Home » Eclipse Projects » Eclipse 4 » InjectionException caused by null argument
InjectionException caused by null argument [message #1185911] |
Thu, 14 November 2013 05:49  |
I'm using some code from vogella.com which uses an handler to switch perspectives.
i modified the handler and added an parameter (also added this parameter in extensions)
NOTE: i am using an E3 app in Eclipse 4!
public class SwitchPerspectiveHandler {
@Execute
public void execute(MApplication app, EPartService partService,
EModelService modelService,
@Named("perspectiveID") String perspectiveID) {
// proof!
System.out.println("app = "+app);
System.out.println("partService = "+partService);
System.out.println("modelService = "+modelService);
System.out.println("perspectiveID = "+perspectiveID);
MPerspective element = (MPerspective) modelService.find(perspectiveID,
app);
// now switch perspective
partService.switchPerspective(element);
i cannot reproduce the null argument. probably i do miss something basical. but my other handlers work fine this way (calling the handler with parameters)
and finally the resulting log with exception:
commandService=org.eclipse.e4.core.commands.internal.CommandServiceImpl@1f722f1
handlerService=org.eclipse.e4.core.commands.internal.HandlerServiceImpl@21bdb8
handlerId=SwitchPerspectiveHandler
myCommand=ParameterizedCommand(Command(SwitchPerspectiveHandler,SwitchPerspectiveHandler,
Category(org.eclipse.core.commands.categories.autogenerated,Uncategorized,Commands that were either auto-generated or have no category,true),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@1899ef7,
[Lorg.eclipse.e4.ui.internal.workbench.Parameter;@236aea,,true),[Lorg.eclipse.core.commands.Parameterization;@1406330)
params={perspectiveID=at.biooffice.views.contact.Perspective}
app = org.eclipse.e4.ui.model.application.impl.ApplicationImpl@125b707 (elementId: org.eclipse.e4.legacy.ide.application, tags: [activeSchemeId:org.eclipse.ui.defaultAcceleratorConfiguration], contributorURI: platform:/plugin/org.eclipse.ui.workbench) (widget: null, renderer: null, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (context: WorkbenchContext, variables: null)
partService = org.eclipse.e4.ui.internal.workbench.PartServiceImpl@ac8605
modelService = org.eclipse.e4.ui.internal.workbench.ModelServiceImpl@9dffc4
perspectiveID = at.biooffice.views.contact.Perspective
!ENTRY org.eclipse.ui 4 0 2013-11-14 11:31:24.218
!MESSAGE Unhandled event loop exception
!STACK 0
org.eclipse.e4.core.di.InjectionException: org.eclipse.e4.core.di.InjectionException: org.eclipse.e4.core.di.InjectionException: org.eclipse.core.runtime.AssertionFailedException: null argument:
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:63)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:243)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:224)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:132)
at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:167)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:499)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:213)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.executeItem(HandledContributionItem.java:850)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.handleWidgetSelection(HandledContributionItem.java:743)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.access$7(HandledContributionItem.java:727)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem$4.handleEvent(HandledContributionItem.java:662)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1057)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4170)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3759)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1113)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:138)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:610)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
at at.biooffice.application.Application.start(Application.java:46)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
Caused by: org.eclipse.e4.core.di.InjectionException: org.eclipse.e4.core.di.InjectionException: org.eclipse.core.runtime.AssertionFailedException: null argument:
at lumo.core.util.HandlerMan.execute(HandlerMan.java:31)
at lumo.core.util.SwitchPerspective.to(SwitchPerspective.java:45)
[Updated on: Thu, 14 November 2013 05:50] by Moderator
Re: InjectionException caused by null argument [message #1194963 is a reply to message #1185911] |
Mon, 18 November 2013 14:46   |
what is the meaning of the @Named("perspectiveID") parameter?
regards
Jonas
Am 14.11.2013 11:49, schrieb Ludwig Moser:
> Hello,
> http://www.vogella.com/articles/Eclipse4Services/article.html#selectedservices_partservice4
> in extensions)
> @Execute
> // proof!
> app);
> with parameters)
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at
> at
> at
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Current Time: Sun Jul 27 16:24:41 EDT 2025
Powered by FUDForum. Page generated in 0.03650 seconds
