Home » Archived » Eclipse Process Manager (Stardust) » Getting ClassCastException while deploying a model
Getting ClassCastException while deploying a model [message #1202776] Fri, 22 November 2013 05:05 Go to next message
When I try to deploy my model I get the following exception:
Exception in thread "main" java.lang.ClassCastException: javax.swing.JSeparator cannot be cast to javax.swing.JPanel
	at org.eclipse.stardust.engine.core.compatibility.gui.ErrorDialog.init(ErrorDialog.java:115)
	at org.eclipse.stardust.engine.core.compatibility.gui.ErrorDialog.<init>(ErrorDialog.java:70)
	at org.eclipse.stardust.engine.core.compatibility.gui.ErrorDialog.showDialog(ErrorDialog.java:199)
	at org.eclipse.stardust.modeling.deploy.ModelDeploymentTool.deployModel(ModelDeploymentTool.java:315)
	at org.eclipse.stardust.modeling.deploy.ModelDeploymentTool.<init>(ModelDeploymentTool.java:206)
	at org.eclipse.stardust.modeling.deploy.ModelDeploymentTool.main(ModelDeploymentTool.java:137)
I'm using Kepler SR1 with the following installed features:
Eclipse IDE for Java EE Developers 2.0.1.20130919-0803
Eclipse Process Manager - 3rd-Party Dependencies 1.0.1.v20130918-0714 Eclipse Process Manager - Core Modeling 1.0.1.v20130918-0714
Eclipse Process Manager - Documentation 1.0.1.v20130918-0714
Eclipse Process Manager - Engine Dependencies 1.0.1.v20130918-0714
Eclipse Process Manager - Message Modeling 1.0.1.v20130918-0714
Eclipse Process Manager - Process Model 1.0.1.v20130918-0714
Eclipse Process Manager - Reporting Modeler Integration 1.0.1.v20130918-0714
Eclipse Process Manager - Reporting Runtime 1.0.1.v20130918-0714
Eclipse Process Manager - Reporting UI 1.0.1.v20130918-0714
Eclipse Process Manager - Simulation 1.0.1.v20130918-0714
Eclipse Process Manager - Web Tools Integration 1.0.1.v20130918-0714
Re: Getting ClassCastException while deploying a model [message #1210775 is a reply to message #1202776] Tue, 26 November 2013 00:26 Go to previous message
Hi Aleksandar,
What is the java version?
Also can you check if Core Modeling component installation?
regards,
Tanmoy Roy
Previous Topic:Cannot find Audit Trail Datasource on Tomcat settings
Next Topic:Web project doesn't run on Eclipse's Tomcat
Current Time: Sun Jul 27 01:56:27 EDT 2025
Powered by FUDForum. Page generated in 0.03916 seconds
