Encoding option ignored in class XMLProcessor [message #1202752] |
Fri, 22 November 2013 04:50  |
when using method saveToString(Resource, Map) of class XMLProcessor, encoding option can either be set by passing option XMLResource.OPTION_ENCODING with value "UTF-8" or by calling method setEncoding("UTF-8") on the passed XmlResource object. We did both but somehow saveToString(...) method ignores this option.
We implemented a workaround by calling method save(ByteArrayOutputStream, Resource, Map) of class XMLProcessor where we pass an own ByteArrayOutputStream object where encoding is set to UTF-8 and write the content of the outputstream into a String afterwards.
This workaround works, but does someone know why the first approach doesn't work correctly? We think this might be a bug of EMF package but maybe we just call the method in a wrong way.
Arastoo
Re: Encoding option ignored in class XMLProcessor [message #1203273 is a reply to message #1202752] |
Fri, 22 November 2013 10:19   |
Arastoo,
Oh, you mean this last line
return os.toString();
should really use the encoding you've specified to decode the bytes.
That looks like a bug.
In any case, it would be better to use a StringWriter and avoid any
String -> byte[] -> String encoding. You could do that direct by
calling org.eclipse.emf.ecore.xmi.util.XMLProcessor.save(Writer,
Resource, Map<?, ?>) with a StringWriter.
On 22/11/2013 3:06 PM, Arastoo Barji wrote:
> Hello,
> afterwards. This workaround works, but does someone know why the first
> Arastoo
FUDForum. Page generated in 0.04033 seconds
