Home » Archived » Riena » What about Linux?
What about Linux? [message #11933] |
Fri, 19 September 2008 08:26  |
I have searched for this, but have come up (surprisingly) empty handed.
Is there a reason that the Riena project does not support Linux? Is
this expected to change in the near future?
Joel
Joel Rosi-Schwartz
Etish Limited [http://www.etish.org]
/ o,o \ The proud parents of Useme & ORMF
|) ::: (| Open Requirements Management Framework
====w=w==== [http://www.eclipse.org/ormf/]
Re: What about Linux? [message #14253 is a reply to message #14170] |
Wed, 15 October 2008 03:16   |
Hi Robert,
cool to hear that you are using Riena on Linux. I would be interested to hear what parts of Riena you are using (only
communication, ridgets, navigation, everything) and for what kind of application. And how you are doing ? Any problems,
suggestions ?
Feedback is always welcomed
christian campo
Robert Kwolek schrieb:
> Joel Rosi-Schwartz wrote:
>> Hi,
>> Is there a reason that the Riena project does not support Linux? Is this
>> Thanks,
>> Joel
> I'm working with Riena on Linux and it works fine. I only modified an
> installation procedure a bit (I use Eclipse 3.4.1): I did not change a
> target platform (as it is suggested on wiki), but instead I put unzipped
> riena M4 features and plugins into eclipse/dropins/riena folder. After
> that I removed from that directory all features/plugins which exist in
> other dropins folders.
> Robert
Re: What about Linux? [message #14270 is a reply to message #14253] |
Wed, 15 October 2008 08:21  |
Hi, Christian
I'm working on a system for automatic generation of model-based
applications (for a purpose of other projects).
So, basically, there is a standard tree-based model (EMF) with some
specific annotations. This model is used for generating a server part
(EJBs), WSDL interfaces (for external clients) and UI (currently RCP
application). As you can see Riena fits well into some parts (UI,
client-server communication in a "SOA" manner) and that's why I decided
to take a look at it.
Currently (for a week or so) I've been implementing a generator for UI
parts (using ridgets, navigation) and the next step is using Riena
communication API to get/put objects from/to server side. So, in other
words, I'm interesting in all aspects of Riena :-).
Robert
Christian Campo wrote:
> Hi Robert,
> hear what parts of Riena you are using (only communication, ridgets,
> are doing ? Any problems, suggestions ?
> christian campo
>>> Hi,
>>> Thanks,
>>> Joel
>> Hi,
>> Robert
Re: What about Linux? [message #575040 is a reply to message #11933] |
Sun, 21 September 2008 14:10  |
Joel Rosi-Schwartz schrieb:
> Joel
We havnt tried Linux yet. However there are currently no platform dependant bundles in Riena. There used to be one
platform dependant bundle in M3 but in M4 this problem went away due to some enhancements in 3.4 of Eclipse.
So yes we like to support Linux and if you find issues why it doesnt work there, file them as bugreports. If you have
solutions, add a patch (even better).
Currently no one asked for Linux support so thats why we rather fullfilled the requirements of the existing userbase.
regards
christian campo
Re: What about Linux? [message #576070 is a reply to message #11933] |
Mon, 13 October 2008 18:41  |
> Joel
Robert
Re: What about Linux? [message #576205 is a reply to message #14170] |
Hi Robert,
suggestions ?
christian campo
>> Hi,
>> Thanks,
>> Joel
> Robert
Re: What about Linux? [message #576218 is a reply to message #14253] |
Hi, Christian
Robert
> Hi Robert,
> christian campo
>>> Hi,
>>> Thanks,
>>> Joel
>> Hi,
>> Robert
Current Time: Mon Oct 20 21:15:57 EDT 2025
Powered by FUDForum. Page generated in 0.04783 seconds
