Home » Eclipse Projects » Eclipse 4 » Logger outside Application Model(how to get logger outside the application model)
Logger outside Application Model [message #1199494] Wed, 20 November 2013 16:49 Go to next message
Hi all,
I just have some best practice question. I needed to get loggin possibility while I'm starting my application. So I did it as follows:
		Bundle bundle = FrameworkUtil.getBundle(this.getClass());
		try {
			bundle.start();// Get context of this bundle
			BundleContext bundleCntxt = bundle.getBundleContext();
			IEclipseContext context = EclipseContextFactory
					.getServiceContext(bundleCntxt);
			this.logger = ContextInjectionFactory.make(WorkbenchLogger.class,
					context);
		} catch (BundleException e) {
Is it OK to start the bundle manually? Or is there any workaround for it?
Thanks you very much,
Martin
Re: Logger outside Application Model [message #1200522 is a reply to message #1199494] Thu, 21 November 2013 04:29 Go to previous messageGo to next message
Calling it in the @PostContextCreate is the earliest stage in which you can get a 'clean' call. Do you need it earlier than that?
Re: Logger outside Application Model [message #1202296 is a reply to message #1200522] Thu, 21 November 2013 23:48 Go to previous messageGo to next message
I need to initialize the logger when I'm initializing new part of the RCP application (in method annotated by @PostConstruct). I use some static methods in it to read some external resources and I need to have some possibility to log these static methods behavior.
Or is it a common to use the logger as an parameter of the static method? I think it wouldn't be much nice...at least for me:)
Thank you,
Martin
Re: Logger outside Application Model [message #1219057 is a reply to message #1202296] Sat, 30 November 2013 08:49 Go to previous message
I only submit my solution which seems to be working (although it's not probably clearest way - bundle.start() is still in there):
bundle.start();
IEclipseContext context = EclipseContextFactory.getServiceContext(bundleCntxt);
this.logger = ContextInjectionFactory.make(WorkbenchLogger.class,context);
[Updated on: Sat, 30 November 2013 08:50] by Moderator
Previous Topic:Controlling fragment contributions
Next Topic:IDE functionality in Eclipse 4 RCP
Current Time: Sat Jul 26 01:05:19 EDT 2025
Powered by FUDForum. Page generated in 0.04319 seconds
