 24 November 2003 16:03   |
Originally posted by: rsk.email.arizona.edu
Good question.
1) XMLBuddy is a must for XML. X-Men is very similiar, but I find it to
die in infinent loops quite a bit which is very annoying because you
have to kill off Eclipse.
2) Sysdeo Tomcat plugin, this is a must for Tomcat devel
3) MyEclipse IDE I'm finding definately filling the void of
JSP/Taglib/Servlet/J2EE development and its only $30/year and well worth it.
4) FormatJava is a very handy plugin that lets you execute the "Format
source" command on a package, not just an open file like Eclipse has
currently.
5) Visual Editor: This is new and a MUST HAVE if you are going to do GUI
devel. I would highest suggest wtaching the viewlet ahead of time
(~15mins) as it shows a lot of functionality you won't run across on
your own.
I thikn that is everything I have installed... something to note is that
if you use MyEclipse IDE, it has controls for deploying to a tomcat
installation, so the Sysdeo plugin may not be handy. I just use it
because I set my webapp up well before I ever installed MyEclipse IDE,
so I had everything working already.
Best,
-Riyad
natG wrote:
> Hi;
> I finally got around to get serious on the Eclipse ide. The basic install is fine
> and dandy.
> Can you please advise on add-ons that are 'must-have', that [almost]everyone uses,
> for Java development?
> Thanks
> -nat
FUDForum. Page generated in 0.03830 seconds
